- TPI - custom chip - EGR
- $100 camaro
- EECS ?? What are the options?
- 98 K1500 4l60e trans bolt in for thirdgen?
- Anyone installed this Borla exhaust before?
- Black Dog
- It's alive!!!
- Chip for 305TBI to 355TBI... Where do I go?
- Brakes?
- Need help.....info about my 160 thermostat
- best stock fuel inj??
- what does this wire connect to?
- Any links to a site that lists SBC cylinder heads?
- SLP runners on a 305?
- Power Steering Pump Woes
- What port size is a '91 stock y-pipe? (Exhaust replacement ideas too!)
- Fan... and overheating...
- how much hp gain with extractors?
- tpi motor
- Whats the stock gear ratio on a 88 iroc
- engine swap
- Cars made
- New track times...check-em out!
- Vacuum Lines/Plumbling
- fuel pressure gauges
- cant keep the big block cool
- Trouble Starting
- Cam/Crank shaft Positions
- What year was the camshaft bad in the camaro?
- Need help on engine swap
- smog junk
- Distributor Help
- cooling fan problems
- Missing header bolts?
- hp mods for 305
- anyone ever have this unusual problem?
- Starting problem
- ya so i forgot i own a 3rd gen
- Pulling out Tail lights
- Tranny Rebuild Time?
- New spark Plug and wires replacement
- Corvette servo
- Which is better? Open element or dual-snorkel?
- Car won't Start ( Serious HELP is Needed
- "VATS"
- 87 Iroc SB 350 headers
- Will they fit???
- WOO, WOO!! Got antother Z28!
- I need a Y-PIPE for my 3rd gen Z28
- Edelbrock Carb on stock intake
- How rare is my car???
- Pan hard
- How rare is this otion package
- L98 heads on a tbi 350
- Motor mounts
- Exhaust
- Steering wheel ?
- weber clutch/flywheel?
- Map sensor vac port
- 1986 305 TPI running rough, 3 different codes. Ideas?
- 305 tpi on a 350
- Rim's question
- Changing from Convent Oil to Mobil1
- Flow Master Aftercat Exhaust Can I get it off??
- Will a MSD 6A fit
- My Serpentine belt keeps splitting
- '89 TPI - no start - can you help?
- ???? totally clueless on this problem
- Dropping in the new engine.
- First Car/Camaro
- 700R4 plug question
- IROCZ TPI to 1st Gen SB
- Another Torque Thrust II Post...
- Code 54 back and better than ever.
- ls1 motor mounts
- "BLACK DOG" Camaro
- Performance parts to upgrade ride?
- Crank pulley bolts torque specs???
- Need ALOT of help!
- ultimate exhaust system
- Camaros SUCK!!!
- Pssing emmissions with a carb
- Damned dual-snorkel intake wont fit!
- Camaros: hard to handle in rain?
- dynoed the 305 TBI/N20
- Modding TPI
- Cam for my engine???
- T-56 swap costs?
- Where Is The Vehicle Speed Sensor Buffer On The 89??
- 87 IROC 350 to TPI
- Please hep w/ the designation of the cylinder numbers...
- Charging problem..
- Alarm system.
- Peg Leggin it.
- Help with cam
- TH350 & torque arm problem
- 350 with 5spds
- cam problem
- rust f#$@in' sucks
- How do you set roller rockers on a 91 350 tpi car?
- what type of fuel filters do 'maro's have?
- LT1 in 89 z28
- power steering hose on 87 iroc
- just bought 91 rs what mods to do
- Starter Issues / Brake Issues
- Need Help!!!!!
- alternator wires?
- Intake/Exhaust
- what time would my car run
- Engine Swaps
- Just bought an '86 Camaro- What should I do.
- newbe question kinda
- Horn Button Problem
- 84 Z28 emissions question
- Car wont start.. no ignition power....
- 350 HO Deluxe Swappers
- Good header back system?
- spark plugs
- about to buy 88 V6 Camaro
- 305 twin turbo?
- free mods
- 3rd Gen "Choke" light
- Looking for headers, what do you recommend?
- iroc help
- Problem with air filter base not clearing distributor
- Throttle Body / Water Crossover Sensor......
- 87 IROC 350 4bbl or TPI? PLEASE!
- fuel pumps
- Voltage problems, please help!!!
- hatch motor??
- Component Location Manual/Guide
- Looking for raspy, nice, exhaust for 92 z28?
- L98 with a manual tranny
- Vortec heads?
- Heater Valve problems-Help!
- Quick Question
- stupid question, spark plugs
- Engine for '92
- 355 AFR HSR Cam Selection
- HIGH Idle
- Skipping TPI350
- 1986/87 tpi 305
- Myth or real world gains?
- 89 wiring help needed
- question about a complete drivetrain swap on a 91
- firewall ? anybody ?
- exhaust leak
- need help
- 1986 Computer controled
- Offset/Drop base air cleaner?
- Car wont start.. makes a dry exhaust noise, doens't sound gassy
- Alternator
- HEI help
- What engine to start with?
- March Mid Mount Serpentine Setup Info + Pics
- What in the hell?! Battery charging wire
- Changing thremostat- Please help!
- Spark plug gap
- smoking
- Headers
- Rebuilt Engines ?
- Air pump solenoid location
- Time for a dumb question
- very confused, Alt wiring..HELP!!!
- Engine Knocking
- Idle, the car and i both confused
- Where should i go to get a nice catback
- Sticking brakes
- intake manifold torque specs
- brake booster swap?
- 88 Iroc Cutting Out 1500-2500 Rpm
- Paper air filters vs. "Special" filters
- Horse power and AC unit
- Dyno results, a little dissapointed.
- Electric Cutout
- Power steering pump pulley install
- Buying a new muffler today... but i need suggestions
- Mr. Gasket Street Scoop Pictures
- Engine Compression
- Carb - Running Pig Rich - Engine Shake At Idle
- Fans not turning on. Need help troublshooting.
- Too much fuel after Ford 5.0 injectors installed?
- hatch will not open on 92' z28
- probelms with idle on 92 z28
- Do I need new valve seals?
- TBI to Carb Question
- Spark Plugs?
- Busted Tranny mount mabye caused more probs?
- serious overheating / already used search
- 27 or 30 spline?
- carb-nos plate=clearance?
- fuel problem ?,help please
- QUICK! Easy easy easy question
- Replace fuseable link for fans?
- motor falls at 5200 what is wroung
- Which engine mod next?
- Need a throttle cable for LT1 swap.
- Why do these sub-frame connectors look so funny?
- Just not what I was expecting
- my car(duno where else to put this)
- vaccum lines
- Fuel System...Please Help!!!
- Factory Oil Cooler Hoses.........
- cam bearings for cc306
- Oil Cooler hookup w/o heater core........
- Tachometer usage
- enginetech moly rings?
- Intake height help
- Ram Jet and hood clearance?
- Carb help, car sat since 1997
- Engines in!
- nitrous
- My new Project
- Houston we have a problem!!!!
- Spuddering when trying to accelerate
- EGR Help
- Just picked up my '87 i-rocz...
- 89 WS6 Dual-cat exhaust question
- Any forced induction guys here?
- Electric hatch motor???
- 3rd gen tach problem
- Info needed on GM reman engines .
- Converting Automatic Trany to Manual
- Coil...No Spark???
- New Motor Red Hot Headers
- extended cranking to startup
- 350 build up
- Fog Light Mounting
- TCI breakway 2400 converter wont slide in
- Camel backs, 882`s or 1.94 305 heads
- harmonic damper install question
- New to the Boards and just bought a 83 Camaro
- Fiberglass doors???
- so glad i dont live in LA
- 2.8L to 5.7L engine swap???
- Getting rid of PCV?
- the 700R4's limit
- How many Splines??????
- Horsepower estimation on this setup
- A few electrical questions
- How can yout ell when your engine isn't "matched" properly?
- a bolt missing in the tpi runner to lower intake..
- Newbie Questions/Problems
- 89 RS starting problems
- flywheel question/problem
- Picking a carburetor.
- turbo400 or 700 tranny?
- Need some major advice
- new engine
- Question on Holley Stealth Ram?
