- Dayton Daytona ZR tires?
- tuned port motor for carbed application
- Mass Air Sensor Upgrade
- who does this to a camaro????
- 1/8th or 1/4 times 305's with 2.73's
- LT1 SBC for sale, giving ya'll a heads up
- SLP LOUDMOUTH on my IROC-Z
- What intake do you have on your car?
- Rims to get???
- Ready for spring???
- 1987 - 305 Tpi - S/r Torquer 305 Head - Cam
- Lifter Question...
- T-tops
- Powerglide in a 3rd gen??
- Burnout Problem
- Advice on a 92 v8?
- searching for third gen. what are o-rings?
- building L98 for midrange torque
- Springs for vortec heads with LT4 Hot cam
- 83 trans am weight??
- 1988 tbi iroc?
- Parts to Compliment 2032 Crane Cam?
- help w/ paint
- 1986 Irocz???????
- Nasty WOT bogging...
- double roller clearance problems
- Manual Fan Switch, Dual App.
- to Rippin92rs and your 3rd gen camaro
- dyno'ed today...whatcha think?
- Losing patience with a problem
- Camel backs or AFR 195`s
- What Headers Should I get?
- which trans cable can i use?:confused:
- how do i tell a tbi iroc from a tbi rs?
- Many people were wrong!
- Temp gauge going buzzerk!
- How accurate are the....
- 89 RS Timing
- por 15 body work (the restogrip and straitline)
- 17 inch rims for my Iroc
- Flex fan or dual electrics?
- push rods
- Are there any N/A 300 hp tpi 305's?
- Need expert help!
- TH350 short/long tailshaft
- Easiest Tranmission Swap
- lt1 super ram or stealth ram ??
- the big apple circus is here(time to change sprak plugs)
- Demon Carb + Kickdown cable. Geometry Help needed.
- An Idea for the Future...
- ordered my rear rebuild parts today
- oil leak help
- Driveshaft Length
- Hypertech Fan Switch!!!!
- few Q's about zz4
- Exhaust sytem????
- couple questions on what fluids i should use
- Fan Relay
- Whats the best way to put on an intake???
- paintjob?? ideas??
- Auburn or zexel torsen, which is better?
- code 43 after rebuild
- HELP! Hesitiation...
- Prothane suspension kits
- Kumho Ecsta ASX tires??
- Help Please Tach Bounce Pwr Loss
- Power steering help
- 305 tranny
- wireing help
- Another Disc to Drum Question
- help with my iroc-z rims
- Power window gets stuck
- T-56 swap question
- Lug pattern
- track rules????
- No Engine or Drivetrain
- 2 quick videos of my Z
- converter help
- Bogs, misses after 3000 rpms
- Question about 700R4 in 305/350 '87s?
- Gauge Help
- rearend question
- bogg's and wont idel
- Air dam won't stay on!
- Tokico Lowering springs
- Turbo Mufflers..Any good?
- guage pod in place of ash trey?
- 88 RS 2.8 Power Adders
- Tuning options for tpi?
- 350 TPI Cam
- component sizes for 350
- 88 IROC, New member need help!!!
- Help, I think I broke it....
- Who's spraying their TPI cars?
- Starting Problem!! Please Help!!
- Verifying a 305 from a Crate 350
- 350 question
- zz4 or something else
- Injector question
- 92 camaro on ebay
- Throttle Body Question
- T5 and T56 Trannies
- taking off my driveshaft
- 383 Stroker Damper/Flywheel ??
- Piston part number question
- just got my camaro
- How sterotypical is your third gen!?
- ring gear
- Bosch Injector # 0280155931 ????? what are they???
- 3rd Gen salvage yard in Canada ?
- Tranny in. now i got a new problem...
- How can I find damper diameter?
- Check Engine Light question
- Cam For 305
- Tranny leak. Too much pressure?
- speedo question
- good 305 cam
- New SuperChevy issue on TPI
- Parts from a 305 to a 357
- Finally changing rearends!
- Question About Computer
- So I just ordered my Vortec Heads and Intake
- Buying an IROC... could use some advice
- TBBP kit for '92 350
- taking off egr
- heres an idea
- looking at a Z28
- Aftermarket Oil pan for stroker, what fits?
- explain gears to me
- 3.73's?
- Fuel Filter Change
- Proportioning valve
- What size and type Pushrods to get?
- I Think This Falls Under MAJOR Tranny Problems...
- 87 drum to 88 disk
- Help me!! Please!!!
- 4th Gen Wheels on 3rd Gen
- will these sfc's fit?
- Adjustable MAF for TPI, now a reality.
- Buying a camaro... is a 305 worth it?
- anyone wanna touch this?
- Suggestions on changing the plugs
- is there anyway to find out..
- V6 Intake Pipe
- I hear Camaros rattle themselves loose...
- 88 Camaro 305 115,000 Miles
- what wheels do like?
- Fuel pressure
- Pics Of My 92!
- big block in my roc
- lt1 with 4l60e trans question?
- A Heated O2 Sensor?
- bodywork
- Motor Swap: Street Legal?
- Fuel Pressure Regulator
- SLP Shorties vs. Hooker LTs.
- Dual electric fans-wiring and turn on.
- Mid 80s trans am steering wheel question
- Is my choke operating normal?
- what the hel did i do, what is normal
- SLP Headers with A.I.R
- shift question 700r4
- 305 bogging
- i need the greatj,s help hit me up great jay
- 2 Seater 3rd Gen!?!?!?!?
- tranny question
- cam lobes
- Rear end gear swap
- Paint Code...
- free firebird!!!!!with these parts work with a 305 or 350tpi
- new engine what should it rev at
- not sure i understand "flash" codes
- idear
- what would you do?
- where do i find this
- Stock air filter swap results
- Anyone who`s takin a T.P.I off in here
- Engine whining...
- measureing tires for speedo gears
- Heated O2 Sensor Question
- Tpi 383
- questions about my 700r4
- spohn
- Anyone running a 400 SB?
- SLP's 92 Firehawk rim question
- 406 short blocks
- Aluminum driveshaft...what is the benefit?
- Shortblock needed where to go
- sdpc engine
- cam identification
- Firebird/Trans AM aftermarket hoods?
- 2000 ss wheels
- fog lights
- Lt1 cam in L98 TPI
- Brakes?
- 2 engine power specs-which one?
- rear end
- Intake/Sensor Questions
- Hypertech fan switch
- i hate going to the chevy dealership
- Which Shifter?
- CC 306 cam in a 305?
- cracked and warped end caps?
- pulling a gas tank from an 89 gta
- Cam Swap in 91 Firebird Question
- Feels good to be back, just bought a IROC
- damn the rain, any suggestions
- Finally got my 92 Firebird....Problems?
- how do i know
- Pressure building in gas tank!!!
- How much should a 305 bare block weigh?
- what should i put on my t top gaskets
- Starter lugging? kickback?
- another question for aklim
- coolant overflowing from fill bottle
- fuel presure?
- Thinking about picking up a new car
- Anybody have pics of 15x10 wheels with 5" backspacing?
- where is the engine temperature being read from?
- getting car out of storage
- Some painting questions
- MAC SFC's on Ebay
- TPI CENSOR's
- Headers
- tranformation
- what is the normal operating temp?
- MAC Exhaust
- god i hope i got 26 splines
- Camaro for the day
- Question about buying STB
- Tranny??????
- Best 700 converters?
- how do i put on my louvers?
- Rings on a 400
- Exhaust Question
- Cooling Fans
- Selling Price??
- flowmaster exhaust
- O2 sensor placement question...
- extended cranking before startup
- iroc-z and z28
- Do you think its worth it?
- need great/cheap heads for l98 that will make me 350 rwhp
- drop in replacement engine for 92 rs camaro
- i want my car to turn better
- TPI conversion
- Rate your shocks...
- Manifold Censor
- exhaust question
- magnaflow mufflers
