3rd Gen / L98 Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
  1. picture
  2. what tranny should i use
  3. TBI to carb Q's
  4. 454?
  5. Just aquired an '89 IROC, has some problems
  6. speedo
  7. My firebird is Gone
  8. 3rd brake light issues.
  9. Check engine light?
  10. Adjustable pressure regulator on HSR
  11. CD Player help.
  12. 350 building
  13. Slow Turning Start,whats the deal
  14. Transmission stuck to block...Need help
  15. Lots of heat soak
  16. Water pump did the wierdest thing...is it broken again?
  17. RPM Issue
  18. from one motor to the next
  19. new rotating assembly??
  20. Where can I find info about engines in general
  21. Compression Ratio 350 TPI
  22. what oil do YOU use?
  23. breaking problems, proportioning valve???
  24. need to replace fuel pump
  25. overheating
  26. Headers Install Question
  27. 9th Injector Elimination
  28. BBC exhaust
  29. problems...
  30. Best vendors for 3rd gens
  31. GMMG chambered on a TPI
  32. chirping second, and a hatch motor
  33. These L98's just do not like heat at all...
  34. Corvette 2 IROC
  35. Speed sensor on 700r4
  36. Doug Nash 5 speed
  37. Finally some 1/4 times! Whatcha think?
  38. help!!!! Engine Wongt Start!
  39. TPI off for motor pull...right?
  40. wires with headers question
  41. brakes on a 92 rs
  42. Found why my check engine light was on.
  43. Ram Air Hood
  44. My car revs itself!
  45. Input/ help required
  46. Torque arm bolt sizes?
  47. 82-83 Fiberglass Hood
  48. Whats a good performance distributer
  49. Cruise/HSR problem?
  50. Pitman Arm - Idler Arm - Labor Involved - Any Kits?
  51. Fog Light Bulb Number?
  52. I need help big time
  53. cam installation
  54. what would cause this?
  55. Most Potential?
  56. Dual Fans on 92 - 350...Are we there yet papa smurf??
  57. 78 350 fit into an 83 camaro?
  58. engine rebuild
  59. Tha Berly! Needs A few Mods
  60. hoping this is the battery only
  61. Subframes on, framed tweaked
  62. L98 vs. 1955-1986 small block
  63. Head Gasket Coolant holes?
  64. 1 problem and a question.
  65. What do u think of my pitman <-- chk out the video
  66. Bad Torque Converter
  67. New Brakes
  68. Part number needed, 3rd brake light
  69. Radio wont pick up signal...
  70. Trying not to wreck my dash
  71. New Tach
  72. 1988 2.8 V6 Camaro to 350 TPI
  73. Custom build
  74. test drive question
  75. HELP! Market value on '88 convertible??
  76. Dying battery
  77. Anyone got this combo?.
  78. lingenfelter
  79. Black smoke under WOT, smells rich, bad MPG....
  80. rear view mirror placement
  81. Tranny Gear Ratios...
  82. New
  83. pilot bearing
  84. Engine break in
  85. 3rd gen SPOHN tranny mounted Torque Arm owners inside please!
  86. Low Clutch Pedal
  87. Will someone please help me w/ finding brakes?
  88. can i bleed the master cylindar while its in the car
  89. harmonic balancer
  90. Not able to start car
  91. Ran my daily driver at the track...
  92. New Rebuild, ECM Problems
  93. Didn't all 91 z28's come with tpi?
  94. Best Positive Rear end for a 305 4bbl.
  95. Cross Fire Injection?
  96. A/C help!!!!
  97. L98 T56 computer
  98. Door frame weatherstrip OER ?
  99. 350 H.O. Kit GM
  100. Braking distance 3rd gen ?
  101. Just scored some headers!
  102. Easiest way to take this power antenna out
  103. ready to buy and install my hatch motor
  104. Anybody in the PA NJ DE MD area.......
  105. Overheated and now ive got smoke comming out the exhaust
  106. Cluster muck
  107. Steerign column switch firebird to camaro
  108. mystery hose unplugged for cruise control
  109. just won some rims
  110. forth gen steering wheel in my 87?
  111. Steering Column Loose
  112. thinking about a 350 HO
  113. Why won`t my Zed start??????????
  114. need help 1985 Trans Am
  115. lots of smoke
  116. Valve Cover Leak
  117. Is the 3 Row Radiator worth it?
  118. hood help now!!!
  119. Any tricks on changing the heater core quickly?
  120. clutch problems
  121. 305 H.O heads on 350 block
  122. Q-jet or Holley??
  123. Thinking about an 82 for 2400
  124. spoiler gaskets
  125. new car pics
  126. Grant Classic Series Steering Wheel
  127. Anyone start an LT1 Swap building everything from scratch?
  128. What is stock FP for a TPI?
  129. TPI Fuel PSI, how low is too low?
  130. 89 trans am GTA
  131. compression question
  132. rearend question
  133. the engine for the most power and speed?
  134. Having trouble with coolant, help?
  135. Fix Taillight w/ Covers?
  136. Quadrajet Leaking?
  137. 383 guys, need header help!!!!!!!
  138. Low Pedal
  139. 3rd gen firebird info
  140. if you want pics of true duals on a 3rd gen click here
  141. 89 firebird gta info
  142. WHAT kind of distributor caps are these?!
  143. Ticking noise comming from SVO's...
  144. why so hard to find convert?
  145. Need tips/help on cooling my BBC 3rd gen
  146. about how long does it take to do a v8 - V8 engine swap
  147. Can a 3rd generation coupe be made into a............
  148. Leather Seats
  149. low RPM problem
  150. starting problems
  151. if i check a couple spark plugs for their condition do i need to re-antiseize the thr
  152. is their supposed to be a seal or grommet that goes around the pcv valve
  153. Third Gen Info?
  154. >>>Post your times with full exhaust!<<<
  155. perimeter style valve covers which gasket method works best
  156. Pros and Cons to the Holley HSR
  157. Can someone explain the intake system of a V6?
  158. How do you pull a plenum and runner set? How much are they worth?
  159. goautocenter.com
  160. Need to buy an intake elbow that looks like this..
  161. Best upgrades for a 305 to get the most power.
  162. What battey brand do you use, i need to pick a new one
  163. My lt4 conversion is gone, TBI cam to match hot cam rumble?
  164. Buildsheet ?
  165. What's a set of aluminum l98 heads worth?
  166. Looking for a 3rd gen, have no idea where to start.
  167. Oil on valve cover/under car
  168. oily plugs...
  169. question
  170. fuel system screwy LG4 (pump, filter, bad gas, sensor??) code 21
  171. Transmission toasted....
  172. rack and pinion in a third gen
  173. Balncer vs. chain????
  174. Underdrive Water Pump Pulley...
  175. fiberglass fenders
  176. 700R4 problem, please help!
  177. Condensation in air filter
  178. Mystery 3rd Gen Wheels...Any have any clue how to find these
  179. Iroc 17 Inch Chrome Wheels on 1992 z28...
  180. Bad fuel pump, right?
  181. Oil Pump
  182. took off the air horn, gas is oil black??
  183. Need Help on Irocs rear brakes
  184. Performance differences from 5.0 and 5.7L
  185. True Dual Dynomax HELP PLEASE!
  186. True Dual dynomax HELP PLEASE!
  187. air intake
  188. speedometer conversion
  189. what is the stock LG4 thermostat rating?
  190. smog pump bull
  191. Is a Duel Fan setup for the Radiator the way to go?
  192. Posi Question
  193. LG4's have a MAP sensor?
  194. Parting out mint 87 gta w/mods
  195. still low RPM problem...
  196. Noisy Brake Hardware??
  197. Crash
  198. These are the right tools for the quadrajet
  199. Magnaflow
  200. hard starting the Z???
  201. air cleaner help
  202. Throttle body intake question
  203. how do things just go out of adjustment, like timing or carburator
  204. OFF-ROAD, LIFTED 92 RS CAMARO, how much do ya think?
  205. Oil Pan Trouble!
  206. 350 turbo speedo gears...
  207. Dyno results from LT1 intake swap worth 52 RWHP
  208. tpi -2- carb.
  209. About to pull off rear bumper- what tools needed
  210. fan relay
  211. I bought a posessed car.
  212. Manual Steering Box for 3rd Gen
  213. gauge cluster!!!
  214. Is my car really a Z?
  215. first start
  216. washing engine
  217. changing shocks and struts
  218. Just killed my Turbo - 400
  219. What can I buy???
  220. Do convertibles loose power?
  221. rear end fluid change
  222. Car not running, need help
  223. What steering box do I have?
  224. Carburators..
  225. Suspension modifications
  226. Sway bars once again
  227. CD player isnt getting power..need help please
  228. cutting springs
  229. 4 point harness
  230. why did my rear go up after LCA's
  231. t56 swappers-which cable x?
  232. HSR & Thermostat Housing Issue
  233. Which 305 heads for 350
  234. Anyone running a.....
  235. just new heads or a whole new engine?
  236. i know this isnt drivetrain, but they dont reply to me
  237. Quickly, how do I remove my front bumper?
  238. LT1 intake, or HSR?
  239. Oil Pressure Guage Problem
  240. Putting engine back in....Problems
  241. '88 Firebird spoiler option???
  242. softseal
  243. Eagle ESP Cranks
  244. Bad Date Impression?? Alternator Dies on Date
  245. rs 90 swap 94 LT4 vette motor and tranny
  246. Alternator for 1992 z28 fit into a 1991 RS???
  247. what are good plugs to use on moderately mod'd L98?
  248. holley tpi stealth ram
  249. Aftermarket and swap question...
  250. tpi, code 34
