- Loose steering column
- rear end gears
- How do I remove my door handles?
- what is the best way to fix an oil leak?
- Gas in Charcoal Canister
- Car doesn't have power under 2500 rpms
- tuning input needed!!
- New Window Motors Help
- replaced fuel pump. now whats wrong?
- milestone achieved on 88!!!
- traction?
- Installing Edelbrock Headers
- Car covers
- Driveability problem
- power surging
- Suggestions on Heads
- Problems with early 3rd gen F-bodies?
- Brake pedal swap
- Would I need a Chip?
- Where to put an open air filter?
- Jumped timing?
- ECM Grounds
- Sold my 92, Bought a 88 Vette.
- cool looking headlights
- Aftermarket Chips
- Cardomain Updated *PIX*
- headers do i have it all
- Knocking on startup
- Crate TPI/Vortec..help fast!
- L98 stock pushrod length?
- HELP!! Motor Problem!
- i got a question about heads---need help
- sequential turn signals
- SLP Rims
- what is the bone stock clearance of an LG4/l69 in a camaro
- What engine do I have here?
- Need a chip burnt
- clearance problems?
- clear side marker lights
- what to grab off a ws6 firebird
- injectors not firing/pulsing
- ALL MOTOR and No more computer or electric
- HELP!!! Timing
- 305 to 350
- How to tell engines
- fuel delivery
- O2 sensor came out while I was driving...
- Igniton Amplifier
- 1.6 Roller tip rockers, Will they fit???
- fault code 52
- need a carfax done please
- Hissing TPI...smog vacuum?
- 355 or 383
- Estimated HP
- Compression Test Q & A...
- Differential Oil
- fuel CALPAK
- camaro's totalled...
- coolant..
- adjusting the TV Cable?
- anyone know how to tighten the steering wheel?
- hood clearance
- O2 Sensor & Headers
- 383 computer chip, help please!
- horsepower on a 89 gta 5.7 a4 duel cat g92
- Enjoying the heat is good WHEN......
- Im looking to get an exhaust need help
- Speedometer stopped working
- Motor Swap Questions...
- Rough idle, no throttle
- spring isolators
- HSR and cam Dyno
- IROC overheated... HELP!!!
- What the hell is wrong with my Holley
- 383 stroker swap
- Help me figure out my CR
- new trans
- Need A Little HELP
- 383?
- Alternator Noise
- 87 wiring harness vs. 88 wiring harness (TPI)
- Horsepower
- got the k member in some pic`s too
- flowmaster question
- Need help with electrical problems
- Carb Problem
- Is thirdgen.org down?
- TBI Intake Idea
- vacuum with 224/230 cam
- fuel injector cleaning systems
- Good price for a 90 iroc?
- AC question
- aaaaahhhhhhhhhh fire!!!!!!
- timing cover question
- bulletproof tranny rebuild
- fuel system
- tell my how to get my pinion seal out!!!!!
- Think im Running on seven!?!
- Car not starting when hot,, can anyone help????
- Will my headers fit on AFR's?
- NO gears in 700R4
- 3rd gen Speedo replacement question
- Gauges..
- What Cam?
- Finally got another Camaro
- why is my lg4 doing this
- Auto Xray 240 maual
- angle plug heads on 3rd gens
- new skools pull so hard compared to third gens
- Found problem with my car
- rear end
- ws6
- 3rd Gen Noob lookin to buy!
- Stupid noise
- Air Filter
- Don't think the car is running on all cylinders
- Is it time for new brakes??
- MAF Sensor Problem
- Need axle shaft for 86 10-bolt disc
- Build Sheet for '92 ?
- R.I.P. My LB9...Help me find an L98..
- Need help/opinions..car is running EXTREMELY rich!
- Smog Stuff
- First mods for 350 TPI
- pulled intake apart and now car won't start!
- New exhaust??
- flat spot
- wiring for tpi to carburetor help.
- Vapor Lock Problems
- superram VS. miniram
- Help on Timing a 350....
- Help. newbie looking to start a 3gen project
- 03 Cobra injectors work on Camaro
- head gasket blown
- Carburetor?
- Hotchkis SFCs
- L98's get no respect!
- 1989 WS-6 Firebird Formula for sale
- Questions about DFI...
- Air Foil, Does it make any difference?
- Bad Gas????
- Switching from mass air flow to speed density.
- door panel swap
- Price Estimate for 5 speed swap
- Hood clearence on a 3rd gen--LG4/Q-Jet....
- 91 Z28s equipped with ABS?
- HELP! Trans won't stay in park
- Need vin number
- Fuel sending unit wiring question.
- New to Camaros... Questions
- Dual Exhaust Kits???
- Berlinetta, good bad, ugly?
- carb or fuel injection
- AHHH!!! Lady Camaro won't start!
- Car doesnt shift at all when started?!?
- ALL L98 owners....please respond
- draw and high idel
- TBI Cold Air Intake
- won't fire up
- Drag co efficiency
- stock stats for the 91 RS 305
- thamks in advance
- hmm, what do you think of this engine should i buy it
- Will This Work?
- Post Pictures of Camaro's with RAM AIR HOOD
- Where can I find a GM Crate 350?
- 91 carbed car
- thermostat
- anyone try and put a tranny "inside" the car? to ship it i mean
- hatch motor electrical draw
- Long hard day Racing & more problems with my car.
- Smoke From the Small Tubes Running to the Cylinders
- I can't hear my car :(
- Car wont stay on
- tranny probs 700-r4
- I might have found my next camaro
- Still Have Engine Problems
- at a loss...
- Dyno'd my Engine today
- 300ish RWHP...L98 or LT1?
- who's running flowmasters with what tips
- Camaro keeps pushing 240 degrees and went over 260 while driving today.....HELP!?
- Location of MAF burn off module on TPI?.
- New Carb or Rebuild
- Few questions to clear things up
- 25th Ann camaro; certificate of destruction...
- Throw out bearing / Clutch return spring
- What offset do I need on 18" rims???
- Apparently i didnt figure my problem out.
- Electrical Problem: I turn on heater and the fuse blows
- Fans work sometimes?
- tranny problems
- Another Overheating Problem
- Rear End Options
- Exuast leak.....
- Tranny leak.....
- Newbie Engine Recommendations
- Bleeding brakes
- Getting more horsepower...
- Engine Start Up
- How's this for a 3rd Gen engine?
- Pictures of 4 Inch Cowl Hood
- Jegs Has Free Shipping?!?!?
- am i running TOO cold? what does your temp gauge ussually read
- Buying 4-bolt main 350 for my 86 Iroc
- Any V6 and V8 compatible transmissions?
- distributorless ignition for a TPI
- LS1 injecters?
- Highest lift with stock L98 springs?
- HSR and 85-89 L98
- LT1 install, what clamshells?
- Trany cooler help (BBC Guys)
- My heater and AC are broken: blower questions inside
- Stock temperature for a 91 camaro rs
- anyone know any sure ways of telling if an ecm or memcal is bad?
- oh thank god, driving again
- tired of ripping my knuckles
- 85 trans am. just dont know
- ??Anyone sell line lock kits with pre-bent lines('84 Z-28)??
- Lowering Springs for 3rd Gen Camaro
- Cheap 4 Inch Cowl Hood
- Newbie here with questions about building up a motor
- 1986 305 TPI intake manifold leak
- tranny swap
- no ac heater box
- 2.8 bogs bad!
- Noise from Rear after warm
- Water Pumps....
- marbles in a metal pan
- Blown axle...need help with gears!
- Best Color For A 3rd Gen??
- Failed inspection! Please help....
- SS-Hood
- SS-Hood
- Which muffler for my Camaro?
- can't gain traction
- Blowing my 5A fuse
- Lets try this again....Engine problems...
- L-98
- Paintless dent removal or new roof skin?
- throttle body
- need a radiator!
- what rims?
- Torx bolts???
- high power cooling?
- Colder Spark Plugs?
- 90 RS tranny problems
- the clicking, blinking choke light....
- any suggestions for a cat on a 86 iroc??
- polishing question?
