- Another cam swap Q&A
- 01 Temp gauge = Dumby light
- SS Pkg-SLP or Chevy
- B&M trans cooler and ftra question.
- a pic of my dynograph
- post Flowtech LT install
- New to LS1.. Dumb Question :)
- header install problem
- Questions about Z28
- where to buy wires for ls1 that u make yourself.
- New BBK SSI-Series LS1 Intake Manifold
- Yet another cam question!
- New NA record?
- New oener, simple questions! =)
- MY SS is making broken sounds!!!!
- Air lid or K&N FIPK...
- Dyno Tune Today...
- Spark Plugs and Wires
- Lids on 2000+ vehicles
- headers - good deal
- Header install.. need help
- gas mileage differences 01+
- heads
- Ltd. Funds...Headers or cam first?
- Service engine soon?
- 91 0ct causing SES light? California
- which cam for A4
- My LS1
- LS-1 article in CHEVY Hi Perf.
- top end
- new dyno numbers today
- What is an LS1 "crate" motor?
- What are some common 1/4 mile times for a '98 Z28 A4?
- Upgrading
- Need some adice on piston slap?
- 30,000 Mile check
- damn camaro
- How much HP...would you guess?
- Sparkplugs
- I hit the rev limiter, did it break anything?
- what type of oil do you modded guys use?
- AP-Engineering in the September 2004 issue of Chevy High Performance!
- WS6 Airbox
- Fast 90mm TB: Where to get 4 inch air intake tube?
- What's better SLP cold air kit or K&N filter charger?
- Smooth bellows worth it?
- LS1 not running right
- 90k Tune-Up and Maintenance
- couple wire harness and egr questions...
- Need a mechanics opinion---is my engine shot?
- Wanting some 15" wheels and slicks on my lowered TA, what do i get?
- Help w/ 02 sim install
- Header Install
- Spark Plugs
- O2 Simms
- Ls1 Vs. Lt1
- Headers...in CA.
- ls1 motors
- what is it worth?
- what would you need to beat this car?
- Need torque specs
- Getting ready to pick up an '01 SS
- Whining coming from the engine!
- LS6 Intake????
- True Duals Second thoughts
- Lowering Car Need Some Help
- Difference between shocks and struts
- Will bad O2's make the car run rich?
- Is first gear selectable in a 1998 Camaro Z28 A4 2.73 gears?
- TRex Thunder Racing Cam
- Cutouts: Do They Really Help?
- Blue Smoke
- New dyno numbers
- Service engine light question
- strange noise coming from valve cover...LS1
- Best exhaust to install for HP gains?
- SLP flowpac vs SSRA
- comp cam base circle
- cost of big cube ls1
- need help figuring out what gears i have???
- Holes In Lid???
- y-pipe and hooker lt's
- SLP Underdrive pulley
- Engine Missing Rookie needs help
- Results after cam install tr230/224
- Car died on the way home :(
- Placebo or Actual SOTP Difference
- LS6 intake vs. LSX
- Loud exhaust setup
- LS6 Cam
- kook header's
- Qtec upgrade for motor? Pitman?
- Please help with RWHP numbers! :(
- Help ID this SLP intake mod?
- COMP 978 SPRINGS. Machining required?
- Does magnaflow sound good / give good hp gains?
- Nothing Like To Much Torque....
- LS1 Tractioin Control Question
- What else for MAC install?
- Anyone using oil additive to quiet piston nock?
- LS1 vs LT1
- Need some Idea / Help
- LS1 blcok w/ TPI conversion
- Help!! Intake Manifold questions
- Rocker arm kit installation Question?
- LS1 conversion
- hooker y-pipe on Pacestter headers?
- wrecked 02 i am pulling engine,trans need to know top or bootom,FOR BODY SHOP REPAIRS
- Here's the mystery connector, can anyone ID it?
- 6.0 ?s
- Need help...real easy
- What do ya think
- Y pipe help
- Possible?
- Help me kill a srt-4
- "GM Hotcam"
- Question on HTPP III
- Shorty headers worth it..
- Need quick answer, argue with dealer over repair
- LS1 Gauges on the Fritz
- Which TB: Shaner S2 or LS1speed Inc>>>
- Slight whistling at 1200rpm accel
- Bang - Help!
- ls6 intake
- Is this 2001 SS a good deal?
- Rookie Engine Mods
- How Loud?
- installed MAC off road pipe on my 00 Ls1 and car runs like crap?
- mods or supercharge
- Engine Cuts at 120
- cam and heads
- pondering cam swap...input???
- G-tech On My 99 Ss
- Best cam for stock LS1?
- cam timing
- Airbox
- Hooker Headers and Y-Pipe
- IDIOT dealer problems, Bank 1?! Which is which?
- 402 short blocks for under $3500.
- Affordable rotating assemblies are just around the corner!
- Cam tuning question
- about that pcv mod on install university...
- What Pulley To Get?
- Squeaking belt tensioner
- What heads for my setup?
- ASP pulley question?
- 400 to wheels...
- good idea/bad idea?
- exhuast cut-outs
- MAF screen removal
- Sputtering under WOT
- flowmaster SES???
- headers Q
- Zo6 conversion
- Harlan Shift light install problems
- Which Maf better?
- Hedman LT's and back exhaust for LS1's
- Bought car, have a few ?'s
- Best Pricing???
- Did I make a mistake? LS1 nightmare
- Car shift 1st to 4th quickly after CAM install
- Longtube exhaust note....
- Just pulled my codes.........
- LS1 Swap into Mid Engine Sand Buggy Questions..
- adapter
- ?? on off road pipe.........
- RPM's ??
- check engine light??
- Spring Compressor.. cam install ?
- Stock heads with what cam and headers?
- CAI came on all SLP cars right? mine doesnt
- All opinions, comments, ideas, etc welcome......
- Bore out to 382ci
- header and Y pipe question
- X-Pipe?
- Cam Swap Hint
- 98 Z28 with 105k on the clock
- Think I can break 400hp?
- what exhaust for 2000 ss camaro
- Can a Cam setup be had for around $400?
- ls1 head vs ls6 ?
- Weird engine behaviour
- How to force A/C compressor to come on?
- What Mods Next?
- vibration @ 100+ mph
- supercharge
- cam suggestions
- TSP Rumbler
- best heads and cam with stock exhaust for Ca.
- 02 LS6 in 99 SS
- Too low for Hooker LT's?
- 98 EGR delete
- Another...Camshaft question
- Starter? Ignition Switch? Clutch/Starter Switch?
- Best Headers for LS1
- new LS1 Owner
- Lost some top end??Any ideas?
- Just bought a 2000 ss but...
- mustang dyno
- Carb intake manifold for LS1?
- track kill message board
- LS1 to LS2?
- LS2 vs LS6
- What should i dyno?
- big inch ls-1
- Stock LS1 M6 1/4 mi times
- Change oil light
- ASP Pulley, Yay or Nay?
- Sputtering at low RPMs
- LS1 swap
- Currently have GMMG, lookin at Texas Speed True Duals. Good idea?
- 1998 Z28 Mod list - please make suggestions
- Ultimate LS1 Heads (apparently)
- Gen 3 GM Hotcam
- 1998 Trans am cam question
- Just installed Pacesetter LT's, questions
- heads/cam LS1 = 290rwhp????
- Which valve spring tool? (link)
- Questions about my heads/cam setup
- ls6 intake on 98 ss
- dynomax bullet muffler on a 98 t/a with longtubes?
- simple mods to make a little quicker before i get my headers
- Extreme Chassis? Heard of them??? Beware..
- low oil light
- blinking SES?
- Loud Popping after Header Install...help
- exhaust question ?
- Doing Ram Air Mod Right Now, Have Question
- Need some advice on modding LS1 motor
- engine noise?
- Overheating?!
- just got 99 firehawk
- What is the performace difference between 1997 Z28 vs. 1999 Z28
- stock SS RWHP
- o2 problem please help
- Lowered with 2.5" true duals... --Pics--
- Can someone explain the LS1 vs. LT1 fuel,system to me?
- Which heads? LS1, LS6, or 6.0L?
- The time has come...how do I replace my EGR valve?
- Dont Laugh Intake Question
- O2 sensor interchangability
- Need some help with coolant light
- Oil change.
- Short block
- AC Delco Rapidfire or NGK???
- y-pipe help please
- FAST!!! need help on MTI Clear lid(2000)
- SLP lid question
- LS6 block and comp
- Ls1 Airlid-will It Fit My 02?
