3rd Gen / L98 Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
  1. tuned port changed to carburetor ??
  2. Holley Stealth Ram and SLP runners
  3. milled/ported stock throttle body? 48-52mm ??
  4. is my mechanic on acid?
  5. LS1 aluminum driveshaft?
  6. 52mm Holley TPI TB-noise?
  7. Exhaust Suggestions - Muffler Rusted Off
  8. Where can i get the Iroc-z center
  9. cross drilled rotor swap
  10. jet pulleys
  11. Engine Temp.
  12. Motor dies when trying to get right on it....
  13. What do I need to make an LT1 work for my '88
  14. Loose door handles
  15. Difference between...
  16. a v6 700r4 tq. converter on a v8 700r4?
  17. Car Stalling
  18. Car Stalling
  19. Swapping power steering to manual?
  20. Transmission fluid change
  21. Mobil 1 Decal & Stuff
  22. Transmission problem, what do you think?
  23. Headlight problem
  24. seems like car is running rich
  25. Hesitates when gas hit really fast
  26. Interelated Problems --> Crappy Preformance help
  27. Starting problem.
  28. broken bolt rant
  29. Has anyone replaced their distributor???
  30. air foil install
  31. hp/tq # 85 Trans am
  32. Auto To T-5 swap
  33. lowering springs
  34. Forced Induction
  35. speed limiter?
  36. Y-pipe 350 single 3" cat
  37. how much to get 300 rwhp
  38. Wow, smell of gas BAD
  39. window motor
  40. inline fuel pumps
  41. New heads
  42. Is my hypertech chip the problem??
  43. My IROC-Z
  44. Will this exhaust affect my setup? (picīs)
  45. tpi wiring harness
  46. Reasons for detonation
  47. is it possible to use TPI intake on a vortec heads?
  48. Building up the 305...question about cams
  49. Part number for charcoal canister
  50. Darn Hatch Motor!
  51. There is a hole in my exhaust manifold
  52. Scat vs. Eagle
  53. A few motor questions...Please Help...
  54. installing ram air boxes
  55. Headlight Dimmer Switch
  56. Fuel Pressure Regulator
  57. custom guages
  58. Car not charging properly?
  59. 82-84 f-bod with an AMC 390 and 4spd?
  60. LOUD NOISE under the car ... : (
  61. gas gauge problem
  62. 3.73 4.11 ??? t5 t56 ?? which one?
  63. t56 in a 1990 camaro? will it fit?
  64. Need Pics of 91-92 Camaro with Cragar S/S Rims
  65. what's the h.p/trq. on 91-92 camaros
  66. Shift Kit?
  67. What Kinda Brakes You Guys Runnnin?
  68. RPM's in 1st
  69. T56 into a 1990 350 automatic ???
  70. Iroc?
  71. Brake Lights
  72. shift kit installation?
  73. For those who want a Stealth Ram
  74. Do I have a tranny problem?
  75. Carb size in 85 5.0?
  76. EGR Valve
  77. fuel injectors???
  78. drive shaft length
  79. how do I change valve springs? HELP!
  80. how do i install these pulleys
  81. Tranny scaring me.
  82. drivers side door mirror removal and other q's
  83. lowering pros/cons
  84. Are the runners Aluminum or iron
  85. Which gears are considered "performance"?
  86. Using a hammer on your starter?
  87. Rear End
  88. Sick and wrong
  89. Dart heads and edelbrook manifold
  90. how much hp does it have 205 or 230.
  91. lt1 short block (ebay)
  92. SGI-5 ??? t-56?
  93. Hookers header..home made y-pipe ??
  94. A/C removal !! ??
  95. BBK throttle body 52mm or 58mm?
  96. More input on poor idle please
  97. long start up
  98. T-5 Shift Pin?
  99. Torque Specs for T56 Install
  100. Valve Seals are Toast!
  101. 305's Internally Balanced?
  102. What size swaybar in my '92?
  103. Auto to T-56
  104. M.A.F. Connectors.
  105. Headers?
  106. Engine Cleaner
  107. Harness swap Q's......
  108. Significance of a Torque Arm
  109. Cam install
  110. vibrations
  111. 350+ stroker motor cams
  112. Harness swap Q's.......
  113. TBI injector ratings
  114. 350 TPI TRACK TIMES?? stock
  115. Smoking when started
  116. Difference between 350 and 305 computer?
  117. where to find 9 bolt rear axle
  118. A ??? for all the 3rd gen people
  119. Needed PICS of SLP 2OTL
  120. 3rd Gen guage cluster swap
  121. has anyone heard of this body kit???
  122. How reliable is your third gen?
  123. cam basics
  124. 4 inch Mufflex
  125. plenum
  126. Speedo recalibration
  127. fuel injector identification??
  128. Oil weight
  129. unplug alternator?? helps times?
  130. 2.8 to 305 swap ...
  131. Code 32 pissing me off
  132. 3" exhaust = 3" Y-pipe ???
  133. Temp. gauge goes to 240!! but doesn't overheat??
  134. Trunk no open
  135. FUEL INJECTORS-need help
  136. smog pump emissions crap WTF
  137. T56 is Here!
  138. How much for a T5?
  139. ANYONE with a 350 TPI
  140. ANYONE with a 305 tpi !!
  141. TPI vs MiniRam vs....
  142. How much trunk space in the 90-92s?
  143. Is this really necessary???
  144. My new hatch motor won't install!
  145. where can i find a LT1 cam for my 91 305 TPI
  146. A/C Heat problems.. only defroster vent is working ??
  147. Black plastic box under hood?? smog pump??
  148. 5.7 IROC-Z/GTA Question
  149. gas life
  150. How much can my t-tops hold
  151. help me pick my mods
  152. engine mount swap...
  153. Are there fuses for fuel injectors??
  154. Park safety switch wires
  155. best cam choice
  156. clear head light conversion
  157. Monte Carlo swap questons
  158. 82 - 84 Camaro Owners: Where Shieldshield Spray Nozzle is located
  159. Do I have 9 bolt? I'm getting diff RPO code meanings...
  160. Dual Electric Fans ??
  161. 98 Z28 dies on highway........
  162. What manual do you recommend?
  163. Porting and Polishing Plenum ???
  164. Normal Temp for a 350 TPI ?
  165. could it be a timing???
  166. Motor Ideas
  167. Throttle Body
  168. Knock, Knock
  169. Plenum ???
  170. sub frame connectors
  171. dual exhaust question
  172. Thermostat size???
  173. What to do to a 350?
  174. Which one is better
  175. Which is better
  176. TBI TB coolant bypass
  177. Need advice on what to do with some great 3rd gen parts
  178. Junkyard hunting...T56s....
  179. v-8 to v-8 swap
  180. 700-R4 Kickdown
  181. Ford fuel injectors into a Chevy ??
  182. T56 swap question.
  183. help! 85 iroc 305
  184. What exhaust came on these
  185. TPIS ZZ9 cam, need opinions
  186. How do dealers charge?
  187. No Vacum
  188. Quiet Muffler Selection
  189. Air Damn?? Custom air boxes ??
  190. transmission explosion
  191. How to tell powerbands of heads and cams?
  192. putting the iroc-z sideways
  193. Spark Plugs
  194. i never knew there was a kit for this
  195. Parts car for sale
  196. Resistance specs for 91RS coolant temp gauge?
  197. Help with paint quick
  198. 305 fuel pump to 350 swap carbed
  199. 700R4 Weird Problem
  200. 700R4 and 4L60E weight
  201. exhaust pipe restriction
  202. Another Exhaust Question
  203. Nitrous
  204. i dislike my underdrive pulleys
  205. 700107 Centerfoce....how is it diff?
  206. After sitting for 5 years, heres the problems
  207. T56 For Sale!
  208. EGR question with a ZZ4 350 in a 3rd gen
  209. Shipping A Car?
  210. 3rd gen roll bar on a convertible
  211. 5speed swap
  212. What kind of engine oil goes itno a 1988 GTA?
  213. 2.8 swap to 350
  214. anyone have a magnaflow cat-back
  215. MSD 6A Box
  216. Transmission problems
  217. Real Big Big block question..
  218. 2.8 to 3.4 swap
  219. Hp numbers for a modded 305
  220. Why manifolds not headers?
  221. Walbro Fuel Pressure Regulator
  222. no dash lights tail lights or license plate lights
  223. best 350?
  224. Why are my RPMs so low?
  225. What is the brand of paint GM uses
  226. no insturment panel/tail/parking lights
  227. New Interior- need feedback
  228. Crazy Go Nuts University
  229. size of rear end
  230. adding 3.73 gears and a 700r4 shift kit
  231. Fuel pump just died, need recomendations.
  232. Estemated ET?
  233. Ok, figured out a cam, couple questions
  234. Intake Valves
  235. gears
  236. Shaved my blinkers!
  237. Throttle problem :/
  238. Shifter Knob
  239. Question about gauges and t-top holders
  240. fuel pump
  241. MAF sensor Bad?
  242. Factory Oil cooler questons
  243. vacum hose repair?
  244. used car reliability information
  245. Emissions question
  246. Adjusting my Throttle
  247. Why does everyone think that every
  248. 84 Camaro LT1 engine swap
  249. Accel Intake Runners Superram
  250. Infl Rest ?????
