- please help me!!!
- 305 ?'s
- Corvette Converter good Idea.
- Be carefull!!
- Need some help with finishing off the engine in my IROC
- I need More help!!!
- I got an Iroc!!!
- cosmetic exhaust
- i need help finishing my motor swap
- big block SS hood or IROC turbo hood?
- Trans help needed
- Accel Super Coil TPI For Sale
- T56 wiring...
- i want more power
- Unicorn's Do Exist.. I guess..
- H.O. Dual Snorkle Air Cleaner/Make it fit?
- '91 wheels...
- 383 to a T-5
- 305 needs more power
- With a carb does the stock IROC hood have the clerance to run a regular fan?
- Anyone have the Jet Hot 2000 Colored header coating?
- Help with rebuilding 350
- major exhaust questions
- motor question
- really nasty idle
- power mirror ?s
- can a paxton blower made for 88-92 TPI work on an 87 TPI?
- New Delphi 130 amp alternator will fit on 3rd gen V8 serp accessory bracket!
- 88 MAF 2.8 work with 85 2.8?
- I need an experiened opinion
- Size of TPI Throttle Body
- What's wrong with my car?
- Stock Lt-1 cam specs?
- Fuel pump problems
- 6sp conversion kit
- lookin for an 86-89 Iroc Z.
- TPI Throttle Body
- Ecm
- Cam button
- What To Switch To Rear Disk Brakes
- Heads up on Gas Tanks for 3rd Gen F-body
- tire ?
- Bleeder screw is leaking,Got the brake lines and all the air out but now what please
- Choke light on
- List Of Problems
- Finaly found out why it's been idleing funny!
- Need a Complete Exhaust
- car hesitates...why?!?!?
- Airaid
- 4barrel to TPI 305 conversion?
- accessory brackets
- alternator and power steering?
- 86 305 carb diagram
- Is a rebuild worth it
- Pic of My Paxton SN-92 Supercharger
- forged internals
- somethings up with the clutch
- tubular front
- Where can I pick up a L98 motor?
- I'm glad my pop-up stopper works......
- Wheels....
- Need fuel lines...
- Are the accessory mounting holes the same on pre '87 and '87+ cyl. heads?
- 15" IROC wheels
- Can the frame take it?
- How much canit handle
- New Rear gears
- exhaust
- Want a new hood
- running rich...tryed simple stuff...need help
- Anybody W/ The Stock Intake From A TB 305 Car!!!!
- Z28.com Event
- For those who want 6-speeds...
- problem with speedo
- Air cleaner
- 350 slower than mine (k block???)??? please read
- BORG WARNER tranny any good?
- Whats wrong w/ temp gauge
- After how many years is a car considered a classic?
- 700r4 Question
- Pics of Irocs??
- MAF screen removal
- Gutting air box. How do I do it?
- HELP! determining ring gear size
- 90 FB 3.1L 700R4 Tranny Q
- K-1 styling kits
- Baffled gas tank on E-bay
- Cowl hood
- How much will it cost (est.) to switch from an auto to a 6sp tranny?
- Check out my ROH Snypers!!!
- Doors
- engine ?
- supercharging an 87 Z
- lt4 hot cam too much for stock valvetrain?
- do I need limited slip additive?
- reinstalling a tpi motor ??????
- ls1 in a third gen
- Milodon pan fitting...
- Posi Rear
- Simple questions
- opinions on the holley systemax 425 horse system
- need some help
- What's this noise?
- 88 Iroc power adders
- lt4 intake?
- where to find?
- 305 TBI noise
- Labor costs?
- gears!
- Sounds like a diesel
- Requesting pic's of airbox gutting
- Turn Signals/Emergency Flashers
- Choke Light Still on, need help
- Paging ChevyKen...
- 6 Speed shift pattern logo...
- The real "Fast and the Furious" F-Body's/How fast are y'all's?
- more on 88 Iroc Power Adders
- APC Steering Wheels SUCK!
- Bad gas milage out of TBI
- gear suggestions
- found a 350!
- repairing a fiberglass hood
- want 91/92, 350, stick, and t-tops...
- Question on Compression
- Is this a good price?
- tpi zz4
- What is wrong??? suggestions???
- Battery???
- Mpfi
- trans am ssa???
- Winter's over soon, I need plans!
- Changing Speedometers?
- rear out of camaro possible
- Mini-Ram
- rear latch
- Big Plans, Need input
- heater hose question
- Problem's??
- What Damage Can a Bent Panhard Bar Cause???
- Help me choose springs!!
- What Cars Can I Find A 9Bolt Rear???
- Knowledge Please!
- stock guages and lt1 motor
- Cable driven speedo w/ t-56
- lt1 conversion ?s
- Show me your Wheels!
- 1987 IROC on Ebay. But... I have a question about it..
- Heads on a 305 tpi
- Tranny Help!!
- Need "Driving" tips.
- Good Deal??
- Alright 3rd Gen'ers...Help With A Carb on My 84 TA...
- tpi on a 305?sup
- whats wrong with my friends engine
- Update on Project Ugly Duckling
- rear end ?
- Help needed. Which fuse to pull for Fuel pump (92 camaro)?
- FS 86 Z28 in San Fran Bay Area
- Which manifold to go with. Opinions apreciated
- Alernator Belt Screaming
- head quostion
- Replacement carb for 82 camaro
- buying a L98
- Buying a 3rd gen
- Smoke on cold start?
- 305 TPI Hard to start and runs rough?
- Hood for RS
- LS6 into 3rd gen
- which intake ?
- timing
- Motor
- New chip, where's my timing at?
- 350 tpi mileage???
- rear shocks
- anyone have a guess as to the power of this combo?
- mail slot tail pipes?
- 700r4 Problems
- Have the option to get a 350, do you think its worth it.
- Fuses
- heads and a cam
- Headers for LG4 ????
- !982 Indy Pace car OWNERS
- muffler!!!
- what to use 84 or 90
- scoggindickeytpi base
- Ethylene Glycol VS. Dexcool
- will this work?
- exhaust ?s with lt1 and 3rd gen
- Question regarding gear swaps
- Rear end ?s
- What To do Guys? Engine Is Toast. Literally.
- Am I getting ripped?
- aftermarket oil pan???
- ignition boxes
- questions about the 84 and what i should do(i'm a newbie)
- Stripe kit for 1982 Camaro Berlinetta
- A.i.r??
- Wanting to Remove A/C and Powersteering What Alternator Bracket to use?
- electrical problems Help!!
- Fuse Panel & Other Probs.
- port and polish intake
- Victor Junior Heads
- How much is a 3rd gen Formula going for?
- spark plugs
- tranny troubles
- Looking For A 92 Z
- z28 fog lamps question.
- 85 z28
- 305 horse power ?
- Center caps for 5 spokes?
- Aluminum Driveshaft
- 95 Vette LT1 into 92 RS?!?!?
- computer chips
- 87 TA for parts
- cheap + Easy mods
- gauge cluster
- AC delete...
- My rear 4th gen conversion(Warning, Lots of pics)
- Mid 11s, what is your combo?
- tire width
- Block ID #'s on 305, where are they?
- want to buy a cowl 2 1/4 hood for my 92
- engine/transmission swap advice
- Requesting Blue Camaro W/ Black Stripes
- 87 Iroc
- Hp
- Starting problem
- what size stall
- pics of my 383...
- I sure hope that 2.02 1.60's will fit in stockers
- cheapest pro 5.0 shifter?
- Quick.....does a 90' TBI have just 1 O2 sensor?
- anyone run a patc "raptor" converter ?
- Please help...Size of O2 sensor nut?
- Best mods for TPI 305 - whatcha guys got??
- Help! Code 32 & tranny shifting too high of RPM's
- upgrading front suspension can u help???
- What size bolts?
- Objects in mirror are Mustangs
- 3rd gen camaro
- how much $ to fix this?
- 7/16'' Stud or 3/8'' Stud
- shocks and struts
- rebuilding a 700r4 yourself
- Steering column loose
- T5 trans
- LT1 or LS1 heads on ex-tpi...
- Using Diffrent size tires?
- ideas needed
- lets talk cams
