  1. What is the performace difference between 1997 Z28 vs. 1999 Z28
  2. stock SS RWHP
  3. o2 problem please help
  4. Lowered with 2.5" true duals... --Pics--
  5. Can someone explain the LS1 vs. LT1 fuel,system to me?
  6. Which heads? LS1, LS6, or 6.0L?
  7. The time has come...how do I replace my EGR valve?
  8. Dont Laugh Intake Question
  9. O2 sensor interchangability
  10. Need some help with coolant light
  11. Oil change.
  12. Short block
  13. AC Delco Rapidfire or NGK???
  14. y-pipe help please
  15. FAST!!! need help on MTI Clear lid(2000)
  16. SLP lid question
  17. LS6 block and comp
  18. Ls1 Airlid-will It Fit My 02?
  19. Just got a LS1
  20. differences in 98-00 LS1, 01-02, and LS6 cams?
  21. o2 or cat... what to do?
  22. Buying Cutout- Got a few questions.
  23. Keep Poping Pcming Fuse. Any Ideas
  24. Help!
  25. Ram air hood with no ram air (pics)
  26. ASP Pulley install--- charging issues now..
  27. ls1 air lid
  28. Dyno #'s
  29. I got one for you guys....
  30. How much do aluminum heads weigh?
  31. 99 v8 leaks water from overflow cap?
  32. What should I do first?
  33. TNT F-1 Kit with Aftermarket TB
  34. Weld draglites? What specs
  35. whos uses hypertech and what setting do you use?
  36. Need Help!!!
  37. knock retard...
  38. 99 z, buying new heads, center or perimeter bolt valve covers?
  39. loud mouth
  40. dual/dual part numbers. help
  41. LS6 PCV conversion??
  42. Exhaust help for a Camaro lover in the UK please
  43. The Volant CAIS really has made a difference...
  44. OPINIONS: Texas Speed true-Dual Rumbler exhaust
  45. LS1 Pushrod Warranty/Recall on Pushrods?
  46. car making ticking noise????
  47. Help!!! Car not running right after ASP pulley install
  48. Ls1 programming!
  49. Help for a newbie?
  50. Rattling sound on acceleration
  51. misfires that don't set blinking SES light
  52. Where should my a/f ratio be at?
  53. e-cutout question
  54. 99 to 98 water temp sending unit conversion?
  55. I want my WS6 to beat my 03 Cobra...
  56. 2001: Light squeal from front of engine
  57. low dyno numbers
  58. AP Engineering - groundbreaking news! Guaranteed engine delivery times!
  59. What headers for lowered T/A?
  60. Electric water pump worth the $$$
  61. amount of psi?
  62. Clearance issues with milled heads/cam ?
  63. electric cut-outs
  64. Why get an ignition? + one other ?
  65. Car Redlines Too Easily With New Exhaust
  66. ls1 to ls6
  67. Squeak Squeak ... not the tensioner
  68. drove a 1998 vette, why does it acclerate diffent from my 99 Z28
  69. Engine Seems Loose in Bay
  70. How well does Hooker Cat Back flow?
  71. Wheel hop?
  72. fuel filter worries
  73. How much can it handle?
  74. ls6 cam installed
  75. rattling sound when going into gear?
  76. Header Question
  77. need ls1 radiator support picture!with airlid off!HELP PLEASE
  78. I didn't want to have to ask...
  79. My f*#@$ing flowmaster fell off!!!!!!!
  80. Air Boxe lids
  81. What do you guys mean by "Free Mods"??
  82. will o2 sensor affect hp?
  83. couple quick PVC questions
  84. Ported my tb and now it wistles
  85. Poor performing Heads cam car, need help! Long post
  86. Sealing air lid with electrical tape?
  87. How do you gain HP/TQ from a pulley?
  88. buying an ls6 block, few questions
  89. True Dual on my TA question.
  90. 160 Thermostat
  91. The New Guy
  92. Weird idle problem yesterday, questions, possible map sens?
  93. Newbie question ...
  94. Duals are on. PICS
  95. Michigan People
  96. Should i mod my high mile SS?
  97. Can the GM dealer do this to the computer?
  98. Lunati vs hotcam vs custom grind
  99. Spark plugs
  100. Canaries under the hood at cold start
  101. how to tune engine with Predator if i can monitor O2s
  102. How much will gears knock off in the 1/4?
  103. BG ram air kit
  104. rattling exhaust
  105. How am I doing?
  106. Nov Chevy Hi Perf LS1 tests
  107. police packaged LS1
  108. LS1 32/37lb Injector Sale
  109. Pacesetter vs Flowtech
  110. headers
  111. How many ponies do I have?
  112. LS1 hot cam vs. LS6 cam
  113. Squeal when a/c clutch engages; stops when disengages
  114. torque?
  115. Just installed alternator; now low idle and low charge
  116. Charge is fine when I start it; drops into yellow when e-brake is released
  117. How can 422 CID Be an LS1?
  118. cats
  119. anybody have # or no store that sells updated PCV
  120. NEED HELP on cam selection...
  121. lt1 guy looking to upgrade to ls1 some Qs
  122. Help with cutout ?
  123. stock LS1 valve stem diameter?
  124. Just had oil change
  125. A/c Delete
  126. Tape Around Lid
  127. mac headers and off road y-pipe?
  128. Race-Prep 91 octane 434 auto C5 makes 530 RWHP!!
  129. 02 sims for off road Y pipe
  130. LS1 coolant lines in stock?
  131. Need to know ASAP, and none of the ls1 forums have been ANY help...
  132. What cam is this Lunati????
  133. cold air induction kit?
  134. To Much Coolant In Resevoir, How to Drain.
  135. Rev limiter
  136. Anyone running the Spintech Catback?
  137. this is a stupid question but....
  138. wondering what track time i can expect...
  139. Have a Local Yokel Resleeve My LS1?
  140. stock 00z28 track times
  141. Running Rich???
  142. mac mid length cats any good, are they pretty freeflowing.
  143. LS1 Bare Block for $300, Good Price?
  144. 1st To 4th Skip Shift
  145. looking to get headers
  146. build your own CAI?
  147. 6.0 iron block vs 5.3 aluminum block
  148. New Best - 13.3 @ 109.7
  149. another damn header question
  150. Wondering about Cold Air Intake??
  151. LS1 Mods
  152. What mods should I do first with a stock '99 TA
  153. Whos cammin?
  154. *PICS* of MTI Clear lid
  155. Will a direct aif flow lid for a 2000 work for a 98?
  156. ZL402 6.0L motor
  157. when using band clamps for y pipe/header install should i use alum. foil?
  158. LS6 in a S10 ?
  159. Forged rotating assemblies noisier?
  160. What kind of lid?
  161. Problem with my LS1 Formula :(
  162. whats the prob?
  163. Thermostat
  164. Looking forward on buying an LS1, A4 or M6?!!?
  165. Most disappointing modded ls1 I've seen
  166. cold-air induction
  167. SLP Dual/ Dual on 2000 SS with restrictor?
  168. What to look for when buying an '01 or '02
  169. cam a tooth off?
  170. Engine overheating...
  171. questions about LS1
  172. what is specific about 97/98 heads?
  173. QTP Headers are in!!!
  174. Cutout and flowmaster
  175. pinging??
  176. ported maf
  177. t-rex cam questions
  178. cutout location
  179. header installation...
  180. LS1 Exhaust Pipe Sizing
  181. free LS1 mods?
  182. Ordered Headers Yesterday...Couple Questions
  183. cheapest place for o2's
  184. feul pressure regulator
  185. rough runing LS1
  186. Can LTs be Connected to Y-Pipe?
  187. A Peak Inside The Engine Of The APE Shop Car
  188. K&N Filters bad for ls1's???
  189. My T/A did something weird yesterday...
  190. y-pipe question
  191. 3rd gear, A4
  192. Car Confused?? Please Advise... :(
  193. MAC Header questions for my 2000 Z28
  194. what is the deal with msd 8.5mm wire hard on ls1 coil pack???
  195. ls1 making strange sound
  196. got a question...
  197. Y pipe fitment
  198. ls6 heads/cam/intake worth $1k??
  199. SSRA or SLP cold air-induc.
  200. looking to make more power
  201. Car won't start
  202. 1000+ hp
  203. Need opinions on cam
  204. Check out these prices...
  205. Another Header Question
  206. Aftermarket accessory switch mounting options
  207. K&N Cleaning Question?
  208. What mod to do next?
  209. Any install tips
  210. Buying a 98 SS.
  211. Which MAF is the best?
  212. Rear
  213. Difference between each year?
  214. Window motor install
  215. Baffle Removal on WS.6
  216. need experienced header feedback
  217. prothane trans mount is to big for the 00 Ls1 camaro?
  218. Hooker Super Competition Headers
  219. 2002 Camaro vs 35th anniversery?
  220. help!! trans mount problem
  221. whoa
  222. engine knocking?
  223. would the gm dealership replace my oil pan gasket under warranty?
  224. LS-1's Do's & Don'ts
  225. changing valve springs...how to tell when piston is at it's top position
  226. LS6 Cam
  227. Noise
  228. Cold-Air Induction Package
  229. Can't clear SES light
  230. Problem Areas
  231. whining??
  232. new 180 sat. need fans to come on at 180?
  233. how to change lifters
  234. engine oil / gasoline scent????????????
  235. anyone uses the deep trans pan for their Ls1's, if so how many total quarts to use?
  236. M1 Oil Filter
  237. camshaft ques...
  238. Rod length
  239. New Heads/Cam to be installed next weekend
  240. Is this possible?
  241. Piston Slap?
  242. 180 stat
  243. K&N Filter oil?
  244. K&N Filter Oil?
  245. hedman long tubes and exhaust
  246. help need mods fast!
  247. need help with 02 TA
  248. Locktight the rocker arm studs???? ASAP
  249. 30-45sec delay before misfires
  250. can use some LS1 guidance...
