- Ls7 $12500 Delivered
- underdrive pulley and lightweight battery?
- flashing SES light
- AIR pump ??
- Moroso Blue Max wires???
- Frustrated - AIR codes won't go away!
- Ricer question
- next mod?
- installed pro kit, now which header's
- Normal for some smoke @ high rpms?
- Oil Pressure Gauge
- Build-up Specs
- AIR - Is it necessary?
- ok got some questions
- What spark plugs does everyone use on their LS1?
- Excellent and free tuning advice
- 95 LT1 swap for 99 LS1 guide
- help please
- 5.3 heads
- ls1 headers JBA
- LT motor compared to LS motor
- Heads are in
- Cleaned K&N FIPK now I have an engine code!
- car issue... smell gas, and was bogging down
- Engine knock when cold
- LS1 cars getting completely trounced by LT1 cars...
- Futral F14 cam questions
- oil psi question
- Lid
- My LS1 Z28 Needed Water And I Didn't Put Any
- Detailing 2002 LS1
- Introducing The Golen LSX Peformance Engine Series!
- comp cam and 5.3 heads
- Easy Mods
- struggles to start
- TPS sensor questions.....weird readings after TPS replacement
- Trying to run 12s...
- this any good?
- Name that smell ...
- 160 thermostat help
- Lid Fitment
- knock sensor bank 2
- 11 second daily driver?
- Head/Cam info
- how long will it last
- New Purchase in the UK
- PCM Error or am I looking at trouble down the road?
- Best way to get 500rwhp out of my new LS1.
- Corvette Vortex air induction on an Fbody
- Low coolant light
- t/a exhaust
- coolant ever leak out of headbolts?
- just did the header install...
- Best Year for C5 Vettes?
- 87 octane on an LS1?????
- Differences in 98-02 z28
- 2 new alternators and still no charging
- Camaro's playing mind games with me...
- Burning Lot's of Oil!
- Stupid question
- Who say an LS2 (or any LSx) can't look nice
- Cam ?
- Airbox elbow hose question
- slp cai, rubber seal install ???, help!!
- Pennzoil vs. Mobile 1
- AIR / EGR whats what?
- Racing fuel???
- induction ?
- just got a slp ss hood, airbox options
- How much HP can 346ci produce? Full internals and boost.
- TR-5 vs. Tr-55 Plug
- Regular Stock 98 Z28 Whats Tha HP On That
- Noise around Water Pump area
- Vacuum Leak - part numer request
- Dyno results from a Patrick G tuned TRAK cammed car w/PRC LS6 2.5's
- 35th anniversary Dyno results
- LS1 Intake question
- Would you buy it?
- Soon to be LS1 powered, questions
- Who has Hooker 1 7/8" Longtubes?
- what intake did a 99 corvette come with
- Look at local LS1 t/a
- Gtx
- Gen III 5.3L Vortec Block Question...
- Help me pick a project!
- 01 6spd z28 surging when going through the gears
- Does anyone have an LS1 That doesn't have a squeaky belt???
- 0w-30 Synthetic Oils
- No oil pressure
- Cheatr cam
- "The recipe for 500 RWHP." - LS1Tech thread! WOW!
- LS2/L92 buildup questions
- Best exhaust gasket?
- Brake, ABS INOP, and service engine light
- whats next
- New motor: oil pressure low at hot idle
- What size injectors in a 1999 LS1?
- LT header install
- What would you spend $300 on?
- 1998 Z28 shuts down at random moments...
- Difference between 1999 Camaro Z28 & 1999 Camaro B4C Z28????
- Who makes these headers? *link inside*
- How hard to Install Exhaust???
- fan question
- LS1 Silverado? LT1?
- what can I do for more HP
- Ls7 Ecm/pcm
- MAF Pops out of lid?!?!?!?
- FAST intake and TB
- Possible the oil pump could be goin out?
- LE2 heads/cam?? Who's running them?
- About to purchase 99 Z28 ... Thoughts please.
- EGR Delete now too lean
- 408 or 418
- Throttle body Water Bypass Kits ?? ID
- HPE S2 cam?
- Car has problem starting! bad alternator?
- car got hot yesterday
- High idle after cars warm/driving
- LS6 swap into lt1 car?
- 2000 z28
- Power and Gas mileage?
- EFILive
- Tune?
- Voltage problem...
- 98-99 lid on an 02?
- car turning off
- Bassani y-pipe
- Finally did the TB coolant bypass
- I Want Alot Of HP Gains On My Stock Z28
- Extra $2,000 What should I do?
- How much wear do mods really put on you car?
- Lifter Noise
- Any interest in a throttle body dress up plate?
- Help,i hurt the T/A, i need new heads,cam
- GEN V direct injection 6.2 L92 well north of 450HP....
- Head Flow #'s.. FYI..
- 671/871 Blowers for LSx Engines
- what heads to go with
- Aren't LS1-s Head gasket failure prone?????
- pcv valve
- LS1 Hot cam or TSP 224
- Whats the best choice
- First order of business
- Stock oil pump for cam? & Timing Chain Q.
- 500 Rwhp Possible?
- SLP Heavy Duty or LS6 Oil Pump
- hottest cali legal cam
- I have a strange hose in my engine bay.
- What size bolt to put LS1 on engine stand?
- 99 SS Power Steering Pulley
- LQ4 Drop-in question, can i use 98-02 Wiring harness and PCM?
- how to delete tube in air box?
- 2000 headers on 98
- good head cam package
- LS1 Water Pump, How difficult is it to replace?
- 1 Owner a.t. black mint 48k miles 10g's Good Deal?
- Pulley bolt?
- which should i do????
- obx longtubes
- LPE:Lingenfelter
- Anyone running bbk ssi 85 intake and throttle body
- '98 LS1 or '00 LS1 ? Choose 1
- 100k Tune Up
- Where to look for block
- Loose starter bolts?
- LS1 in my 96 / LT1 Gauges on LS1 Engine??? Adapter??
- Clogged Cat/Random Misfire
- What do i bore 5.3L to, so i can make 5.7L?
- msd 8.5 wires
- What gear ratio do i need??
- Question on LS1 Pacesetter/ Cat Y Pipe
- Homogoneous Charge Compression Ignition
- easy free mods
- k&n fipk
- True Dual question
- cams....
- 99 LS1 Z28 with high idle speed
- How to check PTV Clearance w/ Play Doh?
- 98 LS1 vs 99-02 LS1
- Lsi Throttle Cable Failure
- First mods for a 07 Z06?
- Idle question for cammed untuned LS1???
- Pick me a camshaft...
- cam specs
- Caddy racing hyd roller lifter question
- Cheapest place to get LS6 Crate ?
- Dynatechs?
- Whining noise?
- 98 Racetronix Plug N Play Kit
- need help getting oil filler neck off...
- Record breaker PaceSetter LT install!
- How much of a gain should I see?
- How hard to change plugs and wires on LS1?
- Timing Chain Tension!!!!
- LS1 Cam Swap Vid on quickperformance.com
- SES Code P1416
- LS7 cam specs?
- changing oil today,what should i get? 61k ls1
- So i kind of have a problem, engine wont start...
- Factory engine temp accurate??????
- What is the measurements of the LS1 Oil Pan bolt?
- 2000 LS1 Oil Pressure Sensor on a 1998 LS1????
- Cometic vs. GM MLS Head Gaskets
- P0507 code and 2000 RPM idle
- Drvier side coil bank misfiring no SES light
- 2004 GTO Powersteering on 1998 LS1?
- Engine Coolant
- service engine light on!!
- 4 SES Codes at once all of a sudden?
- LS1 Oil Pan Gasket...
- LS2 manifold fit LS1 maybe? ?
- overheating & a/c issues
- valve tap? Higher Octane??...read.
- thinking about a LSsomething in the jeep
- misfire?
- What kind of power is a Full Bolt On m6 ls1 putting down?
- Maximum rpm for oem lifters
- Coated main rod and cam bearings?
- LE1 heads and cam = 10s
- Engine Swap...
- Max RPMs with heads/cam??
- Changed out idler pulley, problems.
- 1/8 run
- Pics of TB Bypass?
- Great fuel milage, what happened?
- what would a ls1 sound like if a 918 spring was bad?
- which intake
- My car wont turn right away? Video Inside
- Air Box Lid
- Vette LS2 and GTO LS2 Differences??
- Z28 To SS Conversion
- Mild cam and Stall converter HP gain
- Help with error codes, 01 Trans-Am
- cam & heads confusion
- I know....another code thread..
- Question regarding L76's
- lt1 to ls1 swap
- Need help with my LS1 in 1996 Z28!
- Squealing + Coolant Issues
- I need some pinouts of these 98 LS1 connectors (c100, c105, c210, c220, c230)
- Is this too risky?
- bolt broke off in crank pulley
- I need help customizing my 2002 Camaro SS. Please Help!!!
- LS1 swap officially started, stage 1 pics!
- DD Setup??
- Cheap N/a 700 rwhp
- how do you put springs on with the heads still on?!
- Pilot bearing replacement
- Would This Help
