3rd Gen / L98 Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 [42] 43 44 45 46 47 48
  1. Scam or an ULTRA rare car??
  2. 1989 Z28 5.7lt Tune-up!
  3. Late 80's early 90's bowtie heads?
  4. 28" tire fit?
  5. Anyone with a LT1 and T56???
  6. 4th Gen Dash Swap ?'s
  7. edelbrock carb and 700R4
  8. engin help
  9. Need help Identifying camel hump heads
  10. Can I use any 700r4 or are their camaro specific ones?
  11. 305 TBI Power
  12. TGO's new look...
  13. LT1 intake mod need help
  14. Car wont start, NEED HELP
  15. MAF and header install
  16. Short Throw Shifter
  17. 90-92 Gauge Cluster
  18. vibration on deceleration
  19. Need help with car stalling.
  20. Tire size question?
  21. Tbi ? Please Help Aaahhhhh......
  22. alternator trouble with lt1 swap into 3rd gen
  23. Where did you mount your LT1 computer?
  24. What's the most cost-effective way to increase LG4 horsepower?
  25. Rocker Arms....guideplates or self aligning...
  26. gear drives
  27. Light Problem
  28. Stock 7.2 pushrods
  29. RPM's running high, loss of power
  30. Decisions, Decisions...
  31. "Hencho en Mexico" Blocks
  32. Fuel pump on a C4 corvette?
  33. camaro engine install with headers,need advice
  34. MSD 6A benefits?
  35. New Motor is in
  36. Any options on replacing 700r4
  37. LT1 wiring problems.
  38. Cool third-gen video from 1982!
  39. Starting Problem
  40. centerforce clutch options
  41. LT header install. Help!
  42. whats the width on a 3rd gen rear?
  43. 89 rs / 305 bad computer? 66,000 miles
  44. Decisions, Decisions (Part Deux)
  45. L98 Heads
  46. heads??
  47. Ok, getting 20 inch iroc wheels for my 92, SO
  48. brake light problem
  49. HELP...burning oil dont know why :(
  50. Can factory baseplate be used??
  51. 92 Camaro - TPI - EGR Replaced, LOSS of power??
  52. 94Z door panel go on 86 iroc?
  53. Factory 383 3rd gen
  54. 305 carb to 350 carb
  55. What coolant mixture w/aluminum heads?
  56. Cheap speed
  57. Timing Chains
  58. Installing air/fuel gauge
  59. fuel pressure problems...
  60. Car wont start
  61. 350 engine
  62. What wires to splice for the LT1?
  63. A/C head pressure, A/C and fans?
  64. finding top dead center
  65. Interchange
  66. How big of an engine will fit?
  67. Centerbolt Question
  68. what do you guys think
  69. Smog delete?
  70. questions about headers + y pipe for my 3rd gen
  71. Recommended Carburetor?
  72. Any reason i cant put a solid cam and lifters in my roller engine?
  73. 1990 Gta
  74. I need deeper gears! Are all 3rd gen rears interchangeable?
  75. Went to the track for the first time
  76. Will 3rd and 4th gen seat brackets interchange?
  77. Car won't start....HELP!!!!
  78. 4.7K resistor IAT mod, a question
  79. 2.8 mfi to 5.7 tpi conversion question
  80. Exhaust Manifold boltz
  81. Where so you get chrome billet grills for 92 camaro's?
  82. oil on spark plugs
  83. Exhaust?????????
  84. 305 TPI vs. 350 TPI
  85. car stopped running, help!
  86. Alternator wiring question, kinda odd
  87. crank in 305
  88. Higher Octane Worth It?
  89. where to buy a 3' cowl hood?
  90. How fast are the 1990 GTA`s in the 1/4
  91. will i have to change my push rods?
  92. "Best" Engine Upgrade on a 305?
  93. knocking noise?
  94. Using the stock radiator with LT1..
  95. water pump..how to tell if short or long style
  96. NEED electrical help!
  97. anyone have pics of a 400cid sbc
  98. 1985 v6 to v8
  99. 350TPI Prom
  100. need wiring help
  101. 305TPI Rebuild
  102. ATTENTION 91/91 Camaro's with TPI 305 OR 350
  103. Arcing Sparking
  104. 305 tbi to tpi or carb?
  105. A/C Cooling Fan
  106. Engine Questions
  107. 91 Z28 Rear End Gears
  108. Stainless Steel Roller Rockers
  109. How Many Revs = Too Many?
  110. SLP cold air intake
  111. What engine do i have
  112. are all GTA`s WS6 cars???
  113. 91 305 TBI swapped to 1990 305 TPI = No cranking
  114. Shocks for my 1991 Z
  115. Radio Power
  116. LT1 Swap: How do you hook up MAF?
  117. just bought my first camaro:)
  118. Cooling Fan Problem
  119. C5 brake upgrade complete
  120. '91 rs not startinG? help ASAP
  121. how common is this spoiler??
  122. Help!
  123. Help!
  124. 383 stroker cam?
  125. BW T-5 Rebuild
  126. code 23 on 305 TBI 89RS camaro
  127. Urgent...What caused this????
  128. more questions about my 383 motor!
  129. code 23 on TBI 305
  130. Not sure if this is the right forum...
  131. Is the LT1 MAF the same as LB9?
  132. What causes a tach to be inaccurate?
  133. I need help with posi question.
  134. timing
  135. LT1 cranks and starts but wont run.
  136. 89 rs 305 normal oil press?
  137. supercharged tpi
  138. chip questions...
  139. edelbrock header leaking where the 4 pipes come together? I ahve afew ? about fixing
  140. 350 fit into a 305.....
  141. SLP loudmouth
  142. passing emissions
  143. Serious problem after replace distributor with new Mallory one.
  144. what kinda trans should i go with?
  145. Manuel brakes on a 91 RS
  146. Where'd this vacuum line go?!
  147. 89 RS camaro strange noise
  148. all sorts of problems
  149. This is weird
  150. valve cover
  151. Alum vs. Stock Driveshaft??
  152. test pipe??
  153. adapter plate
  154. QUICK HELP NEEDED! Fuel Injector question!
  155. Ground wire question!
  156. Many Problems Needing Much Help
  157. few new pics of motor swap and new paintjob
  158. FS: 83 Camaro w/350 small block
  159. Should i pickup a 90 T/A for 500?
  160. 160 or 180 thermostat
  161. Baker Electronics VATS bypass module: Have you used it?
  162. Cruise Control
  163. Hooker LT's. Coated or not?
  164. Magnaflow Exhuast
  165. Torque question on 87 L98!!!!!!!!!!
  166. New T56 retrofit Xmember to clear Hooker Longtubes
  167. Rough Idle. Been working on it over a year. Someone smarter than me please help!!
  168. Should I add more unibody support for 400H.P.
  169. 1978 350 into a 1986 z28
  170. This is a 92 z28 with 10K miles. Question
  171. Looks like I'm replacing the timing chain. What else should I do while I'm at it?
  172. RCI poly racing seats
  173. Replacing the fuel pump
  174. EGR valve How do I test and Replace it L98 engine
  175. Delco Bose radio
  176. Need Help With A 83 Camaro
  177. How to Remove Pick-up Coil on '89 305 TPI
  178. car wont move forward
  179. 1991 RS V6 to V8 Swap
  180. 1986 iroc z28 cooling fan relay prob
  181. Long Tube For LT1 swap 3rd Gen
  182. front end....
  183. Flywheels
  184. Valve Lift Queston
  185. Ford Mod Motor injectors work on '88 305 TPI???
  186. can i flat out swap these parts?
  187. Dynomax Muffler
  188. LB9 305 cam, I know it's big, but will it fit and be safe?
  189. Can it fit
  190. Stock Front V8 Springs Needed for 91
  191. Cam Swap question
  192. IROC Z song video! LOOK!!
  193. Edelbrock TPI
  194. Edelbrock TPI
  195. 3RD gen shifter choice
  196. Those of you with aftermarket cams...
  197. ZZ4 1/4 times?????
  198. which is better?
  199. Scoggin Dickey Vortec crate TPI project
  200. Problem with e-brake cables on rear-end swap.
  201. Can I bypass the Crankcase vent to throttle body like this??
  202. engine swap
  203. Vacuum Lines
  204. I need help!
  205. cooling
  206. Suspension Ideas
  207. Rough Idle, help
  208. rear disc conversion
  209. IROC Question
  210. Melted Connector
  211. flywheel for gm crate motor
  212. Need Help with Removing my Power Steering, Anyone??
  213. 92Z Dual Cat setup questions
  214. Mechanical VS. Electric gauges??????
  215. modifying my 383..need some advice
  216. For any of you's that don't read the loung: I am shipping out June 26
  217. Which cam will run best with stock intake
  218. 89 Iroc-z
  219. 88 IROC 305TPI trouble code 36
  220. Please Read!! Best Mods 4 my 89 camaro???
  221. parts car
  222. Magnaflow 15620 on 3rd gen
  223. Check engine light comes on
  224. Check engine light
  225. help with diagnose L03 problems
  226. STUPID fuel pump question?
  227. Ignition wiring need help ASAP!!!
  228. Hard to start
  229. intermittant shake while accelerating
  230. ZZ4 lifters
  231. Identify Speed Pro Hypereutectic Pistons?
  232. plug wire question
  233. how to disable fuel pump
  234. Rear Disc Brakes/ Lines Frozen
  235. Are 87 IROC gauges mech.????
  236. swapping out my 305TPI for a 383 stroker
  237. Monster cam in L98 TPI setup?
  238. DTC 32 EGR Valve
  239. 89 iroc 305 tpi gas milege and tank size
  240. fuel rails???
  241. Need help with my 89' iroc 350 tpi
  242. low or mid mount alt bracket?
  243. low charging voltage need some ideas
  244. fixed fan issue
  245. Engine Shuts Off
  246. Please answer my question real quick!
  247. RPO codes
  248. Falling on its face
  249. superram or stealthram on a 383?
  250. Idle problem, please help!
