- Car is alive
- Converting my 85' Chevy truck to TPI.
- 305 Vortec vs 350 Vortec Heads
- Question about camaro heads
- What year or other info on this ECM
- What to use on vortec heads, guide plates or S/A rockers?
- Crankshaft
- Weiand X-CELerator Aluminum Intke Manifold Single Plane
- Performance problem
- overheating
- I want to put a '77 4v top end on an '82 short block. Anything I should worry about?
- My car pulls badly when I brake....
- So I won some Hedman Headers off of Ebay
- newer nose piece on 83 z28?
- help making a 383 stroker motor with +400 hp?
- Hatch Problems
- Calling all 3rd gen convertibles
- carbon buildup
- HP Estimate
- Gen 1 carbed 383 into my bird?
- slp runners
- oil cooler snap ring and gasket?
- What is it with 160' thermostats?
- Anyone put a 8.5" ten bolt in a 3rd gen????
- I want to supercharge my TPI
- 700r4 tv cable replacement
- Any Turbo or Supercharged LT1 3rd Gens out there ?
- Any tips on restoring sun eaten paint, without repainting it?
- zz4
- yup
- New w/some dumb questions
- What's behind the passenger kick panel under the dash?
- TPI system
- big block third gen??
- 88 Camaro 2.8L v6 to 350 carb - Computer ?
- 400 HP TPI Possible?
- Which Vehicle Speed Sensor?
- Bargain Deals!!!!! #2
- 86' 305, need advice
- Any tips on how to get better acceleration out of an LG4?
- Aftermarket cylinder heads for...
- TV Cable
- Question
- intake base help
- Issues with the late 3rd gen?
- 28in tall tire 10in wide rim clearance????
- "Boxing" a frame in & a couple other ?'s
- Which cam?
- Which size headers?
- Low 13/High 12 second thirdgens
- Swapping Motors
- Cost of Ported Heads
- oil press dropping off after warmup
- super ram question
- 88' 305 TB......O2 Sensor???
- where can I find a supercharger?
- Overheating issues, 4BBL 350
- 86 IROC radiator shrouding
- Front End Issues....Need Estimate on parts
- LT1 stock specs
- Paint Questions
- 350 TPI swap into Rock Crawler
- help me!
- Another exhuast question!
- Did this kill performance?
- Cat & Muffler smoking
- Where should I start
- Has anyone put a LT1 into a 3rd gen?
- Whats The Best Emissions Legal Intake?
- Need to find Longtubes
- What happens after the Cam install?
- Ok.. another stupid header question:
- Heres the deal
- Speedometer Problem
- autometer gauge
- Site about Yoga, meditation, relaxation, the Maha Mantra, Enlightenment and Bhakti
- Need help on parts choice of a build on a 350hp TBI motor...
- Cold Start Valve Sensor
- Cleaning the engine
- Overhauling the 305 :)
- What to do with the heads?
- Heads Up if you need new motor...
- painting
- 427cid 3rd gens?
- Transmission wont shift back into park STUCK!
- 383 finally in but......
- Headlight Flicker
- 1992 Tuned Port Engine FS
- Whats this part called
- englishtowns, slp day,
- 1984 Camaro
- Damn 305's..
- Need some help/suggestions with the exhaust on my 92
- When I shift out of park.....
- Bouncing Oil Gauge
- stock 84 z28 and parts
- winter coming and no wipers...
- Newbie Here
- When rebuilding ?'s
- Big Problem
- I need help with Gaskets and Rebuild sets!
- Anyone wanna help!!???
- hi-po maf sensor
- Spark Plugs
- Tpi
- Anybody here have a hooker cat back exhaust?
- Car Stalling pos. Carb Problem?
- Please help! 4 corner cooling will not allow the distributor to go in.
- Why do SBC's ALWAYS LEAK!?!
- window rain "gutters"
- My Catalyst Converter Size
- Difference in Impala/F-body/Vette LT1?
- 305-326?!?! 350? maybe
- is thirdgen.org down again or is it just me
- Replacing valve seals
- 3rdgen down again?
- Lookin' for any last minute advise with my heater core...
- Car cranking slowly after tranny swap?!?
- Taking the panels off the door
- Question about Gas guage sending unit...
- Will LT1 pulleys/accesories fit???
- 89 fbird 305, need to remove key security
- 305 or 350ci???
- Does my car have a spare tire?
- diesel effect help
- Suspention Advice Needed!!!
- Lt1 and/or aftermarket brakes?
- 86 speedometer ?
- Need Help Single Or Dual Plane Intake
- Shifter Question
- 305tpi---> 350 tpi
- Rattling 700R4?...
- 305-350..smog legal?
- philly area mechanic needed
- carb help
- highway runnin on 4 cyl?
- performance mods for my 91
- V8/v6 T-5???
- iroc..
- Finally got my IROC
- Thermostat
- Power Antenna Replacement
- should i have called BS on this LT1 swap?
- The Vortec headed 350 going in my 92 Bird
- Making my Camaro... lighter please help
- dyno help please
- EGR valve question
- Changing/Flushing Coolant
- Header decision
- Help with a tune up
- Real Header Experiences or stay stock manifold
- TPI Throttle Body Bypass
- Exhaust Question
- Truck or Keep The Iroc???
- will this cam work with my stock tpi?
- IROC-Z 305 to 454 Swap!!!
- how to wire a choke in a previously EFI car?
- turbos and superchargers?????
- Carb guys looking for more air than stock...
- selling my 86 iroc-z
- Taking off the door panel
- few $100, 88 camaro won't start
- Ok guys.. the engine is officially ripped apart!
- Which timing chain and gear?
- Engine Swap Questions
- 36, 38, or 42 lb Lucas injectors for new 383?
- Reverse Side Vents...POSSIBLE??
- Deep Exhaust Note......Straight pipes or Muffler???
- Airdam Mounting Hardware, And a ?
- how do i remove the rear ground fx piece, I hate rust
- Code 54 on 87 2.8 V6
- tpi wiring harness
- Fog Lights
- Homemade SFC???
- looking for engine to replace stock 305
- Questions about the 5L TPI
- Problem with the IROC
- ECM vs. Mechanical readings?
- Installing starter!!! Help Please
- What could be the prob?
- Temp Gauge
- Ses
- eh, damn terd gen......wtf??
- '94 Silverado 1500 5-speed in a Camaro??
- 88 Firebird 700R4 help speedomeater
- Helppp
- hatch question
- Just got 3.73's....Im liking it
- Overkill?
- Tranmission Coolant Lines
- dumb question
- Fuel tank Question
- Where can I find secondary DR rods
- 88-90z28
- Spark Plugs
- Swapped LT1 Question
- Carburator?
- Which bolt to use on main caps?
- Everyone in! 1/4 mile times and cheap parts
- What size injectors did 305's come with?
- Transmission Fluid Level
- where to buy cat-back exhaust 3"
- Dual Exhaust?
- Not starting after tranny swap
- Running Rich w/ Rough Idle
- Shoot Flames from your exhaust????
- I fianally picked out a setup for my 383 tell me what you think
- 3rd gen HVAC Question
- gears! 9 bolt
- Trunk motor broke-How to close trunk???
- Should i build my iroc 305???
- Fuel Regulator
- Need help quick
- Temp Gauge
- Help, noobie needs help with replacein a engine
- Exhaust Manifold Doughnut Gasket Replacement
- Performer intake and Carb
- uh oh! What do i do???
- True dual exhaust, no cats, this kit, is it possible?!?!
- What to do about the tranny?
- What kind of Air cleaner?
- SES Code HELP!!
- should I by 89 305 tpi formula $2100
- ** VIN Check Please ***
- Is it Worth $2,495 ???
- I jerked the ole' 305 out, NOW WHAT?!
- No TV Cable...need some help here
- Fuel Pump Died.....HELP!
- broke my steering gear
- Umm.. Help?!..
- Strong odor of fuel
- choke light on
- t5 to t56 swap ????
- long tubes on an 87 camaro with 5 speed???
- IROC Wheels on my Z.
- Wheel spacer ?
- Headlights acting up.... Please help
- Are 3rd and 4th gen alternators interchangeable?
- Anyone used Tokico HPs? (or Tokico shocks/struts in general)
- Compression test to Compression Ratio
- Anybody installed a elec. exh. cutout
- 305HO help
- Some People*Some advice needed*
- Roller rockers - 305 - 1987 center bolt valve covers
- Are my heads to big
- Brakes practically on fire..
- well, you want to be like that?
- HELP Camaro is vibrating. Suspension??
