3rd Gen / L98 Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
  1. 89 iroc. posibility of 92 inst. cluster swap
  2. Parking Light Bulb
  3. Slp Loudmouth in 3rd gen
  4. engine idles high on 2nd start-up after IAC adjustment
  5. Engine questions
  6. Popping noise from drivers side front?
  7. Where to mount a tachometer ??
  8. which heads???
  9. what is the difference between a 350 TPI and a LT1?
  10. Car runs like crap! pleeease help
  11. Rear Defrost not working
  12. Headers
  13. MSD ignition in TPI?
  14. High Idle??
  15. 350 stalling, part 2
  16. Fuel line from pump to carb questions
  17. Where can I get instructions on how to swap a thermostat?
  18. Proportioning Valve: Drums to Discs
  19. difference between iroc and rs
  20. Suggestions on a spark plug gap ???
  21. New brake upgrade: LS1s for your 3rd gen
  22. OK I'm retarded...dumb Q about gen VI dfi
  23. heater smells
  24. N2O Kit
  25. Car Sound Cat???
  26. Where can i find an intake manifold for a 83 crossfire engine? should i go with carbs
  27. Assembly free 8mm wires?
  28. roller rockers
  29. LT1 into a 3rd gen GTA
  30. Will this bodykit work?
  31. 305 tpi fireing order
  32. in a jam with my ops as we speak
  33. paging Rippin92rs
  34. Radiator fans
  35. 3 inch Y-PIPE ???
  36. Sound System
  37. Does anybody know the hp for a 305ci and or the 0-60?
  38. Service Engine Light... came on, went off
  39. Are Carbs Reliable?
  40. Thinking of buying a IROC-Z...need carfax
  41. no power
  42. Question about 3rd gen weight.
  43. turbo fiberglass hood
  44. How often should this be replaced?
  45. Idle Screw...
  46. WTD: T56 Swap Info
  47. Fuel/ Engine light problem
  48. Single electic fan or Dual electric fans ???
  49. Tapping sound
  50. Crystal Lens Headlights!! Need help Quick!!
  51. Interior Upgrades
  52. BF Goodrich g-force tires?
  53. Benifits of LT1 intake on L98?
  54. Water temp gauge connection?
  55. mods?
  56. Posi Rear
  57. 3.73 gears and sophn subframe connectors
  58. Coolant Temp Sensor Location
  59. Help?????????????????????????/
  60. SES points to MAF. Need help
  61. Are these tires any good?
  62. Just took out the smog pump... have a question
  63. 1988 Iroc
  64. Modified 350TPI
  65. Pulley Question... need help
  66. my other car died and wont start
  67. help with first engine build
  68. Air Intake Snorkel On TPI
  69. Plans for next winter buildup
  70. to the top
  71. 327 question.
  72. Front Disc Brakes
  73. flow #'s
  74. How do i get the spring off my TB
  75. Fuel Gauge Acting Weird
  76. 12 bolt or 9 inch ??
  77. 4-link in a 3rd gen?
  78. Holly Carb Questions
  79. Low Restance Plug Wires???
  80. Plug wire install tips? Getting them on in tight spots?
  81. Ram Air TPI
  82. Are there any free mods for TPI?
  83. TBI High Idle (FYI)
  84. Headlight Flicker?
  85. 305 TBI Power Upgrade
  86. those with fiberglass z-28 high rise spoilers...
  87. what hooker headers will fit best
  88. T5 VSS doesn't want to go into T56...
  89. ford 9" for sell
  90. Longtubes for my TPI
  91. 91-92 gage cluster
  92. Huge Traction Problems (tires I think)
  93. Polishing aluminum rims with clear coat
  94. Should i swap my stock 305 for a 350, or buy a 2002 SS?
  95. Enormous Rattling!!!!
  96. Cabin air filters in 3rd gen?
  97. slp injectors??
  98. the popping is driving me crazy please help 86 Z28
  99. What Belt Size Do I Need?
  100. what is a pony cam!?
  101. Engine Swap Troubles
  102. Will I EVER learn to quit...lol
  103. Who has the fastest 305TPI?
  104. brother wants to trade edelbrock performer rpm heads for L98 heads and TPI.....
  105. Tire Recommendations
  106. Catalytic converter?
  107. leaking coolant *help*
  108. Possible Clutch slippage or grab?
  109. "Early Style 202 Heads"
  110. 3RD gen with LT1 want Supercharger
  111. Cracked Oil Pan!
  112. whole mess of 3rd gen questions
  113. AFPR Question
  114. Paint On Bumper & Fender?
  115. fuel pump q's
  116. Taller centerbolt valve covers....can you get them?
  117. hp junkie!
  118. Sun Pro Gauges?
  119. 85 TPI not right after rebuild, lots of questions!
  120. 700R4 Non Computer Lockup kit
  121. Speed Density guys.....
  122. where's the closest event to san jose
  123. couldnt score the heated garage, car sittin in woods
  124. 88 trans am???
  125. snow is around the corner. is your winter beater ready?
  126. what is the CFM on a stock 90 model TB?
  127. L-98 vs. LT-1 .. 0-60
  128. rims on 85 t/a
  129. MAC Subframe Connectors?
  130. 275's on my iroc-z?
  131. Swapping in a new differential
  132. insurance Q
  133. 305 TPI to ZZ4 Stealth Ram 350
  134. Hood Louver Removal?
  135. Vavle Covers
  136. TPI to Carb
  137. '85 Drop Top Z...rare???
  138. 86' camaro z28
  139. Hesitation
  140. Do you think they will bring back the camaro?
  141. AHH! Banging noise comming from the iroc
  142. L98 dyno sheet
  143. Trying to Replace Power window Motor
  144. Emissions Options
  145. Choke light always on
  146. dj haf and other L98s: what mods?
  147. Hesitates when I punch it
  148. walkthroughs or instructions?
  149. Runs better when MAF Disconnected..
  150. Braking Upgrades
  151. Electric fan
  152. could i shrink wrap my car up for winter to keep it dry outside?
  153. Towbar W/ An '86 Iroc?
  154. mileage question..
  155. fuel gauge
  156. trans swap
  157. Fan Switch and Thermostat
  158. Need help with VSS on my gta
  159. which tranny mount
  160. vette servo and .500 boost valve questions
  161. What ECM in LT1 swap...
  162. Which setup would be faster?
  163. 4th guts into 3rd body....
  164. Painting Intake bad?
  165. Trunk panel
  166. How big can i go for tires on my Z?
  167. Car dies when put in gear
  168. super charge of turbo
  169. Rear Brake Lights in Spoiler All Out
  170. Borrowing one of your V8's for a conversion
  171. 3rd gen, want to make it look like a 2nd or 1st gen
  172. 1984 lg4 cam swap
  173. Msd 6al
  174. 3rd gen stock items
  175. Is it possible to put an LS6 in a 3rd Gen?
  176. help with power door locks
  177. Best camshaft without tuning..
  178. Shifter Assembly...
  179. Oil & Temp Gauge Dont Werk
  180. What should I get 3rd Gen or 4th Gen?
  181. best shifter for a T5?
  182. converting to a roller
  183. the 82 Pace in to the Garage
  184. difference in sound from rod knock and detonation?
  185. Movies IROCs have been in?
  186. What would you do?
  187. is this true?
  188. torque converter
  189. Does anybody know the average gas mileage for a 305 (H)?
  190. Somebody Buy This Now
  191. Can you put Vortech heads on a 305?
  192. IAC Sticking?
  193. broken transmission mount ?????????
  194. How to drop tenths....fast and easy.
  195. Help!!!car Wont Start
  196. tranny problems please help
  197. My turbo 3rd gen to look at...Forsale also
  198. What is the difference between ECM's with AXKW and AXKT?
  199. What should the stock oil gauge read at idle?
  200. Noise from under the hood
  201. Need opinions ASAP!!
  202. kill!!!
  203. Odd, gauge reads 10v, voltmeter reads 13
  204. HELP!!! Holley Stealth Ram Questions!!!
  205. Idle drops when in gear and stopped
  206. Stumbling In D
  207. Need Exhaust Ideas...
  208. Is it possible? True duel exhaust?
  209. Which cam on '83 305?
  210. 1985 IROC for $500.00
  211. Wells MAF ?
  212. Alternate ways to hold up hatch
  213. congrats to roy!
  214. What type of oil?
  215. anyone have pics of a 92 bird interior
  216. Brake noise - videos
  217. Which Torque Converter?
  218. Somebody Hit My Car!!!
  219. whats a 305 bird run??
  220. question about leavin in computer
  221. Taking Out Shift Kit
  222. no speedometer
  223. AFPR going in, question about fuel pressure
  224. 4th gen to 3rd gen radio swap
  225. I PROMISED!!! true dual pics
  226. 88 Iroc Convertible Detuned????
  227. FIREBIRD RADIO POD, ALL THE SAME??
  228. New Question on my 87 gta
  229. Check this out!
  230. Crankshaft Problems
  231. Might be getting an LT1!!!
  232. lets see whos lighter the Firebird or Camaro
  233. 2000 s-10 wheel offset
  234. Car Shut Off And Wont Start!!!
  235. roller lifters from summit in lg4
  236. Put on new carb = OMG
  237. I need a door hinge
  238. Fan will not come on and overheating
  239. Is speed density worth it?
  240. 14.8X on stock LB9(almost)
  241. Can you get paint codes from the VIN?
  242. T5 to T56 swap in an 87 IROC
  243. Removing Shifter assembly
  244. help with Torque Arm
  245. should I put a cam in...
  246. what spare tire?
  247. Ignition Upgrade
  248. GMMG exhaust anyone?
  249. '84 v8 305 5 spd
  250. Trans-Go shift kit, StageII anyone?
