- IrocZ swap?
- crossmember bushings
- Installing a flex fan???
- What hardware will I need?
- Accel Shorty Header plugs?
- ls1 brake upgrade for 3rd gen
- S.o.s.
- Compressions issues...
- wtb: 88 tpi wiring harness from pontiac firebird trans am gta
- no start condition after warm-up
- Rearend Swap
- Speedo "Upgrade"
- Really horrible gas mileage
- Need some help with racing rims, please.
- Whats the positive side on a pigtail plug!!
- auto to manual swap....
- Good Idea?
- Deleting EGR
- Has anyone ran the edelbrock performer rpm roller cam?
- These headers a direct bolt-in?
- engine problems need help bad
- SES light
- 2500 to 6500 rpm on a 400 block...
- Will these fit
- Cam Help.....
- 305 tbi
- HELP! newbie trying to build a 383!
- Ok guys..what did i break this time?
- Quite the dilema here: To Cat or Not to Cat?
- Starter Connections
- Oil Port Hole On 350 Small Block
- Problem number 4,261
- Overheating
- need help identifying these heads
- Exhaust sound level
- 350 tbi
- TPI water pump question
- Borla catback??
- super charging a 91 z28
- exhaust for 86 Camaro
- Idle Compensator Sensor
- Another head question
- TBI bolt on question or whatever
- 350 swap possible?
- 305 becoming a Stroker?
- Injector size????
- HSR requirements???
- two wires to each TBI injector - Help
- trick to change the FP regulator? TBI
- small starter wire staying hot
- Third Gen exhaust question
- 305 heads on a 350?
- LT1 swap headers and catback combo?
- Question on a buddys car (350 TPI why so slow)
- Flow restrictions frame chassis arrangement?
- stock fuel pressure for 88 L98
- Fuel Pump question on a 91 RS
- 4 Wheel Disc
- will these tires fit?
- Code 23 with 84 L69
- TH350 stuck in drive?
- 93-02 seats in a 82-92 camaro
- Question on weight loss in a 3rdgen LT1 swap?
- Exhaust Question!!
- 91z28 after exhaust onto 91 RS (3" vs 2.5")
- racetronics fuel injectors...
- Cooling Fan will not come on Need Help!
- electric water pump question
- Welding How-To Advise and other Tips...
- Choosing Headers and Y-Pipe
- Turbo Info Needed
- 3rd gen engine swap questions
- what would you do
- HSR vs. Gears. What first?
- 86 iroc header question
- Swapping 350 TPI over to a carb
- Cam install question
- Help!! emissions ? about efi to carb swap
- (QDR)Driver Failed
- Well motors out and disassembly has begun..
- Open Element Air Filter
- Speedo Gear coloring
- 350 TBI --- Where is the MAF?
- Headers come with all accessories?
- 1.6 rockers
- Carb
- Removing A.I.R.
- Fuel pump relay?
- Need help finding stock parts for 3gen
- help Engine size confused here
- 350 bottom end question
- This is all A/C crap right?
- need advice on heads, headers, cam for an L98
- Intake question???
- 350 swap into 305
- pulling a tranny, cant get 2 top bolts
- Small block chevy in mustang
- Crud in Engine? Use Kerosene to Clean?
- LT1 Question Swap
- SLP cold air induction
- 9c1 caprice 350 ecu
- Problems with 89 Iroc Z starting...
- 305 TPI put on a 350
- 87 brakes
- Rear swap
- bow tie vortech heads
- Synthetic Oil????
- Header question
- carb issues.....!....?
- Increased fuel consumption after header install?
- New Engine Oil Priming!!
- Realistic Modding Potential -- LB9 V8?
- Exhaust Questions
- Best way to get this car off the ground?
- Lg4 Questions
- fuel injected V6 to Carbed 350
- After Tune Up Car Wont Start
- radio wire colors
- New Motor Start Up Instructions
- Ok.. what are the possibilities of a rearend holding 300+horse?
- Tranny possibilities
- How Difficult is it to Start Up A New Crate Motor
- LG4 Dying on me?!!!
- heads/cam package??
- What temp thermostat?
- car runs like crap.... im stumped
- Ran good - won't restart. list of things needed please. in a bind.
- Attention 88_305
- Injector cutting out on tbi
- wiring diagrams
- Rebuilt Engine
- Fog Lights vs. Ram Air
- cam retaining plate year?
- Free Third Gen Camaro Interior
- Whats the Correct Timing on a 350 SB?
- How high compression can i go?
- whould singal 3in exahust be enought
- Tachometer doesnt read!!
- TPI From LB9 on a L03
- Car Chemistry Header Inserts?
- Manual tranny swap
- Hi guys, I need help!!!!
- Hatch Motor keeps dying!!
- n e one have a clue?
- We Bought the 88 Formula 350TPI
- 86 or 87 engine question
- lo3 to lb9
- Can a manual lock replace a Hatch Motor in a 89???
- Carb cleaner?
- 350 Drop (Eletrical Question)
- exhaust manifold boltz?
- 89 Iroc with T-tops
- Why does my 305 NEED 91 octane??
- first engine upgrade?
- any info on LS1 swap???
- HEads
- Hedmans??
- 92 305 TBI to TPI swap
- Transmission problems, 1984 Z28, 5 speed, manual?
- Gas Tank
- Which is better, Carb or TPI?
- little help with motor mount
- Fuel Injector Installation-
- Question about my car's carpet
- 86 350 tpi motor rebuild suggestions
- cam help with 400
- Flowtech Headers
- CompEngineering Bolt-in SFC C3120*
- Am I in too deep?
- Shifting High?
- Transmission help!
- 305tbi
- 700R4 build up to go with 300 hp/400 ft lb L98
- Strange vs Motive Rear Gears, also which ratio:
- Electrical Question.
- Problems converting to turbo400
- My timing is off apparently
- Underdrive? Pulley Setup?
- fuel Pressure with 5.7 TPI
- Planning an LT1 swap into my 86 Z28
- Installing distributor with engine in
- How Many Teeth In The T56 Tranny Gear?
- Setting the timing broke my MAT sensor?
- Vortec heads on 383
- What cam for a 89 RS camaro 5.0 TBI
- How to install hydraulic brake line on Slave Cylinder
- TPS adjustment question
- tranny for caprice motor
- torque arm bushing
- Noob to 3rd gen
- Performer Or Torker Which Intake
- stock engine accessory limits
- Motor ?
- motor mount ?
- 305 TBI cooling system
- Fuel Pump
- Does Anyone think this is strange
- Another TPS question
- What injectors should I get?
- 80-Z28-350 Stalling When Hot
- Camaro Troubles NEED HELP!!!!!
- Camaro trouble NEED HELP!!!!
- New Motor Breakin???
- Identifying these injectors..
- What Thermostat?
- 305 to 350
- Whats The Best Oil Weight To Use???
- Lost
- Help with Replacing the Rochester Carb...
- bellhousing bolts
- When you get a code 32.....
- maybe you can help with this
- Lt1
- Service Engine Soon
- Power Steering?
- Tockico or KYB
- Could I have a chance against this car?
- Adjust roller rockers - zero lash
- Installing a stealth ram
- umm...my blower motor is stuck on?
- engine swap fuel pressure
- knock sencer
- Ls1 T56 In 89 Iroc!!
- Got a Code 32...
- Engine Hesitation
- RPO Codes
- Misfire on cylinders 2 and 5
- rattling noise on 90 rs
- lack of power/hesitation in my 305 TBI
- 30lb injectors on a stock L98
- Long Tube Headers And Daul Exhaust
- header gaskets
- Quick Tranny ?
- Power loss problems + Hesitation
- Fuel Pump Question
- starts & dies
- Which of these is the best way to go for cat's?
- Starter for my 87
- Run on
- How much is a DECENT 89 GTA worth?
- Can i use this fuel rail?
- low 13's?
- Fuel injector installation
- 455 pontiac.... 500+ horse?
- im back, new times, No probs
- So besides a 305, What else fits a 700R4 Trans?
- Picture time, pics of stuff I dont understand :)
- Fuel pressure gauge
- best low-profile centerbolts?
