3rd Gen / L98 Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 [39] 40 41 42 43 44 45 46 47 48
  1. Time to ditch the ZZ-9....opinions pleeze!!
  2. question about heads and intake...
  3. Help Rebuilt the engine but now........
  4. driveshaft
  5. maf not working
  6. i need a tpi intake for vortec heads
  7. Question about T.V. cable bracket on carb'd engine
  8. Electric Water pump? good idea?
  9. Can i take'em out?
  10. Is this worth it?
  11. Mystery box in engine bay
  12. HELP!car died
  13. Trans cooler lines
  14. SLP bolts
  15. Car is getting painted need to get Stripes Template
  16. putting old stlyle heads with my Tpi
  17. Speedometer Bounce problems
  18. 1992 Chevy Camaro RS - V8
  19. Problem bouncing up and down on highway?
  20. Car is bogging out bad.
  21. 1987--L98 Discussion
  22. new member, got some questions about my car?
  23. Key Stuck in Ignition
  24. Does your Iroc do this?
  25. Does anyone happen to know the GVWR
  26. good deal or not?
  27. auto 305-manual 350 conversion
  28. Help!!!!!!!!!!!!!!!
  29. 87 Iroc Gears.
  30. 87 Iroc Help!
  31. believe engine builder???
  32. What's this worth? (please)
  33. Which do I do? 400+hp 305 or drop in an LT/LS1
  34. Starter
  35. 305 350 swap
  36. trans swap
  37. can a 305 be a fast engine?
  38. re-post? anyone seen this on egay?
  39. holley 650 DP
  40. For all the people that say it wont work
  41. Shorty vs. Long-Tube header for '91 Z28?
  42. Plug Gap On 89 305 Tpi?
  43. What size are 3rd gen rims?
  44. My 89' IROC 350's exhaust system, what do you think?
  45. what all needs to be done....
  46. Running LT1 cam?
  47. I Hate My Car
  48. Dropping Rear to Remove CatBack Tutorial (pics)
  49. Those with rack and pinions in 3rd gens...
  50. New owner and user with engine question
  51. What is involved in putting on a wonder-bar?
  52. tpi setup question
  53. will fourthgen front sway bar fit my 92 z28
  54. looking for a hood for my 92 z28
  55. what would be idle for me?[406]
  56. Z28 Turbo
  57. How do I strengthen my tranny mount.
  58. Can someone PLEASE help me with this noise??
  59. How much for a full 3rd gen performance exhaust?
  60. Help identifying a sound
  61. who sells mass air flow burnoff relays?
  62. Was there such as car made?
  63. where to wire my electric cutout?
  64. Anyone know of any Cold Air Kits OTHER than SLP?
  65. Recalibrating Speedometer
  66. pulling a 305 out...
  67. Need help once again
  68. exhaust
  69. no start condition after warm-up
  70. radiator fan only working when A/C's on
  71. Engine Stalling
  72. Throttle Cable TBI
  73. Valve Stem Seals
  74. Engine trouble?
  75. Injector size
  76. Stroker Kit Sale
  77. Dual Exhaust
  78. upgrading my computer.
  79. Trany bad?
  80. need help- oil pan/girdle clearance
  81. Wiring up a choke.
  82. Mysterious valve on fuel rail....
  83. No fuel!?!?!?!?!?
  84. I need some instruction to fix idle screw set
  85. 4th gen "clone"
  86. Air cleaner flange size
  87. Exhaust
  88. What's involved in and LS1/LT1 swap?
  89. Alternator / Battery Help
  90. Newbie Questions about Tranny Accessories
  91. Cowl Induction
  92. 87 350 Engine A MESS! HELP
  93. HEI upgrades for Computer Controlled HEI modules
  94. missfiring and dying on cold start
  95. pulling a seized engine
  96. Clicked off a new best
  97. how to store car and new tranny
  98. motor question
  99. Cranks but dies 1988 TPI L98
  100. Muffler advice needed
  101. 305 to 350 swap
  102. TPI Blues
  103. ****in Dammit
  104. what 17" tires fit?
  105. Why not shifting hard enough?
  106. stealth ram question
  107. Need Aftermarket Advice
  108. WTF! coolant leaking from my oil cooler lines
  109. steering cloumn?
  110. Full Exhaust suggestions.
  111. How much would a cam do
  112. 200k Miles!
  113. 10.20's?
  114. belt size's?!?! is it possable
  115. 350 Tbi
  116. what are the best pistons and rods for a 305?
  117. best choice for l98 replacment
  118. whats this wire???
  119. digital ignition box...
  120. rebuilt engine won't idle
  121. Ford injectors in a Camaro?
  122. tuned 305 TBI
  123. Ya.. so how do I finish getting the brake-booster out?
  124. timing is going crazy
  125. Switching to carb, Help!!
  126. Holley Fuel Injectors
  127. Wiring issue?
  128. looking for a place to mount a msd box
  129. loss of fuel pressure
  130. Replacing injectors on a TPI
  131. Intermittent no crank problem.. Help!!!
  132. A/C fix question
  133. 24 Lb Injectors In A Stock 350 Engine
  134. Cat question......
  135. next step up for 350 tpi?
  136. LT1 intake manifold on a tpi?!?!?!
  137. rear water passage on intake manifold
  138. digital dash
  139. is it possable to TUNE a mod on a tpi at home??
  140. DO you need a charcoal canister
  141. Started the install on my HSR
  142. Is there a good A/C bracket out there for 3RD-Gen LT1 Swap?
  143. Noisy PCV?
  144. Where can i get a head light motor rebuild?!?!
  145. Need a picture of how your ecm sits under the dash..
  146. Delayed Throttle Response?
  147. Help with 305 topend rebuild/mild build up
  148. running rich
  149. Brace on the rear of the car?
  150. Header options
  151. What the heck is a Camaro ZF!?!?!?
  152. 1989 camaro
  153. More questions
  154. temp problems
  155. Fuel pressure or ECM not opening injectors
  156. Buying a 1985 z28 camaro
  157. couple quick ?s
  158. gen 2 heads on gen 1 block?
  159. Belt size for 92 Z28 minus smog.......
  160. can anyone please help me
  161. Please Help Me!!
  162. Fuel system pressure
  163. 700r4 shifting high
  164. my friend wants to build a 350. Have some questions.
  165. car won't start security/brake light
  166. Please help, fuel pressure problem??
  167. !smog pump, !ac, stock tensioner.
  168. Changing cam in car
  169. tranny shifting problem
  170. idle tuning with cc306
  171. white goo under valve cover
  172. need help with tranny??
  173. What track times and numbers should I expect?
  174. slp cold air intake
  175. Goodyear hoses
  176. 700R4 trans shift cable bracket
  177. Build my own exhaust?
  178. Great...
  179. Derale Adjustable Fan Switch Installation Pics
  180. TPI on old block?
  181. Car shuts off?
  182. Long tube hooker o2 sensors
  183. one little wire..
  184. max fuel pressure
  185. FI vs Carb....Horsepower Difference
  186. tired 5.7 in my 90 formula
  187. 420 hp 84 TA
  188. changing fuel pressure vs mpg
  189. What did you pay to tint back window?
  190. converter 700r4/4l60e
  191. what kind of hp gain can be expected by adding a 400 crank
  192. tach's shot
  193. Power windows
  194. Fuel line
  195. wierd coil on a/c box??
  196. cooling fans won't come on?
  197. What Oil Dipstick can I use for a '91 Z28 with headers?
  198. What temp does Hyp. Thermomaster turn fan on?
  199. code 43
  200. Where can I find a 5 wire maf connector??
  201. 89 camaro rs TBi 5.0
  202. URGENT!!! What's this relay!?!!
  203. Check out these scantool readings for my MAF. Bad?
  204. Which Goodridge brake line model?
  205. Hi, new to forums.. and possibly future camaro owner
  206. tbi to carb- how??
  207. Only Right Wheel Has Power...
  208. Can someone recommend a good brand of exhaust?
  209. jumping timing?
  210. Which is a quieter muffler?
  211. do i need tuning???
  212. Question about L-98 tuning??
  213. A good ammount of CFM for a cooling system?
  214. 1982 Camaro Pace car carb
  215. bad fuel pump?
  216. Hedman headers and hedman y pipe question.
  217. STUPID AUTO ZONE KID!!! needa belt size
  218. Alternator Not Charging
  219. Sway Bar questions.
  220. transmission install prob, pilot bushing too small?
  221. Summit Racing - Borla Exhaust...Crazy!!
  222. I'm missing somthin... tpi wont pull hard enough
  223. 89 RS camaro motor swap...
  224. O'crap Broke It Big This Time!?!?! Help
  225. what should I do with old 4 bolt 350 block
  226. BBK Manifold
  227. 3rd gen f-body and 5grand
  228. 383 Stroker engine vibrations
  229. New Third Gen quarters - Where can I find them?
  230. Stupid head lights
  231. Can somebody ID a part for me?
  232. Trying to hook up an msd 6a???
  233. Does anyone own the "Jongbloed" hood?
  234. 1991 camaro fuse box diagram PLEASE CLICK
  235. So is any of this 305 stuff true?
  236. how can i lower my ET-1/4 time?
  237. Thumbs up to wonderbars!
  238. tpi cam Q please help
  239. So, what should my ignition coil ohm out to?
  240. Electrical or mechanical gauges
  241. 92 rs tbi no start ... help??
  242. question about oil pump gears
  243. Need VATS help!!
  244. Ignition Coil
  245. 1991 - add vortec heads how much cam??
  246. Shorties or TES
  247. Chilton or Haynes
  248. these relays...
  249. lt1/ls1 maf
  250. Wiring experts, help me out!
