- anyone still with oil consumption on their LS1
- best place to hide a switch???
- Installing an LS1 in a 2002 Yukon Denaly
- WATER UNDER MY CARPET!!! UGHH!!!
- Does this sound right for 2:73 gear?
- Adding rear -wheel horsepower.
- 2002 Z28 Order Deadline?
- 3.23 A4 2002 LS1 VS. 2002 Saleen Mustang
- HOW DO I GUT MY CATS
- tsb
- Bought a loudmouth today...I'm freakin stoked!
- Alarm system
- Noises in my car...
- Will these fit?
- Is it worth doing it?
- difference TA & Formula
- Spark plugs and Power Programmer
- SS Exhaust Differences
- Which of these 2 sway bars are better?
- What size wheels will fit my 2002 Camaro Z28?
- HELP!!!
- Reluctor Rings!!!
- the deal on the dealerand the o2 sensors
- whats the best wax to use to remove fine scratches
- whats the best type of alarm to buy for my car???
- Basic mod questions....?
- Is Mobil 1 really worth it?
- Changed Plugs....lost power....help!
- Slp loudmouth and straight pipe..Will that wear out the valves?
- Help installing SLP lid
- Quieting Down the Pro 5.0
- MAF's-Save your money
- What times can I expect with these mods?
- What is the best exhaust system out there for the money?
- Does anybody have any sound clips of a Corsa or B&B exhaust system?
- SLP LS6 intake manifold
- Best headers for a lowered car?
- How much horsepower does a Loudmouth exhaust add?
- Left brake light stops working after using right turn signal.
- clutch installation 2001 M6 tips please
- Ok, my Rev Limiter left made me feel like a smuck? How far can i raise it?
- help on welding an exaust on with out fring the electronics
- Service Vehicle Light ????
- Who makes the best 382 LS1
- Camshaft and Headers Question
- rear end seal leaking?
- exhaust setups
- Plug gaps
- Black Color Okay for Florida?
- T56 experts...HELP cant get case back on
- Phantom Auto Meter Oil Pressure Gauge
- exhaust tips for loudmouth
- Clunking noise when I repeatedly engage and disengage the gas pedal at low rpms?
- Stock exhaust size?
- Whats a better intake?
- Spitting Ls1 98'
- HELP! AC Leaking Water Inside, HELP PLEASE!
- what you think of CenterForce Dual clutch ?
- engine rebuild
- Factory computer settings
- Jim Pace supplied FIPK with wrong filter
- Anyone have a carfax account open
- JUst got it!!, i hope it works fine
- Best shock tower brace?
- How many miles do you have on your LS1?
- New Formula Canadian...
- Engine squeaking when first started in AM
- Shift Kits?
- What should I do next?
- Where in the......
- Lou's short stick...
- Post your idle oil pressure - I am curious ...
- Under Warranty?
- Top Speed on 99 LS-1 auto with 3.23 and 1/4 mile times?
- Free factory Cats!
- Water pours from under dash - need matching towels for carpet. . . .
- discontinuation of SLP underdrive crank damper/pulley
- Exhaust diameters vs HP
- new suncoast hood....w/i
- Red line / Royal Purple oil
- Wheels Locks
- What should be my next mod?
- The 2007 Camaro !?!
- how do you get the M6 handle off?
- Good Heatshield
- What size do i enter into Hpp3 for my tires while programing the gear ratio?
- Help me with my shift points/firmness !
- Traction control module ?
- ne idea on the ses light
- 4:10 Gears
- Any stock stall, bolt-on, 2.73 cars out there faster than mine
- Best place to weld on a cut out????
- Okay,, Best headers for 2000 Trans Am
- Where do I hook up the sender for my autometer oil pressure gauge
- New Sportlines=Nice! Camber=Not so nice!
- Running lean...
- Traction Control
- Some SLP parts questions
- Heads & Cam ???? Please Help!!!
- LS1 in a 3rd gen ?
- Significant HP upgrades for $4200 or less
- good deal or not
- NEED HELP!!! Got the McLeod in and the adjustable master cylinder....
- Rearwheel or crank
- Stock Fuel System
- Might be moving to US from UK, looking at getting a new Z28........
- mufflex exhaust
- MAC offroad y-pipe, need o2 simms?
- A/C question...Please help
- How do I clear the computer error codes
- Help Me Pick My Next Mods, PLEASE!!!
- Ported Throttle Body Question.
- How much horsepower would i get from this?
- Detonation?
- help mod gone bad ?
- Where can I find the RPMs at???
- MSD DIS ignitions!?
- K&N filter installation
- descreening MAF
- Dynoed Today....Car would not stay in 3rd gear!!!!
- WTF, Exhaust install?
- Has anybody heard of Super Sucker ram air kits?
- ? about my electrical system? Please everyone read and try to help?
- Ripped car apart. Giant photos from the garage. Major bandwidth.
- Next Mods??
- Frind has 02 WS6 Pontiac said there is a reacal comming??? LS-1 problem with motor??
- how much louder is an off road y pipe?
- Busted my rear...
- How to adjust Throttle cable
- Lean or rich?
- Eibach Pro Kit ?
- Need help, rear end is whining and I'm 320 mile from home
- discarded plug wires
- gears?
- A4 Tranny slippage?
- IS THIS A GOOD MOVE?
- Will I feel the difference with this change
- Magnaflow installed yesterday.
- Electric cutout question...
- WEIRD Electrical question, please read...
- Please read this... Need some suggestions...
- People With 4:10's and Automatics, Help!!!
- How to troubleshoot dead cruise control?
- HELP!!! Which Camshaft
- LS1 not running right?
- What's the horsepower gain just from cams?
- Anyone get Low OIL light after racing and then have it dissapear after 2 hours?
- Show me the Gears
- i need some help buying tires.
- Gear change effects on top speed?
- Fast-Fast-Faster
- What to do next?
- Would this run 11.4s?
- EVAP code?
- Question for all!
- 10-spoke SS wheel valve stems?
- A few technical questions for rear diff replacements
- Automatic versus Manual
- Upgrading Fuel Lines.......CHECK this out!!!!
- what's better, Paper or OEM gaskets?
- FTRA question
- Really weird problem, please help!
- Air on at start up?
- 2000 T/A wheels
- SLP 160 thermostat no good?
- Where's the cheapest place to buy a headlamp motor?
- aftermarket shifters
- In line fuel pump help
- Would this mod put me safely in to the 12's?
- inquiring...
- Is there an electric waterpump for ls1/ls6?
- Exhaust manifold gasket?
- 4.10 vs 3.73 gears
- IMPORTANT! Please Help Bad Press
- People with 2.73 gears.....
- Mustang rearend on f-bodies??!!!
- Cooling fan mod question... Please read.
- Air Lid Problem need advice
- Throttle cable
- Dana 60 rearend?
- Is LS1 Edit Superior to Hypertech Power Programming?
- Newbie Questions
- New Hooker Catback for LS1s?
- Z28 vs SS
- First mods to do to 2000 Z
- Car wont start at random, could it be the alarm solenoid?
- That time of the CLUTCH...
- 318 RWHP- stock 2000 WS6
- What All Is Needed For New Clutch??How Much? Where?
- Cam swap in ls-1..how hard is it?
- WHAT SHOULD THE TIRE PSI BE FOR STREET TIRES, RUNNIN AT THE TRACK??? OR STREET RACES?
- Ideas on A/C compressor........
- Bought a base Z28 (no options) Have Questions
- How many O2 sensors on an LS1?
- A few questions for ya!!!
- plugs and wires
- Help on a price
- Oil pressure gauge drops
- Hypertech 160 deg. power stat ?
- Need advice on new tires badly
- Any reason I can't put '96 rear diff & gears in a '00? Need help quick, please!
- buying a LS1 , plz HELP!
- anyone using a kirban shifter? opinions of it?
- lca's? stupid question...
- New T-Top
- grinding noise when going in reverse?
- What to do after cutout is installed
- Rear End Whine
- New sway bar, LCAs, and panhard
- Install car alarm, now air bag light
- Caliper Stickers Instead Of Painting
- anyone with a cutout: interior rattle
- Check out what im going to do rto my car!!
- can someone tell me the weight of a 98 z28 and 94 mustang gt
- Window motor replacement difficulty
- what is the link to get to brent frankers appearance page??
- Good price on Shock Tower Braces?
- Are ASR and AirCon related
- 2.73 to 3.73
- Which exhaust is better?
- How will a stock 2001 F-body do against a 1st gen Viper?
- Ugh...Loudmouth doesn't fit well...
- Carbon fiber lid, where do I find it?
- Which exaust si better???
- Where can I find Nitto drags at a good price online?
- Is this cam any Good??
- New SS owner, would like some comments
- Anyone with a Cowl Induction hood an on LS1?
- is is possible to remove a dent from the camaro doors?
- damit i got 2 tickets today
- anyone have ecm pinout info for a 98 f-car?
- Damn throttle cable
- Who will win this race?
- What would it take for an LS6
- Whistling Sound with new BBK TB???
- White face gauges
- Mod Suggestions
- any ideas on which exaust i should get???
- I need help
- OBDII Codes
- Help me with my track times?
- HELP-- PCM Reset?
- Super Short Throw Shifter
- Mufflex 4" !!!!
- What tools needed for cylinder head/cam swap?
- windows leak
- Dynatech longtubes
- 2002 Z28 Question
- question on cutouts?
- Help me advise a friend of what mods to get for h is 2000 V6.
