- Quick Identification Please
- 2002 z28 vin question
- Pulled 4 codes lastnight
- gas cap code
- Engine backfired, now the car wont start??
- P 1415 error code for 98 z28
- What springs are these??
- just bought an 02 z28! fuel question???
- Boggin! But why?
- Car wont idle with the clutch in.....
- SS3600 or SS4000
- 6 Bent PR's and play in the crank bolt...
- differences
- WS6 Ram Air Intake question
- Introducing The All New 1 7/8" TSP Long Tubes!!
- Squires Turbo System
- question about gears
- Its not often you hear an LS1 like this..
- Overheat Question
- 94 1LE or 98 z28
- LS1(98) to LT1(97) Cluster Wiring.....
- Fuel Management Technology-----??HOMEMADE???
- Rev limiter....
- how hard would it be to...
- People with FAST intake/tb
- California Emissions??
- p0137
- Sne
- Need to go faster for around $5000?????
- EGR questions with PICS!!!!
- LS2 w/ APS Twin Turbo- Twin Intercooled Kit
- Need some sites for performance parts
- mufflers....
- Smoke related to headers?
- Left bank not firing (LS1)
- Denso O2's, please help
- LS1 Number
- Heads and Cam done; got some questions
- Greetings!
- Replaced the Water Pump.. Still leaking Antifreeze..
- Uh Oh... Serious issues on the horizon... More than what I at first expected
- LS6/T56 swapped S-10
- Difference between these UDP's??
- Bad Misfire
- Help me find a thread...
- Have you ever wondered how GM's LS2 V8 fits together?
- LSX in my 94 Z71
- obd2 code 430
- motor start up vid
- arp head bolts on a ls2 (searched and cannot find answer)
- 2000
- Do the numbers seem right?
- Great power for Bolt on's
- fidanza clutch?
- spark knock
- Best Spark Plugs???
- Wtf?
- O2 sensor going bad?
- Intake, throttle body, and Manifold
- 10mpg?
- DTC' s PO131 PO151
- Newby to Z28
- Heads and Cam - DONE! (vid) <3 Kraest
- cam question
- 5-Pin Maf diagram or pin out?
- crazy idle
- LS1 with engine knock
- Lt1 gas mileage and fuel requirements
- tunners
- Developed a miss...
- My ebay header installation experience...
- Going to buy 2000 Camaro Z28 MNB M6 34,000 miles
- pcm tune...
- 6.0 conversion
- Bare bones cam swap
- Need help with codes (1416 & 0430)
- 5.3 literv-8
- spark plugs?
- Dyno Results: F13/Patriot Stage II LS6 heads
- Question about LS1 Blancer/Crank Pulley.
- better luck with delco or bosch 02 sensors?
- Crankshaft Position Variation Learn
- A little walk through of our stage 2 LS6 heads :)
- LS1 A/C idler and tension pulleys??? '99 SS
- new car help please....?
- I've been waiting to say this for a while....
- R&R of the TPS
- 97 & 98 corvette owners regulator related
- Ok help me pick a cam.
- Thinking of 5.3 LS swap.....
- 12557335 A/C pulley - sending out feelers
- What does this go to?
- Need help with PCV tube!!
- LS1 Overheating Question
- after header afr?
- Oil leaking from the pulley, yes I screwed up
- Using Cable From OBDI W/OBDII Conector On a OBDII Car?. (Messed Up Gauages)
- withh this work on 2000 firebird?
- LS1 MPG & Gas
- Different Backfire issue
- Idle issues and loss of power???
- Lt-ls
- ls2 swap updated pics
- possible to just replace battery cable end?
- What exactly is the weak spot in the LS1 bottom end?
- 98 Z28 Won't Start
- new cats
- Looking at First Camaro, What to Look For?
- oil pressure question?!?!
- Help with New z28
- Working on a P0410 code / 2000 SS M6
- jason cromer still around?
- last spark plug p/s
- What is this?
- Has anyone used LS1 Granatelli Big G Tuner?
- 5.3 swap into a V6 firebird.
- lid question
- 2000 SS M6 -- Duhh: Where is the PCV?
- PRC LS6/LS2 Heads Get A Face Lift!! 225cc Runners & More!!!
- ls1 offroad go fast parts
- build-up on my ls2
- Ran a compression test on my 98 LS1, tell me what you tnk.
- bad head gasket?
- which throttle body gasket
- B&B Ripper Shifters - Opinions?
- 95 Camaro Z28 - LS7?
- Can Lid and Stock shaped filter have equal power gains over induction tube system
- k&n fipk
- A little help please
- little click, big problem
- Power Steering problem - anyone else have this?
- 1st ever dyno pass!!!
- SSRA vs SS hood ram air
- Bad gas mileage
- Help Needed Troubleshooting Valvetrane issue. Pictures
- pop goes the weasel
- Drive cycles and fully completed OBD
- Lt1-to LS1 swap
- What is this thing next to my horn?
- New to performance on ls1
- LSx swap into b-body
- new to the ls1 n20 ?
- Ram Airs?
- first time at track with ls1
- Mods that will improve MPG???
- ls1 info
- Odometer is not stored in the cluster, right?
- Zo6 Cam
- LS6 Intake Question
- cross section of LS head
- Took the 02 Z28 down the track for the first time yesterday.
- took some time and saving but finally got a ls1 ss
- Replacing my Z-28's Lt1 with a LSX?
- 100k miles 98z28
- Same O2 sensor part# for before and after cat?
- LS1 Water Pump R & R?
- Plug Wire Question
- Heads and Cam question
- 2500 RPM lag?
- 99' SS! What do I get???
- Thinking about an LS1 Car instead of my BB 69 Camaro but???
- Problems taking off
- A/C recharge
- Running too lean..?
- Just Got My First Ls1 Need Help
- Nick Williams 90MM TB and IAC
- LS1 VS. 1st Generation 402 Big Block???
- Bad mileage, hesitates
- need a opinion on clutch for ls1 t56
- 13.5 at the track new best
- Is the ls6 intake worth buying
- Pros and Cons of buying a SC LS1 M6?
- LS1 Heads (241's) milled to .050"??????
- EGR block off plate + tune?
- TS 228R cam
- Knock coming from my T/A
- LS2 Fuel rail covers
- Oil-Burn question
- What Valve Springs are these? (Help Identify)
- Stock Valve Spring Height vs Aftermarket?
- Question about some part of the air dam assembly.
- Is this the correct way to measure lifter preload?
- Car is over heating.... Please help!
- 99 Z28 need some wiring help
- 1999 SS question please help
- ls1
- overheating
- A4 vs. M6-Which would you get?
- An LS1 that hasn't been run in 2+ years at ALL...
- Iron 6.0 vs LS6?
- Ticking after gettting on it hard.
- 98 => on LS1 Ttemperature Gage
- will i need a tune instantly after long tubes
- another new best 13.496
- Check it out FIPK owners
- new to the ls1 scene....
- Upgrades with my heads and cam install
- Difference Between The LS1 and LS2 Engine's??
- Ls1 numbers?
- what are the best plugs
- I think i'm gona do a LS1 in my 70 Z28
- F14 install and Dyno numbers
- cheapest way to hit 410rwhp?
- ls intakes?
- Supercharged LS1 slow!!!
- Got a question
- Check Gauges light?
- Dyno's a bit low?
- Diablo Predator
- Weird Noise
- Trans Am Intake
- Please confirm or raise your Flags on this car
- intermitant Lean condition...
- BS3 and Sensor Wiring
- Help me out!!
- Throttle cams and throttle cables.....
- Here comes winter...
- multiple alternator failures.
- LS! Block Strength??
- Which air lid is the best
- another new best 13.434
- Help needed.........
- burning oil
- 02 Sensor location help.ha
- What does this hose go to? EGR?
- Good Buy
- Catch Can w/out PCV valve
- Kinda weak on the bottom end
- Bi-Tron additives: Sensational claims or real?
- Flycutting
- what's a 6.0 worth?
- how good are the lloyd elloits ls1 packages
- Am I insane? Complete powertrain swap, 2000 Z28 to 93 TA
- Best Cam For An LS1 Engine???
- PCM Codes, bad oxygen sensor? Help! Thanks
- Clutch or motor mount or what?
- Blocks, heads, intake and PCMs
- Low Fuel Pressure in LS1 Transplant! PLEASE HELP
- header install question
- Wideband O2 sensors?
- Valve cover removal on an LS1?
- lq9 engine
- EGR AND AIR Blockoffs
- 1/4 mile predictions. 98 SS
- Head/cam swap on 2002 SS
- Clutch Pedal Noise
- LS1 newb ?
- New Toys
- Hp increase ?
- Vacume leak at iac valve
