  1. New Spark Plug Wires = Noticible Gain
  2. Prices & Installing a Torque converter? 9.5"?
  3. Open and Closed Loop
  4. New Track Times! What you Think
  5. Line Lock ???
  6. Is this covered under factory warranty?
  7. Best set of plugs and wires that won't break the bank?
  8. SLP lid with filter for $100. Good deal?
  9. ZR-1 offsets
  10. race me
  11. Chasing Codes
  12. slp 1.85:1 rocker arms
  13. my first camaro
  14. Centerline Telstars?
  15. What kind've LS1 Camaro should an 18 year old get?
  16. Can I save my battery after the green dot dies?
  17. Recalls
  18. Considering these new mods, which brands are good?
  19. Foolish question about Duals
  20. T-top Wind Noise
  21. suspension testing
  22. Rear end problems!!!!
  23. power ant mod!!
  24. Header Question
  25. Repair manuals for our cars??????
  26. Replacing front blinker...
  27. GM LS6 heads CNC ported
  28. mileage gone downhill all of sudden
  29. SES Light and no Apparent Cause
  30. Super Sucker?
  31. Can the Tazzo VPC work on more than one vehicle??
  32. Programming a 98 LS1
  33. Tips on changing spark plugs
  34. Oil change light came on at 1200 miles???
  35. LS6 intake for an LS1
  36. Who knew bad O2 sensors could really give you bad gas mileage...
  37. Would this be posing???
  38. Ws6
  39. Trying to find a squeek and a grind
  40. How to upgrade rear on 1998 Z28??
  41. tsp or mti.. what lid to get
  42. need some help on tranny
  43. First Mods for SS
  44. Combo?
  45. Spectacle finally has their website back up
  46. help...manual trans. question
  47. I need some advice
  48. another question on my last thread the ls6 intake for ls1
  49. where is the sponsors and LS1 inc pages
  50. lets hear some good exhaust sounds
  51. Cowl Induction for LS1, any benefits?
  52. FS: 1999 Camaro Z28
  53. torque strap
  54. ls1/ls6 exhaust manifolds
  55. Brakes
  56. Newbie Q about SS exhaust
  57. Buy an LS-1
  58. Repetitive thumping noise during hard acceleration?
  59. 3pt. Kenny Brown STB
  60. Cam, headers, and stock exhaust - ultimate sleeper??
  61. Where are the Grease Fittings?
  62. Stock Compression Ratio???
  63. 2002 WS6 wheels
  64. track time questions need help
  65. True dual exhaust?
  66. cross country
  67. Whats the deal with porting your Mass air maeter??
  68. Who would be the one to tell you you voided your warranty?
  69. Slave cylinders on LS1's
  70. Clutch question?
  71. Spark plug gap
  72. Ordered the Magnaflow muffler for my 98 Camaro!
  73. 15-16 MPG, is this normal gas mileage :confused:
  74. Got about a thousand to spend
  75. as homer simpson would say...
  76. Throwing belts and chirping noise
  77. 6-speed problems
  78. Good deal on a 99 SS??
  79. Color Code needed
  80. PPC Spark Plug Wires?
  81. Commercial (corrected)
  82. door bezel switch help!!
  83. cutout & muffler or cutout & catback?
  84. 1/4 mile times need help
  85. Redline Water Wetter compatible/beneficial with DexCool?
  86. ls1 underrated?
  87. SES P1416 ??
  88. Who makes the best LCA's??
  89. LS1 info Please
  90. Whisper lid separating from MAF d/t torque?
  91. Help...Strange Noise Neer Red Line
  92. Looks like im getting the adjustable Borla system! Happy with yours?
  93. can u feel a differance with a torqe converter
  94. how hard is to put on a hood on the camaro?
  95. BMR sfc, torque arm, and tunnel brace
  96. T/A A4 1320 question from a 5.0 guy....
  97. Is there something wrong with my car?
  98. Transmission Surging....?
  99. 450HP w/o NOS???
  100. NITTO 555r tire psi for the street?
  101. What's the most horsepower out of an LS1 N/A?
  102. Motor Oil
  103. Bigger RIms, do I need to do this.....
  104. Need Electrical Help Fast!
  105. Rubber meets the road
  106. New car owners LSI- mileage when you start racing/ dragging
  107. Put in the bottle :)
  108. clunking sound?
  109. More LS1 dummy ?s
  110. 1st time at track-3rd gear
  111. Switching to Synthetic Question
  112. I am thinking on painting my car yellow!!! 02 z28
  113. basic cam questions
  114. Passenger side directional; burnt???!!!
  115. Can you??
  116. is this the shock ?
  117. What is this noise???
  118. Top end not getting oil
  119. tire pressure
  120. Stock '02 T/A times??
  121. camaro chip
  122. Question for Local's, San Jose, CA (cams)
  123. Ok, I changed my mind. I hate my 2.73s.
  124. tick tick tick
  125. Suspension, where to start?
  126. Repetitive thumping noise during hard acceleration? PART 2
  127. passenger side ???
  128. best headers...need all suggestions
  129. brake light
  130. SES light - anyone know this code?
  131. Is Corsa worth the price?
  132. Battery or Altenator?
  133. LS6 Intake and TNT Nitrous Kit
  134. SSRA-go for it
  135. autolite 605?
  136. A question about sound...
  137. slp vs kooks vs jet hots
  138. Gear ratio question
  139. MAFT questions...
  140. SSRA vs. Fast toys ram air kit
  141. how can you tell if...
  142. Turbo ?
  143. looing for a part
  144. I need sheet scanned from the owners manual please!
  145. Does computer tuning make the HPP obsolete?
  146. What is this smell???
  147. Any one else get HOT?
  148. What distinguishes a regular 2002 Z28 from a 35th anniversary one?
  149. mechanic bad mouths cutout
  150. New track numbers
  151. Difference between ticks
  152. need header help
  153. BF Goodrich G-Force??
  154. Car dies... HELP!
  155. ls6 cam swap
  156. Replaced tranny mount w/a poly unit...now lots of noise?
  157. To SuperChip or not, that is the question.
  158. Track Results
  159. Transmision question for the m6 guys
  160. New Dyno #`s
  161. Help(23 pounds ft-lb is ?? in.-ibs)
  162. short belt
  163. sorry to bring this up again...
  164. Borla Sound Clips
  165. 18 inch C5 wheels, what size tires?
  166. Advice on gears, what is needed?
  167. HPP problem
  168. PPC headers
  169. SES light and 6th gear
  170. idle adjustment screw?
  171. Creak Creak Creak
  172. overheat need help please
  173. SLP Y-Pipe
  174. Help!!! DTC P0121 Error ???
  175. slp lid + free ram air hp gains ?
  176. suspension testing
  177. 02 ported and polished Z06 heads and cam
  178. Inline Fuel Pump
  179. 3X3 fernco or the smooth bellow
  180. gauge installation
  181. What next
  182. Best intake manifold for 02 Camaro
  183. new ss
  184. Problems with SLP 85mm MAF?
  185. What gains can I expect from getting a whisper lid?
  186. Flat Tire
  187. Y pipe made by an exhaust shop?
  188. cat-back
  189. How much HP should I have?
  190. Which electric cutout?
  191. Difference between T/A and z28?
  192. cut out installed y pipe?
  193. oil pressure guage sticking
  194. Exhaust manifold removal?
  195. Cold air kits good, but beware of hydrolock!
  196. New
  197. custom exhaust cutout question
  198. 80mm TB or Ported stock TB?
  199. ss hood or supersucker/ftra?
  200. The Replacement's Mods?
  201. high end 3rd noise
  202. 5.3L heads and ZO6 cam
  203. Ls6 intake noise
  204. changing transmissions
  205. Where to find????
  206. Coolant Change Procedure
  207. Exhaust manifold removal?
  208. Piggyback PCM for LS1 Engines
  209. I Got a New LS1
  210. 2000 SS owners in here!
  211. Transmission problem found?
  212. maf sencor help on my ls1
  213. Injector noise?
  214. Questions About Stall Converter and Rear End
  215. a4 shift firmness
  216. stripes
  217. eibach or H&R
  218. Fog Light
  219. Need Help Now Please!!!!!!
  220. WFT,I have an oil leak.
  221. is it ok to jack the car up on the subframe connector?
  222. got money what to buy
  223. SES light came on
  224. Dynomouth Exhaust
  225. GM Warranty Question
  226. GMMG Exhaust: How Loud is it?
  227. Cutting stock 99SS springs to lower car.
  228. whos had A4 tranny problems?
  229. Need Help
  230. Does the Super Sucker come with provisions to seal the airbox?
  231. How much hp can a A4 handle?
  232. What can I get for ported heads and a LS6 intake?
  233. Brake Job by the numbers.
  234. More power from a stop?
  235. New M6 quarter time
  236. Brake Repair
  237. question regarding subframe connectors
  238. rear end questions...
  239. Pontiac Firebird trans am whats the DEAL!!!
  240. pics of the window washer bottle, shroud removed for FIPK
  241. Magnaflow is awesome!
  242. service engine soon light
  243. how much hp can the t-56 take???
  244. Question on changing rearend gears??
  245. extended warranty
  246. Oil Filter Question
  247. What brake pads should I get?
  248. Lower Et's
  249. Cut the crap, is Header coating really worth it?
  250. Need to know size of hex bolt on Strut tower
