- Weight
- HELP, Jet-Hot LT install underway
- carfax request please! thanks!
- changed plugs, again...
- Tires
- Cam
- Need your help before taking my car in to the dealer
- Would you buy this car?
- Ultimate set up
- QTP dyno numbers
- Cai or ssra?
- header install
- LS1/LS6 intake dyno #'s
- Need some opinions
- torque management
- Bad gas mileage...
- just some info
- New intake available for our cars (sheetmetal)
- Can I hose off my LS1 engine?
- Water pump & Alternator removal & install write up needed.
- what should my friends LS1 run?
- E-Cutout ,True Duals or cat-back
- Electrical Silliness
- Need opinions on these tires
- Cam or exhaust question???
- PCV valve
- Re- Wiring
- Need Help Asap
- Average cost of long tube install?
- SLP Airlid Question
- How often do you replace your clutch?
- TO those with long tube headers
- Dyno after Heads/Cam
- Longtubes worth it on a stock ls1?
- Any thoughts on this cam ... 212/218 115lsa
- Sound Clips Page
- LS-1 or LS-6 Intake?
- Smog legal headers
- SLP cold air induction
- where can i get a manual sterring rack and pinion ready to go
- What is this weirdness with Magnaflow....
- sterring sound
- P.V.C. question
- BMR front A-Arms for '00 SS
- LT's Installed, Front O2's not hooked up yet
- ?? on cam install...
- My new over the axle dual exhaust
- PCM tune really required after headers?
- will this setup pass emmissions
- need some opinions on these mods and also have u guys ever heard of this?
- Head and Cam install
- Whos got Pacesetter Longtubes?
- cam installed now i have no reverse
- Rumbler is gonna get me in trouble.. HELP!
- People who have done TB bypass
- Dirt Going Down into intake Valley.
- "new" 98 z28 - what to do first...newbie help
- does the holley powershot make you lose hp like the k&n filter?
- mac longtubes and catted y pipe pros and cons, is it as good as jethot lt?
- List Some Inexpensive Mods
- What about this Air Temp Module or whatever its called
- The power plates finally arrived..
- Alternator battery line will not come off.
- Getting car dyno tuned, should I upgrade injectors?
- Cam Packages...
- SLP Take-Off Shocks
- question
- Thermostat
- Help me with some HEADERS
- will hooker y pipe work with flowtech headers?
- car running SLOWER after headers installed
- Starter problems?
- fans wont come on
- Flow Tech or Pace setter
- Exhaust problem?
- HP for Hooker shorties?
- Dyno full exhaust
- dualing hp
- Stupid question?
- 2000 Z28 with NO power options
- All Borla owners in here please
- LS1/LS6 book?
- Not sure if this has been done or not
- Flowtech headers and Y
- Service Engine Light
- Am I hitting the rev limiter?
- Which Is Better Ssra Or Ssra2?
- FRONT BRAKE ?s
- Getting car dyno tuned monday, few ?'s
- Anyone have this problem?
- Carfax please!
- EFIlive 5.26.1 build`440
- Power Steering pump removal info needed.
- My 99 A4 LS1 dyno numbers..
- Dumb question but it's bothering the s@#% out of me!!!
- lM to loud
- Your Input on this 99
- Replacing fuel pump
- how about this 99 SS?
- A mod that I might not know I have...?
- Need Muffler Part #
- header question
- Help needed
- what do rear spring insulators do for the rear end?
- Rim Question
- K&N filter oil inside the manifold....
- About to buy an LS1....
- How much better is the Bilstein HP option?
- Warranty ?
- Torque Converters. Help.
- Removing rotor stud in 99TA..help?!
- cooling system question
- Quick exhaust question (muffler)
- tires "ozone cracking " ??
- Dealer Services (Engine Cleaning)
- Question About Exhaust and Headers
- Block the EGR or LS6 Intake?
- test drove a 01 Ws6 have a guestion about engine noise
- no start
- LS1 brakes abutment brackets part number???
- Exhaust question
- velocity stack
- Ssra
- some cheap deal on pacesetter headers??
- Is this really an LS1?
- Header Install question
- Another "Whats it worth" question
- An intake question???
- K Intake Question
- Wheel spacers on a Trans Am
- How do I remove a headlight?
- y pipe and headers Q
- 2002 SS specs
- How to remove Convertible top?
- LS1 intake assembly height?
- touble with sister car
- Thermostat ?
- Breather for my '01 Lid?
- question about throttle body bypass mod
- Trex Cam
- Just want to make sure about ses code before I take it to chevy.
- Emissions and pacesetters?
- cats not flowing properly?
- wiring harness
- cammed LS1 HORRIBLE HORRIBLE RESULTS
- Throttle Cam, anyone swap one ?
- headers, y pipe, cats
- LS1 dos & don't article ?
- Cam Swap Help!!!
- Odd question...how often do BOTH fans kick on during normal driving?
- '98 Z28 Individual Coil Packs
- Bassani cat-back
- Is this a good deal?
- will jethot catted y pipe fit on hooker longtubes?
- any real dyno numbers going from stock y pipe to slp y pipe?
- Exhaust Opinion.
- Installed Headers and lost topend!
- Flowtech Headers=badass
- 2001 6-speed z28
- Bassani header install
- locking gas cap for 1999 camaro SS?
- Installing a Walbro 255LPH in a 98 Z28
- stage 2 patriot heads
- Need help BIG time, limp mode? MAF/O2?
- Acting funny after header install!!!
- cam measurements
- Help,no spark.
- where to get pacesetter coated longtubes for 370.00 shipped? hows the y pipe
- what other y pipe will work with pacesetter longtubes on a 00?
- what were all the exhaust options for an SS 98-02
- C2vs.TR 220-224
- lid
- Warranty Question
- New gaskets....hard to do?
- is a tune necessary after longtube install?
- will loudmouth sound good with hooker muffler in resonators place?
- Whos got the link to the custom y-pipe with dual cutouts?
- recalls...don't know where else to throw this thread
- running rich
- Fan switch question?
- Pulleys?
- Replace oil pressure sender without removing intake...
- is this a good ls1 cam?
- I need a mentor.
- gasket
- What's the best LS1 F-body year (1998-2002)?
- GMMG Thread
- fuel rails
- Now should I........
- Replaced horn and fixed yellow headlight this weekend
- gas gauge pegged
- is the hooker aerochamber a chambered muffler like gmmg?
- will ls6 intake be a direct swap with my regualr intake, what year ls1 have these?
- is my trans am really a formula? did the dealer lie?
- what next?
- LT1 Destroying LS1
- air pump question
- What should I expect to pay for a cam swap?
- High milage ls1
- HOT CAM KIT vs... LS6 Conversion..
- Service engine soon light
- Need quick response: MSD or Taylor wires
- Help! My new crank bolt slides into the crank of my used built block
- ls6 intake block off
- My planned set up 2
- Stroker
- Installed Plugs.. more problems!
- what is maft
- Recommended Cam Setups?
- burning oil??
- A comment and a question (got flowtech lt's today)
- slp cold air induction any good?
- Header leak questions
- Whole new exhaust if I get headers?
- Where did you install your catch can?
- Is my ls1 gonna blow up
- if these cars have piston slap from factory why isnt there a recall?
- voiding warranty question
- Oil change
- What else can I do to get more power?
- Royal Purple...does it make a difference???
- Synthetic oil
- TSP Rumbler tips
- Corsa Exhaust Should i Get?
- proper plug gap and larger oil filter #
- Anyone using the Austin scoop?
- Headers??
- Motor Noise
- where can i buy the lid for ramair ?
- TSP rumbler VS Flowmasters
- installing headers....help
- the 98 LS1..iron or aluminum
- Loudmouth too LOUD?
- z28 vs ss vs dual/dual mufflers
- Flowtech header install - one person method
- Just Bought 01 Ram Air
- Smooth Bellow BBK Compatible?
- Jet Hot Y-pipe
- Cam Install
- maf
- what could it be? Starter?
- Step-by-Step Flowtech header Install guide w/ pics
- LS1 Stage 1 Heads by FFHP
- Installing LS6 Intake QUICK QUESTION.NEED SOON
- 1500 Budget
- 160 thermostat kit worth it?
- LSI 345HP boost package?
- whirring sound on startup?
- Vavletrain Question for People w/T1 and Ported Heads
- Anyone have a loudmouth sound bite?
