- fans not coming on?
- Need help figuring this out!!!
- Exhuast scraping noise
- Anyone know a where I can buy a Lexan windsheild for my 3rd gen?
- Positive Traction Differential
- What is this? (found in the door)
- I know its not a supercharger, but....
- tranny acting funny? not completly sure...
- Just won Black Leather interior on Ebay.......
- carberated on 3rd gen?
- Rear end....
- timing..pinging ??
- What CC head? and help me decide on new parts!
- Any one Wanna Buy An IROC-Z?
- Free Mods for a 1990 IROC-Z 5.7
- 2000 vette T56 Direct Swap???
- figuring out future plans.
- 92 Corvette 6speed in my car?
- Torque Arm Mount (T56 Swap)
- Check oil light coming on
- Anyone running a roots blower in their third gen???
- Question about slicks...
- Iroc-ss
- Recommended tairpressure?
- LCA bolt size?
- What is this one worth
- Corvette Seats?
- Vette servo
- cam info
- What's the truth about headers & free flow exhaust ?
- Shocks and struts?
- holley stealth ram?
- electric hatch
- 1987 white iroc-z for sale
- Radiator Flush?
- Carbererated idle adjust???
- OMAHA PICTURES-needs 82-85 for commercial shoot asap in Los Angeles
- Cylinder Heads !
- What is the best intake?
- took care of college, now I'm back..
- Pics of my car
- 160 or 180 thermostat?
- Where to start?
- LT1 Cam Specs
- Help please..I got spray paint on the console of my 92, can I use paint thinner..
- Need part #
- Question
- Injector issues
- 2 relatively easy questions
- Automatic to Manual transmission switch
- when changing ops
- 383 stoker for an 86 camaro
- HELP!!!!!! failed emisions very badly!!!
- FYI, Vortecs + Edl Performer + carb = Don't clear stock hood.
- Gas smell and Tach Problem...need help!
- C.a.i.
- Bad IAC?!? How can I tell?
- Fuel Pump Just Went!
- F-body Engines
- trim panel fasteners---hatchback area
- New steering wheel...air bag ??
- Leak
- Sticking EGR?
- Getting a little further with the window problems
- corvette to camaro driveshaft??
- 350 swap...my fuel pump has no power...
- 305 to 350 on CFI Z28
- k-member swap
- 1981 berlinetta
- exhaust stink
- somebody gimme sum info
- ls1 spindles on 3rd gen?
- Differences between LT1 and tuned port throttle bodies?
- Which engine would be better?
- Rain is not my friend
- miniram owners...
- Tires
- heater core
- Which Shift Kit Should I Get?
- jack up the back
- HELP EGR?, TPS? Check engine light on
- need some tech help
- Whats the first thing you would do...
- Buying second 3rd gen! Appearance questions, LS1/M6 swap questions
- Im out of ideas...please help...runs rough/engine backfire
- Rear shocks-upper bolt
- Another Rear End Question...
- HELP....buyin 82 berlinetta and i need some help!!
- Upgrading rear brakes
- Wheres a good place to get a turbo 350/400
- yeah so
- Fuel filter replacement
- is this posible???
- oops. hehe
- cam and intake help
- idle problem....
- Magnaflow on a 3rd gen...anyone?
- Fuel filter change - mess
- whats up!!! new to the board...
- Fluids
- 305 TBI to 350 TPI
- Pull down latch mechanism - Help!!!
- Torsen?
- Need help with hotcam kit ASAP please!!!!
- Puncutured the Radiator
- What is the best way to repair holes left after spoiler remover?
- suspension whats the best?
- headers, i hate these post too
- Other than the stroker crank what do I need?
- what do you think?
- Smog-legal question
- Emergency brake problem!
- Starting problems now
- small blocks interchangeable on the outside
- Hey everyone, new here
- engine stalling
- factory rim/wheel paint
- billet grille for 3rd gen?
- Heeeeellllppppp!!!!!
- Anyone with a Megashifter
- 700r4 Dimensions?
- Questions About My '90 IROC-Z...
- something's up with the car...
- lowering
- headlights
- How much should I offer for this tranny
- How to remove the seat belts
- Quesion about a 87 IROC
- which is easier?
- how to find cam specs...
- Interior trim help please.......
- 383 hp numbers ?
- Headlight conversion
- Kid from school bought an IROC...
- Ignition question...
- Best mods to start out with
- rear defroster
- Good exhaust combo?
- My car is jacked??
- 3rd gen for sale locally
- B4C Car?
- Vortec 350 swap
- Dyno Run
- strange bogging
- help me clean her up
- Setting the timing.
- transmission swaps
- 305 tpi to 350 tpi ?
- Going to carb
- Is there a fuse for cruise control?
- AFR 195 heads...what do you think of them?
- would anyone track it...
- It's track time!
- Corvette Rims fitting 1991 RS
- Engine knock after changing to open element air filter
- 4th gen to 3rd gen wheels
- electric exhaust cut out
- about to embark on repair for 1st time,need pointers
- PCMforless
- cutout question
- L69 to 400SB swap
- 85 l98 300hp ????
- Injectors and fuel pressure
- block learn numbers?
- Cost of machine worK
- Does anyone need this?
- 305 TPI into 78 truck
- 12 bolt into a 90 iroc ?
- turbo 350 swap
- Hedman Long Tube Spark Plug Problems
- Fuel Injection Questions
- door slam
- Found New Block Numbers
- What brand of Tires do you guys drive ?
- Anyone running the 84-92 Borla system?
- beep beep-horn doesnt work
- What kind of engine...
- Suggestions for a new timing chain
- think about becoming lordmetalz28-gta
- i need help with a big decision
- Transmission Question...
- Blue Smoke at Start
- Cigarette Lighter
- Fuel Filter???
- Stock TPI = 4500 Holley SR = ?????
- Odd "ticking" noise at super low speed
- Fuel, I think.
- Engine Removal
- Fan switch
- *OFFICIAL* LT1 Brakes on a 9-Bolt
- LT1 4th Gen VS L98 3rd Gen
- GMMG exhaust GP anyone?
- 32lb injectors to big ?
- check out my mod plans
- I found a leak but dont know what it is!!!!!!!!!
- 350 turbo in a 3rd gen
- t-56 install
- how far could i take my 305
- MARC 85Z28 Where are you?
- berlinetta specific suspension
- Need Help!
- DJ Haf
- 5 speed must go...parts for sale
- value of TPI system from 87z28
- TBI to Carb
- how do i change the fuel pump in '87 V6
- Wanted! Info on porting TPI System
- really pesky idle misfire
- Installing Power Steering Pump Pulley?
- What is the piston ring land?
- What intake should i get????
- Wheels....and pictures
- have some more for you
- hot start problem
- my car is stalling out...
- hood pins only?
- Seat Belt
- leave the 305 tpi alone
- 86 Camaro - 26 spline rear?
- How about this?
- Synthetic Oil
- Is this a bunch of Bull SH*T ??
- What Y'all Think?
- dissapointed with dyno readings :(
- Good Prices?
- Stupid Question
- You wanna LS1 swao in your 3rd?
- motor building questions
- License Plate Light
- How Much Do Trannys Run For?
- code 36 and 44.. help
- Upgrading rear-end
- 92 B4C and 1LE package?
- Water Pump Cost?
- purchased new mod anybody familiar?
- paint codes
- Its got me thinking
- edelbrock headers
- 1984 305 longtube headers with emission fittings???
- People with aftermarket seats-inside-
- misfire please help
- TPI experts inside
- Home made SFC´s ???
- Is this cam overkill in a 85 l98
- Going back and forth..sell or keep..KEEP, but need advice!
- strange camaro/ fuel pump woes
- Gutting Cat???
- Just installed new TPS
- need history help!
- Overheating?
