- Aftermarket Gauge Cluster
- Clutch Pedal
- T-5 Labor
- help help help. windshield wipers!
- Dash lights not working INST fuse
- IROC-Z idles rough, stalls when hot
- HELP tuning issues
- Service Light
- Lights, Radio, Alarm, ALL WONT WORK!!Help
- Alternator won't charge
- Rebuild 700R4 tranny?
- 90 FB Wierd Electrical Problem
- 91 firebird 400 project help need a cam????????
- Looking at buying a 1991 3rd Gen Camaro
- Fuel Pressure
- Possible to swap gears from 87 posi 9 bolt to 89?
- =( problems
- MiniRam
- Way too much pressure/heat in gas tank
- Weather Stripping
- Understanding Lift Flow Figures
- Seatbelt problem
- Problems with exhaust detonation
- ok, so where is the coolant temperature sensor?
- Tach question
- Awesome Book!
- Exhaust
- LS1 Swap
- Early shifting problem.
- Smoking under hard acceleration...
- 82 or 83 Z28 Convertable,heard of it?
- Best place to get factory decals for 90' Formula?
- 9-bolts and slicks, any luck?
- Puzzled.....:(
- Ring and pinion carrier??
- quick steering wheel adapter question
- Need Help Desperately!!
- Where can i ?
- Vortec Intakes
- is it normal for my 700 R4 to do this
- What all bolts on from 4th gen to 3rd gen
- how tight for the oil drain plug
- Converting to r134a
- crap times at track
- !!HELP!! heater core box
- oem side markers
- oem side markers
- spicer u joint
- Turning over 350
- Removing cat
- White Smoke at Startup
- 69 ZL-1 427 in 69 base camaro with spun bearing is it worth rebuilding???????
- IROC vs. Import
- KYB Shocks
- HELP Coolant Leak
- Car will not start, Air bag??
- rebuilding an engine for my baby, suggestions?
- U joints need opinion asap!!!
- Never ending ping
- I call BS from a third gen owner...
- lowering springs
- need help with emissions
- 20" IROC Rims
- I expected somwhere in the range of 120HP and 250TQ
- Gen Differences?
- Who's in the 12's?
- Do I need charcoal canistor???
- 2.8/3.1 Rejoice
- New car...looking to modifie
- Need Help!
- Engine bogs and "whoosh" sound
- Engine Idle Will Not Stay Constant..Up and Down...Almost Stalling
- Car wouldn't go into overdrive, now it does
- Best way to ! Knock sensor
- Emissions
- 3rd Gens w/ 4th Gen COMPLETE interior
- Crossfire injection
- cross fire injection, truly crap??
- Dumb Question
- How Can I Display My RPO Codes
- Best chip burner for 93 LT1 and earlier cars is?
- borg-warner
- Cruise Control?
- Can I adjust idle speed?
- What is that big black "bulb" for under the driver's side front?
- Exhaust-oil pan rubbing
- Smog legality of engine swaps?
- Power door lock module....where is it?
- Building A Bad A$$ Motor, Let me know what you think!!!
- jet power pulley
- what to do with 383
- Can I use an LT1 starter
- Header Install
- Disadvantages of 350 TPI?
- Which bilstein shocks?
- Way to test IAC valve?
- 4th Gen Console
- does MSD 6al bypass ignition module???
- project 91 firebird400 get swapped to project91firebird409??
- Rusted undercarage??
- emissions
- driveshaft length th350 swap
- ATTN: anyone using/may use a "PowerAid" TBI spacer
- Continuing Coolant Problems
- Need new stock steering wheel
- Tranny Question
- which wheels?
- Anyone got some pictures?
- How do I make six speed trans work with my 91 speedo?
- new to polishing.
- umbrella valve seal orings
- Why does the radiator look this bad?
- What do you think of this smoke? (video)
- dead battery?
- 3.73 gears
- Bad Vibes, high speed
- Are Vortech heads compatible with pre 87 block?
- SLP runners?????
- long tubes headers???
- Name The Problem
- 1990 5 spd tranny???
- Gears question
- High RPM Grinding
- K&N vs. paper filter on near stock enigine?
- stock exhaust size??
- 87 Z28 Camaro $3500 Good Price?
- 700r4 to T-56 swap
- Anyone using remote starter solenoid????
- Th200 to Th350 swap.
- 305 tbi to 350 tpi Help!
- Ignition upgrades
- 81 malibu vs my 83z???
- Keyless entry add on
- cam swap for L98? LT1 ?LT4 hotcam???
- Hood pop problem
- Letting motor sit
- Do any of those infomercial products work?
- Can I use LT1 pulleys/brackets on a regular sbc
- I got my car painted.... problems
- Air Fuel Ratio Gauge?
- 1992 Patrol Car
- Ashtray spring??
- 3.73gearbehind a L-98 350tpi
- yet another question about 4th gen rears
- 1990 5.7 ECM computer and Intake questions..
- 1990 Camaro Air Filters/ Intake question
- thinkin about gettin the holley SR
- getting car painted,primer body work tips?
- fuel questions
- it better be
- Front Sway Bar
- LT1 third gen.
- LT1 Cam for my 3rd Gen
- Car wont start
- L98's in Vettes
- Dynoing my car this weekend
- Need help with Be Cool radiator!!!
- attempting to start winter beater
- LB9 question.
- What sequence of events when starting car?
- 305/350 solid balancer?
- I can't keep coolant in the xpantank
- Adjustable panhard bar?
- Blinker conked out
- What belt size???
- True duals possible on Z28?
- Rear defogger doesn't work
- Fastest ThirdGens?
- can I run 1LE a/c delete pulley if I have no smog pump on bracket??? Anyone know???
- TPI Swap
- how to tell if i have a 350 or 305??
- LT1 intake on a LB9
- How to polish plenum and runners
- 1993 nissan 300zx non turbo
- Diff btwn 88/89 5.7 tpi throttle bodies
- any suggestions?
- Lt1 parts swap!
- Parting out 84 Z... Inquire within...
- What is the best year for the 3rd gen?
- 1988 Camaro Ignition
- Plastic hood scoopes still available?
- AIR FOIL tell me everything you know
- Snake/ Sleepy Eye mod
- Strength of a 10-bolt?
- 3.08's too low for 6-speed?
- What 60-foots can I expect
- Intake ID help.
- SLP 2400 Stall Convertor
- ground effects
- Bay Area Dyno Day
- hesitation/miss
- spark plug reading??
- Dual intake setups
- help with info
- 87 GTA L-98350tpi 1/4 mile times.
- How to find out the gear ratio in your rear end?
- Thinking of dropping this engine in my car...What do you think?
- cruise control lever
- Need Help With T-56
- Holley stealth Ram, having installing problems, HELP!!!
- twin air filter setup, cut out the bottom of airbox ??
- 2.08/1.6'' heads, cam, TH700, gears
- roller rockers
- pic wanted
- New Engine: Advice needed
- My 305 TBI Needs Power!
- LT4 hotcam kit in L98
- difference in 86 and 87 rear ends?
- can't figure out this overheating problem
- Automatic shifter plates
- 10 second n/a 383 possible?
- Pulley Queston
- LCA moutning pic needed
- trany?
- leak from heater core outlet on radiator
- Intake leak question TPI specific
- 4th gen to 3rd gen interior swap?
- throttle body bypass?? resistor chip??
- Buddy bought a 1988 White GTA 305 5L
- Power adders for 89 350 TPI
- idling high??
- HSR going on
- Diff between 89-90-91
- throttle body bypass? resistor chip?
- voltage problems
- Hi-beams
- Stalling while stopped in drive
- Plentum Porting
- Intake ID help.
- Anyone from Corpus Christi, TX
- Improve HVAC air flow?
- For everyone that's ever experienced code 33......please read
- prop valve question for 4th gen rear
- A 9-bolt was given to me!
- Check Engine Codes
- Anyone who knows TH-350 trannys inside please.
- stock hp/trq ratings for all corvettes 82-92
- Seats from a 4th gen
- RPO codes
- 383 & TPI? advice needed
- LT1 Cam question
- switching to carb
- Stealth Ram and 91 Vette???
- 7 5/8 disc rear in 86 Iroc
- Distributor?
- Help!I cant figure this out....
- Location of the buzzer?
- Throttle Body Bypass: Brass fitting?
- super noob questions
