- a little help please
- Power Giving HEADERS
- Car Wont Start
- What did YOU run with full exhuast?
- DTC P0171 Fuel Trim System Lean Bank 1 and P0174
- bad ping after mod install
- Sudden surge/lag in power...
- need tuner in Iowa
- tornado
- just curious
- Magnaflow 3" tips vs stock Z28 tips
- IF you Plan on doing water temp gauge
- ls1 tornado
- What is that
- Can you make an LS1 as fun down low as the LT1's?
- ...And on the 8th plug he said...
- Aftermarket Tach in 98 trans am
- whats the difference: Hooker Comp Vs. Super Comp??
- Clanking noise?
- Oil pressure gauge
- For those who have installed a FAST intake....???'s
- LT1 problems as opposed to LS1's ??
- I will get laughed at for this, but, headers important?
- Problem after header install???
- LS1 Engine Swap Success Stories?
- SLP loudmouth question.
- Ls1 milage question
- Replace intake gaskets...or not?
- High idle....
- which bottom ends on an LS1
- High Mileage LS1
- Cams???
- Pictures of ABS delete kit on 2000 SS
- milling stock heads...how much gain
- Should I Buy.............?
- Loss of bottom end!?
- Question about knock sensor?
- Sould i get my TB ported?
- All tore apart!!
- Exhaust
- I need some recommendations/help
- MAP sensor and FAST intake....?'s
- Small cam install: Need a tune ?
- Where is all the LS1 people at??
- 243 or Dart 205s with f13?
- Lsx ????
- How to lengthen throttle cable for new TB???
- Does anyone know where to get the crane 227 for less than $360?
- Noises after FAST install...
- Leaving it in ONE in an A4 2.73 LS1
- need cam advice...
- I am a LS1 owner all!!
- I think I need a good motor mount, non polyurathane
- removing the oil pan.....?
- Cylinder miss fire
- Valve cover gaskets... One last question
- 9/97 engine with center valve cover bolts??
- oil catch can location?
- Engine swap question
- No *check engine* light. Any schematic guru's here?
- Why are my dyno #'s so low??
- What cam shaft?
- Dyno So Low Its Pathetic!!!!
- ls1 --> ls2<---
- rocker and lifter noise.......
- help with codes
- grease in tb by blade...
- LS1/LS6 intake
- Went to the track tonight.
- Any one have Dyno #'s for MIdS vs LT's??
- Oil Filter Problem on LS1 in Germany
- Z06 Maf
- Katech belt tensioner?
- Mac Mid Length Headers
- Engine noise
- Vacuum Diagram or pics for LS1
- Vacuum Leak maybe?
- LS1 block Strength
- LS1 to LS7. what upgrades can carry over?
- Volant CAI hybrid LT1 Roadmaster question
- tinkerbell oil filter makes me nervous...
- ls1 engine covers
- valve spring help:
- head/cam pairing
- Horsepower?????
- Exhaust mods, good or bad effect on mileage ?
- Scanned the DTC and 2 errors came up!
- Where does your temp gauge sit w/ the 160* stat?
- MAF question...
- Error code, what does it mean?
- fuel rail covers from a vett
- DTC P0121 after FAST install....???
- LS1 rough idle & hesitation
- new roller rockers
- Head Cam Package finalized.
- Dig 6 on 01 TA
- LS1 Dress Up Options
- emissions
- Yo... help!
- Budget H/C setup.... But good...Recomends??
- Catalytic converter tuner
- Engine swaps?/turbo's?
- Lingfelter oil pumps...
- Cut off muffler make car quit?
- Blown LS1 head gasket what chance block is okay?
- Comparing headers...
- Need a quick question answered.. please
- can't decide between two cams. HELP!
- bolt ons
- going to pull engine. need advice please
- doing a rering job
- I need your help deciding....
- SES Codes P155 and P1153
- head/cam swap
- What is casuing these noises?
- ptv clearance questions
- Need opinions on which block to choose
- Is home-made ram air worth it?
- anybody know the base circle on this cam?
- Oxygen Sensor Reading
- knock = fixed..
- what valve spring compressor to use?
- VRE 1970 Camaro 427 LS1 Project
- first mods
- K&N v/s Air Hog
- cam tool, how does this thing work?
- code??
- Question on ported TB
- Motor Swap Help
- Will an LS6 throttle body...
- Problems starting car when cold
- L92 with L76 intake
- wiring issues
- 2001-2002 Intake Question
- Anyone with Patriot stg II/f13 set up?
- Did some engine temp testing today....interesting..
- Much needed info.on Porting the LS1 TB
- how to get 400hp
- Cam w/118K Too Much?
- what fuel additive do you put in a car that isn't driven much?
- random misfire
- Fast intake & 1.7RR's
- another cam question(s)
- NE1 Have Pics Of A LS1 Z28 Exhaust?
- Oil Problems!!!! Need Help Please!!
- Misfire at idle
- 6.0L Block in a 98Z??
- Difference Between 98 through 02 Camaros?
- Hi all quick question
- $ burning a hole in my pocket!
- SLP 1.85 rocker arm packages
- Highway mileage with a cam.
- Service Engine Soon Light
- code??
- Front Seal Oil Leak-Bars Leak?
- LS1 Engine Upgrade
- ok, I've made up my mind... What first...
- have questions about water pump
- cam info needed
- p1416: possible air check valve
- TSP PRC head questions
- High mileage thread.. Over 100,000
- is it my water pump?
- Head/Cam install this week....
- K-member/engine cradel
- iron block 6.0 with ls6 heads
- can the new Z06 handle 200 shot of nitrous?
- water in power steering
- At what point does one need an engine girdle?
- Anone interested in buying Pacesetter headers for a moderately cheap price?
- best place to buy slp lid
- Whining noise?
- Help with deleting AIR
- Is filter breather needed with whisper lid on '00 Z
- will the 2000 ss exhaust fit my 91
- Bolt On LS1s
- Cat Converter question
- Maf
- Maf
- Got the 6.0L installed, BIG HP Ratings....
- Port Throttle Body
- Full Tune up
- another ls1 cranks wont start question
- Help!!
- Tapping from valvetrain - problem solved
- H/C install done, picts and video inside....
- ls1 boltons vs. ls2
- LOUDEST Exhuast
- thanks for advice on cam install, video
- Seafoam on new plugs = bad idea?
- oxygen senors
- stock ls1 head info...
- 2002 Camaro SS Heads and Cam Help
- Ls2 manual ?
- LS6 Intake Manifold on late 2002's
- Nitrous Outlet Boooooorific Specials
- Which Pulley Is This?(Pic)
- slight wistle or whine after cam install
- 350Z enthusiast in 5thgen section wants stock info
- Anyone know of a Shop that does it all?
- Low #s?
- Dual remote oil filter kit...
- Heads and Cam Help
- Once and for all, I have her back!
- little confused on this intake...
- LS6 vs LS7?
- Got my dyno numbers!
- intake and exhaust choice
- The Black Widow #2
- valve slap
- Wierd problem... long story...
- New 383 Dyno Numbers
- Exhaust...reason for low dyno #'s?
- Ram Air dyno question
- ignition relay question
- Black smoke at WOT from light bolt-on 02' Z28
- '99 WS-6(Auto) Stock set-up hitting low 13's w/ 24k miles!
- cam installed and tune, do i need to drill the TB? Video
- Cam Question
- Installed a "Smoothe Bellow" for $5.99, I actually DO feel improvement...
- Car's Hard To Start
- Airbrushed Fbody Bottles
- Help I have a strange Revving problem!
- 160* thermostat???
- Port and Polish...
- Anyone see this!! NUTS!
- Torquer V.3 cam only numbers and some vids!!
- First post, need some help, buying an SS!
- most of my valve springs are broken, Why
- tryin to ditch the blowmaster
- Car not starting :(
- gm head bolts p/n??
- head stud fittment on ls6's?
- Need a reliable machine shop in New Jersey
- How do I get taller install height?
- New Cam (cam experts)
- 98 z-28 vs 99 camaro ss
- 500rwhp 408 iron block how hard?
- Cut out?
- good shop in pa
- New Best in Corvette :)
- Hose Change Procedure
- 10.85 in a Z06 stock with drag radials
- rings damage the block?
- New to the ls1 crowd!
- Help picking a cam.
- Upgrading H/C at high mileage?
- PRC or Patriot Golds
- bbk
- Okay, dont bite my balls off, but, seriously, biggest cam for stock stall
