- At which Lift or duration does your idle get lumpy?
- 420 cid 400 block Limitations
- Will I have to re-jet if i...
- headers, no emission stuff, what should I do?
- 305 tpi went 13.55 today!!
- 1984 Z28
- who would win?93 mustang notch vs. 91 camaro swapped 350Z28
- 305 build up.
- TBI to TPI Swap Help
- Body help !
- Engine pull???
- Mystery Misfire '89 Iroc Z
- Drivability Issue with new 350 in 1987 iroc
- Battle of 3rd gen vs. 4th gen
- Which computer came???
- Floor pan
- Do they make cold air intakes for 3rd gens?
- 3970010, What block do I have??
- Need cam for 383
- going rate for a 9bolt???
- clearance of full length headers and header mufflers?
- Vaccum Controls
- what eninge is a god replacement???
- TV cable hookup & converter lockup on TPI ?
- 400RWHP 355, how does this setup look?
- need headers for 3rd gen for a bbc bigger than 1-7/8 tube's where to buy
- Anyone have 87 l98 vette Engine Specs?
- Fuel Pump Voltage 7v
- How To Free Up Horeses For Free
- Smog stuff removal?
- aluminum bumper support weight savings
- 305HO or NOT???
- 4th gen fuel tank
- injectors on a TPI
- Push Buttons Start Install
- exhaust manifolds get RED HOT!
- Pics of Weld Wheels! Lets see em'
- 1987 camaro z-28 intake specs?? Need help
- 700r4 rebuild
- Stealthram Vacuum lines
- v6 in a 305 tbi car?
- who has Fastburn heads?
- Headers, Exhaust, Nitrous, Sub Frame Connectors
- LT1 upgrade
- TPI MoRe PoWeR!!!!!!!!
- Transmission cooler
- anyone have twisted wedge heads
- UK OWNER 92 Z28 " WONT START " *@//**
- FAN SWITCH< THERMOSTAT
- StealthRam upper rad hose?
- 91 Z28 engine question...
- FUEL PUMP REPLACMENT PART No ?
- V6 rebuild kit
- TC problems after engine install
- Serpentine Belt issue Please Help!!!
- Need help with getting right exhaust
- Need some Help
- crate motor?
- How much could I get for it? :-(
- Where to get 80 series cat-back?
- Tranny Line Question...
- Stealth Ram AFPR
- My 91' 350TPI 5-speed for sale :(
- carpet...
- 69 010 block in 87 iroc z help
- Wanted: 275 RWHP
- Best sounding/preforming exhaust
- 383 or 406????
- got a 350 with 305 tbi top end
- 84 CamaroZ28 L69 HO motor...i want speed!please help
- Is the "HOT" cam a decent choice for my combo?
- Stock-ish L98 Auto times/mph?
- Gasket part # request
- Need some suggestions...
- How to gut airboxes
- How To Make 5.0 A 5.7
- Will this dual-exhaust kit work for me?
- CODES 34 & 44 PLEASE HELP
- FUEL PRESSURE 2 high at startup
- cooling system help
- 305 5.0 TPI in 94 camaro
- Tranny took a Crap After Lucas additive!
- Dynomax mufflers
- Power Tpi!!!!
- L98 TPI to carb?
- new to board
- Tpi Replacment
- 86 to 89 Engine Help
- LT1 in 3rdgen f body. Anything I need to know?
- Holley Stealth Ram
- 3rd gen, mucsle vid/.
- what the common prob?
- anyone looking for a 388 or 383?
- 350 TPI from '91 Caprice police cruiser....
- Who makes a good Y pipe?
- LS1, or LT1
- Am I better off just buying another 3rd Gen?
- How do you Break in a Motor?
- 88 posi?
- Iroc project coming a long.
- Need to tune at all after changing to dual snorkel?
- TPI Question
- head flow numbers?
- Help, Need info on my new 89 WS6 formula
- need help on my 350 sbc
- Guys,I need help car wont start after cam change
- car is choking any1 got any ideas?
- Very stange problem, hard to explain.
- 455 CID in a 3gen ...possible?
- I Got $2000..what can I do?
- How do i fix a broken temp. guage?
- my Camaro is in the shop
- Coolings fans
- how do i put up pics?
- Frozen Locks
- Wieand 144 or 142 Superchargers
- What do you think of this 3rd gen!
- How much for a FULL diagnostic
- pics of my truck (hope this works)
- Fuel Pump
- Extremely high idle
- god damn 3rd gen! problems!!!
- Emissions Help !!!!
- Cam / Lifter ?
- tranny slipping
- Who's the better carb.....Edlebrock, or Holley??
- 88 iroc gauge problem
- Tuning an edelbrock carb !!!
- oil pressure sending unit
- Low Idle Speed
- installed headers on 305
- Trans Dipstick Issue
- '88 2.8, Fuel Pump/Gauge Sending Unit?!?
- got another tranny
- My "new" third gen..
- Low RPM Surge...
- got some pics of my camaro
- just failed smog! results, what do you guys think?
- New BBK TPI Intake???
- Snorkel Intake
- What does it take to get a Tuned port transam to put down 400rwhp
- My odometer is out of control! How do i fix this?!?
- Gmmg
- squeeeeek in back
- exhaust rapping on my subframe connector
- Weird burning smell
- Why are center-bolt valve covers so f$%#^g expensive?
- My new 3rd Gen
- 1986 Engine Decision!!!
- Which gasket set?
- Will this "non-performance" gasket set work?
- Will someone help me with finding piston rings?
- Big Block recommendation
- 4th gen exhaust on 3rd gen
- Car problems
- 305 v 350 poll
- New Motor Dial In Problem.....
- third gen camaro turbo v6 typhoon engine prototype
- Never Produced F-bodys?
- Who makes a stroker kit for the 305's?
- won't hold and idle..
- fowled plugs
- replacement tranny in
- iroc question
- Corvette Tpi Or Camaro Tpi
- Here We Go...350/305heads/.030/10/10 Turn/elgin Rv923p Cam,
- 1986 IROC I'm buying
- vortec heads??? help please
- 91 RS 3.1 Wont start at idle
- TPI porting
- Job Done New tranny installed!
- Headers???
- cast hp rating?
- Engine setups/dyno results/proven combos inside
- Installing distributor
- Any gains from Race gas On a Stock 5.0ho Z28?
- Cooling fan switch for a 3rd gen f body
- Getting TC bolts off on a seized engine
- stock heads CC's
- mid to high 11's
- motor temps
- What is the best Distributor i can put on my 84 Z28h.o?
- Did all IROCs have disc breaks????
- help with 87 IROC with tpi and six speed
- 92 rs to 350
- shifter issue
- new motor startup problem
- 88 iroc problems
- best looking cowl hood
- What To Look For?
- Rear Spoiler
- factory airlid?
- TBI Help... Sensor?? Harware?? Junk??
- so im FINALY....
- 87iroc 350tpi supercharger?
- serpentine belt question
- Overheating problems
- Dyno Tuning
- Help finding rocker-arms please...
- 92 rs tbi-tpi
- Ac Delete ????
- No Spark
- computer question
- looking for 3 inch mandrel bent pipe for 91 RS v8
- I think my holley is shot
- MAF system tuning? questions about the scott book.
- DFI over SD and MAF
- Kandied91Z
- COLD AIR INTAKE for TBI V8's
- Please Tell me more about my L69 motor/ is it worth saving?
- Any interest in Aluminum Iroc center caps..great for those with polished Irocs!
- Holley or Demon
- question about Ram jets
- Ultimate Small Block?
- 40 series flowmaster on 91 rs???
- EFE aka Heat Riser Vacuum Line Routing
- LS1 swap LTs
- body reliablility on high hp
- Valve Cover Choose- Hieght
- Fuel pump question
- Plans for a 305
- Extend heater controls?
- Best high flow cat???
- cold weather and power?
- Price for complete TPI setup?
- cold cranking
- Shift Light Question
- new chip for my 85 and power
- for sale!! 3rd gen 305-350 performance cam kit
- What comes with the H.O. (L69) thats not on the regular LG4
- Starting an L98 car after extended garage time?
- 3rd gen true duals
- 89 RS 305, TBI to TPI???
- plug wires
- Problem with throttle cables.
- Which one os better?
- lg4 upgrade to l69
- 87 GTA 1/4 times?
- Vortec heads
- cc306 equivilent
- Quarter mile times for '87 formula
- looking for True Dual Website
- Anyone else not able to get on thirdgen.org?
- After all my work !!
- Hmmmm...what will happen if i.....
- stock dual elelctric fans on 91 pull how many cfm's??
- Engine Swap
- should i upgrade to this engine?
- Vacuum issues....only 8" ;(
- S-m-o-k-e!!!!!
