- Yahtzee!!!!!!!!!!
- No Cats? Just wondering!
- AIR DTC how to stop it from coming on
- Do headers really = dyno RWHP ????
- Just put flows on and gas gauge dropped?
- Tune Up ??
- Hesitation
- Pics...
- if only..........
- Pacesetter vs. Hooker
- Cold start rattle
- Quick Question, I Need Help!!!!
- Tsp 224r
- timing chain
- Yay or Nay
- patriot heads
- 2.5" or 3" CATS....
- Cats = how much HP loss with headers?
- I need part number for the ls1 90mm t/b
- what shoul i do?
- TSP Rumbler any good?
- 1.8 Rockers for stock LS1
- Prices on Installation
- Car is Too Lean
- How much xtra HP with 224 cam & 100 shot?
- Polyurothaine Engine Mounts. Yes or No? Pros & Cons?
- The new LS7 ...
- Valve sizing
- Some cam feedback please
- how much $ for cam install?
- Why am i losing oil?
- lid or not
- LS1 Problems?
- Questions on intake and induction
- HELP! My LS1 won't GO!
- How would you spend $700
- backfire, misfire when wet now always
- 99 TB on a 02
- Which one should I buy?
- What is a tune worth?
- Starting problem with 99 T/A
- Resleeving ?
- Losing Power Steering Fluid
- difference between ls1 & ls6 intake manifold
- Clicking Sound
- Lazy o2 sensors?
- just got back from autozone...
- QUICK ?, will it hurt to drive w/ MAF unplugged?
- When to change springs?
- Race vs. Emissions?
- which pulley to get?
- ls6 heads
- LSX intake comparison test - which mag?
- questions on an 01 formula
- differences b/t '00 & '01 ls1s ? EGR? etc...
- intakes and fuel injectors
- Dart Heads????
- Car runs like CRAP, Help please
- Macdaddy's Z
- Head Gasket (part # ?)
- Which Cam to get???
- cam install
- 1998 LS1 Z, weird idle... help
- Cam Question
- Slave cylinder mod
- Want to ride in a car with a stall.
- misfire
- O2 Sensors for Bank 1 causing MAP codes??
- cat ? HP gains and gas mileage loss?
- Best heads for LS1
- What way to go ?
- Cylinder Misfiring Woes...
- Those of you with Pacesetter Headers
- I need help w my coolant level sensor!!
- over the axel true duals
- Worth it? header swap
- ls1 header swap and tune-up
- what would it take to produce big numbers?
- Need some help with price quotes that i got on head and cam package.
- What kind of shifter do i need?
- 6.0 crank offset for flexplate
- retarded question.
- high idle speed
- Quick question for you ls1 guys?
- LS6 head/LS1 header which gasket?
- Any maintainance I should do on my car at 40k?
- Air fuel ratio gauge
- 98 SS having starting trouble
- Fuel system
- What times can I expect?
- Question about lsx series motors....
- What brand of U/D pulleys perform best?
- PaceSetter header question
- Max horsepower??
- What tools are needed for???
- Oil Pressure at idle
- Heads And Cam?
- How long will it last?
- New Vette Pics and Vids
- Backfire at low throttle and WOT
- value of a used ls1
- Removal of AIR and EGR
- forged bottom end
- Thinking about Throttle Bodie's.
- Pulled Car From Storage Today & It Won't Hold A Charge, Any Thoughts?
- sound good? i think so :)
- horrible bucking from a stop
- MSD blaster
- Need Help, Header Question?
- Alternater Help
- for all the ls1 guys..im wondering about your fans..
- Is this a good deal?
- PCV question
- Should I reduce before or after the x pipe
- need help, please
- Patriot heads?
- LS1 Blocks
- This Season
- Has anyone tried the
- 11.2-1 OK with 93 pump gas? P/V clear?
- Help with sparkplugs!!
- Finally HERE!!!
- LS1 Fuel rail bore spacing & angle
- Fuel injectors?
- WS6: Lid/SSRA or Volant/FIPK
- LS2 Timing Chain Part Number?
- Cam only 10's?
- Something isn't right in my 98 z28
- What will my C5 dyno at?
- How long did your LS1 fuel pump last?
- Dyno Depression what gives (low dyno numbers)
- Pacesetter O2 System
- GM MLS Head Gasket Part#?
- need service advise
- dirty internals?
- Plugs/Wires
- SLP 160 stat
- Accessory belt?
- Ram Air
- What should I look for when buying a 4th gen Camaro
- Need help with exhaust decision....
- How big with 2.055 valves?
- cold air intake
- need matching heads..
- cam size question
- any help
- TR 230/236 or F14 W/DARTS?
- 02 SS headers
- anyone have these tips?
- Painting mishap!
- Can someone explain the differences in the Borla Exhaust Setups.
- Single Pattern Cam on LS1
- pcv location
- Any warning signs for?
- Strange Engine Noise(Vid inside)
- SLP loud mouth
- heads?
- stock cubes?
- Is it safe to...
- Leaking ?
- El Diablo
- Torque to Angle Indicator for head inst.?
- MAF clean, throttle problem fix!
- Power Steering Leak. . .
- Crackling Noise at Full Throttle
- Idle Problems Plz. help
- What anti freeze do you use?
- 6.0 to 5.7
- water pump ?
- fuel rail question
- Service engine soon?
- Fuel Pressure Question...
- sparks coming from under car?
- Installing Gauges -- Need HELP
- Identify the injector
- Headers and exhaust?
- Tsp Exhaust???
- No Power??
- Another Engine Noise Post
- hp sound right??
- Over-Drive?
- LS2 power?
- Really worth it?
- 2000 LS1 trouble code p1416
- 5.3 head question
- Cam and rocker arm?
- Air pump check valve
- seting timing
- dynatech supermaxx system
- sudden NO start....
- How is this cam?
- When is it time....
- What your best guess?
- Check out this 228?
- Anybody Know Of A Good LS1 Mech In KY
- Clean Carbon Off Top Of These Pistons???
- Best cam for a full bolton
- Self tuning using LS1 Edit, and some questions about O2 sensors
- Hogh Pitched Noise Coming From LS1 Engine
- Anyone have the P/N for a *STOCK* LS6 oil pump?
- cam instaliation
- LT Headers, Noise, Slow
- A few ?'s for you guys
- True dual muffler choices
- lamborghini gallardo!!!
- dual exhaust options
- estimated cost...
- Those of you with Pacesetter LT's
- Electric Cutout installed with powerstick
- y pipe and headers
- SLP cam&head pkg
- Header and exhaust question
- First Post! Got a Questions for you guys.
- Funny vid of my Vette:
- Funny story of shattered Valve Spring Seat...
- Another guess my HP Thread
- just odered Pacesetter LT
- TPS y pipe fitment?
- Procedure For LS1 Rocker Arm Install?
- What next?
- Dyno results for my Z
- SES code
- What it takes ls1 to break into 12s.
- Do i need a different air filter?
- Which mod?
- 2000 SS dyno numbers
- Stroker or cam/heads
- A Coolant Leak with a mind of its own....
- Edelbrock headers?!?!?
- crate engine problems
- putting a 383 in a 98 firebird?
- belt almost off?
- ls1 questions...
- ORY got messed up, what to do?
- Bad gas mileage?
- More Power Needed, Please Help, Currently Have 400RWHP/379RWTQ
- Edelbrock LT?
- What should i expect after the tune?
- slp underdrive pulley power gain??
- Anyone here have an LS1 in an S10?
- SLP Loudmouth and timming retard.
- Conversion?
- loudmouth bolt up
- Good deal?
- best pirce for LM?
- What do you think about this?
- Should I do it? Trade 95 LT1 T/A + Cash for 99 LS1 Z28?
- engine swap
- Will I loose TQ or HP??????
