- How to remove the AC?
- lt1 intake on 1gen SB
- Need help from those with front mount intercoolers.
- 9 bolt gears
- Boom
- seats
- installing the corner wings on iroc-z
- 12 bolt need some help
- factory freak!
- Double Hump Crossmember
- Tranny Problem
- pulling the motor
- Tbi 305 Lo3 Mods?
- wheel/tire package??
- vortec tpi cam recomendations
- Forgot to retorque heads...
- Billet Grille
- What cam for stock heads + HSR?
- what headers does everyone use?
- Rear ends?
- Fuel pump/relay ?
- getting rid of LG4
- 1991 Z-28
- drilling carb adapter
- Steering Wheel
- Converters
- Starting Problems
- Header gaskets
- Pics of engine inspection...SH!T
- Queations, questions, questions...
- HSR update
- 700R4 / Turbo350 swap.... torque arm ???
- How will it run???
- Oil in Distributor
- what year did they make the first IROC with the 350?
- Twin Turbo L98
- rear of camaro
- 1992 b4c camaro
- cat-back or true duals???
- blown head gasket??
- Need help after motor install
- clear corners?
- Drum to Disc swap
- Back seat keep or lose
- 3rd-Gen mailing list down???
- T 5 Question
- Venom 400 Control Module
- Swapping interior door panels?
- Going to 16" IROC rims
- Anyone know any companies who make a rear coilover conversion for the 82-92 F Body??
- 245/50R16's to 255/50R16's
- New Gears 308 to either 373?? or 410??
- What else do you need when perparing a car to an engine swap with twice the power?
- Another t-top Q's
- Max wheel/tire size for 15" wheel?
- Ignition Voltage Question
- rear end question
- 3rd gen stress cracks
- Where to get sway bars?
- Rear end help
- Would I run 12's with this??
- sepentine belt sizing
- LT1 intake/heads conversion
- 8th Digit Vin Engine Codes.
- rear axel
- Aright guys am i the only one, im getting worried, My car bends...ALOT
- aklim
- air pump question
- 95 LT1 starter?
- turbo system for 3rd gen, at last!!
- solid or hydrolic roller
- will 2 bolt hold?
- tranny won't shift into 3rd
- 92 camaro starting prob
- complete lt-1 drivetrain
- Serious trouble, please help!
- is 12 bolt just a housing
- What should I tell the guy?
- spindles
- Superram
- vortec 350 build
- Hey Guys
- how long will she hold up??
- heres what ive planned so far for my rear have i missed anything
- Camaro trivia!!
- Seat Question
- Trick Flow Heads
- modifying the heads
- Top Speed
- How does 1* of timing matter?
- 92 camaro starting problem
- Third gens only..Please.
- FLex-a-lite variable speed control
- GM factory alarm on 95 and newer
- Throttle bodies pouring fuel at startup.
- may have found a hella deal!
- Vacuum hoses?
- L98 Vette heads
- lt1 thirdgen swap
- For 2K, How Fast Can I Go?
- Lt1 4l60e Carb. Questions Please Help!
- Weight of Stock Carpet, 27lbs.
- 88 305 Cam Ideas
- o2 sensor bung
- Oil Weight, Effects?
- Relay Question
- Stealth Ram vs LT1 Intake
- 1988 Camaro RS motor swap ?
- header bolts....
- screwed 16 years ago... and some questions!
- 88 Camaro 305...Intake Manifold HELP
- a.r.p header studs?????
- Do i REALLY need a cat??
- GP on Hawks 5-inch 3-piece Rear Spoiler.
- Does anyone have my car pics?
- HID's on a third gen Camaro??
- Stealthram come in here
- Air Filter
- Cam install q's
- Subs
- 350 stroker
- $650 to spend on a toy... but what?
- anyone here to a hardtop to t-top swap?
- calling any copper metallic owners 'russet' brown paint
- head gasket
- gutting the tpi air lid
- Air cleaner extras
- 305 TPI Heads
- race car emission exemption
- Cam selection what are your thoughts on this one?
- Hey, Looking for a clean 87-92 Z28...
- Dipstick Question
- Fried the tranny What is a better replacement
- Two Questions Inside....
- H.O. Heads On a 91-92 convertible
- pinion angle
- Roller Rockers
- How hard to swap a LT1 into a '89 GTA?
- 90 Cam won't start
- LT1 Heads, started mod'ing today, need help
- Any way to test MAF?
- Big Block Exhaust
- Amplifier question
- axles on an 87 iroc 26 or 28
- Looking for TPI FPR
- My windows fog up
- This Is What Happens When You Blow A Rear???
- Headers to Get????
- Diameter for exhaust on 5.0
- 5 speed conversion
- Stranded for a few minutes.
- EGR Help!
- LS1/T56 in a thirdgen..........Almost done....
- Replacing EGR
- Where 2 start on 92RS 305 TBI??
- need advice
- Drum Brake to Disc Brake Rear Q's
- how often should the thermostat be replaced
- iroc bucking when in drive
- how hard is it to drop the 700r4
- to all my 87 iroc-z boys
- LT1 Cam Dowel Pin Q
- Will 79 rear end fit 92?
- Tranny shifting finiky
- Still looking for a 91-92 Z28...
- drove my first 3rd gen yesterday!
- Timing on a 305 with no cat
- Wheel sizes and backspacing
- bogging at a light cruise
- I'm new and proud!
- canadian $ value of iroc
- 3rd gen rails with 4th gen seats?
- Third Gen Lower Shift Boot
- Code 34
- just a thought
- Pre 87 SBC, LS1 or LT1 Induction System
- Accel Injectors...
- dropping lt1 into 3rd gen, accessories question
- Taking off the upper side skirts suck!!!!
- Anybody changed to the Fastburn head kit from Scoggins on your TPI ?
- Convertors: B&M or TCI?
- Crane Fireball 296 Cam
- angle or straight plug
- Where to buy ABS headliner?
- Repaint Time
- Wiring for 700r4
- for aklim 3rd gen ques
- 4th generation 17's on 3rd gen
- fuel pump question
- what do you think this would run??
- I want to get rid of my TPI...
- 1991 Z-28 fuses (under dash)
- stock times for 305's and tpi 350's
- no muffler for the v6?
- cam's
- 305 Tpi Cam
- An easy question for you lot!.
- 700r4 problems
- LT headers and the y-pipe!
- how do you judge value of a thirdgen?
- Need Suggestions for 92 Ground Kit
- Let's talk more cam's
- 2400 stall?
- Exhaust
- Crankcase hole Size???
- what are the symptoms of an exhaust leak?
- 92 RS Idles Rough Any Ideas?
- sayin goodbye
- Anyone seen a 84 TA with a great body for sale? Complete or Rolling Chassis...
- TPI block w/ 400sbc heads would LT1 intake work
- oil leak - help me
- Best Transmission
- T56 tranny in auto/350
- Rims
- American Muscle Car
- TH700r4 HELP!!!!
- Wipers and Squiters Died
- Removing AC/smog
- I am a member
- 305, 305 HO, or 350 tpi??
- More power froom chevy heads? 350....
- Decal placement measurement for IROC
- Edelbrock STB
- What size carb for a 350
- Cutting floorboards to make room for exhaust
- Is This a Good Price for a 383?
- just put a cup of alcohol in my iroc-z
- Scrapes
- What carb?
- 2.73's to 3.73's
- 87 iroc with 373
- Using 84 lights and stuff on my 92 Bird
- Lt1 cam move powerband up in LB9?
- High Speed Vibration
- fuel lines QUICK
- Stolen 88 Iroc-z North California
- thinking about getting another camaro
- Stock 88 305 TBI how to change to Intake Manifold n Carbureator
- 305 G block
- timing chain and gear replacment interval
- 383 Tpi
- 28 Spline Axles??
- Hypertech Fan Switch
- turbo 350 swap
- Anyone ever seen the flowmaster lookalike Vortex mufflers???
- Need some testimonials about mufflers...
- Hey newbie here
- will a gta front end bolt up to a trans am front end?
- Third Gen F-bodies: why so expensive?
- Heads/Cam TPI 350
