3rd Gen / L98 Engine Tech
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
  1. Does porting and polishing help?
  2. subframe connectors
  3. help with passenger side header-89 IROC
  4. Differentiating between 700r4, th400 and th350?
  5. tires
  6. My paint is finally done!!!!
  7. want to put 4th gen rims on my 3rd gen help please
  8. 3rd Gen Gathering
  9. Fuel line fittings + adapters ?!?!?!
  10. Fanning the Flames
  11. LT1 or what?
  12. TCI Aluminum Pan
  13. subs and box for 3rd gen fs
  14. How restricting is the stock throttle body on a 305 TPI?
  15. Headers and Exhaust
  16. How to modify 12 bolt to fit Camaro?
  17. cutting out @ 1/4 throttle and low rpm
  18. recomendations/driveability questions cc306 and cc503 cams
  19. LT1 vs. TPI Airfoil?
  20. rear end swap....4th to 3rd gen
  21. 4.10 gears in an auto?
  22. PROM help in MINNESOTA
  23. Spring Rate?
  24. heads
  25. 1 bolt will not go in my header!!!!!!!
  26. 92 Camaro 5.7L EGR pic PLEASE????.
  27. 383 in 87 ?
  28. NEUTRAL SAFTEY SWITCH AND REVERSE LIGHT WIRES
  29. stroker for L98 for LT1??
  30. Some questions ^_^
  31. bad exhaust sound....help!
  32. Where should I go from here?
  33. 91-92 taillight question on -87 T/A
  34. Different 305 to 350 question
  35. Tuner Port Injection:extra parts i have
  36. White faced gages?
  37. SLP CAI, i have a question
  38. Fuel Pump ARRRGH!!!
  39. Any way to lower idler arm?
  40. best place to buy l98 long block
  41. What to look for?
  42. Help inside, '87 Iroc Z wtih 350 TPI, what are best mods for it?
  43. Starter
  44. Could anyone guess what problem this is?
  45. Run nitrous, or increase compression?
  46. Question on removing thermostat on 305 TPI
  47. New Gears
  48. Why does his car sound better than mine?
  49. ZZ4 in my 86 Z28??? Will this work? All input inside!
  50. Quick Help me before I buy it. TBI Question
  51. Anyone from Calgary Alberta CANADA
  52. Racing with an Automatic!!
  53. Why will a LS1 alum. drive shaft not fit my car????
  54. Transmission choice
  55. GUYS I NEED HELP ASAP.........
  56. hud
  57. Any luck with junkyards ??
  58. How will this sound ?
  59. What to do if 58mm throttle body
  60. Fuel injector equation.....................?
  61. Coolant Temp Gauge
  62. Headlight Gremlin
  63. car won't start, help!
  64. Hypertech Cool fan switches??
  65. Popping sound when making a sharp U turn, what could it be?
  66. electric hatch question?
  67. Help with parts
  68. Third Gen. v6 compressor question
  69. '84 Z28 running hot...I think
  70. Well it is not the fuel pump.......
  71. NEW JERSEY MEMBERS I NEED HELP
  72. Boring a 350
  73. Anyone know where i can find a new rear spoiler for my 1988 GTA?
  74. instrument panel light problem
  75. Factory tach is readin wrong in my 91 rs, what to do?
  76. Belt slinging problem...?
  77. Valve seals have been changed and now a wierd noise
  78. Which ignition should I get for N20?
  79. Timing marks??
  80. fuel injecton wiring harness
  81. from tpi to carb
  82. Cam suggestions with SR
  83. I think my cat may be clogged
  84. Need to buy plugs and wires, any recommendations?
  85. Underdrive Pulley ???s
  86. ?? FRONT STRUTS ??? KYB GR2
  87. Torque Arm HELP!!!
  88. MAF
  89. Please help, im confounded.
  90. Why is my gas milage so poor???
  91. 400/would you buy this hoodscoop?
  92. Exhaust System Conflicts Question
  93. What type of injection?
  94. Cooling Problem....HELP
  95. Manifold bolts How do you get them LOOSE?
  96. SIRS
  97. looking for Iroc-Z with the 5.7 Liter
  98. automatic swap
  99. cracked exhaust manifold
  100. Are Accel plugs and wires junk?
  101. Replacement hood louvers?
  102. Carb Vs. TPI
  103. anyone who has swapped lt1 how to do AC compressor
  104. EGR on Vette Heads
  105. TPI won't start at operating temp!! PLEASE HELP!!
  106. Holy Codes Batman!
  107. fixed first problem on to the second
  108. Alston Subframe Connectors
  109. Please help! 88 TBI will not stay running in the morning, runs fine in the afternoon
  110. tbi differences
  111. BeCool Radiators
  112. Sweet 3rd Gen....Never seen this color anywhere else.
  113. Couple questions
  114. 84 Z roller BBC/t400
  115. What are these connectors/wires?
  116. T5 leaking
  117. code 32 and 33
  118. Complete t-top roof conversion for sale
  119. 90 RS Automatic, what transmission ?
  120. converting from 305 TBI to 350 TPI ???
  121. Resetting the computer.
  122. Where can I get a good set of 3.73 gears for a 1989 Turbo TA?
  123. I was wondering if I could do this....
  124. 4th Gen rear into my 3rd Gen????
  125. Will platinum plugs burn out faster????
  126. B&M shifter problem on Auto
  127. Painting My Car
  128. how important is TC lock up?
  129. Rims and tires
  130. Anyone know how many CFM stock fans pull?
  131. How long does it take to break in a rebuilt engine?
  132. TPI Track Times
  133. Failed inspection: Smoke coming out after being online for lone time!!! NJ
  134. light blue smoke from tail pipes
  135. black smoke
  136. Damned Electrical Problems!
  137. Audio Problem
  138. Anyone ever used dry ice on there intake?
  139. I need aCold Air induction
  140. What should timing on a 383 be?
  141. how rare is this?
  142. New gears...how to fix speedo???
  143. 1991 RS 5.0 TBI
  144. When is descreening your MAF a good idea?
  145. camshaft for 1991 RS 5.0 TBI
  146. 91 TPI Z28 won't start until it has cooled down.
  147. Rocker Arm Questions
  148. Fastchips?
  149. New guy.... got some questions...
  150. Missfiring!
  151. LS1 V8 camshaft
  152. 1991 RS Starter
  153. Rearend and Ring and Pinion
  154. computer and stereo problems
  155. shifting late
  156. Catco dual cat LASH UP
  157. Seat Belts
  158. Power Pack Exhaust on 89 RS+?!
  159. Timing increases as car heats up?
  160. How hard is it to change ignition?
  161. Question on Gapping the spark plugs i just bought
  162. Camaro 350 TPI times?
  163. New kid, got alot of questions.
  164. 86 Berlinetta v-6 stick to 305 auto turbo350 ...not shifting right.....
  165. Strip Wheels or Paint?
  166. 350 TBI/HO Crate motor
  167. K&N filter & exhaust
  168. new to thirdgens
  169. New Engine Specs
  170. Plenum?
  171. Cam swap into my LB9??
  172. added some new pictures
  173. Pics of TT hood on a 3rd gen?
  174. help!!! installing manual steering box
  175. dyno #s for iroc-z
  176. What type of applications require a different MAF?
  177. Something isn't right ..
  178. Anybody order from 9bolt.com?
  179. headers and exhaust!
  180. Weight of Conv Iroc-Z
  181. Pilot Bearing
  182. TPI Plenum
  183. TB Bypass
  184. Fuel press. regulator
  185. Anyone know where I could get a good chip burned?
  186. Where could I get a dual fan setup?
  187. Headers?MSD?Converter?
  188. Exhaust question
  189. Any modifications for these wheels????
  190. anyone know aplace that ships used parts
  191. New Rad for an '84 Z28
  192. Opinions... dont know anything about 3rd gens.
  193. Open element for TBI
  194. Has anyone done TBI - TPI conversion ?
  195. Headers for a 305 TBI
  196. Not throwing codes.
  197. 90 RS with IROC hood
  198. 87 305 IROC-Z mods?
  199. help me
  200. Anyone with a 4th Gen console? I have questions...
  201. putting in a 305
  202. I need paint codes for a '87 T/A
  203. Exhaust system Q.
  204. Has anyone ever done this?
  205. 92 RS-throw in an LT1-good or bad idea?
  206. Rear Diff Question...
  207. Cranks long time before starting
  208. Timing
  209. opinions from people with experience with headers
  210. pilot bushing removal
  211. I think my coil is stock but my distributers not??
  212. 2nd gear's crunchy
  213. Anyone good with Quadrajets?
  214. 700R4 to a Turbo 350
  215. Need help with vortec heads
  216. What did the TPI cars get that TBI didnt?
  217. Question for anyone with an aftermarket shifter ( Auto )
  218. Aftermarket Rear End
  219. Rear End Noise Click & Scrape
  220. If you have a 91/92 Z28 I need info from U.
  221. Stock 305 TBI cam specs
  222. Newcomer :/
  223. NEED HELP WITH THROTTLE CALBLE
  224. Harris County anybody? Emission probs.
  225. Rear Deck Lid
  226. removal of dampener
  227. t56 problems
  228. Is my BBC a freak?
  229. n00b question
  230. Guys with 4th gen consoles in 3rd gen's look inside
  231. Ideal Project Car Q's
  232. Do I have too many miles for ...
  233. Clutch pedal issue........Please read
  234. Spohn torque arm problem
  235. engine restore?
  236. after market MAF sensor
  237. lt1 runs, now have a header question
  238. parts
  239. What clutch to get????
  240. MY CAR WILL NOT QUIT SMOKING! HELP
  241. Blazer 700R-4 Tranny??
  242. Banks twin turbo kits
  243. Need pics of air box baffle mod.
  244. Anyone ever put LS1 front brakes on a 3rd gen?
  245. 85 Iroc Fuse Layout????
  246. Lost in the terror
  247. F-Body, yes or no.
  248. Weird Problem
  249. Aftermarket Fuel Pump
  250. Turning a 305 into a 350?
