- LS1 Durability
- need some help with deciding?
- Tranny Noise
- Radial Pull???
- what stall converter and a couple of other questions
- TPS modification
- Best drag radials? Are nitto and bfg the only ones?
- Ok here's the combo, guess the power...
- Electrical Question
- all guys with tach or shiftlight inside please
- Borla vs. Stock
- Header install help needed!!!
- wheel backspacing ? for a friend
- A/C Help
- Slp?????????????
- Is this right????
- Which would you prefer? MAF question...
- power antena
- 8# ATI reliable on LS1 Engine?
- Estimate this power combinations
- SLP MAF dyno numbers
- "certified???"
- New product - Meziere "street" electric water pump
- hotcam or old man cam
- SLP LoudMouth owners
- Camshaft Install Questions
- What do heads flow?
- I threw this code p1404....
- Ls1 is in block cam?
- keyyy scratches
- Please answer some questions from over the pond
- Where else can I find this Bad A**...
- ACD Line Lock install kit?
- What are some good - Basic Mods for the LS1
- converter
- ls1 mods
- Alignment Question
- pacesetter headers any good?
- a/c problem
- Will Ws6 Highrise Airbox(PN#12455209) fit under SS Hood?
- Has anyone sold or bought a z28 lately?
- Borla Adjustable Exhaust
- H E A D E R S ?
- Rocker adjustment
- Exciter wire from alternator HELP
- How to tell if LSD is gone
- to all LS1 owners
- Mike Haufpauer?
- Possible to find a 98 SS that does NOT have T-Tops?
- Stock MAF
- Aftermarket Lid or Stock 01 WS6 Induction
- Do you have weatherstripping all the way around your rear glass?
- Help My car is still acting stupid
- Hooker Headers/y-pipe finally got here.
- weird orange fluid leak
- Ss Convterbiles
- Air Bag light after accident
- gains by swapping only mufflers?
- Running Temp question
- Anyone Dynamatted their car?
- Bolt on SFC hardware
- Just Replaced My Pushrods, but now its ticking
- rough idle?
- Free/ cheap mods?
- Is a lid really worth it?
- What makes an SS an SS?
- springs from an lt1 work with an ls1
- how often to check valve clearance?
- Is this true
- Help Need Feedback
- DMH electric cutout, LS1, ok to install?
- Strut Tower Brace question
- What lid is this???
- To those with leaky windows...
- Cutouts
- I think I found the perfect car....
- Should I trade the LT1 for the LS1?
- Need Help with driver side window!
- LS1 Edit vs. Autotap V5
- found very cheap 98 Z28. need to know about it....
- need advice about selling my car
- Loud ticking
- Help. Left bank O2 sensor keeps failing
- Flashing SES light, NEED HELP
- SES light after Shaner S2 install....
- squeak from front passanger side?
- 2001 a4 ws6
- Ring & Pinion Out
- 3 inch Y + Borla + Stock Manifolds?!
- Are Thunder Racing brakes good for the money?
- What do you think of this combo?
- S & W Racing SFCs
- Midwest TC 3000 Stall Track results
- Air tubes off manifolds/headers, do I need them?
- Cutout or Exhaust system ?
- transmission
- lt1 guy with a question
- grilles
- What's a good price for an '02?
- Lowering needs
- FOR SALE: '01 Z-28 LS1 A4 Coupe
- Radiator fan/shroud?
- SpinTech mufflers
- security light stuck on
- Question
- Posi Rear end question
- CAGS trick to disable the dreaded 3-2 shift
- Gauge Install
- I Have A Question?
- loudmouth
- rotors ceramix pads
- ac on = loss of horse power?
- Falken tires
- Need help fast! Interior question
- more of the same
- rear end gears
- i want headers
- CAM or Headers first?
- GMHTP pg. 66, bad dyno?
- Will 2 2.25" pipes flow better than a single 3"?
- ceramic headers or not?
- Cool Plate for you 35th ANNIV guys
- 6 sec ls1
- 02 Brickyard 400 35th SS?
- is one year LS1 better than another?
- QTEC headers & Dyno sheets
- oil filter change intervals
- Arguein w/ a friend: what kinds rods/bottom end are on the LS1?
- Stay with 3.42s or get 3.73s.......
- hypertech question
- Car is too loud, will replacing the cats help
- Weird!!! Had car dynoed yesterday and when I use the A/C the tach revs
- Sensor connector needs a home, HELP
- Headers = Too loud ?
- Anyone know how to turn the daytime running lights off?
- Question for the cutout people
- Header Shootout!!! We need one.
- 98' to 00' What Are Most Common Problems?
- Is there a switch to turn off traction control?
- Question about SSRA
- Y-pipe or not?
- Car whining after reving it up
- 2 questions about Lower Control Arms
- smoke
- What does your blockoff plate look like for your SSRA
- ls6 cam vs. Z06 cam which makes more?
- Urgent: Driving SS in Winter
- Custom Y-Pipe and Cats installed, pics..., also need help!
- oil leak drive shaft
- finished my true dual exhaust, and it sounds AWESOME
- radio wires
- RPM's when shifting
- 3.42s or 3.73s for automatic?
- ready to purchase either the FIPK or the TSP air box
- goodyear f1 gs-d3 tires any comments?
- Smething to check on your cars !
- HELP I need to install headers by Friday
- Welcome all who are from LS1.Com!
- ripper or pro 5.0??
- no tail lights
- Tie Rod end.
- any one know how to install power windows??????
- Pacesetter owners..login
- Need help cleaning leather!!!!
- drag Radial VS Street Tires
- Old rims on 02s? any info?
- Electrical problem. Any help
- Just did pushrod swap...BAD RESULTS...verrry bad
- Won't start! Any ideas?
- I definitely need a new clutch now.
- Are There Any Legal Exhaust Systems As Quiet At The Stock Ss
- Look Inside if u own an LS1.
- Anyone's car chatter when it's turned off?
- tb bypass connector size
- You ever read this?
- What is the stock power Rating
- Off road pipe ?
- Who uses drag radials as their street tire
- How would this sound?
- which water pump??
- Where to get wiring harness and computer
- leaking from AC???
- Need rear help
- Winter Storage Questions
- Question about Heads and Cam
- Help, car idles different!
- Transmission Drain Plug
- Header questions?
- Need your help guys, whats wrong with my car
- can someone plz run a carfax report for me
- TB bypass
- Auto in an SS?
- Longtubes vs N20
- TSP LID Gains
- Dyno Results In
- 2000-2002 Air Lid Question
- Broken Mirror
- longtubes or shorties
- my EBC pads wore out after only 13K? any others?
- $1,000 budget/ What should I do?
- widest 17"
- How do i remove this fork?
- Anomaly Guaranteed to Stump All
- question re: bmr tubular SFC's
- Need help - Power steering died
- What mod should i do next
- Just bought 01 ss...have ?'s
- Header questions
- bay area, CA guys in here
- Do I need to connect the A.I.R. system to my LTs?
- considering buying '98 Z, insider info?-->
- Looking for a parts list
- Different LS1's
- Stereo problem 98 T/A NEED HELP FAST
- How to remove EGR?
- Dyno results within...(cam/headers installed)
- 439.7 Hp /399.0 Tq
- Anyone using this cam
- Spin tech?? or??
- Rear pinion seal install
- 98 Z28 dies on highway........
- Best Brake Pads???
- Do Convertables Leak a lot?
- LS1 Jeep Wrangler
- Installed Edelbrock Torque Arm
- Found a 01 SS A4, is this a good deal?
- Car seems slow w/MAC's and ORY???
- 4L60E acting wierd
- Stripper car weight
- Headers n 02's
- money too spend...
- What are the differences between the 98-02 Trans Ams?
- Will Stock Rearend Hold Up On 540rwhp!!!!
- converter install.. IS it hard?
- LT1 vs. LS1's T56
- My reverse lights dont work!
- Where do I jack up the front of my LS1?
- Worrisome info on our cars...
- Problems with short stick shifters
- Can You Buy Just A ZL1 Motor Through GM?
- Firebird Formula VS Z28 SS (2002's)
- Best deal on a killa I've seen.
- Is ram-air really functional?
- major car problem...bucks, dies, all the bad stuff
- Those of you with cams - are you happy w/ the performance gain ?
- Question/People w/hooker LT & Magnaflow
- What Next? Airflow?
- F-body Potential
- Superchips installation help
- Subframe Connector
