3rd Gen / L98 Engine Tech
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
  1. 4th gen wheels on 3rd gen
  2. 91 rs rear end question
  3. Please help. Red hot primary on new motor
  4. Tranny gurus inside
  5. Front Spring Replacement
  6. Manual Tranny w/ 350?
  7. Twin Turbo Set-up on 305/need help
  8. Finally got pics up!
  9. cat converters?!!
  10. Question about fuel pump...
  11. How Much to get into the 11's?
  12. What could happen if i..?
  13. different distributor?
  14. Z28 Gauge replacement
  15. 17x11 zr1s
  16. Idling too HIGH
  17. 115 to 145 gauge swap
  18. rides
  19. rear end spindel #
  20. HELP! Engine will not rev past ~ 2200 RPM...
  21. 12 bolt question
  22. preference and questions about eaton/auburn posi unit
  23. Cam installed, now car shakes
  24. Iroc will not idle after it's hot
  25. What is IAC and how to adjust TPS
  26. Stock MAF and limitaions?
  27. L98 questions
  28. Hooker Supercomp. LT Headers
  29. hooker super comp long tube headers
  30. Gauge switch
  31. Attn: Guys who converted TPI to carb. How did you do the throttle linkage?
  32. what color?
  33. options
  34. Where is the vats module
  35. Duel Snorkel setup?
  36. Increase horsepower to 85/Z28
  37. What kinda carb should I be looking for?
  38. Cooling issues
  39. Just guesses would make me happy
  40. Are stock Snorkles on TPI's restrictive???
  41. OK...fast and CHEAP! What do I get??
  42. Operation Rally Stroker
  43. Sevice Engine Soon Light--EGR Valve?
  44. Anyone know the rearend width???
  45. MAT relocate
  46. cam select and speed density?
  47. Objects in mirrors are Mustangs
  48. Transmission up grades
  49. Brand new 89 Camaro Owner
  50. What open element to get?
  51. R these guys bsing? Or do y'all think there's merit 2 the setups they tested?
  52. What Blower; what Boost?
  53. What's the wheelbase of a 3rd gen?
  54. IAC ?default? position?
  55. Smog pump question
  56. Ram Air Pics
  57. Bad Distributor?
  58. T56 swap kit
  59. estimated outcome against 94z28
  60. what to do, broken wheel?
  61. 236/242 too big for SD?
  62. 82-92 Dana 44 Wanted
  63. ARHG! Need some help here folks!
  64. I think I broke the hose for my new oil gauge?
  65. Getting rid of cat
  66. wheelbase
  67. Dual Snorkle on TBI
  68. Anyone have pics of aftermarket seats?
  69. Engine Rebuild
  70. Question for people who have done a t-56 swap.
  71. Weight of car
  72. Cleaning Brake Light Covers
  73. 9-bolt ratios
  74. new manual transmission
  75. What wire for TACH?
  76. DUY LT1 intake conversion
  77. Tranny Help Within The Next 15 Minutes Plz!!!
  78. put my 91 SC z28 into a wall....wondering cheapest way to fix
  79. I need your opinions on this seat ASAP!!!!!!!!
  80. T-56 swap
  81. Holley Fuel Pump??
  82. Throttle Body upgrade questions
  83. Adding HP to a T top f body, this a problem?
  84. tach/speedo ???
  85. SS 10 spoke Chrome Rims...
  86. Car died in reverse, now wont start!!
  87. inspection plate on T56...
  88. Where can I get a fly wheel for a...
  89. Car dies in reverse
  90. Distributor wiring order..
  91. Ease Diagnostocs software...
  92. 91-92 dash in 86 iroc
  93. Car dies after 5 minutes, is it the Computer??
  94. Fuse Box?
  95. Adjusting IAC
  96. Supercharged 383
  97. Improve handling?
  98. My IROC is in Speed Style & Sound
  99. favorite camaro stores
  100. Let's Talk Coil Springs
  101. Can I remove my heater core?
  102. timing cover for 383
  103. polishing wheels?
  104. Anyone Seen a 84 TA For Sale Lately??
  105. LT1 with T-5 trans, which starter?
  106. Why does everything have to be so tough?
  107. Got the Rockers, Springs, and seals! Anything else?
  108. not starting when heated up
  109. found the power draw in my car... need help
  110. Car Wont Start HELP ASAP
  111. Does Anyone Have POLY/SPERICAL LCAs and PANHARD
  112. Need help
  113. Vortec heads...machine ?'s.
  114. gonna beef up my 305 a bit
  115. Where does the volt guage take its reading??
  116. Best places to look for a 305 or 350?
  117. 305 TPI 5 Speed Cars?
  118. What else could be causing bad gas milage?
  119. Tranny / Torque converter questions
  120. Where to Tap for TQ Converter Drain Plug (700r4)
  121. frontbrake
  122. 86 IROC High Idle help!
  123. harmonic balancer question
  124. Entire RPM range miss (or something)
  125. traction
  126. clicking when attempting to start
  127. Drop Spindles wanted--NEW or USED(1986 IROC-Z)
  128. pricing rear end with gears
  129. urgent tire question
  130. power antenna
  131. Rebuilding the distributor q's..
  132. Caprice LT1 into thirdgen. Questions within.
  133. rear question
  134. trans question
  135. Headlight switch replacement
  136. gtec pro
  137. steering squeek/creeking?
  138. SFC's, modding your mods?
  139. Best Place/Site to find a 700 R4 tranny?
  140. Holley's "Stealth Ram"intake
  141. friend is looking at a 1990 Iroc
  142. Fan Switch
  143. Color code?
  144. Do these numbers look OK?
  145. 82-86 power mirror fit a 91?
  146. New member
  147. TPI idles fine then after 5min. dies.
  148. 350 or 305 how to tell
  149. Trans-Go install time?
  150. Explain 160* thermostats
  151. It Works!!!!!
  152. Suspension
  153. where is the VATS computer located
  154. Got my concealed beams to WORK again!!!!
  155. camaro vs trans am
  156. Biggest 15" wheel for the rear?
  157. How much more power would a dual 4 carburator give me?
  158. slp header questions
  159. how do i get more noise?
  160. Anyone running BMR?
  161. Worth anything???
  162. Anyone have any sound bytes for Mufflex?
  163. Help with cam selection for a 305TBI
  164. 3rd Gen Big Block Headers?
  165. 1989 Chevrolet Camaro
  166. blowing instrument lamp fuse since stereo install
  167. O God Wtf??????
  168. 305 T.B.I. build up or Chuck?
  169. Attn: 1SLOSBC
  170. Need engine
  171. Th700r4
  172. motor and trans mounts for lt1 conversion
  173. Holley Stealth Ram MPI
  174. are they 26 or 28 spline?
  175. axles/gears/posi
  176. airfoil
  177. Camaro VaraJet Carb specs?
  178. Pace car value?
  179. Fuel Injectors
  180. How do I adjust that 700R4 cable that ataches to the throttle?
  181. tpi throtle body flow
  182. transmission problem
  183. How hard will it be to rebuild my carb
  184. ZZ4 with a stealth ram
  185. fuel pump
  186. Quick ? for you Tremec owners
  187. excessive vibration@60-65 mph?
  188. 1.6 Rockers on 355 TPI?
  189. Gearing Reccomendations
  190. throttle bodies
  191. Cali. model or not
  192. 3rd gen 1/4 mile times
  193. Car theft attempt... get a Kill switch?
  194. Paging- kandied91z
  195. 3rd gen 1/4 mile time
  196. How to do a fuel injection to carb conversion
  197. motor swap...how to pass emissions?
  198. anyone not using 1-wire o2 sensor
  199. Anyone need an LT1 intake?
  200. anyone know the backspacing of a 3rd gen wheel?
  201. LS1 3rd Gen Progress...(PICS)
  202. Transmission oil line diameter
  203. good rear end for 300+ hp?
  204. Air Line to the Cat
  205. nitrous???
  206. 3rd gen rear ???
  207. ACC fuse keeps blowing !!!!
  208. bose lid in 88 iroc.
  209. brake coversion??
  210. carb or fuel inj.
  211. roots blowers
  212. TPI motor upgrades?
  213. shaved door handles
  214. Installing t-tops on a hardtop
  215. VATS Issues
  216. 305 to a 350 swap
  217. body integrity? "wonder bar"?
  218. LT1 heads on a non-LT1 350
  219. ? on computer and speed
  220. 150$ for an iroc wheel? overpriced?
  221. L98?
  222. 4th gen center console in a 3rd gen
  223. polishing iroc wheels? info
  224. unopened/sealed can of brake fluid what is the self life, dot 4
  225. 4th gen steering wheel
  226. new pictures....
  227. Finally!!!
  228. Adjustable Fuel Pressure Regulators
  229. Aluminum Driveshaft...worth it?
  230. Lt1 Lt4 Plastic Valve Covers
  231. New Guy
  232. Fuel pressure guage
  233. Anyone here running this combo?
  234. 86 IROC Computer help!
  235. heater core/ a/c delete firewall question
  236. Bought A Camaro
  237. engine swaping
  238. Prices for T-56's and 700R4's
  239. fuel pressure regulator
  240. headers
  241. damaged gears
  242. t-5 tranny problem **Help plz**
  243. How do i get my steering column apart??!?
  244. New here and I need alot of help
  245. Whats it worth?
  246. 12 second 305? is it possible?
  247. Planning for future power.
  248. lt1 and 3rd gen radiator
  249. Why won't my fan shut off
  250. torque ?
