3rd Gen / L98 Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
  1. 305 to 350 tpi
  2. Folks running with 383 strokers....
  3. Water Temp Gauge Question?
  4. Tranny compatibility question
  5. How much would a LT1 3rd gen be worth?
  6. Need Cam advice
  7. Transmission Question
  8. Carb or fuel injecion
  9. cheap hp&trq???
  10. ram air vs. cold air intake
  11. This Cant be....
  12. broken rocker stud
  13. Adjusting TPS on a SD ECM
  14. plug wires
  15. 305 to 350 what parts
  16. another engine question
  17. Where is the ECM grounded
  18. quadrajet
  19. steering column trouble
  20. is it possible
  21. Fault in Quad Driver Module
  22. V6 to V8 swap. what's involved?
  23. changing rocker arms effect vacuum?
  24. Darn Exhuast Leak
  25. how do u disable speed limiter
  26. weld draglites
  27. different rears for 3rd gens?? (10 bolt,9bolt,etc.)??
  28. Subframe
  29. How long to change front brake pads?
  30. E CutOut
  31. Cam info requested....Which one, which one??
  32. LT4 notHot cam?????
  33. Gears
  34. 305 to 350
  35. Longtubes better and cheaper than hookers?
  36. Is it a 350? or not
  37. Fuel Injector sizing calculator?
  38. Limits to the TPI intake system
  39. T-5 vs T-56
  40. Where to get Victor JR intaked flowed
  41. my Z is runnin like sh*t
  42. SLP Cams
  43. Injectors 22lb or 24lb????
  44. Which Tranny?
  45. I think I found the problem - the computer
  46. considering.?.?
  47. berlinetta digital dash swap
  48. dash removal
  49. wiring harness help
  50. 3rd gen to 4th gen rear end swap
  51. flowtech headers
  52. comp cam
  53. t-top leakage
  54. headers
  55. rear axle bearing seals
  56. rear ends???
  57. A/C Heater Controls
  58. Weird ZZTop IROC
  59. Transmission trouble..
  60. What do you guys think?
  61. l69 dual intake air cleaner ducts..
  62. Nice Suprises found during L98 extraction
  63. O.K. Time for the LT1/ Any good links?
  64. looking to buy 3rd gen camaro to "build", which year to get??
  65. Looking into Domestic...
  66. 92 RS 305 tbi won't start
  67. 3rd Gen Blackouts, PLEASE HELP!
  68. Can U Put A Big Block In A 1987-1982 Camaro
  69. Quick!!!!!!
  70. Steering wheel swaps?
  71. Motor Mounts
  72. Firing Order on big block
  73. Air cleaner hood clearance
  74. unibody
  75. Exhaust Fumes
  76. ricer math.... sorry
  77. Installing Hurst Shifter
  78. Which heads to go with?
  79. difference between v6 and v8 models?
  80. $1200 to spend
  81. Need to upgrade Chasis - Need suggestions
  82. My car is having problems. Help would be greeeaat.
  83. my car sits an inch higher on one side!
  84. 89 Iroc-z convt.
  85. stalling out
  86. 12 bolt
  87. Start naming your 12 second 350 combos....
  88. 385 fastburn
  89. Do SLP headers # 3001C have....
  90. putting a rack and pinion on a 3rd gen
  91. tranny
  92. 2nd Gen threads on lugs the same as 3rd Gen?
  93. cowl hoods
  94. goin crate??
  95. '91 Z28 305?
  96. 700r4 speedo bounce-electric
  97. building 350 for my camaro
  98. How long did your stock tranny last after engine swap?
  99. doesn't warm up
  100. Injector Tapping
  101. Help with idle problems
  102. LT4 hotcam legal on L98 in California???
  103. Effects of not having o2 sensor
  104. what to do please hlp no more garage
  105. Trans Am rear end
  106. olympics edition ???
  107. Single fan to dual fan,any difference?
  108. Updated L98 Progress Page
  109. 1991 Camaro Z28, a steal??
  110. Take a look at this Chassis.
  111. HSR purchase
  112. How to stuff a Olds 400 where a Chevy 305 used to be
  113. Here's a Pic, where to remove the break pads?
  114. Sanderson
  115. At
  116. Tire question
  117. Since I have my ECM sitting on the floor
  118. 350 TPI rebuild kits?
  119. disc brake conversion kits
  120. Proportioning valve
  121. LT1 Heads: Accessories Q?
  122. Mass Air Flow
  123. 250HP from a 305TPI???
  124. PCV and oil consumption...
  125. Transmission Type?
  126. 91 RS 305 questions
  127. 3rd gen buyers guide
  128. T56 swap into 3rd gen
  129. cat back
  130. 1989 Camaro RS Burnout
  131. Check Out My 1992
  132. What will i run 1/4 mile?
  133. 87 Iroc AIRBOX modification
  134. Help! Fuel pump won't shut off
  135. Biggest tire on 16" '86 z28 rims?
  136. 350 SLP TPI Headers on a 305 TPI???
  137. air in the cooling system?
  138. TPI to Carb guys in here
  139. found a nice 3rd gen locally
  140. interior suggestions?
  141. SWEEET, pics of the RS boys..
  142. coilovers??
  143. TPI intake w/ vortec heads??
  144. Brake-in new motor help
  145. Fabricating Louver Brackets
  146. Nitto 555R
  147. LT-1 CAM in into LB9?
  148. Shift Knob Thread Size
  149. 91 tpi interchange with 87?
  150. cool item
  151. 94 posi into an 89 open?
  152. distributer?
  153. what kind of tranny?
  154. New Engine for third gen
  155. Is this a bunch of CRAP????
  156. 10 spokes on third gens
  157. firing up new but dormant engine
  158. Runs like crap after mods.
  159. polished ground effect emblems??
  160. 83 Camaro LG4
  161. Starter grinding problem
  162. 3rd GEN Single fan & Dual fan CFM Rating?
  163. 3rd Gen Oil Pressure Gauges
  164. back spacing
  165. computer
  166. ecu program
  167. What years had the third brake light on the upper window?
  168. 86 for $300 no motor Good deal???
  169. please help, whats this light mean??
  170. Anyone know dimensions of '86-'92 clutch?
  171. Cleaning vents
  172. egr crap
  173. Help! How to remove center console???
  174. gas tank removal
  175. engines?!?
  176. Wiring power windows and doors
  177. Scan tool?
  178. 3rd Gen Tech Wakeup Call!!!!!!
  179. Filling a 1LE gas tank
  180. Dropping the rear and lower control arm Q's
  181. Replacing Vents
  182. Y-Pipe from 4th gen on a 3ed gen??
  183. 91 rs
  184. 88 IROC 350 what cam?
  185. rear end ??
  186. need new shifter!!!
  187. door sills??
  188. Say Iit Ain't So....
  189. Need Engine Project Advice
  190. Carb metering... help
  191. How can I make a 10 bolt handle 400HP?
  192. Wheels fitting??
  193. Springs
  194. Check out the website
  195. F41 RS's got THE biggest sway bars right?
  196. transmission coolers
  197. 383 cam selection
  198. FS: Wheel Adapters, 2", 3rd Gen Camaro, S10, Blazer
  199. 4l60=700r4 Tc?
  200. Fuel Pump
  201. HRS Camshaft Recommendation?
  202. HSR camshaft recommendations ??
  203. Spark plug gap Q
  204. Head bolt specifications
  205. help me shop for some goodies
  206. How do us lowly RS's stand to 3800 '98+ Cars?
  207. Guys with Spohn T56 Crossmembers...inside
  208. drivetrain question
  209. 1.5 months left of snow. what do you have planned
  210. rust on the door seams
  211. 88 305 - Help With Good Carb N Intake Combination
  212. Wiring Fans to Always On
  213. legality question
  214. the rarest 3rd gen ever!
  215. What tool/blade do I use to cut sheet metal?
  216. 88 GTA Shocks
  217. i need part numbers!!
  218. Shims for Borg Warner differential
  219. 3rd gen driveshaft length
  220. anyone using Comp Cams 1.52 Roller Tip rockers?
  221. How hard is replacing weatherstipping. Those who have done it inside please
  222. quick imputs from people with an auto car i was curious Stock shift knob.. Options?
  223. 305? Want to beef her up? For Cheap? Come on in.
  224. Another Transmission Question...
  225. Exhaust idea
  226. tell me what ya think
  227. 1988 Firebird oil pan removal
  228. 91 drum brakes
  229. Electric Fans
  230. Vortec Head Question
  231. Headers for My Application
  232. 86 restoration
  233. Interior restoration
  234. soft seal door seals??
  235. Exhaust Help
  236. Miracle Cam, Head, Intake combo
  237. trans swap kit
  238. Water Pump
  239. LT1 swap A/C need expert advice
  240. What muffler would sound the best ?
  241. LT1 Heads came today, updated the site!
  242. Where can I get 1 header?
  243. what's going on
  244. pre-91 RS vs 91 Z28
  245. A couple questions about my LT1 swap.
  246. Need help with L98 buildup
  247. 88 IROC L98 running rough
  248. suggestions on cc305 vs. cc306??
  249. help?wheels
  250. Does it matter which way the temp sensor is wired?
