3rd Gen / L98 Engine Tech
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
  1. Just Broke my Fuel Line to the Filter....
  2. LT1 cams
  3. LS1 transplant
  4. Please HELP! Distributor won't go back in correctly...
  5. Anyone who has had their chip reprogrammed...
  6. Clunking noise
  7. STROKER question
  8. vapor lock???
  9. tranny leak..
  10. is a 91 Firebird V6 worth $3500
  11. Gas in Oil, Is my Pan Gasket Dead?
  12. fuel inj. cleaner
  13. anyone here use the G2 twisted wedge heads?
  14. Boyd Coddington Timeless-2's.......
  15. Power handling question
  16. LT1 Radiator ?
  17. smashed
  18. 4th Gen Seats in a 3rd Gen?
  19. 84 camaro
  20. Wish me Luck, LT1 cam goes in tomorrow~!
  21. Need 3rd Gen Help?? Buying soon!!
  22. I need some interior parts!
  23. Will 4th gen wheels fit 92 RS???
  24. this seems odd
  25. 25th Aniversary Specs
  26. Who has best bang for the buck performance chip?
  27. Need Better Brakes
  28. need some parts
  29. new cam f*#*ed up my idle
  30. rear brake rotors
  31. Rear Compartment Cargo Cover
  32. Gearing WIth T-56 Tranny IN 3rd Gen car?????
  33. I'm having a problem with my car
  34. how to overcome? (kinda long)
  35. Need help with shock?
  36. 86 T/A $3500?
  37. Need color advice - red IROC codes and shades
  38. antifreeze in floorboard...possible causes?
  39. 92RS 305/TBI What to do for performance
  40. Which Rocker Arms for Stock?
  41. Starting problems...
  42. 700r4.com Tranny Arrives :)
  43. HELP !!!!
  44. differance between 9 and 10 bolt
  45. DO I NEED A CUSTOM CHIP CAUSE OF MY MODS?
  46. Brake problem?? or is it normal??
  47. cool fuel ????
  48. P295/50R15 on 15x10 rims
  49. disk break locking up warning
  50. Close Ratio Steering Box???
  51. Quick gears question
  52. how rare are 85 Irocs with the 305 HO (l69)???
  53. Fuel smell
  54. Need help fast!!
  55. Custom, CNC machined, billet Alum strut mounts available
  56. 350 blocks
  57. rear wheelhouse panels
  58. Sunroof Tech......Gimme your thoughts
  59. header pipes
  60. Factory Black Lug Nuts
  61. POSI REAR END
  62. valve adjustment. HELP!!!!
  63. Smoke show vids...
  64. Red Button by my fuse box
  65. rear-end
  66. check engine light
  67. Tach needle sticking...what can/should I do?
  68. Clunk Noise from Rear
  69. need more power
  70. oil pan = take motor out?
  71. Whoo Hoo my car is N/A and now it sounds like i got a blower
  72. surges
  73. Automatic Trunk Latch Problem.
  74. sub frame connectors
  75. overheating problem with in town driving
  76. Fan problems
  77. Need to make up 1/2 second, all on motor
  78. Need help picking out a 350 crate
  79. Wheel fitment ?
  80. Dual Exhaust
  81. Running rich...
  82. oil leak cant find it!
  83. speedo recalibration
  84. Noise from Rear of Car
  85. When I turn the wheel it chokes....
  86. new end links will not fit!?!?
  87. Broken thermostat bolt stuck in head
  88. blinker problem
  89. 82 tranny options
  90. paging: 1FastFormula
  91. END LINK PROBLEM...
  92. HELP!!!! car won't start!
  93. WOW, crappy track times
  94. about shift kit/trans.
  95. AFTERMARKET CATALOGES !!!!!
  96. EGR
  97. Floor Pan
  98. Anyone that has bought new fenders please look within
  99. Check engine light question....
  100. Low vacuum due to low LSA????
  101. Tuning help, track times fell off..
  102. air condition????
  103. Track bar
  104. What were the engines options for an `86 Z28
  105. ANyone in alberta?
  106. Engine build up question
  107. hmmmmmmmmm
  108. SMOKE ON COLD START UP ON A 350 TPI
  109. 91 Z-28 Opinions
  110. Anyone else stuck in Utah? I need to some local help!
  111. Need help w/ choosing exhaust system
  112. What is required????
  113. Exhaust Man. Gasket blowing like a hooker
  114. Stock Drivetrain worries
  115. cowl firebird hood
  116. Low Buck - Performance Heads?
  117. Looking for some dyno2000 info please
  118. Rear end
  119. hood
  120. More on my Sunroof expedition......
  121. MORE PROBLEMS!
  122. got some new pictures
  123. Start Up problem?? please help
  124. Big Block in 3rd gen?
  125. Finally selling my RS need to know what to ask for it.
  126. cold start valve
  127. I need a F-body!!!!!!!!
  128. continued problems with temp.
  129. A few thirdgen questions...............
  130. black smoke?
  131. 2.5 radiator
  132. who makes front lower control arms for 3rd gens?
  133. head comparison
  134. for sale
  135. Tranny and clutch issues
  136. Traction Problems
  137. flamethrower????????
  138. Gutting my Cat?
  139. How to tell it is a 4 bolt main?
  140. ALL PROBLEM SOLVERS PLEASE READ
  141. stock exhaust measurements?
  142. Someone tell me this swaybar can be fixed...
  143. rearend tech.
  144. Opinions on this crate?
  145. starter????
  146. Speed Limiter??? How can I get rid of it?>??
  147. 305 to 350 swap!!! What do I need to change/adjust???
  148. MAF to MAP?
  149. B&M convertor F/S
  150. Building Sub-frame connectors
  151. Can a Carbed 84 305 H.O be a 14 sec ride
  152. How much HP?
  153. I THINK ITS THE ECM!
  154. Smallblock 400? Cost? What do you think of my planned set up?
  155. 383 charger to firebird???
  156. 1982 Twin Turbo Camaros
  157. I've modded the hell out of my 305TPI, Any suggestions or helpful hints?
  158. amps drop car doesnt run!
  159. Need some Help
  160. Stupid question but I need an answer !
  161. 4th Gen SLP Loudmouth
  162. what mods for putting big block in a third gen?
  163. Anyone ever put a LT1 cam in your L98?
  164. what to get factory or aftermarket strutmount plate
  165. Clutch pedals
  166. Rear wheel backspacing?
  167. Shift Kit
  168. Electronic Spark Control
  169. Motor Mounts
  170. Replacing PCV and hoses...
  171. BRakes Pulling HArd RIght! SCary **** Guys HElp *
  172. Air conditioner(can't spell) question
  173. T-56 trans into 3rd gen can only handle 450 Ft. LBS TOrque??? I Need more
  174. TIMING WTF?
  175. Rattle In Dash
  176. looking for performance
  177. Suspension
  178. HELP --Crankshaft frozen???
  179. Suspension: What would u do?
  180. Tranny mount?
  181. Drivetrain issues
  182. Testing new sig.
  183. coil springs
  184. can some of you guys, take a look at this for me
  185. 90 RS - Source for wheel center caps ??
  186. Subframes...
  187. wire fanatics
  188. Rough idle
  189. straight pipes.......YUCK plz read
  190. pistons
  191. Anyone have any suggestions for Torque arms?
  192. auto cut outs????????
  193. ? 4,500 rpms max without SES light on
  194. Found a hood.... rare?
  195. Tuning fuel pressure from O2 readings?
  196. Gears?
  197. flowmaster or hooker?
  198. how much horsepower ????
  199. Subframe conectors ??
  200. Questions about 350..
  201. where to buy auto cut outs?
  202. 350 Fan Switch in 305
  203. Need Help: all u 3rd gen. proud owners..
  204. pistons
  205. iroc mod
  206. Torque Arm Placement ON FORD 9 INCH???
  207. I Need a Fuel Injector Clip
  208. MASS AIR FLO SENSOR
  209. AFPR vacuum line!!!
  210. Drilling into the intake manifold
  211. Crickets On The Clutch Pedal?
  212. chips?
  213. Nitrous Results inside!! (long)
  214. Question for you guys...
  215. Which shifter should I get?
  216. 2.8L problems...
  217. How many miles before it's too much?
  218. where to get sway bar bushings??
  219. 350 implant
  220. Distributer shot?
  221. Want to buy a 1988 Trans Am GTA with a 305...Have a question
  222. Alternates toTPIS Mini-Ram???
  223. Harness Bar
  224. Burned Valve?
  225. HELP! Intake and Runners.................
  226. Where 2 Buy Spark Plug Wires for 3rd Gen??
  227. Block heater stuck in block, what now???
  228. How do you test a distributer?
  229. tranny compatible?
  230. Where is the computer located on a 1988 Trans Am?
  231. Distributor problems
  232. O.K. no LT1 cam, what cams are you running.
  233. 2.8 t0 350 swap
  234. nos want to know
  235. thirdgen.org???
  236. Steve10358 or anyone else who can help I have a question...
  237. V8 Conversion
  238. 2 1/2 or 4" third gens cowl hoods
  239. engine ID
  240. My 2.8 runs hot & blew a rad hose :(
  241. 3RD. GEN. IGNITION
  242. Carbed 305 to Carbed 350
  243. t5 hurst shifter stops :
  244. I have a question about my 3rd Gen GTA
  245. How much 134A in a '85 Camaro?
  246. Will this 350 replace my 305 Carbed? 86 Z28
  247. 86 Z
  248. Any Suggestion?
  249. 2002 35th Anniversary Camaro SS Wheels
  250. Lubed your... HEADLIGHT DIMMER SWITCH lately ?!?
