- tremec tko 2 vs richmond 6 speed
- ram air install need help
- fog light question
- Rear end question
- I need manual fan control?
- cam z28 question (noobish?)
- Question on Torque Converter
- might be getting rid of the 3rd gen for a 4th
- Motor and a few other questions
- DropZone Or Eibach Springs????
- Headman headers
- Help, car not putting out spark like it should.
- Synthetic trans fluid
- Sd Vs Maf
- need some help figuring out what this clunking sound is
- hit a curb going 40mph
- injector swap.
- LS1/T56 In a third gen?
- Starter
- redline fluids??
- Should I buy??
- Clunka-Chunka Tranny Again!!
- need to know rims sizes!?!?!?!?
- who wants to help me pick a wheel?
- MAP sensor?????
- Another rear end question...
- A/C question. blowing the fan fuse
- intermittent misfire... tach needle jumps
- Symptoms of cracked block.
- Anybody tried summit headers?
- 1.6 Ratio Rockers
- Sohn.net
- Differences in 91 and 92
- 350 vs 305
- foggy parking lights
- Need your opinion for new engine
- axle movement
- Idle trouble!
- 86' Iroc-z
- simple egr question
- good or bad choice
- SuperRam vs. LT1 Intake (finally)
- MPG On an 86 IROC?
- 1990 Camaro TPI 305 350 help! please : )
- 3rd gen rear chunk help!
- 1990 camaro 350 tpi
- What does blueprinted mean with built engines?
- opening up hood louvers...
- Aerodynamics of a 3rd gen
- Factory Rev limit? Lets talk about it..
- Help with strong exhaust odor
- Purchasing an 86 Z28
- New Holley Stealthram Benefits/Questions
- est. COST for 6sp conv. Vs th350
- anyone have hedman long tubes?
- A/C vent problem
- Got a T-56, question about flywheel
- Engine Swap Questions
- Help With A 350 Camaro Tpi
- LT4 HotCam
- MAF burnoff
- Iroc-z Stickers
- Help With A 1990 Camaro 350 TPI
- torque converter stall speed
- What does Liters mean?
- fuel pump not priming for hot starts.....
- Will Edelbrock performer intake work with Vortec Heads?
- How do I install Roller lifters?
- crossmember
- 700r4 13 vane pump upgrade
- 3rd gen video
- Rim Size
- 700r4 .500 boost valve
- What do I need : T56?
- My LT1 got totaled last night, now I have a T56. Help!
- L98 Aluminum headsvs Vortec Cast Iron heads
- headlight motors
- Head and Cam Combo???
- Over heating issues, I think I need a new fan.
- Wheel bearing
- 1st gear Rev HELP!!!
- hatch mortor
- Hey, PRO BUILT!!!! What happened to your web page??
- 350 Questions
- Front sway bar?
- Best way to separate Tire/Wheel
- Distributor cap and rotor ??? 89 IROC
- 1990 Iroc-z
- who has 91-92 145 mph speedometers???
- Open element air cleaner Q's
- 92, TBI, Questions...
- Top speed
- Ignition
- camber question...
- Broken center console lid
- What are the best traction boltons for an 83 Z28??
- Charcoal Canister hoses...
- What Blower for a 89 IROC
- 700r4
- running like crap after header /y-pipe install
- trunk pull down
- Is there anything i should do before or after putting a 383
- 180 degree headers
- what should I do to beef up a 700R4
- what size carb
- Is the swap worth it
- Alternative to SGI-5
- New factory carpet and back panels
- 3.08 gear
- need a rear for a 1990 camaro 3.73 posi in NJ
- any LT1 swappers??
- Decisions
- Problem with new ignition wires?
- Can I use the stock chip ......
- Fuel pump change is a PITA
- Gonna take her out to the track
- Please tell me who makes tubular kmembers!
- Rear-End Question
- Lca
- 9 bolt swap with lt1 brakes, what e-brake cables
- 10 bolt discs
- 4-cyl. Camaro
- Temp sensor ???
- LCA promlem
- selling car
- Code 33
- Car wants to lag before the power
- is it true
- Nice B4C, 3600 miles!
- 305 to 383 swap
- we got air and maybe spark
- Check for T56 in the mail
- 52mm throttle body
- What kind of intake
- New Mach 1 in Neighborhood
- Lunati or someone else???
- Cheap Easy Mods? IROC
- Swapping PBR rear disc system to 87 non pbr 9 bolt
- good or bad idea
- pictures of slp 85 to 87 cold air
- 350 to 383 streetability
- C5 front brakes on a thirdgen
- towing question
- Do I need Bigger Injectors?
- Water pump = overheating
- GMPP TBI Intake Manifold Vs Edelbrock Performer RPM?
- LT1 or Stealth Ram?
- V8 Swap into V6 Camaro
- Polishing a Stealth Ram
- How do i found out if its 5.0 or 5.7
- older z28 guy needs help
- older camaro guy needs rear help
- Stock hp for 87 Trans Am?
- pulleys and high watt stereo
- Help!!!!!
- 85 to 87 slp cia help?
- what are my options?!
- Drag Wheel/Tire setup
- Airfoil on L98
- Do slp CAI help?
- Power Window's rattle
- Ya'll post some video's , please
- H-4 headlights
- ignition timing
- She's Coming Along
- '83 Z28 clutch
- Rebuilding a 700r4
- Spend all on car, or not?
- How to get dist. rotor off??
- OK to take off my cat?
- performance chip skeptics/proof
- how to get a rusted out brake bleeder screw out?
- cable-x / vss wires...
- Audio Wiring
- Quick Alt question guys!
- Making my Z28 faster
- rebuilding a holley
- O2 problem
- Race with '87 Iroc-Z
- Good place to buy rims online for a 90 Iroc-Z
- LT1 Swap won't Start
- Running out of ideas!! :'(
- v6 to v8 problem
- WTB: Badges
- Fuel pump/pressure problem
- Ignition module need help
- Power Window Motors
- Open Top Sites
- Guage Pod For convertible
- 350 Heads vers.305 Heads ZZ4 vers. L98
- oil pressure guage
- Trunk Dont Open
- im confused...true duals
- What octane gas should I be running?
- Bmr Trak Pak?
- slugish after tranny swap
- roll cage vs sfc's
- swapping in a manual transmission into my auto 89 iroc
- ALDL and TPS problem
- MSD noise - HELP!!!!!
- motorized hatch
- Lightbulbs for 87-89 style spoiler mounted brake light???
- What do I do?!?!!?
- Brake Light & Check Engine Soon Lights
- Wheel Lock
- computer problems
- Weight of a stripped down 3rd gen? (race ready)
- taking off front bumper
- need help
- 5.0 to lt1 swap
- leak...?
- Having ALOT of trouble with vapor lock
- old heads/intake gone, new ones ready to go...but...
- SLP vers. AS&M runners
- what parts should i scoop?
- Why is my timeslip so lousy? Help needed.
- noise from #8 intake valve or???
- electric fans on 98 degree days
- what size stall should i get?
- spun on the lawn
- underdrive pulley for hp
- squealing belts
- Timing on TPI
- Low RPM miss
- Spark plugs
- 84 single fan car( fan intermittently dose not come on)
- Simple question...
- Engine swap q's
- Hey My 87 Z-28 Has A 335tpi Stroker
- strange hose unplugged
- help which cam guy's???
- rear end is shot, what are my best options?
- 700r4 Question
- where can i go to learn about rear ends?
- hood insulation
- Any '92 Z-28's in here ?
- a bunch of problems
- Where can i get a used T-56???
- Has anybody have
- How to bore a cylinder
- Reinstalling the shifter for my 1989 Firebird automatic
- rpo codes
- porting 305 heads
- why does only one fan work???
- do these track times seem right??
- anyone running different gears???
- name that part.
- 2.25" Spacers for 4th gen wheels: $100!
- Tach adjustment
- cam vs. stall
