- when can I go full syn oil, put the motor in 3 years ago and only have 1,500 miles on
- fuel pump/ manual, how long do they last? what are signs that it may need to be repla
- What to buy for my TPI??
- 115 Mph Shutdown
- headers2
- We have surging.
- Help!! Oil leak!!
- 10:1 Compression ? Detonation ?
- Who has Hooker Long Tubes?
- What do these switches do?
- Attention: badgta
- wierd sound(train like)
- Carb Doctors inside please!!!
- convertible roll bar
- Edlebrock Victor Jr. heads any good?
- f 5.0 tune port question upgrade??
- Another T-56 swap question in which Search Cannot help.
- bbc 454, need tranny advice
- Stumble off the line
- New Canadian here - about to buy a project
- Distributor bolt stuck
- What should I get
- 83 Daytona 500 TA Repro Floormats
- Want 200hp
- Anyone have DynoMax LT's?
- what does single center line rims mean??
- What cam should i pick
- whats EGR?
- gas tanks
- Speedo swap questions
- Low Oil Pressure
- modded mileage?
- Oil pressure Gage
- Should I keep my Car, or by another?
- Retrofit T56 6 speed transmission
- 305 tpi 60 degree?
- Sidepipes
- Need input ASAP. Disc Rear non posi WORTH IT???
- Can you add POSI to a non posi rearend???
- turn signals
- Third Gen T-Top
- a stronger rearend for under 1k$, can i?
- gas gauge
- Stock 383 GTA???
- Hurst shifter, Yahooo!
- Need help w\ vacumn hose routing for 84 H.O.
- Got the 350 in.
- 4th gen to 3rd gen conversion?
- How many mile are too many for ....
- What can i top out at?
- Video Chic
- 84 TA carb on a 82 Z28
- Will 4th gen SS rims fit on a 88?
- I got the new L98 in but now it wont start?!?!
- posi
- cutout question
- Oil Pressure gauge is lifeless.
- T5 transmission/clutch problems...
- How common uncommon is this
- Rear Ends
- 700r4 tranny.. what can it handle?
- How can I tell what engine is in the car?
- Mobil 1, 500 miles a year how often should I change it?
- tv cable question
- found a turbo 400
- how high will she rev??
- I Got My Blue Ox!!!!
- Ah, bought a carb, need some help with it though :)
- EGR worth it?
- tranny trouble
- Mixture Control Solenoid for Q-jet carbs......
- adjusting idle on edelbrock 600 performer
- Where's my spare?
- Squeeky breaks?
- My car is clunking!
- What does this number mean
- How much are rear backing plates worth?
- vin codes
- posi2
- New to Board
- Deleting A/C
- 5.0 Tbi Blues
- Pulled 700R4... Now air/fuel guage doesn't work???
- Question about IROC foglights
- Anyone ever put a 91 dash in an 85?
- parking brake seized!!
- A nostalgic memory for Camaro owners
- Front Tubular LCA for 3rd Gen.
- Need to know what kind of carrier ASAP!
- underdrive pulleys
- Thermostat
- upper bolt on T56 pedal swap...
- subframe connectors
- True duals PIC
- Air Bag,smog
- lower control arms
- Strange problem
- lt1 conversion
- radiator cap
- New, Need Some Info
- header question
- Fan Shroud Question
- Header Install Advice
- discontinued 3rd gen parts
- rear end problem?????????
- 86 Ta
- Big Block In Third Gen?
- Be wary of GTAuto/GTFiberglass
- Some 3rd gen interior piece for sale
- o2 sensor
- TPI Headers??
- LT1 3rd gen times
- bolt on SFC
- rim size
- oil pressure
- my engines (pic - huge 56k warning)
- has anybody seen a 325 50 15 dragradial on a 3rd gen
- 305 TPI questions
- 1987 ping roc
- Knock sensors
- Seat swapout Question
- 305 or 350
- headers
- exhaust cut outs?
- 5/6 speed question
- Help! What goes here!?
- 2 chamber flowmaster direct fit?
- disk brake parts
- o2 sensor replacement
- Stumbling at 35 and 55?
- Engine Over Heating
- Error code on a LG4...
- speedometer
- Engine Code and header question!
- exhaust question
- engine rev
- frikkin plastic!!
- I am looking for those black plastic grills for the rear window
- windshield wipers
- Need some Head.... suggestions.
- What heads are you guys running? Long question.
- Jet Hot Coating
- anybody have used gears??
- Headers??
- 10 bolt, 9-bolt swap
- 9" ?'s
- Headliner for 3rd gen camaro?
- Rollor Rockers
- alum rearend cover, no drain/fill plug?
- Bare bones TBI
- 1 3/4" full length headers, sbc
- What timing chain to use?
- My exhaust tips are so ugly, I need new ones
- TPI Stumbling at 3000rpm, tried everything!
- MUST GO! 1987 Camaro!
- My 91 Bird Wont Start How Can I Bypass The Pass Key?
- 87 camaro
- I see at Ebay a 9 inch setup for 3rd gen
- PASS/VATS , AIR, and LT1 EDIT
- LS1 T56 or LT1 T56????
- Ideal Combustion?
- tire width
- car Bucking and pinging
- gears
- Manual Steering Box from S10
- TBI Pulley options
- Sensor question.
- Anyone have pictures of their subframe connectors installed?
- Rear Shocks
- Ws6 rims?
- Need help fast.. wheel dilemma!
- Quick help on wheels fitment
- RPM Jumps
- Exhaust Question
- Flowmaster exhaust ?
- Stock HP?
- What do pistons look like that have experienced a lot of detonation?
- 3.42 to 3.73 gain?
- Idle Speed
- Fender Allgnment
- Should I get a 3rd gen?
- has anyone ever done this?
- Smog Equipment
- stock belt length
- LT1 swap almost done, a few last questions, please help
- White puff of smoke
- Simple Compression Question
- 3rd gen diet
- suspension
- CHoose your Parts Stores accordingly
- Spring Insulators
- lt1 conversion + external oil cooler
- passing emissions laws
- vortec heads & intake
- tell me if im stupid
- smashed up Z28
- exhaust pipe banging floorpan, questions
- Oil coming out the tail pipes?
- Best performance tire
- pinging at startup???
- 700r4 tranny help
- Those cool headlights?
- Plugs and Wires
- Where is the Turn Signal Flasher Located?
- header fitting qustion... photos also
- Accel EFI Questions CALMAP
- track width
- 305/350 Cam
- Help!!! Tire needed.....
- Loud Speedometer
- 3rd Gen dual exhaust pics
- bypassing smog pump/ac
- back pressure
- cold air intake
- Once in a while weird noise on startup
- service engine soon!!
- So now that I plan on keeping my 86 Z....
- Polishing rims
- Going Fast For Little Cash
- Distributor Cap Wire Diagram
- Bolt pattern on my 80?
- shifter pics...
- I Need More Power!
- ECM blown? Big help needed fast...
- crazy camaro 4 sale
- Great 305 for sale!!!
- NEED INfO FOR camaro iroc z 91 cab PLZ HELP!
- t-56 trans questions
- Engine Struggles when started
- Building a 383
- 3.73 posi install , help!!!!
- 1987 z28
- Self-Align or Not?
- Anyone ever put 91 or 92 GF's on a 82 - 90??
- White Gauges from Duranged Design
- 400 small block
- Hose will be Hose.
- Question on oil-smoking
- Question on my Rear-End
- carbon fiber driveshaft?
- 80-85 vs 86and on block
- Digital display
- FYI Superram VS large tube runners
- Need input on how to go 12's
- Hood Clearance
- What do I need to do with this swap
- Questions about 3rd gens.
- problems starting the car...
- need help with trans
- Fuse Box
