- intake manifolds?
- My Tires Rub
- few easy specs q's need answer fairly quick if you please
- Whisper Motorsports cold air system
- good headers and y-pipe?
- Factory Exhaust? Skip Shift?
- Electric radiator fans
- 98-02 K&N FIPK
- whoops! broke a wire....
- Anyone have the powerflo exhaust from SLP?
- newbie LS1 question
- Putting $2000 into car let me know if this setup looks good
- Curious LT1 owner: how hard to make LS1 500 rwhp NA?
- 6.0L LS1 in Escalade
- Problem with stock air filter and SLP lid
- oil pump gets starved during super hard braking procedures
- CAGS vs Me
- Damn they were tight
- whats to gain from a hypertech programmer
- z06 MAf in LS1
- 1.85 roller rockers and a supercharger?
- Re-Useable Filter vs Paper Filter
- LS2 heads?
- who has the best price for the TCI torque converter for the LS1?
- part number of LS1 and LS6 intakes...
- Is $4000.00 a good price?
- Sparkplug questions?
- Speedo Recalibration with Hypertech after LS1 Edit?
- MAF questions???
- Will the FIPK work with aftermarket MAF?
- Hpp Iii
- Headers for my 02 SS
- Weird one... oil leak... but not what you think
- Aluminum driveshaft in stock '98 LS1?
- Help! Car won't start
- Please help a Z28 owner in the UK
- Nitro,Supercharger,Turbo
- T-stat question
- C6 427 Engine in a 98 Firebird
- cam selection
- anyone ever heard of "diablo" programmer?
- Real Gains with Predator
- my A/C exploded, need advice
- Need your oppinion
- what dont i need?
- cooling
- about my stock rims
- NEWBIE: Which parts first??? 1999 SS
- pulley assembly
- I want 430+ rwhp...what setup should i go with?
- New Dyno #'S
- TSP torquer cam
- Is a 3500 stall to much for a stock engine daily driven LS1?
- stalling engine no codes
- how much of a gain.
- Where the heck is it
- Diablosport Questions
- 2002 LS1 Has A Slight Miss
- power gain... but a backfire???
- Vararam Velocity Stack
- LS1 Block avaliable?
- ASR light
- Alright i need a rough estimate on how much this would cost...
- FlowPac or FIPK
- no fire or injectors on passenger side
- friendly tip/reminder to 98 - 99 LS1 f-body cars
- guys with Ls1 A4 trans that have deleted TM how long has your trans lasted?
- header length?
- ANOTHER header thread
- update on plug swap...
- *Help* Fuel return line - Pro Charger
- Exhaust Note
- Anyone familar with this muffler?
- A Header is a Header????
- Car has vibration at idle
- Filter test
- removing exhaust... need help quick
- Free EGR mod question
- PS & Oil coolers
- Finally Installed My Headers
- Interested in an 98 SS got a few questions..
- TB and MANIFOLD
- HELP, please
- a/c cycling switch question
- HELP!! Where to buy 02 Sensors!!
- Vacuum leak??
- Ordering a cam... (pretty detailed)
- 98 LS1 Surpise Shutdown...
- Added AFR205's to my 230 cam results...
- dang.. didn't expect this at 13k... problems...
- Hooking Up Air/Fuel gauge
- Smog Question
- Stupid Brake Question
- stroked ls1
- How to make more HP out of a ZZ430??
- Stock ls1 goes 12's
- Ticking (Not Piston Slap)
- Need some help please!!
- Looking into buying a Z28 or SS
- DIY mods...where to find them???
- EGR and Air Pump delete...
- Whats to gain from an underdrive pulley?
- Just A Chevy Question?
- Should I buy headers or not?
- Clutch Problem... ??
- lt1 or ls1
- Engine Mods
- Patriot heads
- Got my car on the Dyno...this look right???
- questions about installing my B&M trans cooler
- True duals improved my 1/4 time!
- where are the PCM BAT and fuses
- 78mm ported throttle bodies, where to find
- 3 Engine Codes
- Guys that run low 12s w/4.10 gearing
- MTI head and cam products?
- SLP Lid Question
- Clicking sound at high RPM
- lobe separation
- Worst accuring LS 1 problem?
- Let's talk about cat-backs...
- ANOTHER head and cam question
- Colder plugs and 160* thermo cause emissions test failure?
- Got a formula
- Power window problem
- v6 to v8 swap... long, and part list inside...
- Precision Race Components Cylinder Head Specs & Pics!!
- LS6 intake, do I need other mods aswell?
- Valves Sticking????
- How much does it cost to get the differential oil changed at the dealership?
- I want jethots and orp, any advice?
- Cam installation question
- O2 Sim Question
- air temp module?
- 400hp at the wheels? realistic builds and cost?
- need quick help with shift light install
- How much HP? SC ?
- Headers!!!
- Time to change O2 sensors
- 305 Tires hitting Wheel Well
- Pilot Bearing install ?
- Cam choices
- What Exhaust Tips?
- Anyone have this book?
- True dualers inside plz
- what stall would you guys get for your LS1 TCI or YANK?
- porting the MAF
- ls6 intake
- ported throttle body and smooth bellow
- Rear-end clicking noise w/ an M6...do any of you hear it?
- Intake help!!!
- "LOW OIL" Lamp want go off - Oil is ok
- Hooker lt install questions.
- what is a cutout?
- Tuning a stock car
- Getting past the SES light w/ headers
- 2000 Camaro SS vs. 2000 Audi S4
- Belt Tensioner
- still idling rough..
- Time to change speedometer detting?
- brisk premium LGS spark plugs
- header/emission questions
- UPDATE some of you asked for on my tranny troubles...
- 2000 SS cam
- Need to find Center exhaust tips
- Pulling Codes.
- Quick LID help, working on it right now
- DTC P0751 what could the problem be?
- Gummy Orange coolant-- head gasket?? HELP!?!?
- Don't know what kind of CAM I need!!
- gigliotti g2??
- Y-pipe
- Help: Coil Pack Help
- Turbonator
- Gutted cat, worth it?
- Loudmouth II with LT?
- removing cats for track... will ses light cause retard or loss of power?
- Need Y-pipe with cats for flowtech long tube headers
- engine light after installs
- Highflow cat and back pressure?
- Need help about buyin a chip??
- Oil
- intake side question
- Anyone know how I can pass emmissions in Indiana with long tubes??
- 99 T/A trouble
- overheating problem
- Harland Sharp 1.8 RR's
- LS1 engine removal techniuque
- help please anybody! exhaust related
- aftermarket y pipe on stock ls1 ?
- What are some typical LS1 Problems?
- slp air lid?
- FINALLY ! the chirping sound is gone
- Whats a good company that sells 98 ls1 long or short blocks?
- chirping noise
- Your Dyno # Winner Is
- Aftermarket LS1 Perimeter Valve Covers
- will flowmaster series 80 from LT1 fit LS1
- benifits to header size?
- burning oil
- no muffler vs. a cutout
- rubbing noise
- Clunk in the Rear.
- would a 3000 stall be good for my 373 gears for my Ls1?
- How big is to big?(exhaust)
- Gears are next-
- Bead Blasting Aluminum Cylinder Heads???
- my brake is being... MEAN
- need help deciding on tuning
- Lotta squeeking on my 02 frnt suspension?
- I seem to have a squinking noise from the back.
- i put 1/4 quart of oil more than required, is that ok?
- Some stuff is in!
- Myth?
- TSP Torquer Cam - results
- Stock performance numbers?
- Fuel Pump dying?
- experienced cat back owners
- Today I recieved my TCI 3000 stall for my Ls1 and I have a question to ask.
- New Car and need some ideas..
- 500 HP to the wheels?
- Stock 00' SS........273 rwhp on the dyno correct?
- what size gauge fits perfectly in the square opening of the console?
- The BEST LT Headers?
- exhaust gaskets
- anyone looking for a smooth bellow..but dont wanna pay 30$+..try this place
- LS1 Spec 3 clutch more reliable than the LT1 version?
- Disadvantages of a 5.3?
- Which is better TR224/TR230????
- Engine prob.
- 425HP LS1. What would I need?
- fast idle?
- Clicking sounds underneathe my 00' T/A while shifting from first to second??????
- Lane's True Duals pics
- LT's w/cats VS Mids w/cats
- Selling my 98 V6 3.8L .. What should I list it for??
- Removed C clips from the transmission line and still the lines won't come off
- dyno for LS1 hotcam
- Good deal or not?
- which is better 98 or 99 for this price...
- Cam Info
- 5.3 in a corvette
- Deleting the EGR worth doing on 98 to 00 Ls1 models?
- cams
- After Headers SES can't be removed
- Question about installing my torque converter in my LS1
- So i was looking through my paperwork on the car i bought
- Need a new oil pan...
- tools for the job???
- Check Gauges Light????
