- What do you think the bumpstop and EGR tube mods are worth?
- What do you think my next go fast 'bolt on' should be...
- Help Installing Hurst Shifter
- valvetrain mod?
- Harwood SS Hoods
- 4.10's vs. 3.73's... What's the diff?
- Gran MAF and Therm
- Instructions on how to port TB?
- Anyone have an LS6 head?
- Will it compare to an 02 trans am?
- I have the SLP dual-dual, will a cut-out do anything for me?
- Clutch wont disengauge!!
- If you guys had my car...what would you do?
- Triple guage pod for 97-01 camaros... will it work for birds?
- Problems with low coolant light
- Orlando area CORSA /GMMG owners........
- Replacement Shocks
- Need Quick Answer On Brake Problem
- is replacing my CATS with 2 cutouts a good idea??
- Pics / sound of GMMG.........
- Just hit 500 miles, ?'s about Maintenance.
- Big bore short stroke LS1/6
- trouble getting my TA in program mode
- Synthetic oil bad for new engine?
- Big problem after header install...Please help!!
- Put the T/A on the dyno today
- Noise from cyl #3
- exhaust question
- LS-1 hot cam
- Camaro Legends Tour
- Car feels sluggish and is whining louder than normal. Only 870 miles!!
- Need some more horsepower...help!
- Got a Problem! Need Some Advice!!
- McLeod street twin clutch Q - help!!
- GM LS1 hot cam kit and 1,8 rockers......
- WS6 TransAm newbie questions
- 2002 SS Coolant Question
- What is LS1 edit?
- Should i install 4.10s now, or wait...
- need input on possible rear gear change on 02 limited ed SS 345hp
- Rear Engine Noise
- Head Lights
- Clear corner light installation.
- Headers from an 84?
- 12-bolt Rear End Swap from pickup to '98+F-Body??
- Where can i get a pair of LS-6 heads??
- How Much More RWHP To Go From 12.8's to 11.8's?
- 3.42's vs 3.73's
- black smoke.
- Brake shop messed up
- EGR delete.......
- 1st mods to my ss
- Am I over-filling my oil?????
- Squeeling in my steering!
- Fuel Filter???
- 6-Speed Manual Questions - I'm still somewhat of a Virgin =)
- Newbie here.. just wanna say hi
- QA1 shocks
- Rims/Tires
- Is there any trick to getting the SS scoop insert out ? ?
- Dyno Results
- Finally got the car scanned! Suprising!
- Had Auto Zone scan my codes today..heres what I found
- 3 more days of V6 driving...02 Formula next
- Taking my cats off...
- Decisions, decisions
- exhaust for LS1 T/A
- New Z28 owner
- Ordered off road y-pipe have ?
- What do auto ls1 norm rwhp???
- Rear caliper question...
- K&N FIPK or lid and CAI?
- Quick question about 4.10s
- how many tenths would i drop if i used bfg drag radials??? how much with nittos???
- General Maintenance
- fuel filter
- Need Info On BG F-Body Gathering
- Will a 93-97 dash fit in a 2000
- Got a problem
- What is behind the ugly plastic grill on my SS????
- Bilstein Shocks
- T/A WS6, M6 --- idle speed?
- does the 98 ls1 have any problems
- 409 LS1 motor with ATI F1 - 672.9hp/618.6 torque so far
- Cam guys, whats your setup.....I need advice
- Anyone try to buy a new Firebird lately?
- LS1 problems
- What belt will replace the serpentine and bypass the power steering pump?
- Need help with warranty for friend
- 98-2000 z28
- LS1 or LT1??
- ATR Cat-back exhaust?
- Hypertech or Jetchip for 2002 Corvette?
- Shifter noise
- K&N....worth it?
- The Camaro Z29
- LS1 Mods
- Hooker ORY and Emissions testing
- Please help Gears
- How much does it usually cost for a 383 stroker kit?
- New lightweight G2 LCA's and PHR!
- Just Heads?
- Y-pipe glowing
- What to do with $300
- Cold Air Induction + Idler Pulley
- Differences: Z28 vs SS
- Dynomouth with my Flowmaster 80?
- Underdrive pulley question?
- What is the stock gear ratio in a 98 Z?
- Check out this 2002 SS on Ebay...
- Hooker LT's.....should this be my next mod?
- FLP Install, what else should I do?
- 93 shop manual to assemble 94 engine
- length of your shaft and other questions :)
- has anyone converted their automatic LS1 to a 6 speed trans?
- How much oil?
- LS6 heads on a LS1?
- PULLEY/BELT QUESTION PLEASE HELP.
- Will an exhaust cutout add more power than a catback?
- Bilstein BTS
- Dumb questions about WS-6 Ram Air
- h/c combo
- ASR won't turn on. ANY IDEA'S
- 03 cobra dyno ???
- can someone look up car fax for this vin? asap
- Diesel Sound\Pinging Noise
- LS6 Parts?
- Stock 2002 z28 mod advice
- I have a real quick question I need answered
- Possibly buying 2000 Z28 M6...what to look for.
- what are some good first mods for an 00 SS?
- help On mods
- Air lid modification
- I need help of what belt will fit an ls1?
- Anyone have painted calipers? Lets see um!
- L.G. Motorsports 12.8" GStop brake kits in stock!
- QA1 Suspension Deal
- Crap, I'm going crazy
- A few where to buy questions.
- SS vs '98 Eclipse GSX!!!!
- Hurst shifter question
- longtubes (choices)
- Auto headlights
- Not The Last Year of Camaro
- Ever get you entire fuel system cleaned?
- drilling the throttle plate on h/c camaros?
- Tampa/St. Pete...who can welm my SFC's
- TIRES ON A NEW Z28??????
- what's the ratio for A4 in overdrive?
- Jet-hot hooker longtube GP inside..........
- how does an LS1 ignition Differ from an LT1?
- Any interest in a 2000 A4 Z28 w/ 15,000 on the clock????
- Any precations using fuel system cleaner?
- Open or Closed Loop with 160 Stat?
- 12 bolt rear end question?
- daily driver 420 rwhp possible?
- head ??
- what to look for.. from day 1??
- Pro 5.0 shifter...
- g2 springs-shocks?
- Plugs and wires?
- Time to replace my clutch, need suggestions...
- Alternatives to dual/dual muffler
- Where can I find front Camaro inserts???
- Pinion seal damaged - rear-end shot
- motive gears are they good quality gears?
- PLEASE HELP! ANYone with ANYideas
- Engine Taking a Crap on me??
- Fog Light Problem??
- new member
- I cant get my car to stop pinging!
- Wow! I love this thing!
- what are the "free mods" everyone does??
- will my new car get faster once the motor is broken in?
- T/C question
- 2 questions
- what type of mounting hardware to use for the rear ground effect piece
- problem found, but what caused it???
- Do i need gasket for off road Y install
- Auto 2-3 shift bouncing off rev liter at WOT
- what exactly does this mod do?
- Took car to the track....idles rough now
- Transgo--Good Idea???
- Power Surge from hell
- will 4.10 gears fit inside the stock housing?
- I know what cam Im going with.......
- plugs and wires question
- Vibration in Steering Wheel
- Lids and LT headers in Calif
- Dynomouth or Corsa
- Just Added SLP Lid and KN Filter!!
- NOS OCTANE BOOSTER
- NEED HELP PUTTING IN NEW TACH!!!!
- LS1 or LT1
- Drag radials
- Please explain the DynoMouth
- Might be a cool idea (for T/A)
- top speed M-6, 3.42's with non zr tires
- 35th anniversary wheels.....
- Cam swap... hard?
- Weird A4 transmission glitch - anybody else ever have something like this ?
- Noise coming from rear when shifting?
- Largest wheel size
- Piston/Valve Clearance on H/C Package
- Grill mod with facia on-cheap and easy!!
- Magnaflow Muffler - Should I?
- About to get a C5.. Suggestions on first mods?
- Magnaflow VS Corsa
- Torque Converter?
- Quick Questions about T/As
- Differences: SS vs WS6
- Aww crap
- Tranny Question
- First time track results
- Paint Problems??
- Lost my wheels locks...what do I do?
- Brakes groaning
- What is stock stat temp in a 2001 WS6?
- Extended warranty worth it?
- Getting into the 13s
- Help...Extra hole in my SLP Lid!
- 6.0 ls1
- Electrical Problem I think :(
- Transgo,T/C, and Gear Questions?!?!
- generation 5.. v10's?
- For Sale: 2000 WS6 Wrecked, Clean Title
- Stock heat range or + 1???
- What does your LICENSE PLATE say?
- Anyone here ever removed/connected/replaced their A/C lines?
- More Horses w/out SuperCharging
- Rear End
- 2002 Z DIFFERENTIAL IS NOT PAINTED
- Resurfacing flywheel??
- Aftermarket Stereo?
- Drill Out Mod
- Woo Hoo! Check out this deal!
- clutch selection
- Opinions on Wilwood brake systems wanted
- 2002 SS with SLP options
- thud sound coming from tranny (A4)
- TRUE Dual exhaust on Z28??
- Brighter fog lights
- SLP Y-pipe
- Need some info, couldn't find it anywhere
- my LS1 was LOW on oil.
- 14 fired at GM for leaking info about the new LS2 'camless' 500HP engine.........
- Tranny swap from auto to M6
- Bad Tensioner pulley...AGAIN!!!!
- Dumb Question. Is the 5.7 V8 a 350?
- help with Y-pipe ?
