- question about lsi engine & tranny
- Installed Pacesetters! One problem..
- Which ones are rare...
- SLP Air Box Lid, smooth bellows
- SLP or FLP LT Headers
- Rattle when I start the car.
- I need emergency help
- New bone stock 2000 SS times
- New SLP Underdrive pulley?
- LS1 Catalytic Converter
- Got a ton of question concerning an LS1 for a project car
- Block Heaters?
- should I switch from MAGNAFLOW to TSP RUMBLE CATBACK?
- 98+ Trans am Healights
- rear shocks
- Dielectric Grease for T-tops
- Holy ****!!!
- Oil catch can
- Where to get a good deal on a QTP cutout?
- ls6 intake on ls1
- Whats wrong with this time? Input PLEASE!
- Do factory SS hoods have heat shields and bar codes
- need rims
- g-tech...blown fuse?
- Gay horn sound
- zr1 wheels
- what free mods are there for 00 ls1?
- Flowmaster american thunder 3" for 00 ls1, yes or no? need 300-400.00 catback
- what year ls6 intake works on a 00 ls1 and what cars have them
- is gu5 3.23 gears or 3.42? why does my a4 ta have 3,23 gears
- do all 00 trans ams have aluminum ds?
- is slp loudmouth good exhaust and does it have good hp gains?
- whats next
- going to check out a LS1 tomorrow ... good or bad car?
- how much ground clearance with lanes tru duals?
- Dynomax bullet
- please help guys will i get more hp from lid, cai, bellows or ram air induction?
- ive seen some guys saying k&n filter robs hp on ls1 is this true?
- Where to find some chrome ZO6 wheels????
- Best Catback for pricewise? Sound? Performance? Overall?
- Difference between SSs from 99-02 ?
- Fuel level!!
- h/c or sc
- air pump removal
- E-Cutouts going bad?
- Hooker long tube & y-pipe HP loss
- To port MAF or not?
- QTP Longtube Headers
- True Duals
- do tey still use dexcool in 00 ls1?
- tire size
- Rotors on ebay
- Low Dyno? LT's,ORY, Cam
- MASC performance Heads and cam packages now available!!
- M.A.S.C Performance Nitrous Oxide special!
- brake squeak... new pads?
- what is the HP rating for LS1???
- Climate Control Fan
- alternative to O2 sims?
- Suspension Advice
- Removing cats?!?!
- Ls1 Cam
- Loud Mouth Knock Off??
- Installed my Flowmasters!
- slp lid and 2000 ss hood
- Exhaust for 2002 Z28
- My planned mods
- SS option on a 2000 Camaro?
- Problem with my LT1 A4 to M6 LS1 swap
- ls1 header install question
- Help with sfc's
- slp cai,lid and ram air hood or ram air hood and ram air box?
- Z almost stalls
- cutout pointless on a magnaflow?
- what next after exhaust?
- fuel pump
- LS1 fuel consumption
- how do I....
- Interesting bit of trivia regarding the battery tray.
- Lower Control arms coming lose again?
- LS1 T56 conversion
- Underdrive pulleys
- pros and cons about slp 160* thermostat
- when doing longtubes and exhaust what cats should i go with
- Questions ASP pulley
- aftermarket maf or not?
- do i need crankcase breather for lid for 00 ta?
- Baer Brake Packages
- when getting slp longtubes should i get the ones with or w/o air and egr fittings
- does slp have more than 1 y pipe for their longtubes and loudmouth?
- Radiator messed up??
- Curious about suspension...
- need a good pad for drilled and slotted powerstop rotors
- Fuel on E?
- Dash question
- LS1 ScanMaster GP is going to end soon!
- should i be making more hp?
- stock gears replaced at 22,500 miles
- Need a y-pipe for the TA, who sells them?
- Magnaflow catback install
- Long Tubes with 3.73's?
- Need help asap
- raspy sound from flowmaster???
- dual cutouts on a bolt on car? gains worth while?
- do you keep your ls1 in 3rd gear or d
- Machine Shops
- ABS Brake Modulator
- What to do Next...?
- ‘00 z28 no ASR ?!!
- Cam ?????????
- 02 Sensors
- Corsa Installed 1st Impressions!
- Getting The Z Tuned?
- ??? for Jason D
- What kind of oil and capacity...
- when i put the brakes on and am about ready to come to a stop i hear a slight clickin
- Did fan switch mod, SES light came on, please help!
- Racing fuel
- LS1 throttle body = Ram Jet throttle body?
- i think i dynoed kind of low
- Dual cutouts vs single cutout.
- TSP Rumbler Sounds Clips?
- who has more HP
- Requesting sound clip LS1 idle under engine
- Straightpipes, or keep my Borla??? Please help!
- OBD2 Scanner for $189. Worth it?
- ac delco pf58 or pf 59
- Best Exhaust setup under $400? Best Lid?
- Oil pressure drop at high rpm?
- LS6-C5R motor?
- does the slp lid come with everything i need to install air tube?
- ssra or ftra?
- need help with rear main seal
- Brake Problem!!!
- QTEC Question
- Dyno #'s from today...
- Awesome Dyno Day!
- Help! Pacesetter or Flowtech Headers? Which one? Need to know soon!
- Custom Ram Air Intake
- R/T Y-Pipe/High Flow Cats
- C4 Vette vs SS...middle console cushion...why not?
- Couple of fuel questions
- 2000 Camaro SS stock HP?
- People who have installed long tube headers inside please
- Seafoam
- has anyone gone 12s or better with slp loudmouth n/a without aftermarket converter
- will slp y pipe work with other longtubes besides slp?
- do you gain any hp or reduce any et when you remove the air and egr?
- which longtubes that are decently priced will let me runs cats?
- Jet-Hot LT Install - K-Member Modification?
- brake change
- easy one - exhaust manifold bolt size
- Need new engine
- How Much
- Wheels for my ride
- REAR susp. bottoming out at slow speeds?
- 2001 camaro wheel offsets
- 5.3 heads on my LS1?
- Help with cams
- Curious about my car vs a 97 z.
- whats your oil pressure?
- peeps on ls1 are saying volant adds 7 more hp than lid
- EGR/AIR trouble codes...$$$!?
- Please Help (after Cam Dyno)
- Can a Cam-Only LS1 run 10's?
- Should I change my plugs and wires?
- NEW Under Axle Pics are Here!!
- LS1 Upgrade
- Dyno Results
- so basically if i want longtubes with y pipe and cats im gonna pay 1000+ :(
- paging nittanymarine
- New set-up loading up at idle and low rpms
- If GM won't do it, someone else will. (Getting new engine)
- What's up w/the LQ4's low RPM horsepower peak?
- What type of headlight bulb?
- thoughts of JET HOT longtube intstall...
- bought my wife an LS1
- 3.73 and Loudmouth.
- Another "what's next" question...
- My TSP Rumbler Video Clip
- slp 85mm
- any reason to NOT reuse stock manifold bolts?
- Some questions about WS6 hood and intake system
- OK, I got the tools and the time, how do I fix my EGR Valve?
- Cam install... Any help?
- can i use cats and or true duals with jet hot longtubes?
- Fords DOHC 32 Valve vs. LS1
- how man o2 sensors does 00 ta have?
- want true duals but am afraid its much louder than loudmouth opinons please.
- does anyone who has jethot longtubes an y pipe not have the y pipe hitting floor pan
- Fan Switch Worth It?
- A/C aircon ...q?
- is running rich a bad thing?
- No Power Steering????
- bc smoothies with 285 tires
- Want/need a free owners manual?
- changing plugs
- i pipe diameter?
- Traction Control question
- LS1 Prices??
- dyno run
- DRL lens question
- anyone running a 228/228 .581/.581 114 LSA
- Any one have the ASA cam 232/232 .525/.525?
- SLP loudmouth on highway, how loud?
- NITTANYMARINE: What shop in pa does true duals you were talking about? jersey, md??
- Cam and emissions
- SuperMaxx header package
- mandrel bent true duals vs non mandrel bent is it a big difference?
- Those Of You That Have LT's and Loudmouth
- what is gmmg website?
- hooker catback, tsp rumbler or loudmouth with chambered muffler pros& cons
- Man, do flowmasters suck...
- How many of you have mixed fuel - I.E. run the cheapie stuff ?
- The perfect Air Fuel Ratio
- Blue Springs max lift? please help
- Pacesetter Y Pipe?
- 98-02 Fbody GM Repair Manuals
- SS suspension question??
- which air filter do you use?
- 2001 SS -- perfect!
- maf
- most quiet 4" muffler
- Are these shift lights any good?
- Does fuel filter type make a difference?
- HELP!! Car wont start!
- Y-pipe/Programer Question
- header question
- Blowing Fuses, Electronic Guys In Here!
- Help Me Please!
- fixing to buy camaro ss with ls6?
- Dying fuel pump
- Idling Problems after mods...help please
- Look at this deal on pacesetters....Unbeatable ....
- SLP "flo-pack"
- Gutting cats?
- Pacesetter, Jet Hot, or Flowtech headers
- Dynoed Cam
- How difficult to install an intake?
- the new mustang
- SES question-catalyst inefficiency
- brake install guide?
- Da Biggest Bull$hit Ever Heard!!!
- Year of the LS-1
- price of used LS1
- 2000 SS rated hp???
- Calling out help from all the ls1 owners
- Power steering & Water Pump leak screwed alternator?
- 315 on 9" rim??
- spring pressure
