3rd Gen / L98 Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
  1. New Camaro Owner needs some ?'s answered
  2. Which Fuel pump?
  3. Rearend Gears
  4. everybody says to do it but how hard is it really?
  5. What size injectors?
  6. mid range sputter...
  7. Speedo Blowout picture
  8. shavin the handles?
  9. Compression ratio & cyl head cc
  10. RPMS drop when giving gas
  11. 250hp 305 Can it be done?
  12. LT1 Swap into my 84 TA.....Questions for those whove done it or know bout it...
  13. need help with new motor 86 TA
  14. Stock bottom end goes 11.6's NA
  15. 1991 Camaro z28 350 v-8 5.7 with only 13,000 orginal miles
  16. got my new heart for my 88
  17. what do yall think about this setup?
  18. trans problems
  19. How much did it cost to build your motor?
  20. hatch pulldown
  21. Moderatorts please help
  22. Wiring CD Player
  23. Update on brakes - Im screwed
  24. Headman Headers?
  25. anyone try to refinish rims?
  26. How many driving miles do Nitto 555r's last?
  27. Ported Stock L98 Heads: Quality and Price
  28. question, please help
  29. What would it take for my LB9 to get into the 13's?
  30. drive shaft and Y pipe
  31. Help
  32. Car Broken Down!
  33. how does a converted LT1 intake with Dart's compare to stock LT1 motor???
  34. TPI sensors
  35. All 88 GTA's have VATS?
  36. Does that Mr. Clean Autro Dry car cleaner really work?
  37. Drive shaft help ASAP
  38. synthetic blend switch
  39. 8pt Roll Bars? HeLp
  40. Deal on a longblock
  41. Air Foil Question...
  42. Specs on a 3rd Gen
  43. opinions on my engine
  44. remote starters/alarms/2 way car pagers/window roll up/keyless
  45. getting the comp to show any codes
  46. canfield 195's
  47. My first Camaro!
  48. What do ya think of TPIS cams?
  49. Head options...
  50. Help Choosing Oil Additive
  51. Installing Z-28 High Rise Spoiler
  52. header ?
  53. Electric turbo/supercharger?????
  54. Fuel Pressure
  55. Starters
  56. Give me Idea's for Future Mods
  57. Anyone ever switch over to Fuel Injection???
  58. knocking 40 psi of fuel pressure to 7
  59. Friend is selling iroc
  60. Someone tried to steal my car questions about repair.
  61. Tilt Steering slop
  62. Spark Plug Suggestions?
  63. Need a solid solution....
  64. Please help...I'm lost
  65. rear shocks.
  66. 84 Camaro parting out
  67. Code 12??
  68. Drive shaft help
  69. What do you..
  70. more power for my car
  71. transmission swap
  72. Swapping out my TBI for a TPI, what's involved?
  73. What makes the tranny fluid flow???
  74. Low rear gears stress drivetrain more?
  75. Striped stud on back wheel
  76. PST products
  77. Hatch Pull Down Unit
  78. Sound Problem
  79. has anyone used these roller rockers?
  80. Getting L98 heads ready for Hotcam
  81. One cause for flooding TPI
  82. Lg4 Power????!!?
  83. charging??? voltage gauge???
  84. Slow Car!
  85. Will the flowmaster 80 series muffler work with my Camaro?
  86. window motor?
  87. electrical issue
  88. Iroc-z ??
  89. Will these Vortec heads work?
  90. Which Helms manual?
  91. LT4 hotcam or CC304 in 305TPI?
  92. Comp 983 springs---Worth it?
  93. Stock dyno numbers are finally in....
  94. Flowmaster- Good or Bad?
  95. What's the deal with the 3rd Gen?
  96. Help!!!
  97. Ebay Ram Air Boxes??
  98. who would win?modded 3rd tpi vs. modded mustang
  99. Still working on the brakes - caliper question
  100. Q about bumper cover
  101. cold start hesitation
  102. baer touring kit?
  103. Brake Line HELL
  104. Ran my 1988 Formy in the 1/8th tonight, check my results...
  105. Books On Camaro's/ TPI's
  106. rocker arms breaking
  107. Exhaust Question, want your opinion
  108. 1987+--> ALL SBC's Hydraulic Roller?
  109. Spinning a 383
  110. inline fuel pump
  111. Sounds Like Metal Touching...
  112. Interior Ideas
  113. How To Tell If You Have An Exaust Leaak?
  114. do I need the O2 sensor thats in the manifold
  115. which head gasket for vortec heads?
  116. Year One
  117. 383 lifespan?????
  118. Tripometer Stopped Working
  119. Still...
  120. aluminum underdrive a/c delete pulley???
  121. regearing my blown rear
  122. how to stud tires
  123. coolent burning
  124. Cylinder Head/Intake/Injector/Cam matching
  125. Converting TBI to TPI
  126. Chirping sound from valve covers
  127. ! 9th fuel injector
  128. SHOULD I SELL MY 4th gen for 3rd
  129. stall converter 700r4
  130. learned something about cam timing
  131. easily accessible exterior transmission filter?
  132. Oil On Spark Plug 1 and 2
  133. Adjusting "TV Cable"
  134. 89 Camaro FREE!
  135. What would you guess my hp is?
  136. Stock L98 numbers
  137. TBI questions...
  138. rear end parts list
  139. 1988 z28 convertable rare?
  140. Code 36!!
  141. Valve cover gaskets
  142. wheel locks
  143. 2 leaky tranny questions
  144. 95 neon for 86 t/a... fair trade?
  145. 2.8 to 305
  146. help car caught on fire
  147. 1996 Impala SS vs 1992 Z28 5.7
  148. Spring help
  149. Sweet!
  150. So what is it then?
  151. 85 TPI do they have speed or revv limeters?
  152. Tick Tick Tick Tick, ahhhh sh*t
  153. 58mm tpis throttle body
  154. I have a full edelbrock exhaust, iwas just wondering what you think of the system?
  155. What Kind Of Gas Do You Guys Use?
  156. What differences do wider wheels make?
  157. Anyone else have a loose steering column?
  158. 86 2 lt1
  159. Hesitation from Reverse To Drive
  160. Making the Stealth Ram emissions legal
  161. 700R4 bolt up to older SBC right?
  162. 1LE Oil Cooler??
  163. Car idles rough and backfires after header install. Why?
  164. Car runs rough at idle, and backfires after header install. Why?
  165. Now What?
  166. aklim, whats your opinion
  167. 3rd gen chassis stuff
  168. '87 ECM in a '92 RS
  169. Headlight options
  170. factory fiberglass hood not just on the 82's?
  171. dual cat down pipes
  172. I need to insulate my spark plug wires from my headers
  173. How Do I Know What I need For My 700-R4?
  174. restoration time
  175. bad fuel pump....
  176. cams n' stuff
  177. Running Problems
  178. TPI 350 modification
  179. Raptor rebuild in tranny and now.........
  180. 1987 trans am hp #'s
  181. IrocZ Gears
  182. it's time to upgrade
  183. 1992 305 vs 350
  184. building for SilverState Challenge
  185. Alternator wiring prob...
  186. I picked up an 84 T/A for free!
  187. Xmas/ Birthday presents from my husband to my car
  188. wierd signs from my iroc-z
  189. rocker arms
  190. Stock Iron L98 heads on 383
  191. anyone know how much an intake weighs?
  192. vacuum
  193. Doors won't lock
  194. Rear end gears... which one to get?
  195. true duals
  196. What needs to be done to cut the cat's?
  197. Changing The FUEL PUMP !
  198. 91 Formula Price
  199. Owners of 9bolt rearends please check this out! Sponsors dealing with 3rd gens too!
  200. ZZ4, lt-4 hot cam users help
  201. 4th gen brakes on a 3rd gen
  202. why are sparks created when the battery is reconnected on a car
  203. LT1 cam in an L98
  204. High or standard pressure fuel pump?
  205. anyone with an ASCD SS hood...
  206. 87 Stang GT vs 89 Formula WS6
  207. Adding functional Ram Air to the ASCD SS hood
  208. OH NO! Car died on me! Need some help
  209. Y-pipe manufactured for hedman long tube headers?
  210. Ricer's got ahold of a 3rd Gen...
  211. '87 Tranny Q need help
  212. TPI to Carb swap, fuel pump?
  213. Can a hydraulic roller be used with flat tappet lifters??
  214. retro fit hyd. lifters for 87+ sbc
  215. Mech. Fuel Pump
  216. Gauges
  217. 400 BB in 3rd gen
  218. What are the symptoms of a miss?
  219. Looking to build fast 350TPI, any suggestions??
  220. Holley TBI
  221. Problem with IROC rear. Can Someone Help?
  222. t5 flywheel ?'s
  223. 89 RS Ignition Problems?
  224. cutting/connecting fuel line
  225. any seggestions?
  226. Underdrive pulleys
  227. Anyone running ZZ4 + TPI?
  228. guys that have done a TPI to carb swap in here
  229. Which ECm is the one for SD?
  230. Automatic vs. Manual. = Reduced HP?
  231. Braided Fuel Lines???
  232. parts
  233. Modifying the Mass Airflow Sensor
  234. Found a 92 Z28 5.7
  235. no heat in my LT1 powered Z, hellllp!
  236. Overlap and optimal cylinder head flow range
  237. Pro Toplines non-centerbolt?
  238. Do you guys have manual fan switches???
  239. Looking for Y-pipe for my Hooker LT's
  240. Ordered myself some Christmas presents...
  241. People with subs in the hatch
  242. Fuel Pump Help
  243. wheel squeaking
  244. 500 hp @ 6500rpm, 350 lb-ft at 2000rpm
  245. '96chevy 1500 350 engine question
  246. Car starts then dies help!
  247. hydrolic clutch help
  248. electric water pump on the street?
  249. 13yr old stock springs
  250. Picked up an '87 IROC-Z with an L98 today.
