- Removing weight, need help
- Speedometer Problem
- Free 305 long block Dallas area
- How to dissable a power antena
- 2.8 v6 to 5.7 v8 TPI (1988)
- code 54........
- Idle is very high
- Anyone know of a good site that shows how to port an intake manifold?
- Who does the best.........
- Tornado
- does anyone know if?
- Energy Suspension stuff
- Holley Throttle Body
- basic 3rd gen advice
- figureing it all out
- mini-ram/stealth ram
- best replacement for a factory t5 tranny
- Owner of GM 350 HO looking for Miniram answers
- What are the measurements on a T-Top bag???
- Wiring harness questions.
- 3rd gen HP ability?
- New Transmission
- 2 questions
- underdive pully set
- Runing hot
- Strange fuse found, what is it
- Weak shifts on 700R4 with shift kit
- 350 swap questions!
- Leaking Coolant. But from where?
- TPI Kickdown cable???
- TPI conversation to an LT1
- Will this distributor work?
- Air cleaner/assembly question
- website address for pro-built (new)
- please answer quick question on 700r4 rebuild
- just wondering about hp
- How do I beat a 94-98 Mustang GT in my TBI?
- car won't start???
- Belt on A/C Pump Going
- Gonna put my motor back together tonight. Which intake do you use?
- afpr
- 91' and 70' model blocks the same??
- model?
- Quick TBI questions
- How do I lower a third gen?
- C5 seats in a 3rd gen?
- Mint 1le
- Air cleaner?
- Offset for third gen wheels.
- need wiring diagram
- power hatch
- How much heavyer are power seats compaired to standard
- Hedman Shorty Headers - Do they drop right in?
- EGR help!!
- How do I adjust timing with a Vacuum advance HEI?
- HOW TO INSTALL A TACH on TPI (87)
- looking to dump ac and air pump
- Engine Light
- What all do I need to stick a lt1 cam in my car?
- A Very Rare Trans Am!!!!
- starter question
- Hood Louvers lifting at high speed
- high amounts of hydrocarbons
- Thinking about heads for 305
- T-Handle FINALLY came in!
- Perfect 3rd Gen?
- Single-best mod to a third gen
- AFPR ?s
- What car is this?
- my seats?!?!?
- 400 sbc strength?
- Where do I buy a 1984 5.0 H.O. Dual snorkel air cleaner?
- What heads are available for the TBI?
- First Gear Kick-down and turn signal question...
- anyone put 4th gen carpet in a 3rd gen?
- Seat Brackets
- wierd accleration at highspeeds
- SLP Intake Runners & Poor Performance
- tpi
- carb
- tpi
- transmission
- Wheels and Tire Issue
- 91 Z28 intake gaskets
- turbo
- trans cooler install
- battery relocation/ground effects problem HELP!
- starter or solenoid?
- WIPERS: what's busted?
- Suspension
- Computer Chip key
- anyone need an airbag?
- So what is next?
- I need a 3rd gen rear end.
- Grinding (metal on metal) during turning?
- 91-92 ground effects
- stealth ram pics
- stock heads
- TPI pcv question...
- L98 dies in the morning....
- what flywheel does it have?
- what size tranny cooler do I get??
- 90 Iroc Mis At Idile
- K&N open air element
- A/C doesn't work! help!
- Steering play/looseness
- Port/Polish TB?
- Iroc-Z wheels
- She's alive!!
- Polish wheels on my RS?
- LS-1 rear brake swap
- L98 idles at 1500 in park......
- headers/ypipe/exhuast?
- Serious Transmission Questions, Help!!!
- Rear end and brake conversion question?
- Head Gasket?
- For Sale: 1984 Custom Camaro
- Does the ZZ4 have a forged crank?
- Help me build.
- Need Favor: PICs of TBI engine
- Tire Questions?
- Spring install help
- carburetor adjustment?
- What Happens @ 100,000 Miles?
- what are your opinions on B F GOODRICH COMP G-FORCE TA KDWS TIRES???????????????????
- another underdrive pulley question
- 86Z shifter assembly to 89 IROC???
- Couple questions
- Strange Problem with my re-built 350TPI
- TBI v. TPI
- Air Pump question
- tpi/ to blower carb?
- Emissions. Dun Dun Dun.
- Is a 700R4 Tranny able to work with a 350 HO engine???
- Ignition Upgrade....
- Paging DarthIROC
- Corvette heads?
- backspacing
- 91 Z28 window lift motor replacement
- Coil-over struts
- 26 spline or 28 spline
- I hate powdercoated wheels
- Help Please!
- 700R4 manual valve body or shift kit?
- 1982 z28
- ? kind of power out of tpi
- Driveshaft Problem
- She has air; all systems go
- No real choice when it comes to lowering springs
- LT-1 in a 86 I-Roc
- 90 iroc computer trouble or not.
- Keeping her cool???
- Need to replace rear seal. Gotta ?
- open/closed loop/limp home help
- TB Bypass??
- TPI Vs. Carburator?
- Best Sub frame connectors
- Best performance radiator
- Installing guages, have questions!!
- terrified
- Rare GTA Digital Dash
- My friend is looking at an 85 IROC need opinions on what it is worth
- Header Choices?
- Tips on looking for short circut???
- running weird??
- ZZ4 and LT4 questions
- f/s firebird hood 82-92 ram air ws-6 cheap
- battery tray
- Vibration after tranny mount install!
- Cam Selection
- where's the power?
- Very loose auto shifter.
- what tranny do I have?
- HOW do i get the center caps off of my RS rims??
- 1988 Iroc-Z
- What SBC's came with PM rods?
- Can my stock diff can keep up with my new engine???
- Do i really need SFC?
- Tokico Shocks/Struts
- Mufflex Exhaust with a Spintech muffler
- idle
- Charging AC
- does a 1991 305 TBI have the same flexplate as a 1990 350 TPI
- Speedo not working after gauge cluster swap..
- Buy My Car!
- long tubes and a starter
- radiator fans acting gay
- Eibach pro kit springs. Anyone want a set?
- Help! Computer Controlled Quadrajet Questions
- 3 inch exhausr. Mistake? Help please.
- Lifter dia. of a 89' SBC??
- Limited Slip died???
- 383
- 8.8 mm wires
- 305 Swap ?'s ...
- Keep blowing ACC FUSE?
- 84 Z28 HO Transmission
- 700R4 Rebuild Questions....
- Stock 305 with boost 1/4 times ???
- 7 vane or 10 vane pump??
- Block casting Numbers
- I know the answer but need explaination
- Chatroom dont work
- does full roller rockers make more noise than stock?
- Need a MAF sensor.
- need to help pay for funeral so i have to sell my dream
- Some pics of my car
- tire size?
- Exhaust question
- Quick, easy question..........
- Please Help!
- Fuel leak?
- engine seems to be revving too high!
- 5 speed and 6 speed flywheels
- headliner sagging
- help help!! broken new head!!
- 92 RS Questions...
- Lifters?? 80-85 block
- Might be getting a LT1 from a 95 Caprice....
- If I build this stuff, will people buy it?
- Rattling Stick!
- wanna get more power for my 89
- degreeing a cam
- Long Tube Hedders...
- Tranny Crossmember?
- Wanna blow a very little bit of cash on something fun and useless
- Car Lurches When Shifted P to D
- White smoke during start up
- rebuilt 700r4 value
- stall
- TPI Chip Burning
- true dual 3"
- Swapping from MAF to Speed Density. Input???
- Cam?Nice smog legal one out there?
- LT1 rear brakes same as L98 rear brakes? (non 1LE)
- Waterbury Connecticut???
- Need Help On Some Performance Mods...
- Competition Engineering Bolt-on Sub-Frame
- gutting the mas
- Headers/emissions
- What the Heck!
- Need Some Feedback.
- electric fuel pump shuts off to hooley 4bbl carb
- some ring and pinion questions
- What do u guys think of my 92's New paint?
- Question
- hood louvers
- Replacing 700R4 with a 350, any problems???
- A/C not moving any air
- Those who have the Cable-X from Abbott...
