3rd Gen / L98 Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43 44 45 46 47 48
  1. speed sensor question
  2. fire from coil to cap, but not spark plugs
  3. Where can I find Emissions Legal Headers for third gen?
  4. Crank, Fuel, No spark?
  5. My Camaro is teh sux0rs!!1!
  6. Brake Vacuum Bost And Trans
  7. ECM Codes decode
  8. Original '84 Z28 w/ L69 is it worth keeping and upgrading?
  9. Tune up needed.
  10. ECM Code 36
  11. L98 to LT1
  12. 327 or 350
  13. Its Alive!!!!!
  14. My Iroc is catching smoke
  15. Miniram II and NEW Trickflows heads possible for sale!!
  16. geting rid of the computer
  17. 3-wire o2 sensor part number
  18. Bad Ignition Swithch
  19. Smog Pump
  20. I need a new Timing Chain and cover, have a few questions
  21. rear hatch
  22. Help with cam specs for my engine...
  23. Bad ESC Fusible link or Fan link?
  24. GM Performance div. ZZ 383
  25. 3rdGen T-shirt
  26. Whats a solid 305 tpi going for these days?
  27. Open Air Filter
  28. Still working on my 91 RS
  29. To Sell or not 2 sell...
  30. Door Panel Conversion
  31. 350 Stroker kit install
  32. Poor idle... still
  33. Huge loss of power and High RPM
  34. plugs on 89 camaro rs 305
  35. bad injectors
  36. shedding pounds?
  37. Overbore Price?
  38. Air Cleaner Problem Clearence problem ...
  39. new camaro owner
  40. Ok I need help with my POS starter
  41. Bucking 89 TBI RS
  42. Anyone use Dart Pro 1 heads?
  43. Barry Grant Speed Demon carbs..
  44. Yay My 305 Is Running! Thank You Everybody And Thumpinta!
  45. info for a freind
  46. Difference between SD and MAF ect
  47. A possible crankcase leak
  48. Need help with a vacuum line..
  49. 400CI in a 1988 Formula
  50. Cams?
  51. just some performance questions?
  52. new exsaust
  53. 350 TPI Headers
  54. Throttle Jump
  55. coolent leak
  56. injector sizing
  57. Hatch motor
  58. 76cc torquers on a 350. worth it?
  59. Exhaust/Muffler
  60. 88 iroc 350 tpi
  61. Some Pics of the Restoration so far
  62. High-flow converters
  63. whick chip they look the same but cost different??
  64. Stepnose of flatnose
  65. TPI going on a 260HP Mercruiser
  66. Any 10 or 11 sec. 3rd gens, in here PLZ
  67. Radiator Hoses & Radiator
  68. Strange Vibration...
  69. Does The Fuel Pump Run Constantly
  70. true dual exhaust
  71. Wow been a long time
  72. LT1 Swap
  73. New motor
  74. Engine ready for mods
  75. looking for a hood
  76. 91 Z28 355 1LE---> BAD brakes :(
  77. 84 Trans Am Headers
  78. screw 10s 0r 11s,i want 9s
  79. Paxton Supercharged 1989 Tpi Help!!!
  80. Stock cam specs?
  81. getting a new car
  82. 91 Z28 1LE on Barrett-Jackson Wed
  83. EGR Removal
  84. i got a code 32
  85. sorry for being late
  86. Timing vs. Octane
  87. manual air/fuel ratio tune
  88. Can't Find 383 Stroker Flywheel
  89. Exhaust question
  90. RPM stutter, car shuts off
  91. Reference signal voltage high
  92. Cooling problem
  93. build sheets for 3rd gen?
  94. aaaahhhhhhhh
  95. Intake Upgrades
  96. Hey Babbie.. if you are seeing this check it out!
  97. 350 heads on a 305HO
  98. 89 IROC-Z fans stopped working!!!!
  99. Choke Light
  100. How can I get rid of my AC pump?
  101. fan shreaded its bearing... i think
  102. 305 intake swap?
  103. Replacement TBI
  104. Bipolar Temperatures
  105. 89 RS Camaro Upgrades
  106. gas in pouring out of the oilpan
  107. L98 shortblock weight
  108. 1973 350 engine!
  109. starting issues
  110. Catalytic Converter
  111. Fixing rot on inside of door edges!
  112. need info on timing and firing orders v8 350 in a 88 firebird/trans am
  113. help
  114. wiring problems...
  115. Dual mufflers on 3rd gen
  116. how close?
  117. got pics posted
  118. Which Motor is this?
  119. l98 intake
  120. Just BOMBED Emissions Test
  121. what engine
  122. my dads friends new car
  123. Third gen motor mount question
  124. Third gen motor mount question
  125. L69 Question
  126. Rear Suspension
  127. Engine Gurus needed, WTF does this mean on the pistons???
  128. What camshaft are you running in your speed density setup?
  129. Motor
  130. l98 cam
  131. Building for torque for pickup
  132. Y pipe question??
  133. Main bearings shot, crank scored......options?
  134. To carb or not to carb....
  135. Vin number help..
  136. Correct idle?
  137. Rims
  138. Smog Pump Application...
  139. Best place to get........
  140. Lt1 T56 Swap for 3rd Gen???!:eek:
  141. best exhaust?
  142. EGR Parts
  143. Need a chip burnt for my car
  144. Stock Fuel Pump
  145. What engine do i have?
  146. Dyno of an HSR 305
  147. 89 305 TPI swap questions
  148. 98-02 LCS's and Panhard bar?
  149. Is it possible to maintain emissions when installing an LT1?
  150. 90 5.0 Header Help! Pass side hit A/C Box
  151. Aftermarket Carbs
  152. What is the correct redline for a 1988 Iroc 305TPI???
  153. roller rockers in 87 tpi different pushrods?
  154. aftermarket intake for 87 l98 no stealth ram?
  155. HELP! crack between header + AIR tubes
  156. For Sale 91 Camaro RS
  157. How to pick an LB9 cam?
  158. timing an 89 350tpi
  159. 1982 Exhaust Hanger--Need your advice
  160. 1/8 Scale IROC-Z Model on Ebay!
  161. What could I expect
  162. 383, HSR, cc306 cam, and Brodix or Dart heads?
  163. lt4 in a 87
  164. Please Help
  165. help please
  166. Engine cutting out, need help please.
  167. Modify Thermostat on Race Engine?
  168. Acronyms
  169. Need 85-89 350 TPI ESC Module Part Number
  170. Help me solve my mystery
  171. WTB Firebird Formula 350 dual cat-who owns one
  172. header time
  173. Is My Mechanic Nuts?
  174. Felpro 1205 to a AFR 6820 ???
  175. Now That we Figured that out...
  176. L98 heads on LB9
  177. 89 camaro fuel pump?
  178. need to ID a zz9 or zz4 cam...
  179. to swap, or not to swap
  180. What to do?
  181. quick ?
  182. LT1 to LT4 on 3rd gen
  183. Car turning but not starting
  184. Combo estimate hp an cam selections
  185. Build or Swap?
  186. Speedometer doesn't work
  187. L98 Regulator Diaphram
  188. TPI Combo Q
  189. vats in an 88 ?
  190. 88 tpi iroc - is 286hr too much?
  191. Want to spray a TPI 305...need some expert opinions
  192. 350/30 Corvette Engine
  193. TPI to some kinda intake question.
  194. Last minute checklist for LT1 install!!
  195. Choke and Voltage Drain
  196. Help Get Thirdgen Models Made!!!
  197. V6/454 swap, need info.
  198. LT4 Hotcam
  199. 305 TBI to 350 TBI....Anybody done this before?
  200. car just dies & wont start
  201. G92 vs 1LE
  202. Stock Compression???
  203. 383
  204. 84 z28, go 383 or no?
  205. 1991 Camaro Idling Issue
  206. A G92?
  207. what do i do with my car
  208. 1989 Camaro Not starting
  209. 4th gen door panels
  210. Aftermarket oil pan?
  211. What is stock horse power for a 350?
  212. Wanted to know what others think...
  213. thirdgen down?
  214. Third Gen Trans Am speedo question
  215. handling info?????
  216. Plug wires question
  217. HSR and LT4 hot cam
  218. Converting my 350 V belt system to serpentine system
  219. Paxton SN-93 Supercharger help.
  220. Water pump return port?
  221. Starter Problems...
  222. Need Help Fast
  223. Installing headers on a 3rd gen
  224. k&n filter for 92 Z28
  225. Anyone need a driveshaft safety loop?
  226. need TC specifications from a Z28 350 TPI
  227. anyone have a vacuum diagram 4 a 89 rs stock 305
  228. parts off a 88 Iroc z
  229. Cam questions
  230. 91 Z28 TPI failed NOX test California
  231. HELP-coil placement on a trans am
  232. TGO *appears* to be back up!
  233. Will LT1 cam and heads work on a L98
  234. Team3rdgen hacked?
  235. 496 into thirdgen underway.
  236. Rattling Coming from Catalytic Converter Area I Believe...
  237. backfiring 87 z28
  238. 89 RS 305 TBI with California Emissions
  239. Vette oilpan on Camaro?
  240. What in the world have I got myself into.....
  241. 305 Crate
  242. iroc on ebay with tbi
  243. Big block 84 firebird
  244. cam install
  245. Getting the most from my engine.
  246. Borg Warner 9 bolt gears???
  247. LT1 Swappers inside please!
  248. TGO is down again (maintenance/upgrade)
  249. 305 TBI fuel/air mix
  250. 25th anniversary Z28
