- How much power can a performer intake make?
- How to internally balance a rotating assembly
- Water Pump - what to go with??
- LT1 or L98
- hey guy's
- ok this TBI = No performance
- Need opinions....please help.
- lt1 swap..
- LED Lights vs. Bulbs for instrument Panel
- mechanical (non electric) remot operated cutout
- Lowering
- K-member help
- 305 Tpi
- 180cc heads on a 355
- spindles
- still veering right after alignment?
- Header Wrap
- Urgent Question
- L98 + bolt-ons = 12.80's!!!
- 1992 Camaro Transmission/clutch problem
- OEM V8 radiator part #?
- RIP to my L98
- New rims, any performance difference?
- i hate my cuz
- custom exhaust
- My brakes are bad...
- Code 15, doesnt rev past 2200rpms
- Where does one get an IAC adapter for the TPI throttle body?
- how not to get your radio locked out
- 160mph guage cluster?
- what next
- Wheel offsets?
- Car runnin Rich
- 92 Rs ???
- Hyper Pistons
- LT1 Cam swap and porting Questions!!!Need HELP!
- Which headers to get for an LT1 going into my thirdgen?
- My Hatch motor....ARGGH!
- black charcoal canister
- Wheel spacers for 17 inchers
- I finally got my 383 home guys with big cams in here
- Header Size
- water temperature sending unit part number PLEASE
- Mobile Syn. Blend
- 383 Horsepower Estimates
- 1992 Camaro Z28 Tpi, Mods???
- Cat Price: How possible?
- Ahahahahaha
- what year did TPI come in vettes?
- Fix your door hinges!
- Spintech sound clip
- Well they brooke into my car
- Engine Mounts Do Not Fit
- OFF BaLaNcE
- subframe connectors question?
- syno results from HSR swap
- I Need Help?!?!
- I need Help Please?!?!
- y pipe help
- My Project T/A
- Long tube, 6-speed guys look in here
- Oil pressure sending unit
- Do the 6 cylinder Gen 3s have same rearend as 8s?
- antifreeze aditive tablets???
- Removal of Charcoal Canister
- Water Temp Sending Unit
- mojave green converters??
- Shocks or Struts???
- sluggish ??
- V6 to TPI 350 swap
- L03, LB9, L98 intake questions
- Holley Stealth Ram
- My IROC has a problem.
- how much can a 700R4 handle?
- holley stealth ram vs. mini ram
- Help!! Glowing Header Tube
- why do the lowering kits always lower the front more then the rear?
- Hedman LT Question
- ss or no?
- fuel line
- Need opinions/advice...please!
- a/c deletion
- Whatcha guys think about the GMPP Deluxe 350 HO crate?
- 3 wire o2 sensor, what kind?
- Wow
- Wife killed my car
- Pro Topline/Pro Action Heads
- Will I need?
- what does it take to get the carpet out
- Project T/A: Cleaning the fuel tank.
- Posi from 83 rear to 87 rear?
- Will I need spacers for 17in wheels?
- started my page
- 12 bolt
- Project T/A: It started!
- TH2004R info
- third gen rack
- 92 camaro project
- Gears
- anyone ever try to make their own fiberglass(or other material) parts. like spoilers
- oil pressure
- No keys...need to get out of park
- New Monte Carlo SS's remind me of 3rd gens
- Factory Fuel Pressure
- Timming, help!
- 406TPI whats in voled and how much power now muchcost ect????
- Paint and Prep Help
- Hurst Shifter Install?
- Hi Im New Here
- Intstall HSR intake
- 9 bolt, how much power can it take?
- exhaust
- Nelson Racing uses HSR
- Auto trans dipstick
- 305 to 350 swap.. what do I need?
- Wide Tires
- 1989 Camaro Project
- oil pressure fuel cut off switch
- Going From TPI to Carb. Need Help
- Reccommended AFPR
- Looking to build a sweet stroker but need some help
- New Heads/Cam Time...Need Advice!
- headers
- Problem with my L69
- Vaccum leak or distributor?
- my LG4 is comming along :)
- Fuel Injectors
- 89-92 camaro engine
- Hi im new here too hello!!!!
- new 3rdgen in my future
- 88 fuel management
- TPI on Vortec 350
- guage problem
- carb to TPI
- Buyin a 3rd gen
- PAINT REMOVAL from bumper
- warm air, no heat
- Odd Problem
- Camaro I might be looking at, opinions?
- Rookie Question
- Almost bought an 95 Z yesterday.....
- which carburetor
- synthetic ATF to slick for clutches?
- Stock T-5 shift knob thread?
- Exhaust pipe size
- Electric choke adjustment + Crappy gas mileage.
- Flat tappet and (factory) roller cam interchange possibilities- THE REAL ANSWERS
- What do the brake pads susposed to be...
- Aluminum Panhard bar ??
- Gas Tank / Fuel Line Dilema..........
- anyone use a trans star torque converter?
- First Time RS Owner Here.
- dual exhaust????
- LT1 in 3rd gen
- How much horse does a LB9 have?
- Any difference between the 2
- Cold Air Intake
- Which Tires??
- SD Systems still have a MAF right?
- Manual to automatic
- Taking off the front bumper cover.
- Idle starts at 1k, slowly rises to 1.5k
- This is ridiculous, I'm getting 7MPG...carb 350 help.
- Car Only Runs When Starter Is Cranking
- Surging at low speeds/gas smell
- Good Place to buy a 3rd gen?
- Performance Upgrades
- 1991 Zr1 Z28
- why do you even drive this junk
- back fireing
- Anybody else ever tried this?
- Fiberglass Replacement Fenders for street
- much help needed
- 3rd Gen Weight Reduction
- Ignition upgrades
- 2 questions.........
- Mystery Vaccume lines
- Any reason I can't use rubber fuel line hose as part of the fuel pickup in the tank?
- engine swap
- What rim & Tire Combo are you running?
- Big Block
- Rear End Gear Change (G80)
- Dual Exhaust
- Check engine light on camaro
- Have - Stock 88 F- Body 305 Want - 350 Horsepower
- How to route belt after AC + Smog pump delete
- Skinnies Up front
- Best 350 short block crate motor
- SFC Install
- LCA relocation?
- trans swap
- Power Steering Pump Pulley
- modding up a 8.5" rear end
- interior
- I'm blowing fog/headlights out...voltage regulator?
- vindication!
- stock times
- which manufacturer??
- Supperram users
- what year did the SBC go to the 1pc rear main seal?
- Please post you sound clips
- i'm new here...
- Firdbird Lights =====> Camaro Lights
- iroc-z tpi on a 350
- ECU with LG4????
- cam question
- roll cage?
- EGR Valve
- LT1 intake on 350tpi,what do I need?
- why is the ground strap getting really hot
- Does anyone have any clear pics of
- Is this right?
- Where can i get the locking lug key?
- 350 TPI Fuel Injectors
- 87 camaro gauges
- Oil Pressure Sending Unit
- Question on Torque Converter stall speed for MiniRam
- 90 FB headlight motors
- Can I fit 275/60r/15's on 15x7 rims?
- LG4 POWA FO YA FEWL! (vid of Z28james's Z)
- Question about T-Tops
- Question on brake job.
- Hedman Headers
- Will these fit my car
- Ignition stuck on 89 IROC.... anyone have similar probs?
- 87 to 88 on up drive belt swap?
- afr heads
- SLP header problem...something doesn't add up-
- how to get BIG power from an L98
- carb & intake swap
- shorties and y-pipe
- Anyone here have Borla?
- Does this really work?
- Chassis evolution?
- It's bout the fans.......
- 1987 IROC Z/28 RPO codes? is this a 1LE?
- summit dual exhaust
- got my latest z28 today
- lets pick out a cam
- Cruise Control swap?
- What Sized Throttle Body would be best for my 305?
- Electric fans
- How Do I Bypass The Smog Pump?
- Times after mods.
- What should I do?
- What is the HIGHEST HP you have seen come from a 305 block?
- Transmission leaking fluid!! Please Help!
- TH 400 Help
- Best way to tow a third gen
- Trany Lines
