- cam and head question
- Quick!! I Need Tq Specs!!
- LID or K&N Setup
- NEED HELP!!! WEIRD LS1 Sound....
- Car will NOT start. Need help!!!
- What weight oil does everyone run???
- Coil packs and Missfire
- Octane
- Need to upgrade Clutch
- Funny noise from LS1
- Okay Ls1 Guru's Come Inside
- Edelbrock LT headers with sportline springs??
- What would be a good exhaust system???
- Turning a flywheel when replacing the clutch?
- Who has went carbureted with their LS1??
- DMH e-cutout electrical?
- LS1, LS2 and LS6 differences????
- Tranny swap question
- Hooker Headers
- Changed O2 sensor still not running right
- Which coolant for LS1?
- Help! Engine Trouble
- Lids
- Borla?
- Looking for Header Recommendations for 98 SS
- Loudmouth Vs Loudmouth 2 Which is better?
- Bigger injectors
- Buying C5 on Sunday, Need some input
- Diablosport Predator
- Need Advice!!
- Bassani Exhaust
- Launch
- Rear End Whine (yes i searched, have a ?)
- No oil at startup/#5 cylinder misfire
- Header Installation
- Car warms up, then low idle and oil pressure after driving???
- Question on LS6 clutch
- I've got some problems...
- LT Header Question?????
- new rockes for a 408ci
- Lt1 Vs. Ls1 in 94' Camaro
- Car wont start after Intake Install. HELP!!
- Chip
- Intake Manifold
- Car Won't Start
- Finally got me an Ls1!
- Ls6?
- Best Cam??
- So I ordered an 18'' chambered muffler......
- the right cam
- My ASP Pulley seperated! :(
- mac ory
- My LS1 traps 97...help!
- Driving..Oil Pressure Gauge Drops to 0!!!
- Service Light HELP
- Smooth Bellows
- Ls1 Question
- egr sims
- dual flowmasters
- Anyone else have center-mount SLP dual exhaust that is broken in half?
- TSP PRC Stage 2.5 Heads or Stock LS6 Heads ?
- Ok guys, you're the experts. What is wrong with my car.
- SES Light - Engine Hesitates...Lean?
- Guess My Dyno Numbers
- Changing oil pump, what else?
- Ls1 spark plug change...
- headers
- Some Info on Precision Race Components Cylinder Heads!
- Temp guage problem...
- Testing an Idle Air Control Valve
- GM changed spark plug gap for ls1's!?!?!?
- Gen III motor build up
- Disapointed With Track Times
- Dynatech Supermaxx Headers
- Borla Adjustable Catback
- sweet thunder
- what to do with AIR and EGR with LT install, 2000 ws6
- Shock installation Info needed
- Installed pro 5.0 today, forgot 1 thing. suggestions?
- thermostat questions
- Mods: Need Advice
- Hints, tips, suggestions...
- ls1 swap into 78 delta 88
- Dex Coolant/Every 5 Years?
- o2 sensor help??
- lsx intake question
- just uploaded pics of various 35th anni SS things many of you may not have seen
- K&N Filter question?
- sspddmn
- how much louder
- help on selecting the right cam for my 98 Z28
- Anyone know if the power steering pulley...
- ls1 exhaust what brand should i look into
- Flowmaster 70 series or 80series which is better overall?
- Stock vs SLP MAF???
- LT headers...what all do I get?
- need help changing wiper motor
- thermostat?
- A question I've had for some time about Ultra Z hoods and SS Hoods
- Should I feel bad...?
- safe to use comp cam 522-529 lift on a stock springs
- starter problems
- SLP Performance Pac's, has anyone ever used one?
- 140mph limit???
- High Idle of SS Camaro 6sp.
- '02 Z28 A4 LS1 stock injector question;
- need help on a ls6 svalve springs
- help
- What Cam??
- $ 5000 To Play With
- Sudden Power Burst @ WOT
- Stock Z28 Exhaust Tip Question
- Problem with headers
- TB bypass mod?
- 01 Z28 Tune-up ???'s
- fuel injectors
- PCM tuning?
- Car sputters and pops what the hell!!??
- LS6 Intake hardware..???What do I need?
- Brake help!!
- Where to improve?
- When will I need to upgrade injectors???
- stroker benefits?
- ORY w/o simms...
- in know this is stupid but help please
- Why are my spark plugs like this! HELP!!
- got new SLP center-mount exhaust tips in the mail today -have new bracket thing
- Exhaust smells kind of sweet and tips are black around edges......HELP
- Terrible screeching sound, can someone help me??
- 5.3 heads compression?
- throwing around true duals ideas...
- Cam too big for daily driver?
- Port and Polich yourself???
- off road pipe
- Pacesetter LT Headers
- Rough idle...poor mpg....no codes
- My Dyno Numbers
- LS1&LS6 engines
- Stock rear ratio.... pls don't flame
- brake problem
- Tune Up?
- PCM question
- Help!!!!!
- how much power?
- ditch my borla?
- overheating ??
- Ported Heads and Stock Cam
- GM Top engine cleaner, did the search but have questions
- Cylinder Mode Misfire Index(Counts)???
- Thinking..
- Questions about 2000-2002 Z-28's
- Ported T/B
- Had headers installed?? check this out
- ls6 with headers
- stock cats with headers
- What are the best headers out there?
- FIPK by K&N?
- Steering wheel shutter?
- Help wiring gauges
- Advancing 02 LS6 cam
- 2002 Camaro Among best for 3 year Dependability
- Small & Large Hp Short Blocks Now Available!!!
- Can I look at an LS1 engine and determine what year car it is out of?
- Head Porting for 02 LS1 heads in Ga?
- test drove a mustang gt, ha ha!!
- engine backfire...Please help me
- different mods and fuel milage
- LS1 Throttlebody bolt pattern dimensions?
- Power cut when I turn the car on.
- What else do i need to run with this 96 LT4?
- the little mods...how much do they really do?
- break in?
- SLP Headers, more power w/ w/o cats?
- anything i need to know?
- Why is my car blowing the eng ctrl fuse?
- WHY THE HELL does my belt keep trying to come off?
- What are good pads and rotors to switch to on 16" rims?
- Intake manifold question
- SLP loudmouth II OR HOOKER cat back??????????
- Tensioner Noise - Question
- doing an ls1 swap
- UPDATE:Overheating problem because of P/S Cooler
- rubber hose on 2002 intake
- HELP overheat and now Knocking!
- metalic ringing noise from front of engine when warm
- Cam Swap on an LS1 style truck motor
- Xpiped True Duals......or keep the GMMG?
- Anyone with TSP Duals...
- Hotcam Kit Question
- OEM throttle body
- bank 1, is the drivers side right?
- belt squeak
- need opinion please
- missfiring ls6
- Anybody ever use Slick 50 in their LS1 ?
- This should be fun. Put these in order
- Rhoads lifters
- LS1 Exhaust Header Differences?
- buying a 02 WS6..little help
- IMPORTANT: 5.3l LS1?
- Im getting an ls1 and selling my lt1. What do i need to know?
- my friends 00 Z wont catch 2nd w/ TC off...
- LS1 manifold question, interchangable by year 98-02??
- 6.0 using oil.
- Tornato thing
- Installing a new Water Pump please help.
- exhaust pictures please!!
- need some opinions and advice.
- Low RPM hesitation
- LS2 "Auto Vs Manual" Big diffrence?
- Temp still says 210
- car wont start
- Got a 02 WS6
- SLP Dual/Dual and/or Spintech w/Mac's owners inside please...
- oil for piston slap
- Cam Questions
- Big power in an A4
- LS1 "freescan" and ALDL cable
- LS2 Question
- best fit/install and performance exhaust
- 0W-40 Mobil One?
- So What Next?
- Check engine Light
- How much can HP change due to outside cond.?
- Pacesetter LT/TSP True Duals with Cats???
- what to look for?
- who has rebuilt their engine theirself?
- High power A4 pt.2
- Does my camaro got a chip in it???
- Intake Manifold?
- Pics of engines???
- Coil relocation brackets???
- install kit for headers..
- stalling when tipping into the gas??
- headers
- How do you check to see if/where you have a vacuum leak?
- Have questions about Borla cat back
- cheaTR or Comp 224 CAM?
- Best exhaust/ Best airlid
- Please Help, Random Misfire/Lean Condition!
- What's the avg cost for 02 ls1
- Ugh! Lack of Power in 2000 WS6
- Attention Misfire/Ignition wizards!!!!!
- People with pacesetter headers
- Thermostat
- HELP tranny temp gauge installation problem
- magnaflow and z28 ground fx problem
- Purpose of pin connector in alternator?
- Lifters and Cam removal?
- spark plugs
