3rd Gen / L98 Engine Tech
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
  1. Forging Differences 5140 vs 4130 vs 4140
  2. Need help tuning!
  3. Gas tank dilema..................
  4. 24# Injectors will they be to much
  5. What up with Spohn!!!
  6. Attention 3rd gen historians... QUESTION...
  7. spintech mufflers
  8. holley stealth intake
  9. roller rockers
  10. Stealth Ram install pics
  11. Need Help!!
  12. trunk area
  13. Tranmission problems
  14. Anyone ever hear of S&W racecars or own any of there stuff??
  15. What would I have to buy to run a 383?
  16. Still debating engine options... opinions needed
  17. Camshaft upgrade...
  18. Stroke a 350 to 383????
  19. Alternator good, but not charging... (starter related?)
  20. AFTERMARKET CAMARO COMPUTOR
  21. Idles High
  22. Shifter "hop"
  23. the dreaded thud from the rear suspension
  24. how to set timing
  25. Magnecore Wires???
  26. Seat covers...Are they worth it???
  27. Why is my car ideling hot?
  28. 3rd Gen/2nd Gen Fbody chief at Bowling Green
  29. value??????????????
  30. Someone wanna help me choose my next upgrade
  31. Need some help on headers install.........
  32. TH-350 installation
  33. snapped bolt!
  34. My car is acting odd....
  35. Rear end noise?
  36. march power and amp pulleys on an 89auto.
  37. 91 Camaro for Sale, New Engine
  38. Bad click/pop noise at low RPMs after build up
  39. What can be causing this misfire/stuttering??
  40. Will l98 heads bolt up without any problems?
  41. KYB Opinions??
  42. What size engine came in 90 IROC?
  43. Whats the part # for a K&N that clamps on the TB?
  44. Need Help With Magnum TPI Project Car--Induction Solution Needed
  45. help me
  46. Oil pressure question.
  47. T-5 Trans and QuadraJunk QUestions. 83 Camaro
  48. stumble at cruise speeds
  49. Will the shorter iroc front springs fit on a normal z
  50. 700r4 rebuild kits
  51. Running duel exhaust. Don't tell me it can't be done.
  52. Radiator Need help!
  53. gm fastburn heads?
  54. Will a bigblock fit in a 3rd gen?
  55. Smoke on start up
  56. Newbie - Tire size on stock '88 rims
  57. Almost forgot
  58. is .045 to much of a gap on my Rapidfires????
  59. Help!! Bad hesitation @3000rpms in 1st gear
  60. Are there any kits sold to lift the back end of a Z 1 Inch?
  61. AC retrofit
  62. Best Shop Manual?
  63. smog pump removal
  64. Egnition switch
  65. Lock-up connector on 88-92 700r4 trans ...question
  66. Tail Lights ?????
  67. Timing on TPI
  68. Rebuild a T5???
  69. FOUND!!!!!!!!
  70. 3rd Gen LS1 swap
  71. Any recomendations for an intake?
  72. 1 LE brake
  73. 1988 block info
  74. Best source for new GM ring & pinions?
  75. Pop-up headlight sticking
  76. Problem
  77. fuel pumps
  78. Where to buy diagnostics programs.......
  79. Opinions on mud flaps/splash guards
  80. Dumb question?
  81. anyone have 1992 camaro rs specs......
  82. I'm buying an 89 Formula and I need your opinion
  83. Were the 92 stripes painted on or stickers?
  84. I need help!
  85. installing a new motor soon!
  86. spohn performance brake kit
  87. TPI fuel system questions
  88. Lookin for pics of 305/350 TB, front view
  89. I did not know where else to post this.
  90. bad blow by and what causes it?
  91. installing fuel tank
  92. 86-iroc no spark help!
  93. new guy !!!!
  94. new exhaust sound!!!
  95. Rough Idle
  96. how do i remove fuel pump
  97. speedo cluster question?
  98. Will 97+ 5 Spoke Rims fit my 84 TA?? anyone know??? read!
  99. brake
  100. don't want them oval rims
  101. Rim Question
  102. Brake upgrade
  103. 86 z28 options
  104. Will 87 Firebird interior fit my 88 camaro?
  105. A/C too cold?
  106. cleaning out 3rd gen stuff avail
  107. TPI performance????
  108. Where to buy a stock TPI alternator pulley for 88 IROC
  109. WTB: '89-'92 305 TPI 5speed Camaro
  110. Car won't start after sitting for 30 mins
  111. Need some advice bad...
  112. '82 Z28 questions
  113. H.O. Dual Snorkle swap
  114. Just wanted to say whats up.
  115. Speedometer Question. I did search.
  116. Color code
  117. camshaft
  118. Im new so please help
  119. How many 91-92 trans am verts were made??
  120. convertible top questions
  121. what's the trick to seating the tranny pump?
  122. What are my chances?
  123. Open Element
  124. Solutions to my car running really fuel rich.
  125. 2.8L 84 Camaro misfiring on acceleration
  126. Fuel injector lbs
  127. do I need a new starter?? Please read
  128. Carburation Blues...
  129. My E-Tec dyno numbers (long post)
  130. 3rd gen sites??
  131. Please help, car will not run.
  132. Quick quistion
  133. reverse valve body tranny's
  134. Non Tech: 1/25 1987 IROC-Z Model kit
  135. Free ram-air mod?
  136. RPM gauge
  137. What brands available for fan switch?
  138. MAF?
  139. Cast iron manifolds
  140. stripe kits?
  141. Busted Gas tank
  142. Help, my 'bird is spewing oil badly
  143. What tires to get
  144. where should i start my modifications?
  145. How do you descreen a MAF?
  146. automatic to manual?
  147. Replacement carpet ? Year One vs ACC ?
  148. What should I sell my jet stage 2 chip for?
  149. question on lifters and rockers
  150. Can I put my 01Z28 shocks and spring on my 92 RS
  151. 5 speed upper console
  152. Who has the best T-top weatherstripping kit?
  153. New car is a piece, NEED HELP!
  154. A funny noise when I punch it??
  155. I need 350 swap help
  156. What is needed for 95' Z wheels on 90' Formula?
  157. 84 z28 engine light????????
  158. oil leaking 305 tpi 85 Z28
  159. V8 To V6 Swap
  160. will a comp cam 305 from an LT1 work in a L98 TPI
  161. Spohn TQ arn th400 in a thirdgen
  162. Performance Upgrades for '89L98
  163. Interior
  164. Anyone here from Pennsylvania?
  165. Need Help With Smog B.S.
  166. 84 Z28 engine fan problems
  167. New Interior for my 82'
  168. Oil pan fit?????????
  169. swapping an LT1 TB into my superram
  170. Camaro 1985
  171. fixed my fuel leak but now stalls at abything more than 50% throttle
  172. Speedo probz...
  173. proper way to hardwire fan?
  174. Non t-top 91/92 How much ?
  175. detonation!!!
  176. Anyone know anything about Air Flow Research (AFR) heads??
  177. 92 305TBI to 89 350 TPI, what do I do about the speedometer?
  178. Engine stuttering when cold...please read
  179. How much for a rebuild???
  180. electrical problem still!
  181. Valve cover gaskets
  182. Intake manifold question
  183. Dumb question.
  184. what should i do now?
  185. How can I stay at WOT in 4th gear??
  186. benefits of ram air?
  187. ball joint removal????
  188. left turn signal not working
  189. Anyone have a 383 and pass the sniffer?
  190. Front end shake (VERY BAD!!!)
  191. O2 sensor questions...
  192. We should get together a group of 3rd Gens to represent us in the Hot Rod Power Tour
  193. How important is it to have KYB 5 ways all the way around?
  194. throaty muffler for an 84z????????
  195. I finally got my pics on here, Tell me what you think.
  196. Ok, here are my pics, see if it'll work this time.
  197. My car is putting out large amounts of NOX. Will not pass inspection.
  198. Nology Wires????
  199. Knock sensor is retarding the $hit out of the timing in my car.
  200. What's the best air intake?
  201. I need Head
  202. Torque Arm?
  203. has anyone actually put a 89 TPI, wire harness and computer in a 91 or 92 RS
  204. cooling system acting crazy
  205. Can someone tell me what may be casusing an overly stiff brake pedal?
  206. electric fan switch where are you?
  207. something loose/broken in the front end???
  208. Guaging interest: burn my own chips or ed wright
  209. Open element filter on my TBI ?
  210. cooling system acting crazy
  211. hood louver kit
  212. How do you pull the pins out of the drivers side harness plug?
  213. LT1 Swap: Started it Up for First time today WOOHOO
  214. 89 IROC....tell me something about his car
  215. Bilstein shocks and struts how good are they
  216. 3rd gens w/T-tops how much power do you have
  217. Leather Seats Where to Buy Resources!!!
  218. Need some part numbers....
  219. What the hell happened????
  220. cams too big
  221. Ram Air Intake
  222. Arg... SLP way to much, other headers that are great?
  223. Dual Exhaust? PLEASE?!
  224. Can anyone help me with a plug question?
  225. Wheel locks
  226. radiator dimensions
  227. Need Help Choosing Pistons...
  228. 4:10 gears
  229. car wont start
  230. Brakes on my 87 LT1 GTA
  231. Re-building rear end
  232. I need your help with some ECM Files...community support!!!
  233. silly question regarding IROC-Z tachs
  234. Were exactly does the TPI sticker go on the back bummper?
  235. jetting question for secondaries
  236. 180 thermostat does it affect performance?
  237. 305 to 350 clutch question
  238. NO CLUE whats goin on
  239. Good Deal?
  240. I just installed dual 12" radiator fans on my car.
  241. Anyone out there got a dual fan Set-up for Sale, or tell me the best place to get one
  242. Oil Pan R & R
  243. Where are the RPO codes at?
  244. 1982 Berlinetta 305 auto, where to start?
  245. I think i messed up my block
  246. I'm published!!!
  247. vortech head question
  248. "Turn that $hit down..."
  249. Rust in Rear is this a bad sign?
  250. where to find custom rear decals for the bumper of car
