- I have $5K to put into my car
- Do all ls1's have skip shift???
- Chick w/ ?'s - Help
- How does the Firebird Headlight System Work?
- Keyless Entry
- Part # for rear diff cover gasket?
- Free Comp Cams Cam!!!!
- auto?
- Loudmouth on ls1 m6?????
- which shocks to get with mac springs????
- which cam to get with stage 2 heads???
- 98 LS-1 into an 85 Vette? (LS-1 Related)
- Anyone here using the Qwik Stick?
- Is an oil change really noticible?
- New Eagle F1's - opinions?
- How many miles do you have on your 2002?
- Getting the trunk to actually lift up? Replace shocks?
- LS1 faster then TTA?
- How many here have had the PCM reprogrammed by the dealer - for whatever reason ?
- Anyone put 4.10 gears in a 98-02 NON SS or WS6 Fbody?
- changing the fuel filter...
- Double Roller Timing Chain
- '99 C5 rims on 99 Z28
- Cam input
- ASAP...doin slp fan switch install.......
- How low should I go w/18s?
- install of front springs.....
- Hypertech Question HELP!!!!!
- Torque Converters
- NEW??just got pro 5.0 need experience
- Bad Clutch??
- Good Sites To Order From
- To late to run Royal purple in the rear end?
- '02 exhaust suggestions
- Change to Synthetic
- SLP Y-Pipe
- digital gauges in gauge pod.......
- Can someone tell me how to attach a picture to post?
- 11.99 need roll cage?
- 8pt roll cage for 200 shipped......
- This Is A Big Help!!!!!
- pro/con for y pipe?
- A little help please>>>>>>
- Lost T-top at 70 mph
- need to know about LS1
- rough idle and error code...
- FYI: a "cure" for the LS1 piston slap??
- Buying LT Headers which ones?
- installing a b&m shifter
- LS6 Intake?
- ***robvas******
- Another Clutch question..
- time for another oil wieght thread.
- strange new sounds from the trany... help!!
- Removing the muffler
- Whats the difference in..
- Driveshaft?????
- A4 clunking sound
- Will these mods get me where I want to be.
- Question about cleaning engine compartment?
- What size bullet?
- A couple hypertech questions
- Yet another clutch ? please help
- Rear Clunk
- spinning one tire help!!!!!
- spinning one wheel
- Guages wont work!
- Hpa Sfc's
- maybe a dumb question
- quick help me in here...swapping sprins but....
- A new ls1 site. www.ls1camaro.net
- 160 Thermostat
- Bad Code
- Where to place cut-outs on true dual X-pipe setup?
- Newbie here, any advise
- People who are 21 to 27 how much are u paying for insurance for your LS1
- Corsa Exhaust
- Finally found out 99 ls1 injectors will work on 3.8 need help on fuel pressure
- Z-28 info
- Exhaust Types
- will fipk work well with ss hood???
- Oil out of Cut-out?
- MO6 vs. A4 any chance for the M06??
- how durable are the A4's in an LS1?
- 02 LS6 and stock LS1 cam specs
- what MPG can i expect from an A4?
- Installed SLP Loudmouth now have shifting problems
- expected hp gains from cut out?
- CLUTCH went out... What do you know about SPEC STAGE 3 ???
- Speedometer problem
- Need help on WEIGHT REDUCTION!!!
- correct weight
- 13.3? for almost stock?
- New Guy here saying Hi!
- Dumb headlight question
- Random tech ypipe for Mac headers
- BMR vs Spohn vs ???
- 10W-30 in LS1's?
- Cat-Back Prices
- Where is the air bag sensor?
- And The Winner Of The Free Comps Cams Cam Is....
- C5 power under-rated like F-body???
- just installed plugs
- what spark plugs come with the LS1 from the factory?
- Ideas for taking care of Pro 5.0 noise
- Mobil-1 oil filters and free ram air?
- I shouldn't have to ask this, but I am.........RE: tire size
- Stock LS1 <1 valve size?
- Hooker Headers/Corsa install probelm...
- Weird Problem
- Any of you descreening the MAF?
- Descreened MAF vs. aftermarket MAF ends - do the MAF ends offer more flow ?
- Air Pump Removal
- So uh...about those Jet-Hot Headers. Anyone got them yet?
- FRA and factory Ram Air ... WS6
- newbie with question
- Wheel ramps that fit under a 98+ T/A???
- CD Changer Adaptor?
- Cup Holder Mod
- 6 speed
- HP gain from pullies?
- oil change with headers
- Major differences in Z28/SS
- What's the easiest way to reset your PCM?
- Bent K-member??
- Would 245/45/16 work with the stock rims if I....
- Need some good advice
- SLP LT'S finally in!! But..
- Cat-Back True Dual Question...
- If you have Long Tubes and no cats get in here please>>>>
- Which is faster? Please Explain!
- Donaldson vs K&N
- 12 Bolt Rear Questions
- Traction Control Q's
- Help!! Low Oil Light on '02
- cut-outs, where and what size?
- t-56 tranny
- How many miles on synthetic oil???
- gauges?? why wont they work on my 00
- Heating question:
- cars runs better after resetting pcm and burnt smell?
- knock question
- O2 (oxygen) sensors..
- Did a full synthetic oil change and dyno!
- Hurst Comp M6 shifter
- piston slap?
- K&N FIPK, is it worth the $
- cams
- escaping GM's diagnostic computer check's
- Please help me figure out this noise/vibration!!!
- weight difference between the Holley...
- Added a few new mods to my LS1 page...
- What to do???
- auto tranny question
- Clucth help !!!
- How do you know if you have a bent rod???
- Clutch sticking when car cold
- Fuel Mileage
- Which LS1
- T56 Fluid
- ss grille info
- how do you jack up your car with that rock gaurd thing in the way?
- is my red line higher??
- Creaking from the rear suspension
- My 80 TA vs My 99 TA
- Warranty Question
- LS1 vs LT1
- Best Heads and Cam for an LS1
- speedo and tires ?
- Importing European Camaro in Canada.
- Question on Zo6 clutch?
- Important Piston Issue
- Front Brake Rotor Q?Q?Q?'s
- Grinding in reverse Gear.......
- Shop in So. FL to do subframe install at a good price?
- Anyone hear this or notice?
- Anyone descreen their MAF and want to give me the screen??
- Hp Ratings 99-03 Z28 + SS
- Vin
- mustang gurus
- LS1Tech vs. LT1Tech~ LT1 owners more loyal?
- Which heads?????
- LS1 Hot Cam
- Winter Mods
- ? About Replacing an LS1 with Another
- coverting my z to ram-air
- SLP Quad Tips & Fascia on an '01 ?
- Air/Fuel ratio tuning..
- Need wire diagram for convertible switch>>
- t tops
- differences between ws6 and t/a?
- Why are the fog lights on the LS1 cars so dim?
- Which intake system?
- Good deal on the Magna Flow catback
- Gear Question Please Read!!!
- MSD 6SL question
- Attention Everyone, READ ME
- High rise ram air
- Question about my a/f ratio and dyno
- Weld in Subframe Connectors Installed!!!!!
- What shocks should I get?
- Ram Air
- Oil Change for LS1s
- FTRA or whisper Ram air?
- LS1 headlight harness??conversion? help!
- Rearend help please!!!
- 2002 35th Anniversary Z28
- Vibration at 70 and higher
- do c5 rotors/calipers fit a ls1 z?
- WHich cam....comp or thunder
- which heads???? stage 2 abs speed or 6.0 L
- how much for labor on heads and cam???
- tranny service
- A4 WOT Kickdown @ 70MPH - ever hear a "gurgling" sound ?
- Another Satisfied Dynomouth Owner
- Install University "Rear Hatch Release: Fix #2" REALLY WORKS!!!
- 99 SS How much it worth?
- rear end fluid change
- Will a 2000 Trans am Cruise Control unit work for a '98 Z28 Camaro?
- Eagle F1 GS-D3 vs. Firehawk SZ50's
- Door hinges
- valve sizes?
- Cats ???????
- will stock corvette rims fit the 2000 camaro
- Just got my loudmouth
- rocker arms
- DiabloSport Predator Settings Question
- Need help please. Looking into an engine swap.
- How easy is it to get 400 hp from these motors?
- i installed a SLP airbox lid today....
- 2002 Z28
- Best pair of mufflers; Dual guys help :)
- Are BMR subframe connectors good?
- Is my WS6 SLOW, OK, Quick, ?
- SS Tire Pressure, Factory Spec?
- Factory LS1 throttle body size
- Holly Power Sold sold out.... Donald okay?
- weight gain vs losted pick up
- skip shift
- induction suggestions
- Synthetic ATF in M6
- transmission
- Catalytic Converter
- 60hp w/throttle vs 100shot n20
- Descreened MAF w/ MAFT?
- Hooker equal length headers
- How much does a Cam cost
- Any ID#'s on 02 Z06 Cam?
- Just got a 00' SS! Now what mods?
