3rd Gen / L98 Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30] 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
  1. Cam, Heads, Intake Combo
  2. HSR vs. miniram vs. superram and N/A or boost?
  3. Where are the Iroc part sites?
  4. Test fuel injectors and fuel regulator out of car?
  5. Free or DIY Mods
  6. Changing Auto to a Manual,HELP!
  7. 335 C.I. Stroker
  8. New Cam Yay!!!
  9. Ramjet Vs. Mini-RAM 3
  10. Got a problem
  11. Exhaust Opinions...
  12. Overheating?
  13. Speedo & new gears
  14. Important Question!!!
  15. Daul Cooling Fan conversion
  16. L-98 carb ?
  17. Spare tire
  18. carb to injected??
  19. Headliner repair
  20. info on superchargin a 350
  21. billet wheels
  22. extra vacuum lines
  23. having major problem
  24. Couple questions for the experts...
  25. Which is better, going to a LS1 or Lt1?
  26. Y Pipe
  27. Back of egr solenoid
  28. Installing a Cutout...
  29. What is this part called?
  30. What RPM should an A4 tranny shift at?
  31. Vortec rocker arm stud
  32. build me an engine that....
  33. Rattling noise and check light...
  34. distributor tunning question!
  35. what was the tranny called in the 92 camaro's?
  36. Bad valve seals,does lucas stop the bleeding
  37. aftermarket Parts
  38. car turns over but won't start, help me please!
  39. none of my guages work...
  40. At what RPM does the beastly LG4 make the most torque and horsepower
  41. hitting up my ugly rims with tal strip and sand paper , some adivce needed
  42. Exhaust Pipe Diameter on 90 305 TPI
  43. New Car for me :)
  44. Lost oil pressure
  45. what heads
  46. Basic Camaro Question
  47. Traction Bars VS. Lift Bars
  48. battery mounts
  49. how bout this cam
  50. Make my ride smoother
  51. Wich Intake Manifold?
  52. Head Porting
  53. torque converter questions
  54. 305 TPI to 350 TPI
  55. Damper for engine
  56. Code 34
  57. Which gaskets?
  58. Flame throwers?!
  59. Mini High Torque Starter
  60. Could you tune a 3rd gen with an AFC?
  61. Knock sensor question -
  62. What is this thing???
  63. Just made some purchase's
  64. Running Rich....Bad Computer?
  65. Harmonic balancer.
  66. Water Pump
  67. Another Basic Camaro Question
  68. 3rd Gen Posi Unit
  69. Yet another brake upgrade available!
  70. Where can I find a 305 H.O. air cleaner?
  71. '82 Z28 exhaust question
  72. Header/Y-pipe/Cutout Combo?
  73. links and pics of big block 3rd gens
  74. Difference between T-5 and T-10
  75. Broke water neck bolt, now what?
  76. determine injector size?
  77. Engine will not crank
  78. Fan control (via a relay) and idle on carbed 350
  79. ECM Conector
  80. Subframe connectors question
  81. black headlight pockets?
  82. will fourth-gen seats mount easily in 3rd
  83. A/C Conversion kit
  84. Fans again
  85. Really Need Help Fast On A Ramjet!!!
  86. cam selection help!
  87. radiator
  88. how is vacuum important?
  89. Chip for 305 to 350
  90. edlebrock torque arm
  91. Driveshaft question
  92. Need advise for my 3rd gen friend
  93. Boring a 355-cost/size?
  94. out with the old in with the new(sorta)
  95. want to charge my l98
  96. Wiring Problem
  97. weird problem
  98. Trouble Codes
  99. Do I Have Posi?
  100. should an exhaust leak pop?
  101. Best cam for HSR
  102. lt1 intake gains on 305 with stock heads
  103. Can a TPI with this many miles handle this?
  104. hedman longtubes
  105. got new shocks/struts/springs on a budget
  106. T56 swap causing code 24?
  107. a dream and an oil leak.
  108. when doing a t56 swap.
  109. I just got my fan control kit and I'm lost..any electrically gifted people out there?
  110. Carb conversion
  111. Running Lights/Parking lights are out!
  112. Fan Switch still not working
  113. Breakdown
  114. Carborator
  115. Fuel injector wires installed correctly?
  116. V6 to V8 Question
  117. TPI to Carb
  118. what kind of gas is best? regular or premium
  119. aklim hsr fuel lines
  120. New injectors installed, now backfires, won't hold pressure!!
  121. HELP! Starting problem on 90 RS 305TBI
  122. type of rearend to buy?
  123. couple quick, stupid questions
  124. I'm gettng a 85 Z28!
  125. shifts too soon
  126. MAF upgrade
  127. burning a chip
  128. fog light question
  129. possible to pull motor and tranny without unbolting,bout to do it need help now!!
  130. whats the best 4th gen seat
  131. The Beast is out! *PICS*
  132. Rocker Arm Question
  133. my exhaust is getting me stoned.......
  134. New fuel injectors fixed several problems
  135. Throttle body ?s
  136. Knocking problem and codes
  137. 700R4 question
  138. some questions on my header and driveshaft purchase.
  139. Cluster issues....
  140. chip interchange
  141. 18" rims on a 3rd gen
  142. caprice, monte, celebrity headlight swap
  143. Pushrods
  144. 58mm TB?
  145. Ticking noise in front end
  146. another 700 question
  147. headers
  148. sportlines with headers?
  149. Steering Issues
  150. What rear end?
  151. can a vortec 350 be put in?
  152. louvers smashed! aahhhhhhhhhhhhh
  153. need help picking my next 3rd gen
  154. supercharger???
  155. 97 LT! into a 89 bird
  156. tranny crossmember
  157. Redoing front brakes. brake lines?
  158. coulda of roasted a mustang gt 88-92 on the highway (still got him)
  159. '86 z-28
  160. 2.90 to 3.73 gear swap-what do I need to change?
  161. convertible questions
  162. 305 Redline
  163. Soon to be a new 3rd Gen owner
  164. 88 Vette In 88 Camaro
  165. Which would you do?
  166. will traction bars solve my torque arm problem?
  167. Timing and distriution
  168. 6.0 liter swap?
  169. QUICK HELP NEEDED-holley 255lph intank pump ?
  170. another tranny question
  171. Could this cause a timing problem?
  172. Engine Stripped.....Injectors?
  173. Update on my 305 rebuild
  174. front coilover setup?
  175. distributor problem?
  176. clips for 87gta spoiler
  177. T-56 swap into 85 camaro...
  178. 82 Z28 engine question
  179. window problem
  180. Haynes auto manuels suck.
  181. vacum line
  182. Can you run 3.73 rear with a 700R4?
  183. 82 to 92 big block camaros
  184. Cooling Fan
  185. Quick tranny swap question
  186. carb which one to use
  187. 9 bolt gears (where to get them asap)
  188. Long Tube Headers?
  189. C-4 brake
  190. Does anyone know the flow rate of the TPI cold start injector?
  191. 350 Q's
  192. clunking during semi-heavy throttle
  193. scan master
  194. cooling system
  195. What's involved in swapping 4th gen rear end to 3rd gen?
  196. 305 oil capacity?
  197. GMMP or Corsa?
  198. rpm at 60
  199. well i went and bought another iroc after a vette
  200. code 32? help!
  201. 89 camaro gears
  202. Fuel Injector failures
  203. Where to get valve covers
  204. oil pump drive
  205. wierd shift question
  206. Replacement for a 350 turbo?
  207. Recharging AC- where are the high and low lines?
  208. TPI problem, tb is wissels.
  209. How to remove Center Caps on wheel
  210. 305 TBI mods
  211. Hedman Headers question
  212. adding a tranny cooler
  213. New headliner.
  214. finally got my first 3rd gen
  215. new hood
  216. Didnt know I was that fast
  217. Best type of SFCs
  218. Engine upgrade advice
  219. cooling fans not coming on help
  220. 04 Z06 rims on 85 IROC?
  221. Question about the 5L TPI - LB9
  222. Electronic Fuel Pump
  223. Newbie With 2 Thirdgens
  224. Top speed with 2.23's?
  225. Need a cat for a 87IROC
  226. Going Old School with a 92 RS
  227. 17x11 rears
  228. Lt1/Ls1 swap in 3rd gen
  229. help
  230. car running hot
  231. Burning a chip or buying one?
  232. Thnkn bout puttin a 350 into a 89 RS
  233. Firebird Taillight Wiring Diagram Needed
  234. Radiator Help... Big block
  235. ROH RT wheels, Finaly on!
  236. 305 Heads and 350 Heads
  237. shift kit help plz!!
  238. 700R4 To Turbo 350 Swap !!
  239. HSR help
  240. 1le
  241. Value ?
  242. What temperature should I be running?
  243. 5 way harness help
  244. coil overs
  245. Dyno Tuning
  246. not about a camaro but plese help
  247. GTA cloning bird cancelled i want my GTAS stuff back!!:-(
  248. can somebody walk me thru this window motor install
  249. cold air intake suggestions?
  250. still overheating...high idle
