- Tune Port Engines
- Can someone help me
- new exhaust system
- Spring Install Guide
- map sensor
- Reverse Rotation Verses Standard Rotation Water Pump??
- 91 camaro roller cam in 92 truck
- About to spray! Which plugs?
- New motor, rough idle- runs better warm than.......
- Computer Programming
- The 305 is dead.........any suggestions on a new engine?
- 305 Heads...
- Which Is Better: Reverse Or Standard Rotation Water Pump??
- IS IT BETTER TO RUN HEATER HOSES DIRECTLY TO INTAKE & WATER PUMP?
- Keyless Entry....
- car will not Idle all of the sudden
- Installed New Air Filter
- $1095.34
- Single to dual radiator?
- Racetronix Wiring Harness Instructions
- So....I just bought and LT1/T56...
- LT1/LS1 Heads
- LT1/LS1 Intake
- Has anyone swapped an automatic out w/ a T-56?
- What to do with my 1988 Firebird?
- Alternator Replacement????
- Worth it?
- Is the 305 L98 Worth Building??
- Confusing Error Codes
- Hooker Competition cat-back
- New Guy + Pictures
- cooling fan
- Anyone here ever seen a comparisson test of aftermarket TPI runners?
- Cam Question??
- Inside Temperature Gauge Post - Rumor or Real??
- 1992 Cooling Fans Schematics - Help Diagnose Fans Not Turning ON
- engine swap - bracket problem
- Thinking about buying a '91 3.1 V6, need some help
- what to set my timing too
- lalala
- What makes the 305 TBI suck so bad?
- Camshaft upgrade.
- Somebodys got to have an answer for this.......
- Derale Adjustable Fan Switch (DAFS) - #16759 - Extra info
- T-5 Tranny dilema......
- LT1 in 87 TA
- 305 Cam Numbers/Ranges
- Camaro Wheelie Movie
- It's offical, I hate my car
- Lt-1 swap into 1991 RS
- 1984 305ho to 350ho swap question
- LT1 guy needs help with buddies TPI setup
- Low buck project
- aftermarket parts
- 88 z 5.ol engine swap ?
- need ur guys help
- I need to port SLP Runners
- Repalcement Steering box
- Am I screwed or can I do something about this?
- Finally found out what I did to my engine
- Cylinder heads - which to get??
- Quick cam ?...
- Who has 383 TPI motors????
- intakes
- 1 piece vs. 2 piece rear main seal
- Need sum timing tips asap... bout to spray
- Possible ignition problem
- Shifter Problem????????
- best trans for a tpi
- 305 Vs. 350
- Reoving chrome from exhaust tips?
- Max valve lift for 350 TBI?
- rice eater
- 4th gen (98+) front brakes on a 3rd gen
- Stalls when its raining?!
- Fuel pump
- Hot Mods?
- Starting Problems!!
- 383 Tpi
- Crank bolt heli coiled and just a tiny bit slanted
- High Shift Point?!
- Door Hinges
- Vortec Vs Center Bolt?
- ZZ4 cam?
- Will a v6 alternator work on a v8?
- Carb Or Tpi?
- Headers installed, now backfiring @ idle and bad gas milage
- ECM going south?
- stealth ram and ram air
- K Member + Stock style A Arms
- 4th gen dash in 3rd gen car?
- Ok, so I'm confused...question about a 3rd gen I was looking at buying
- valve guides
- Long Spark Plug Wires
- Anyone
- Just curious
- Do any of you guys run a TPIS custom chip?
- tank fuel pump delete
- Anyone running a MiniRam setup?
- 334 debate and y not continued
- Where can I get a stainless steel Bolt set for a TPI set up
- 305 TPI 5 speed
- Shaking Past 65mph...New Suspesion, Rims & Tires...Puzzled :(
- no gas? cant start? bad fuel pump?
- When did 3rd gens get the 6 digit odo?
- So how reliable will a 3rd gen be if I get one in good shape???
- Engine block ID Question. 350 or 305?
- simple dash question
- 1989 should be the oldest 3rd gen I search for ????
- Windage Tray in Oil Galley Need To Go Back In?
- 90 iroc z value?
- Hesitation when I first push down on the pedal
- A4 to M6 speedo question.
- Installing the LT1
- 89 Gta
- Remember how i said i thought my ecm was going south...
- Full Tune up...what to do?
- HELP, bad idle, hesitation
- Spring Questions
- porting tb?
- Exhaust help
- Can I change the gauge cluster on my 3rd gen?
- Need Help,Washed my 5.7 liter and now,
- classic third gen stuff
- Injector question
- Engine Number Location on TransAm - Anybody???
- tips on pulling an l98 out of a vette
- New Spohn 3rd gen parts
- '83 police package camaro?
- Need some quick advice on an IROC-Z
- Stroker Kits Street legal?
- Slow speed surge
- Very Rough Idle and Engine Turns Off!! Why??
- Finally got it all together
- new problem??????
- tubular K member
- Fuel prob, help
- Smoke when started
- Trick flow heads
- Where can I get a cam for my 89 RS???
- Drilling out stock holes for new gauges.
- HELP, Burning A Lot Of FUEL!!!
- Fuel Injector Cleaner's - Recommendations...
- 84 Z-28 wiring issues
- Is the fuel pressure relieved or not?
- Looking for wiring Harness Diagram,
- Is this a crazy 3rd gen idea?
- Headers for 91RS
- SEVERE loss in mileage...any Ideas? Please?
- Replacing a stud..... how hard is it?
- Custom Hood Pics..Yay Or Nay?
- Engine ran rough, now missing badly
- New Timing Chain/Ignition Timing
- Found quite a bit of my problem was in the parts...
- Torque Arm Hitting Floorboard
- 305 tbi - 350 tbi HELP!
- third gen value?
- Installing a hurst 4 speed Indy shifter?
- Header Cracked, because wrap?
- Whats the best fuel to use for 86 TransAm ??
- loudmouth on a 85 camaro?
- Car has alittle misfire at idle, runs rough at 2,500 rpm what could it be?
- Slightly rough idle
- Headers/Exhaust
- Never underestimate the importance of a properly running ignition system
- What would it take?
- Need some measurements...can I even get a 3rd gen in the driveway?
- Trying to locate a pic of 400 oem pioneer flexplate
- 1 3/4" Shorties?
- L98
- Voltage Regulator
- A.I.R. Pump Will Not Spin
- TBI->4bbl
- Does anyone know what color coil wires are a stock 86 lg4 Z28 replaceing with accel
- Installing the LT1. Parts needed.
- 91 RS TBI Riser, what gives!!!
- New Member IROCU2
- anyone running this cam?
- Differences between RS and Z28
- speedo/inst. lights
- lg4
- EGR Question
- 1987 IROC Scoggin Dickey Vortec 360 hp crate engine project
- Wet plenum and runners
- LT1 in 3rd gen....motor mounts used???
- Alloy Wheel Size Question
- Wiring harness cross over?
- What cam to use here
- Cam Opinions
- Bellhousing Problem
- Is there anything i shoule clean or check/tighten under dist cap?
- Camaro Error Light
- Crane Cam Gold Rocker Arms
- LT1/T56 Swap: Speedometer, Mechanical or Electronic?
- evil gremlin?
- So Third gen's use a Gen 1 engine?
- how to put a 454 into a 88 irocn
- What lifters should I use for an 87 L98?
- How's this combo sound?
- how to step up the power for a 1989 formula 350 but stay reliable
- help me out PLEASE!!!
- Caddy motor swap
- Upside down Charcoal canister???
- starter problem
- How much is a LB9/700R4 worth?
- camshaft in a 5.0 TBI from a 4gen
- Engine Swap Help
- E85 Fuel
- 3rd Gen ?
- Turbonator ???
- Headers
- More Swap Questions: TPI headers for my LT1
- LT1 into a 91 maro HELP
- Help, my car won't start.
- Let's discuss the 5L
- Just wondering
- 1990 Cam Specs
- More 3rd Gen questions
- 305TPI aluminum L98 heads
- rough idle
- Body question on convert
- What's the best temp for a Thermostat?
- Trunk leak ??
- Alright, what the hell is scavenging?
- can any1 get me a pic of this....it would be amazing
- Injector Connector ?
- Headers, glasspacks, straight pipes...
- Looking for aftermarket Thermostat Housing for 87 Vette
- Anyone seen aftermarket annodized fuel rails?
- My IROC says 5.7 Tuned Port Injection
- How does "Batch Fire" injection work.
- 305 Tpi
- engine swap question
- Upgrading Cam...Computer Ques.
- Anyone else have an RS that just won't die??
- Z28 vs Iroc-z
- Replacing Stem Valve Seals in a 305 engine
- new motor overheated
- Newbie here. Need some advice on buying a camaro
- Shorties or longtubes?
- So whats my rocker arm stud size?
- Will 4th gen "salad shooters" fit?
- What gears do I have?
- I Feel Like an Idiot...help lol
- RPO codes for 1989
- SOMEONE! please help me with picking a full exhaust system!
- Might have to sell the Z.. how much do you tink I can get?
- Injector question! Will these work as a replacement?
- 19hp and 59lb of torque with an adjustable fuel pressure regulator???
- Rear hatch problems, need advice
