3rd Gen / L98 Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
  1. Trobleshooting A Squeeling Clutch Noise
  2. 1985 z28 1/4 mile time?
  3. 28 Spline Axles????
  4. 1985 iroc z28 350 tpi info....
  5. Weird idle
  6. header/exhaust circumference
  7. Tripple gauge pod! Anone make them?
  8. Who's trapping over 110mph, N/A?
  9. Found a car finally... should I buy it...
  10. 305s w/hooker
  11. TPI fits on any SBC, right?
  12. 3 inch duals w/2 inch mufflers
  13. loudest/best sounding exhaust
  14. im looking for windage tray/main bearing studs from ARP
  15. car of the month!
  16. wolf car bra
  17. Swapping 700r4 into 1982 - what parts do I need?
  18. Fitment issues with headers on vortech heads in a 1982 with 700r4
  19. manifold vacuum
  20. 3rd gen dual fan on lt1
  21. New 3rd gen member
  22. aftermarket steering wheels
  23. tach needle jumping
  24. Squeek from clutch fork pivot point
  25. West coast converter's 4 3rd gen?
  26. May use rear end gears from S10- or Monte-where can I decode the axle ratios?
  27. stock vss ?
  28. 383/6 speed questions?
  29. Lt1
  30. Flywheel Question
  31. 84 Z28 Heater core probs? PLEASE HELP
  32. New Home for 350 TPI
  33. Torque Converter Question
  34. What do you think of this setup?
  35. I Just Picked Up Some Hookers
  36. need help choosing
  37. 84 Z28 will anyone sell me that plastic fin under my car?
  38. NEED answers right now! about posi unit..
  39. If an engines burning oil will it always be blue smoke?
  40. Knock sensor.......
  41. Is this a decent deal on an 84?
  42. which wheels should i get?
  43. Hard Warm Starts
  44. It took me 5 hours...
  45. probably the most asked question.....
  46. stock tpi mods
  47. How much for this ta
  48. A good heads and cam package?
  49. head ?
  50. Which battery charger should i get
  51. New Rims and tires!!!!!!
  52. Mufflex Y-Pipe
  53. roller lifters????
  54. Camaro wont start. Battery or Starter??
  55. 3rd Generation engine
  56. 383 question
  57. l98 vs lt1 fuel consumption
  58. Bought a camaro
  59. Problem after tune-up
  60. Posi Question
  61. Identifing Year Of Motor
  62. had to do it
  63. bottom shock bolt TQ spec? what is it?
  64. Shift Kit Question
  65. takin my 87 iroc-z out today.
  66. starting problems
  67. lift?
  68. tbi 305
  69. cross drilled + apex kevlar pads
  70. How can I make my Camaro faster?
  71. Racing Seats in an Iroc
  72. IROC Z Gold Wheels 16 inch
  73. Cowl induction or ram air???????
  74. tuning tip for 2.8L
  75. Car backfires, please help!
  76. fuel pump thingy not clicking in dash
  77. mini starter
  78. weiand 7525
  79. Flowmaster 80 series
  80. What doors fit what?
  81. 83 Crossfire Injection...
  82. Need Serious Tuning Advice!!!!
  83. Will LT1 poly motor mounts fit 3rd Gen?
  84. StealthRam Intake and Air Foil
  85. K&N Air Filter to Throttle Body #
  86. Why resurface a flywheel?
  87. is it posi?
  88. Exaust with sumped gas tank
  89. its on baby, come torque with me
  90. tell me all u know about front main tranny seal
  91. Front Window stop?
  92. oil pressure sending unit
  93. Tubes Going Into My Headers???
  94. Dyno Tuning
  95. Coil spring Installation
  96. different posi question
  97. which size socket for taking off fenders..
  98. F car 3rd gen roll cages
  99. what size tire??
  100. those with miniram?
  101. choice sparkplugs?
  102. some question about my gear experiences
  103. ecm help!
  104. Tapping sound from the valve cover
  105. EGR Valve
  106. 3.42's in! whats up?
  107. hooker header question, on my iroc-z
  108. Almost time to Sell my
  109. hottest chick in an i-roc
  110. BAD overheat
  111. ZR1's on my Formula (10 pictures)
  112. I blew the doors off a Honda!& im getting sued
  113. were ca I fin honda "PINK"
  114. body parts for my dads 88' camaro
  115. Carb or TPI? What should I do
  116. roller cam ?
  117. Flowmaster website Question
  118. Looking for wheels
  119. overheat at idle?
  120. What Size Rims For My Tires
  121. my rear brake hard line sprung a leak what should i do
  122. afr190 dyno at 288.rwhp
  123. transmission won't shift
  124. question for 94ltimaro
  125. question about header size and performance
  126. Flipping The Air Box Lid...More Sound From Engine...10 More HP???
  127. Oil, rats, and arms... need adivce...
  128. Fan Switch / Knock Sensor Wires
  129. TBI to Carb Conversion questions
  130. Can anyone diagnose the problem?
  131. How much for a decent paint job on a 3rd gen?
  132. ground effects removal on a 92
  133. front suspension parts
  134. Where to put battery disconnect switch?
  135. Car starts, then won't start, repeats..
  136. HELP!! engine swap in 91 Firebird
  137. Why does my fan wiring keep getting fried?
  138. Transmission Flush & Rearend Build
  139. Will a clutch from a 2.8L S-10 fit?
  140. A/C controls
  141. dash lights
  142. Header Question
  143. rearend
  144. ported maf didnt work?
  145. Speaker Sizes and Sub question
  146. starting trouble!
  147. breaking in a flowmaster
  148. More mods
  149. factory style roller cam in early "non roller" block.
  150. need help with cam number
  151. Throttle Body Plates-where to get?
  152. Oil Question...QUICK!!!
  153. how damaging is brake fluid (on tires, wheels, body)
  154. accel header plugs
  155. what do original floormats look like?
  156. Where does this ground strap connect to?
  157. What is this connector to?
  158. cant find correct headers
  159. hp rating
  160. carb jets/rods
  161. Finally got some pics of my 3rd Gen
  162. new pads and rotors brakes still soft
  163. What sensor is this?
  164. Ahh Darn
  165. TPI to Carb swap
  166. highflow cat
  167. Shift bulb by the shifter
  168. 3:42 gear swap question?
  169. where to find a MAF
  170. Loud Ticking coming from Harmonic Balanceor.
  171. TBI to LT1..fuel pump ?
  172. Help me diagnose this please
  173. Push rod length question
  174. How to set timing after new distributor install?
  175. Brother getting 84
  176. puttin and knocking sound
  177. t56 tranny
  178. AFR Heads
  179. Do i need to pull motor to install headers
  180. Cracked Flexplate
  181. need help
  182. aftermarket computer chip
  183. Clear flood mode?
  184. Quick LT1 Heads question
  185. 86 Iroc info needed
  186. Loose steering
  187. Do tachs break?
  188. Do I really need a thermac?
  189. what can i do??
  190. Vette Heads and Cam
  191. 1990 Iroc... good or bad?
  192. Where to get GM weather pack connectors?
  193. Bad to remove the MAF screen?
  194. What causes a pig rich condition?
  195. S10 axles fit?
  196. t-top compatibility
  197. DESPERATE FOR HELP! 86-87 TPI owners, EASY question
  198. LS1 swap
  199. 1982 Indy pace car for sale
  200. changing brake pads
  201. couple of thins i noticed during oil change
  202. clutch master cylinder
  203. lt1 in thirdgen
  204. Ticking sound from IAC?
  205. 383 stroker
  206. What the hell is that noise?
  207. TV cable - RPM shift points
  208. HELP i NEED SOME 295/50r16'S
  209. alternator bracket on edelbrock intake
  210. what can anyone tell me about the 82 pace car?
  211. dist. trouble
  212. Oil keeps leaking from oil filter
  213. what is the best distributer & wires for an 84Z
  214. Intake Question
  215. Lingenfelter box and wipers
  216. Which one is the CTS?
  217. AHHH CRAP! Not another problem... =\
  218. Where to buy PVC hose and EGR vacuum hose?
  219. Few purge canister questions
  220. Should i buy this Iroc
  221. im so damned disgusted with my camaro
  222. Sporadic timing?
  223. Spohn Torque Arm Q's
  224. moody tranny seal
  225. Hypertech Fan Switch
  226. pics of 4 inch cowl hood on a 3rd gen
  227. switching rearends
  228. cheapest way to get 500 Hp out of a 406?
  229. Exhaust on my 84 Z-28
  230. New best with my TPI.
  231. new pipe
  232. Fan Question...
  233. Manually cranking the car?
  234. What different colors of RTV silicone gasket maker
  235. Any thermostat switches turn on @ 185*?
  236. Problem running secondary fan before primary?
  237. so check this mess out
  238. Thats it!, I give up! just came back from the track
  239. Brake line fittings
  240. Why so much carbon buildup in the intake?
  241. Can't get the spring of my door back in!
  242. Vacuum line on a 305 TBI
  243. Where to get fuel injectors?
  244. why so why so
  245. Now whats wrong?
  246. Car Running Rich
  247. stock irocz rims size?
  248. No headlights, radio or hatch release, HELP!
  249. failed emissions
  250. Torque specs for waterpump?
