3rd Gen / L98 Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 [33] 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
  1. becool rad install help!
  2. Electric water pumps?
  3. Just bought a 9 bolt posi (3 series)...what gears?
  4. ???? bout overheating
  5. 80 series vs 40 series
  6. hopefully all everybody with grand national expertise help!!
  7. Replacing Factory Q-Jet with Edelbrock
  8. HSR Stroker Motor Has A New Home
  9. Casting numbers
  10. anyone know how to tell a T/A from a GTA by different parts?
  11. dash swap
  12. Gettin frustrated
  13. Sequential taillights (revisited)
  14. Fog light bezels anyone???
  15. TPI faster then new Z
  16. Passing emissions with headers with motor swap.
  17. 1989 Iroc TB problems
  18. Any Solid Advice
  19. Checking fuel pressure on a carbureator and a problem with my car.
  20. I found the runners, but no plenum?
  21. Temp Gauge not workin..
  22. TH400 or TH350
  23. Should I be running Premium GAS?
  24. this is weird
  25. Dressup
  26. Open Element w/ Cowl Vs. Stock
  27. Frugal Formul??? Any updates????
  28. How does a 305TPI look different than a 350TPI?
  29. why do i have only one tranny cooler line going into my radiator????
  30. belt routing without AC
  31. SFCs arrived today!
  32. Where to hook up an oil temp gauge sender
  33. EGR removal from TPI
  34. Installing a kill switch to prevent theft
  35. HSR Fuel Pressure and Timing Question...
  36. What go-fast part next?
  37. Which Strut Tower Brace?
  38. will LT1 accessory brackets fit a sbc?
  39. mad dog transmissons
  40. carb help
  41. gmhtp fastest l-98 in the country
  42. What would you do with $5,000?
  43. What is a cold start problem...? Maybe thats my prob...
  44. headers
  45. yo guys i need a lil help on this
  46. Few 4th gen > 3rd gen part ?'s
  47. Will this cold-air intake fit on an 82 carb?
  48. Engine swap decision
  49. swaping motors.....
  50. How much to advance timing?
  51. 350 TBI motor questions
  52. MiniRam question-
  53. 3rd gen ???'s
  54. Gears in rear???
  55. help help help please
  56. 80 series vs 40 series vs aerochamber
  57. RE: Thermostat
  58. miniram & thermostat housing?
  59. Help Picking out Gears...
  60. stupid trans question....
  61. Motor ID #
  62. Which Ground Effects Look Better?
  63. Installing a custom alarm: need power lock schematic
  64. How To Rig Up Exhaust With Long Tube Headers?
  65. TB or IAC problem??
  66. Anti Rice
  67. Weird problem
  68. Removing the A/C system...
  69. Grinding Noise from rear of car
  70. Sparked something in engine bay
  71. Fixing my tilt steering column: what tools are needed?
  72. Fuel Rails?
  73. newbi saying hi
  74. Need O2 sensor extension wire
  75. TC Stall Question
  76. Coughing, Choking Camaro
  77. Stuffing An Ls1/t56 In A '89 Rs
  78. 88 iroc not starting
  79. Similar to the Gov. of New Jersey, I have an annoucment to make.
  80. Good Cam Kit????
  81. Red Car...Silver or Black Accents???
  82. TBI Air Intake (pics)
  83. LS1 Rearend Swap
  84. 86 305 Tpi Help Plz!!!!!!!
  85. 4th gen trans am spoiler on 3rd gen Maro?
  86. Got serious vibration issue w/new 383, please help!!!
  87. One or two O2 sensor??
  88. Rebirth
  89. Calling all '84s....
  90. direct intake swap?
  91. Need Explanation for stall TC's
  92. Fan Trouble Please Help!!!!!!!
  93. Will the Lt1 bolt up to my 700R4????
  94. Swap question
  95. How do I take the fuel pump out?
  96. Ignition Upgrades
  97. dual snorkel air cleaner on a 305 4bbl...
  98. Tranny suggestions for replacing a IROC's tranny
  99. need help with idel and power surge
  100. Wierd Idle Question
  101. Found a great deal on an 84 Z. What to look for?
  102. Air intake from a Camaro to a firebird?
  103. Best catback for a 91' Z28?
  104. mass air flow sensor/starting
  105. O2 sensor hole on Hedman Street Header?
  106. Engine Buildup questions
  107. Tranny suggestions
  108. What transmission is in a '84 Z28?
  109. Wheel backspacing
  110. MAF plenum to speed density
  111. Temp sensor resitance range?
  112. Rearend Locker
  113. Rear end stregth ??
  114. Need help with new motor (Dist. and wiring related)
  115. New motor ready to go in, need advise!
  116. how long will a 10 bolt hold up?
  117. 3rd gen long tubes?
  118. 3rd. Gen. T/A headlight relay
  119. My headlights work, but when i put on highbeams one of them turns off
  120. dual snorkel air cleaner:where can i find the hoses and...
  121. 92 camaro starting problem
  122. question about dual fans in a 92 z
  123. 3rd Gen Cars With 4th Gen Rears... Rims???
  124. Car Dying Why I Donno
  125. how do i know if im in overdrive?
  126. New motor quick questions.
  127. Mass air flow sensor 88 fire bird
  128. drive and overdrive top out at the same MPH...
  129. Starter or Ignition Coil???
  130. 4th gen with 3rd gen wheels...Rims???
  131. Code 13
  132. 1991 350 Headers Install
  133. Belt size With AC delete
  134. need help about to buy a maro (i think)
  135. Will these valve covers fit
  136. switching from tbi to carb can i pass smog
  137. who makes k-members for third gens?
  138. T-56 questions
  139. 700r4 problems
  140. Engine Block Casting #'s
  141. 1986 IROC camaro for sale!
  142. Bogging?...86 T.P.I
  143. How much of a difference (performance wise) is there between the berlinetta, z28, ect
  144. is this a ferrari or f body camaro?
  145. Starter Change on 92 - Snapped Bolt on Manifold and my back is killing me
  146. Where is the ignition wire and what is the crank fuse?
  147. Speedometer not working
  148. 305 TBI Performance questions
  149. Assorted Newb questions
  150. Exhaust and Intake questions
  151. Carb Spacers
  152. LT1 + T-5 = Good, bad, or ugly?
  153. Drag Springs Help
  154. drac unit
  155. 1987 starting problems
  156. Couple questions on Spark plugs and lifter adj.
  157. It's like the engine died...
  158. Changing steering wheels effect anything?
  159. Guage cluster questions. Maybe you have the answer.
  160. code 33, one month after code 34
  161. What are the signs of a bad carburator??
  162. HEADER ?????? hooker 2460's HELP FAST
  163. Need help verifying ECM
  164. Where to find...
  165. Whos runing Skinnies up front?????
  166. FINALLY bought another third gen!!
  167. Fastest Mods?
  168. 1988 TBI Starting trouble
  169. Put edelbrock carb on 84 trans am , question about timing advance.
  170. L98 + super t-10?
  171. smogging an 1987 Z28
  172. central control lock
  173. Spraying a 2.8L Camaro... suggestions needed
  174. 4 bolt block oiling Question for my 3rd Gen
  175. mods for a 87z
  176. "Hard to reach screw" for heater core question.
  177. Brake warning light just came on...What could it be?
  178. Can I do this? Will it work?
  179. fuel rails leaking
  180. Rear Axel Seal/Bearing Q 90 FB
  181. Question about vortec intake manifold
  182. Question from newcomer
  183. super ram
  184. 88 Tpi plenum swap??
  185. How many of u leak oil
  186. Hypertech fan switch
  187. Steering wheel shakes while driving
  188. Fuel Injectors
  189. TPI to Carb...Please Help!
  190. 3.27's or 3.70's for a TPI 350? (9 bolt)
  191. problem after trans swap
  192. what is the size of the stock intermidiate exhaust pipe just after the cat???
  193. What do i have to do to fix a jumpy speedometer?
  194. How much HP and TQ from a L98
  195. Manifold-back exhaust system?
  196. Tach is off??
  197. new piston or mill heads?
  198. Flexplate diameters with 700R4 trans....
  199. Hot Cam in l98 problems
  200. Head, Intake, And Cam Combos
  201. Exhaust
  202. What waterneck used w/ TPIS Mini-Ram?????
  203. What o-rings to use with a TPIS MiniRam w/ Ford fuel injectors???
  204. KANDIED91-CHP article-
  205. Umm.. Help?!..
  206. Do I need a new rear-end?
  207. Thinking about getting a 3rd gen
  208. once a week
  209. speed limiter
  210. what are you using?
  211. GM 12 Bolt Cut Down....COST???
  212. Is my starter on its way out?
  213. New car, whats it gonna run at the track?
  214. First mods for TPI??
  215. Engine almost done still have questions fro those with 350 vortec heads
  216. How much will gears knock off in the 1/4?
  217. 8.5 in 3rd gen
  218. Rust Showing Up
  219. cut out
  220. Are these good valve-cover gaskets?
  221. TCC Tranny
  222. Car Audio Help
  223. Any predictions for rwhp????
  224. Ignition module??
  225. cheap turbo setup for your 3rd gen take a look
  226. engine temp sensor?
  227. high 12 sec 305
  228. mini tub???
  229. 1.6 roller rockers, is this a good buy
  230. HELP! wtf is wrong with it
  231. Where are the VATS on my 92 bird?!?!
  232. Torq Thruster II's
  233. Need help with a stroked sbc 350
  234. Headers, and install
  235. Looking for a new Exhaust and Muffler
  236. break line HELL
  237. Flow Direction of Fuel Filter?
  238. Help me get my Z28 Started!!!!!
  239. How does the loudmouth Sound????
  240. New best with the TPI
  241. What should I do ???????
  242. Nothing like it..
  243. How many o2 sensors
  244. Is there a speed limiter on an 83 Berlinetta (lg4)?
  245. 383 '91 Z.....advice (loong) HSR system
  246. tpi bolts?
  247. Water Necks universal?
  248. Bargain Deals....
  249. What does EGR stand for again?
  250. Will this manifold fit my computer?
