- Where can I get a carsound/magnaflow cat???
- Replacing steering column, questions...
- Pass Key Ii......
- power brake booster
- What other cars use same rear end as 1983?
- Idle problems!!
- idle problems
- msd ignition ? on 92 tbi
- Beretta bumper on an Iroc ???
- fuel gauge issues, help
- front wheels hitting inner guards
- Grand Caravan
- removing alternator
- This is why i hate gm HIGH TECH MAG
- Any one place a lt1 cam in a early flat tappet block.
- Smokin on start up.
- 305 tpi to 350 tpi swap
- how do i bleed the brakes?
- Rear Spacers for 4th Gen Rims???
- Fitting Zr1's on a 3rd gen...3 questions??
- 2.8 liter/5 speed guys,need clutch opinions
- How much horsepower???
- L98 Underrated?
- Taking door panels apart
- Update
- t5/wc ?'s
- LT1 intake swap maybe?
- Problems when starting up
- Interesting analysis of my car smoking when starting up
- wiring/ignition problem
- 84 Clutch Slave alternatives?
- Tpi?
- Vibration at 3500 rpm
- 305 smog pump removal
- storage for winter
- Is this cam too big
- A/C and SMOG pump DELETE PULLEYS
- Brake vacume...etc
- TPI TA having trouble starting
- Ecm Grounds/ignition Switch
- LT4 hotcam in 305 TPI
- free 5.0 TPI long block Dallas area
- Does anyone know about the Secondary Air Injection bypass valve??
- V6 - V8 Swap. Listen Up Boys
- daily burnout
- 396 out of an L98?
- 18 or 20" Irocs
- What year did third gens switch to R-134a?
- Deciding on an engine combo, needs power estimates....
- Changing out differential for earlier 3rd Gen disc brake rear
- Discs on Drum 10-bolt
- gauges
- Backfiring
- Cleaning up the Engine Bay
- Oil In Throttle Body And Plenum ???
- Stupid Question
- Dyno Tuneing 1 results
- WOW, talk about a better idle
- Speed Sensor Hell
- temperature sensor wtf
- lod slam noise
- trying to pick up free HP will this work???
- right cooling fan always on.
- Readjusting Shift Points and Tach
- Can anyone help with a 1983 Caprice?
- 89 305 vortech
- Shocks/Struts ???
- Antenna Motor
- engine swap questions???
- '89 IROC backend higher than '92 RS> Spring Rates?
- 1990 irocz 305 ci
- Comparison and Opinion Time...
- Break Fluid Leak
- Whats the best...
- Energy Suspenion HyperFlex Kit
- Beefing up the 10-bolt
- Tps Adjustment and picking up some extra throttle
- iroc-z model
- How can you find out what size swaybar is in a 3'rd gen.
- Can forged pistons be milled to lower compression?
- Ticking?
- Just bought a car, differential died 8 hrs later
- Getting Paint Of The Front Bumper!
- 2.73 Disc Posi Rear
- computer codes
- RE:LT1 4th Gen VS L98 3rd Gen
- rev problem
- rev problem
- Will 4th gen carrier work in a 3rd gen car?
- Electrical Problem>>Parking lights
- Small yellow light under heater vents??
- Hatch Motor ???
- Rear Gear--> Speedo
- My Car wont start
- 305 heads vs 350 heads
- can i use LT1 rods?
- what motor mounts for my 1986 LT1 swap?
- How much of a gain?
- Design full EFI system for my carbed race motor
- Spark Plug decision
- junkyard trip
- VSS and buffer box????????
- Still having an alternator prob..Help~!~
- driver side mirror
- 355 engine question!?!?!?!?!
- Which one
- i need help badddddddd
- 350 Question
- where to buy accel shorty plugs?
- I need to rotate my tires, I have diffrent sizes front &rear how should I do it?
- Throttle sticks, only when car on
- Front panels missaligned.
- Crazy image request for you 3rd Gen guys...
- Do 4th gen seats bolt right up on a 3rd gen?
- 12's or out it comes!
- Any way to put ground effects or a different front lip on a 1986 V6 camaro??
- 6spd swap in progress! Questions inside
- what timing set
- wont start with est bypass connected?!?
- Dyno Tuneing 2 completed
- bent pushrods
- Keyless Entry car owners - inside!
- What's up with my idle?
- A/C delete Pulley
- Overheating Issue
- It keeps stalling...some help...
- can't get steering wheel off
- 383 and t56
- Idle Problems
- Advice on Speed density car
- Supercharger Problem
- what do LCA relocation brakets do?
- Track results with 150 shot/ET streets/Converter Lockup.
- How to tell if i have a drop or not
- headed to the track mid to high 13's
- TPI Heads???
- Spark plug example with 3000 miles
- heading to englishtown for fbody meet
- Good websites to buy 350 TPI Parts?
- LTI block vs L98 block
- balance a 383?
- Changing Alternator Pulley
- To much for a 2 bolt?
- Fogging windows
- Top engine cleaner directions
- Score
- Autoxray??????
- Where Can I Buy a Y- PIPE ????
- oil???
- Exhaust manifold needed for 305 Tbi
- Need your help chosing exhaust bros!
- Shifter Knob Clip
- Is it possible to change my 4-speed automatic to a 6-speed automatic
- M.A.S. color coded wire diagram
- no check engine light
- numbers on intake ?
- Signs Of Fuel Pump Goin Out?
- 305TPI Heads Vs. 350TPI Heads Vs. Vette 350TPI Heads???
- Hlloey Stealth Ram Questions
- dual snorkel/ open element question
- HP/TQ Gain with L98 Vette Heads?
- 2.73's to 3.73's
- interior
- Is there a way to take the free play out of the steering wheel?
- Converting to Fuel Injection
- TPI stumble at WOT
- dimmer switch
- Aftermarket lower intake?
- 700r4 Transmission
- Code 43 Question
- Stalling story...part II
- Good exhaust system?
- LT1 Swaped!
- Guys with holley 4barrels + 305
- why were early third gens so much weaker then later third gens?
- Header clearance from steering........
- 4 Quarts of Oil in a 350 ??
- Fog Lights??
- Dying up top
- Should i use unleaded gas or super unleaded gas for my 83 berlinetta v8?
- tuned port
- to stroke or not to stroke
- Track Times with L31 350 project
- Induction
- 4th gen rear in a 3rd gen?
- oil pressure
- Fuel pump?
- What happens if I don't plug the header where the air pump vavle is suppose to be?
- my pictures and times for all 3rd gen message board
- Which Ignition Coil Should I Get?
- TPI to Carb swap?
- Good intake for 87 Z28 w/ LG4
- Took the Feeble 305 to the Dyno today! 262.2 RWHP
- Open Element Questions
- TPS voltage
- Too cold a spark plug?
- who wants to play name that sound
- AC fan motor stopped
- Fuel Delivery Problem (Pressure Loss WOT)
- how much can a t-5 handle?
- I can smell gas...
- The choke does not want to kick off? Car wants to idle high? any ideas
- New best for vortec headed 350
- Parking Brake Cables Part #?
- want 275/40 R17 tires..
- Need help from carbed guys
- Carburator for '86 Z28?
- reverse lights out?
- Crystal Lens Headlights
- Dashboard Problem... WTF
- Bolt-In SFC's?
- Need to find a dyno
- WOT=stall, what gives
- Has the sun gotten to my paint?
- Taking out the speed limiter
- 110mph gage cluster
- EGR. Whats it do?
- question
- post times...Steve10358
- Distributor Question
- Th200c To Th700r4
- Speedometer acting whack
- Fuel Pump Question
- Carbed Z28, what will she run?
- code 33 and 36
- vortec heads and intake on 383
- How much stronger are the 9 bolt rears?
- tpi intake manifold
- Floor mats - someone show me theirs?
- Manifold Air Temprature relocating kit
- Any info about an '83 crossfire engine?
- T-tops...what is the difference between latch and pin style??
- Holley Carb probs please help!
- Some pics of my car
- Does anybody have info about a '83 crossfire engine?
- Need your opinion
- 1989 Idle problem
- future of my iroc-z
- Transmission Question?
- engine swap for a 350 from a 2.8l v6
- A few pics of the Formy
- vette intake manifold on 86 tpi
- IAT sensor
- Whats the better hood? A Cowl Induction or a Ram Hood? Or is there something else?
- Question
- How Many Sensors?
- Name That Problem
- real 1le??????
- help w/ building a good TPI motor
- 3rd gen 5.7 vs LS1/LT1
