- $500 What Mod??? HELP!!!!!
- MAF question
- Need help!! Which tires??
- 53 degrees, low humidity, 14.2's @ 99mph ...
- How much air pressure to change springs?
- SLP 85mm MAF on a 2000 SS A4???
- 130 mph rattling
- How much horsepower do i have?
- LS6 springs w/ aftermarket cam???
- Traction control and ABS HELP
- Jet hot headers
- Realistically... whats right?
- oil changing
- Simple ? for you experts
- Engine balancing question.
- Stripped bolt
- Engine balancer/pulley
- Egr And Air Pump Removal
- oilpan
- Question about Pacesetters
- Need help!!! Leak!
- Too loud?
- Service Vehicle Light - NOT SES
- Couple Questions?
- Dyno Locations in S IL or N WI
- FM14 Cam - Video
- what next
- True Duals
- large cam question
- Miss under load
- pissing power steering fluid
- Oil change light on during recent freeze
- exhaust and oil
- How do you make the temp gauge functional on 99+ cars.
- LS2 Intake or LS6?
- Valve cover leaking
- Manual valve body
- Service engine light flashing?
- 52mm throttle body
- Why exactly do you guys change the "Lid"
- Nasty noise from rear suspension
- SLP Lid VS FIPK??
- Idle + Running Problems
- Safe to use synthetic on a high mileage LS1?
- Supertrapp
- Need Experienced Advice
- Kooks Catted Y pipe?
- Bbk Ls1 Intake Manifold?
- Which exhaust setup?
- LS1 problem
- EGR problem
- Underdrive Pulley Safe?
- what size cam and......
- 160f Thermostat
- Clicking noise coming from under console area......
- Anyone tried to add adjustable stops to their factory Hurst?
- LS1 Valve Covers
- DRL / Blinker Doesn't Work
- Low RPM Misfire / Stutter
- Happy Valentines from HPE
- cam help
- Jet Hot's or Not?
- Should i change my belt?
- How many quarts of differntial fluid will i need?
- Cut-out and O2 sensor location
- Is there just one belt on our LS1s or is there 2?
- New SLP Throttle Body
- SES light with Long headers
- 93 lt1 fbody hypertech thermomaster chips for sale
- ecm year question
- SLP Headers but which ones?
- Will O2 simulators fix Check Engine light???
- Y-pipe hits bottom of car...
- Good Transmission shops in NNJ
- i just changed from synthetic oil to regular..
- what is the diff between an LS1 and LT1
- over the axle heat shield for exhaust.
- Misfire help!
- What numbers do a 6.0L LS1 Iron Block Engine Make?
- SLP Blocks
- torque-eee cam help
- Have you enjoyed your pacesetters?
- internal difference 98-02
- Amsoil? anyone used it
- Just put my SLP lid on had a question
- Metal buzzing sound under the car, 2000 trans am
- Who is running Flo-Pro twisters
- cause of noisy engine
- Whats the price range?
- SLP Loudmouth vs SLP Loudmouth II
- WS6 Stock Air Box Lid
- Switch oil grades 5W30 to 10W30 after 90k?
- Induction Upgrades
- Is the bellow going to the TB really that restrictive?
- Automatic Headlights....again
- Headers....
- How loud & smelly are cat-less long tubes?
- What to do with $2500?
- ( Pocket PC ) OBDII Scanners / Data Loggers requested – recommendations?
- ?? for those with 5.3 heads on their LS1..
- Help....what cam to use....
- EGR removal
- help need stroker engine
- 9.6 sec stock engine ?
- cam question
- engine ping and SES light
- Whats next?
- LS6 intake
- Car cover quiestion
- right direction?
- Pos '98 Oil pump going...consumption too? Options.
- Wrong slp lid
- building up a stock 01 SS
- Borla XR-1
- What first Nitto's or bolt on's?
- 8.1L in an F-Body
- Pacesetter ORY fit LM Intermediate?
- Rod Length Question
- Need some quick info on a few parts.
- Race Gas worth it?
- First Mods but now I have stalling??!!
- Jerking at low Rpms
- RWHP Gain fro a Cat-Back
- Magnaflow opinions??
- Finding the Perfect Cam and Headers
- Charging system ?...
- What you guys think??
- How long for pacesetters install?
- internal engine cleanser?
- *WARNING* Cat-back melting the gas tank...Found when putting on the true duals.
- QTP help???
- Anyone have the new SLP Loudmouth II muffler
- Intake hose?
- How high can stock LS1's rev to?
- This dont sound right.....
- What next?
- pro 5.0 shifter too tall....
- Afr 205 Vs. Stage 2 Ls1
- What gears do i have??
- Help Identify an LS-1
- skip shift light comming on...
- Horsepower
- what are the suspension differences from regular trans ams and ws6 trans ams?
- 02 OEM flywheel question
- Intake Manifold
- Am I missing anything?
- 2001 z28 egr system
- 1LE VIN check...
- Installing Flowmaster muffler...
- Dumb question about thermostats
- ls1 borla on lt1
- Patriot 226/226 585/585 112 Cam? $279?
- Engine belt Q
- converter or exhaust
- 408 Short Block Buildup (I need Suggestions)
- ASP Underdrive Pulley??
- piston slap ?
- what to do next?
- EEC # for 2001 SS?????????
- headers??
- Want to buy AC Delco rapidfires have a question
- Check Engine Light?
- Exhaust ???
- Y- Pipe removal= HP????
- Don't waste your money with bbk
- LS6 Really 405hp? Or over rated?
- track numberd on stock SS
- How hard would this true dual system be to fix? (pics)
- heads & cam
- Injectors Clean?
- Starting to Mod for the Spring
- TSP Rumbler Help! please..
- Catback??
- Best 1/4 Wheels/Tires
- will a borla exhaust off a 95 lt1 fit my 02 ls1 trans am? please help
- Cam: what do yall think of this one??
- V6 Supercharge or V8 Engine Swap?
- Spohn Solid Engine Mounts !!!
- FIPK vs Volant vs Lid + CAI
- Series I Dominator cam
- New Cam..Does this Sound Right?
- NEW 38 lb/hr injector sale
- Car has 65K miles on, what should I replace?
- Any tips for changing spark plugs?
- How difficult is it to swap heads ?
- check engine light
- 3.73 or 4.10s??
- free mods?
- Charging problems
- Can i see some pics of a FIPKII ?
- Question on SLP Loudmouth exhaust
- Computer Programmer
- Any interior resonance/drone with Rumbler catback?
- Edelbrock exhaust vs Flowmaster
- Other Mods?
- Just bought SLP Loudmouth exhaust have question
- air lid VS K+N FIPK
- cam question
- Gasket??
- catback exhaust
- which Headers?
- Replace Belt Tensioner / water entering scoop?
- ticking sound when shift out of park to D
- FM14 Cam Results. True Cam Only.
- o2 simms install help
- SLP Loud Mouth 2
- Location of PCV valve on 98 T/A??
- LS7 Head Flow Data
- Sound clip of my duals
- Possible Fuel Gauge Problem
- Damaged Jet Hot Headers?
- ws6 air box vs stock air box
- difference between zo6 and fbody slave?
- Security system diagram
- LS1 Valve Timing Needed
- what kind of gas milleage?????
- 1.6 rocker arm question
- tell me what to buy first for 99 z28
- What Should This T/A Run?
- Which year is the best for an LS1
- wet tires give bad dyno reads?
- Power Steering Pump
- c5 Vette hp= to z06?
- c5 Vette HUD
- Ok... i know EVERYONE person here will call this BS... but....
- whats the best quiet performance torque arm for the LS1 f bodies?
- Cost of new header gaskets installed
- Gettin a cam.....what else do i need?
- horsepower tv: LS-gun...... lol
- 1.7 Roller Rockers
- Dynatech Header System
- Best Gauges for N/A Car
- code p1416....getting mixed info
- one cylinder missing...update on old problem
- New website
- Opinons?
- is removing the torque management a good thing to do?
- What Camaro?
- Is this Torque Management?
- 510hp LS1?
- ASR light
- programmers?
- switching LS-1 to carb?
- Pacesetter LT's Pic's
- What size socket?????
- spark plug swap
- RPM limiter
- MSD coils...
- 98 Ss Just Starting To Mod Any Suggestions?
