- At what RWHP is it time to upgrade the injectors and/or fuel pump??
- How long will LS1 run ?
- Fuel Pressure Problem
- Cam Suggestions/Help
- Cam Identification Help
- exhaust question
- ? Patriot Heads
- SLP Question - First Post
- aftermarket coil options
- if some one could give me advice
- Differences w the LS1 in the 1998 to 2002??
- Coolant/Leak-Adding "the stuff"
- ls2 headers
- Exhaust?
- BBK vs. LS6 (Intake Manifold)
- WS6 lid
- y-pipe
- LS1 fuel system swap
- General question about the LS1
- Metal grinding noise comming from my engine!!!
- Switch from conventional to synthetic oil
- Can you switch from conventional to synthetic oil
- Clear MTI Air Lid for LS1 - any good?
- Tell me if I'm right?
- Qtp Headers?
- ls1 forged cranks which to buy?
- Stock operating temps of LS1?
- Starting problem on my 2000 Z28
- OHV PFI vs LS!
- head and cam setup
- What companies sell souped-up LS1 engines?
- Anybody running a Cheatr or Old man cam?
- Cold Starting Problems.... need HELP asap!!!
- Couple questions on my 02WS6
- what does it take to beat a cobra?
- I'm an idiot when it comes to cams...HELP!!!
- Why would my crank pulley wobble? HELP!
- Rebuild parts
- dyno/track results from DART LS1 heads?
- Lets talk Exhaust!
- O2 sensor question
- Right y pipe for hooker LT's?
- standard bolt ons
- Need help, blowing the ign 50 maxi amp fuse all the time
- Squeaking noise at Cold Start - Belt or Pulley?
- Need some help- LSX carb conversion not getting spark with supplied ignition box
- Quick water pump question
- 5.3 or pp stage 2 ls6
- Difference between LS1 and LT1
- EGR block off question
- Why Futral Motorsports cams are the best ;)
- Powersteering flush
- ls2 goat or 02 ws6
- LS-1 Stroker kit $4102.00?
- c5r vs sb2.2
- What Cam to use????
- Cam swap questions, *1998* specific,
- ?? Jet Hot Header Installation
- 2001 V6/V8 Engine Swap
- 98 Camaro Z28 - Red Top Optima Battery ???
- Help out a friend
- Lifter noise
- TR230 cam???
- Does anyone have the site where...
- Fra
- what does it take to get 650hp?
- Does this sound right? (Voltage Issue)
- new here
- Has any one seen the LS7 yet.
- Quick Question
- 02 Z28 Backfireing!
- Boring questions....
- LS1 boring question
- True Dual setup
- Horsepower
- ls1 spec
- Split Fire Plugs
- whats it take to get to 450hp
- 98-99 00-02 power difference?
- adjustable fuel pressure regulator
- Bolt ons where to start
- TR Cheater-Cam, Stock Heads and LT headers
- LS1 throttle body help
- How will I like this Exhaust Setup????
- newER car question?
- Headers
- help! cam&head????smoke from exhaust!?!
- MAF Ends??
- Question about true dual install
- LS1 vs. LS2; which has more potential?
- High RPM Miss...Suggestions...
- Idler pulley
- Exhaust
- change valve springs??
- Blown LS1
- LS1 WS6 Ram air exhaust on my 2000 Z28
- Power Programmer?
- looking at a 2000 z28 m6, what if any problems should I look for before purchase?
- New dream is it to much? LS7
- Question about some 6 speed cars
- Question about the 99-02 Camaro engines
- RPM at Idle??
- 98 LS1 lifespan?
- couple questions
- V6 to LS1
- Spark Plugs
- 383sb Questions...
- First Tuneup for Z28's LS1
- It's all here...
- Dyno test for Christmas!
- need new injector clip/plugin/harness...can I use an lt1 part?
- Speedometer, Tac, Odometer, and radio stopped working
- Help On Wiring a Predator Diablo Programmer
- BOLTON+CAM guys...w/stock heads...post your MPH/dyno
- Silly question
- Edelbrock intakes for LS1
- What mods are best for the LS1
- Coated stainless LT headers?
- 2002 ls1 question
- Best mods for a 2000 SS Camaro
- LS1 headers, primary length
- Check Engine/Service Engine - MAF error
- SLP airlid problem
- Sensor on air baffle - how to remove?
- LS1 block clearancing?
- cam
- which setup would u consider
- TB question!!
- Which one????
- What to do next?
- need help
- Evolution of the LS1 Camaro.
- FAST 90/90....what are they doing about the 75mm maf?
- Help
- Best chip for my 98 z28
- Painted Throttle body
- shudder after quick restart...
- 471 cubic inch ls2
- bigger, better MAF, Throttle body for LS1?
- Pics of LS1 crank pulley
- how to pass smog..?!?!??!
- SLP Y-pipe question
- O2 problems with headers
- How good is a 98 Z28 (LS1) with 122k miles?
- ls6 heads?
- Fipk, K&n, Slp, ??
- Wanting to replace cats.
- v6 to v8 swap, opinions plz
- Will lt1 body kit fit Ls1 fbody
- Valve train work
- Shop Quote: Plugs and Wires
- whats better Ls1 or lt4?
- exhaust problems
- Anything to look for in LS1 car?
- Differences between
- header install w/ Y pipe??
- mti R1 cam
- Electrical Problems? LS1 1999 Camaro
- Ses Light
- the right cam
- computer questions
- mustang dyno seems low!!!
- Oil pan Gasket
- What are these headers?
- induction options?
- building ls1 for high rpm
- Help
- advantage of AFR 205s over Dart 205s?
- LS1/6 manifold question
- Quick question on '02 header install
- QTP Header ?
- engine oil
- Can LS1 guys help w/ecu info on 8100 BB
- How much Torque
- Borla off road y-pipe
- Selecting heads and cam
- Poly motor mounts
- Buying LS1 Engine w/ 6-speed this summer
- Service Engine Light after spark plug change
- What gives??
- Engine work for dummies
- Beginner Performance Mods
- LS1 vs LT1
- Need opinions/help w/what type of headers will work best.
- street legal cam??
- 95 Z28 needs motor
- edelbrock headers
- does LS1 have lowend torque
- Woes about switching to ls1.
- Is there any difference between 98s & 99s
- Aftermarket MAF vs Ported/Descreened Stock
- a4,,m6???
- what the owners manual says
- Why are some of the ls1 guys on this thread so spitful
- LS1 valve spring I.D.
- Off-throttle response
- header install ?
- Selling my 93 Z28 and buying a 2000. Have a few questions...
- Which LS...
- LS1 to LS7 or LS6?
- EGR with LS6?
- Loudmouth II + Headers?
- Are these heads worth swapping
- stock cam.......?.........?
- A4 Vs M6
- 98 LS1 swap into 02 car?
- California Smog?
- LS1 street cam
- What do stock firehawks put down?
- Heads and Cam
- accurate o2 sensors???
- how big can and ls1 go?
- What do you think
- new Firehawk
- ls1 block integrity
- New exhaust...
- Rear wheel HP rating on 00 SS
- Headers not the normal question
- Should I be worried?
- HELP!! Header install, mac mids
- I made the Big Change
- Emergency Please Help Me!!!!!!!!!!!
- need fuel part #s
- SES P0442 - 2nd time
- Throttle Body Spacer?
- Serp belt....
- LS2 Swap
- "ASR OFF" light is on
- 98 T/A..is it a problem?
- Full Bolton Numbers
- Will Truck Throttle Body Work? Worth It?
- P/N for 02 LS1 fuel injectors...
- Stock Intake On 98 SS???
- Need Advice PLEASE!!
- have you ever...........;)
- Trans Am --98
- Installing/buying a 2 step.
- What do you think
- ls1 misfire
- mid-lengths any good??
- Cat Back Suggestions
- How tame can I build a mid-11's heads/cam LS1?
- Dyno Tune?
- Slight lope in idle on stock cammed car
- ls2 oil pan
- Piston Slap while Warming up
- Squealing
- LS1 Burning oil???
- '02 LS1, common CE code?
- Futral Motorsports does it AGAIN! AWESOME!
