  1. TSP Custom 220 Cam: 220/220, .564"/.564", 114 LSA
  2. LS1 questions
  3. Lt1 to Ls1
  4. did some checking today...
  5. Fuel Mileage Question - for A4 owners w/ a Stall.
  6. airlid install question- need help quick!
  7. True Duals compared to other Vehicles?
  8. SLP "Performance Prepped"
  9. WIERD start-up problem
  10. FAST LSX questions
  11. Magnaflow/carsound catalytic conv.?
  12. cam or lifters or spring noise?
  13. Ses P0140
  14. so my oil pressure went to zero when i floored the brakes ...
  15. LS1 Swap to a 1st gen Rx-7, help?
  16. to free, or not to free? that is the question..
  17. Whats next? Slow with headers!
  18. So who will be swapping their LS1s to the LS2?
  19. Bassani Headers
  20. oil consumption
  21. Picture request :)
  22. Question about Cams
  23. z06 conversion ????
  24. SlpFlowPac Or 3.73 gears?
  25. headers
  26. Flowtech Vs. Hookers
  27. belt tensonor
  28. How hard is it to replace oil sender?
  29. Mac header exhaust system
  30. headers ?
  31. power steering pump
  32. Blowing blue smoke after h/c swap and synthetic switch..
  33. TB bypass
  34. Headers Or Induction Next?
  35. insane misfires are BACK!!
  36. vr velocity stack
  37. Quick ?: New Z what CAI do u have/Rec.
  38. tb and maf
  39. first mods
  40. High Mileage LS1's??? What to look for?
  41. 2002 Z28 Ss
  42. power steering fluid help!
  43. Just got me a 99' B4C camaro...
  44. waterpump leaking
  45. help! SES and smoke out the pipes
  46. C5R block
  47. which car to get?
  48. texas speed 231/231 cam
  49. Bellows and Lid
  50. heads,cam,header
  51. Headers 1 3/4 or 1 7/8
  52. c5-r cover
  53. ls1 problem
  54. Heads up for those burning oil after a h/c swap.
  55. MOVED: Shift Points!!! Need Help!!!
  56. Alternator
  57. Many problems: Running REAl rich, clicking noise from valvetrain, and SES light on
  58. ls1 engine harness
  59. part #?
  60. stock ac delco plugs or ngktr55?
  61. Stock Pushrods Part #??
  62. Who Makes a Good Waterpump?
  63. volant w/ bgra
  64. Flowtech Headers
  65. Service Engine Soon
  66. Installing Pushrods..anything I should know?
  67. ASP pulley
  68. How do I know if i have an ls6 block?
  69. I heard 98's dyno lower...
  70. thermostats
  71. My 01 WS6 wont start...What gives?
  72. will 5.3 heads on my stock Ls1 increase horsepower
  73. SES code P0430 came up today...
  74. Camshaft Position Sensor
  75. some people say i need a special smaller socket to change plugs
  76. OMG!! What have they done?
  77. Patriot LS1 5.7 Stage 2 Heads any info
  78. 382 Stroker ?
  79. I need your help
  80. valve springs
  81. trouble after cam install
  82. EGR gasket? Blocking of my EGR...
  83. P0300 codes: Blinking SES and rough idle
  84. easy question for LS1 masters
  85. Raining last night, runs bad, no power now
  86. YAY!!! My car burns oil...
  87. Service Engine Soon - P0442
  88. What mods to chose
  89. hi flow lid
  90. Interest in true dual exhaust over the axle
  91. cam or bolt ons, help me
  92. Hooking up after market tach???
  93. Flowtech headers & ory-pipe installed
  94. Airbox front clips
  95. New LS1 power output
  96. AFR Heads w/ CC 224 cam 500+ hp?
  97. Super Gas Project underway !!!
  98. What to look for when shopping for an LS1
  99. 98 LS1, need facts here
  100. How do you check......?
  101. Switching out Stock Headers for Aftermarket
  102. Super Sucker Ram Air
  103. air lid, MAF, filter
  104. Best smog legal heads in cali? Patriots 2?
  105. fitting
  106. Best Valve Springs for .581" Lift
  107. SSRA questions
  108. After lid then what?
  109. Friends New 02 Trans am What mods with this amount of money?
  110. stock heads, biggest cam?
  111. Want to Learn more about the LS1..
  112. lid shopping
  113. po 1416
  114. Diablo Programmer.
  115. ls1 price???
  116. changing the valve springs
  117. Need new pistons...what to do
  118. whisper induction lid vs slp induction lid
  119. LT1 vs LS1
  120. Got valves out....how do you tell what wrong???
  121. Not another "what will run" thread!
  122. Head porting
  123. Heads/Cam swap question
  124. Dyno Results
  125. Codes????
  126. Is This True About The LS1??
  127. lifter change question?
  128. Gots me a new cam whats your opinions
  129. Trouble code
  130. Code PO303
  131. spark plugs
  132. Header installation on my 02 SS
  133. Need dimensions of stock spring seat PN 12565118
  134. A new cam for a mostly stock LS1 question
  135. running rich any ideas?
  136. Quart of oil low after 3000 mile
  137. PLEASE Hurry. What year is this casting number from
  138. SuperMaxx header dyno results
  139. NGK PTR5C-13 plugs found in my TA, questions!
  140. 2k-3k bog
  141. Tr 224/224 114lsa
  142. more cam questions?
  143. Will these mods put me over 350rwhp?
  144. LS6 intake Q
  145. Code P0420
  146. TREX on the way !!!!
  147. valves
  148. Buy LS1 w/ burnt valve?
  149. Comparing the LS1 and LS6 intakes
  150. Just Bought a 2001 Z28
  151. will LS6 drop into 98 t/a?
  152. Ls1?
  153. Ls1 in a 240sx???
  154. Squeaky noise
  155. starting problem
  156. hello cam help which one?
  157. patriot performance
  158. burning oil
  159. 6 Bolt Mains
  160. Need Help Asap
  161. piston slap got the best of me
  162. Best Lid
  163. ticking from passenger coil pack
  164. Sparking valve cover
  165. question what kind of pisitons come with the LS1 engine?
  166. Where Did You Install Your
  167. lid again
  168. ls1 crankshaft
  169. Will these mods make this kind of HP???
  170. Ls1 piston slap, oil consumtion
  171. where to buy SSRA?
  172. LS1 Guru Test...ie my problem
  173. LT1 LS1 swap
  174. Looking for a Sleeper Cam..
  175. spark plug gap with cam
  176. What size are the boltholes on the ront passenger head?
  177. Vacuum gauge question
  178. Long Tubes
  179. mac header install
  180. next mod
  181. Good Cam?
  182. P1416 98 Ls1 Z28
  183. Z06 85mm MAF add power?
  184. what gains would i get from stage II 5.3 ported heads from patriot performance?
  185. ok guys i really need your help
  186. Shorty's No Performance ???
  187. where to buy coil packs??
  188. diff between '98-'99 and '00+ lid?
  189. Cam/heads question
  190. Is the timing right?
  191. Messed up valve springs ...
  192. LTs and smog
  193. ls1 coils ?
  194. good deal?
  195. Casting flash on LS1 heads?
  196. rear end question
  197. 98 ls1 computer ?
  198. Home made polly mounts?
  199. Camaro wont start!
  200. VIN for LS1 equiped chevy
  201. flp
  202. Pace MAF
  203. annoying engine noise - what is it?
  204. performance Q
  205. Are long tubes easier to install on a LS1??
  206. Electric water pump owners>>>in here please!
  207. stock ls1 info
  208. Just bought headers...have questions
  209. What kind of car is this?
  210. Billy Grahams camaro
  211. Top End Performance
  212. Cant decide
  213. New Racetronix F99 Fuel Pump System
  214. Pics from underneath car (radiator area)
  215. I have the slowest cammed LS1 in this country
  216. Ssra????
  217. what size cats
  218. 2001 Camaro Repair Manual
  219. Any1 have any info on putting a LS1 in a Chevelle?
  220. Check out APE's New LS1 5.3 Race Heads!
  221. are the o2 extensions supposed to be the flat 4 pin style or the square kindfor ls1
  222. This really sucks....
  223. Oil monitor?
  224. cam specs, springs needed...etc
  225. how to remove injectors?
  226. 98 LS1 exhaust help
  227. rockers and lifters
  228. does a 00 ls1 have egr?
  229. open headers runs my life.
  230. GMHTP 10 free mods
  231. Best EGR blockoff!!
  232. is this water damaged Ta worth looking at(some motor noise)
  233. LS1 swap
  234. gas mileage woes
  235. Someone must have a link to this article....please
  236. Best 1st mod?
  237. Speedo Help!
  238. Cam help, and other questions
  239. LS1 swap
  240. Can anyone help??
  241. Did all ls1s have an oil pump problem
  242. Should i do it
  243. headers=next mod
  244. o2 sensor problem
  245. Just realized how lucky LS1 guys are
  246. track results of my 02
  247. Pulling the Engine...
  248. Going to take a look at a LS1 for sale...
  249. rocker arms
  250. need a cheap hi-flo cat y-pipe
