- Need serious help please
- Is the only diff In Power between '98-'02 Intake & Cam?
- Couple of questions about buying a used LS1
- how long will the ls-1 be sold?
- Anyone done sidepipes?
- What's this "G2" ??
- what should my car be runnin????
- where to get seat mounting brackets????
- Convertible T/A, Weight? AutoX?
- Will truck intake manifold fit LS1?
- Z-28 Coil Springs
- i need a little help
- ...anyone have this set-up?
- Can I make my fan come on sooner without programming?
- trany swap
- 115 mph Limiter on Z28?
- Mechanical or electrical gauges???
- What's the highest lift you can have on a Cam on stock pistons?
- service engine soon light
- BMR relocation brackets with Moser 12 bolt??
- 285/40/17 on a 98 z28 up front - will it rub?
- Just installed lid, how do I know if it is sealing properly?
- Help me decide on exhaust...
- Burn-Outs in Reverse...
- cutout question
- 01 off road pipe
- What's the best Radical Cam that is also good for spray?
- question about production #s on Z28
- How to Adjust Emergy Brake ?
- What do you protect your LS1 with?
- catback for $150.00?
- No cats means not street legal?
- how to fix driver side window
- Intermitent lights
- Dyno tuned PCM question!!!!
- installing new aluminum DS?
- Links to FLP header install on...
- Reset PCM...
- Slave cylinder issues..
- question about z28 transmission!!
- What exactly is the slave cylinder drill out mod?
- Need Help!!...Car wont satrt this morning :(
- Window issue when it rains and link to motor replacement.
- should I keep the waranty?
- Where do I find out about certain info on my car.
- 160 degree thermostat
- Fast Toys Ram Air questions.
- Should I remove MAF screen?
- A4 to M6
- AVS ES100 vs Nitto Extreme 555
- Twin Turbo Help
- Dyno tuned PMC....
- Less than 7000 miles and back to the dealer tomorrow
- Wheel sensor on the Vettes
- Will 16 inch rims fit??
- Does Z28's have the same transmission as the C5's?
- Aftermarket ECU and Harness?
- eliminating slip regulator
- breaking in my new baby
- Where can I get a SLP Lid + K&N for a low price?
- Guages
- Help. SES code. Atap readings here.
- need info about the add on filter size.. '01-'02
- Hooker LT Headers
- Is the intake for the 01-02's...
- Adjustable Fuel Pressure Regulators on LS1!
- Knocking noise
- 10 Vs 12 Bolt
- Anyone ever dyno SLP LM
- Holley Power Shot ?
- Is the owner of this car a member of the board.
- 275's on 16s
- question about sound
- pinging problem
- Stupid tire question.
- Fuel Return
- clutch material questions
- Ls1 Z28 Vs Ss
- fuel pressure regulator question
- Rattling, Whiney Noises?
- Need some ideas on what's going on.
- slp 85mm mass airflow sensor ??
- Question? Stock Camaro Differential Info
- How easy is it to replace the cam?
- rag tops
- A bunch of questions, that seem stupid
- jet hot/LM
- Service Engine Soon light
- Whoops
- Gear swap
- stock rear gear ratio, '01 Z28
- Guage Setup
- New Dyno sheet posted if interested, see here
- how to install cam and which to get???
- nx solenoid went bad....
- dropping car with mac springs...help with front needed
- what should my car run in 1/4?????
- which cam to get?????????
- air intake
- Those of you with 6-speeds come on in.....
- Question about LS1 Rear end
- catback really necessary?
- good shops in MN?
- how to install vacuum gauge...
- where did u put your slp fan switch...?
- how to install slp fan switch????
- subframe connector install botched
- Those with black dashes in their Firebirds????
- nitrous install?
- SLP Cam and Cylinder Head Pakage?
- Power seats don't work when it is cold out...
- how many are still on their stock pinion seal?
- Headers? Are they worth it?
- LS1 to LS6 swap????
- CNC lower control arms, any difference?
- can you post me some pics of 285/40/17 on the rear
- Temp. range
- Any heard of RadiatorBarn.com?
- new to board
- Anyone know where I can get the Z06 cam/heads at?
- 3 Inch or 2 '1/2 inch Dual pipes??
- The Best Radiator Cleaner?
- Borla or not
- Oil Change coming up. Recommendations?
- Six speed ???
- differential fluid
- Are these brake pads any good?
- Chatter between 1st & 2nd. Normal?
- Aftermarket Clutches
- Subframe connectors? Are they worth it?
- Dyno results - Is this normal?
- SES light after Duals !!!
- Help me out on future mods!!!
- Universal Plug Wire Set??
- Silly little spark plug wire question>>>
- System too lean
- How Much Can I Spray
- Jet-Hot question
- sellin my power seat...where is main unit for it
- Bolt Pattern on wheels
- Lifting the car
- Clunking with clutch in, shifting gears?
- big problem with local dealer what can i do
- High mileage LS1??
- Jerky M6
- Long tube install
- shift light
- Sub frames for 'vert
- Steering wheel for 4th gen?
- New Predator, How is it ???
- Probs w/ y-pipe connecting to 3" exhaust>>
- thermostat mod....
- To All LS1 owners, that have Magnaflow exhaust.........
- Differences in 98-02 cars
- Rear window defroster problem??
- AutoTap and LS1Edit
- Need help w/ true dual exhaust
- LS1 edit etc...
- driverside door noise
- Anyone Use Carfax ??
- B&M ripper shifter...?
- What's the difference between......
- GMMG installed!
- Cutout Wiring
- Looking at a 99 Z28 Conv. Have some questions.
- fluids, not just engine oil?
- Idiot light?
- Cheapest place to get an SLP Loud Mouth?
- Quick question about Flowmaster mufflers.
- rear hatch problems
- Removing the Front Facia
- Have two Questions About Ls1 Heads and Comp
- Wisper lid or FIPK ?
- What is a good set of front brake rotors?
- Rearend help please?
- Got a question, just wanna ease my worries a bit.
- r1 racing seat in ls1......
- Could someone run a Car Fax Report ??
- stage 8 header bolts...
- Nitrous Injection Plate
- SFC question
- Loudmouth Drone??
- Dying Problem
- Rearend trouble
- Missing problem
- Ses
- Clearance question...
- Gear Questions
- 3 Questions?
- My brothers 95Z is in trouble, please help!
- T-56 1st gear grinding
- Need tips on exhaust
- People with a converter please look inside!
- Need Wiring Help!!!!
- Those with SLP bolt-on SFC
- foglight out
- Engine help, Is this knocking?
- Anyone ever have a problem with Borla??
- Headers and Exhaust Question...
- Is Hypertech worth the money?
- Times from last night
- kumho's?
- LS1 A4 shift hard?
- Crappy Dealer techs
- How much is a new Instrument Cluster?
- Rear Brake Rattle--Please Help
- T-Tops and Leakes ??
- Valve Covers
- small dilemma
- LS6 Intake?
- Stock Ground effects
- FTRA and Direct Flo lid
- Clutch help
- Am I totally STUPID or what?
- Noise when going 135......
- Magnaflow Vs Flowmaster
- FYI: New LT header...
- Wanted: Factory SLP Air Lid from 01-02 for trade
- Hypertech, Predator, or Autotap
- PCV Mod
- Proud owner of a new WS6 :)
- Lights
- Does the hooker catback need coating?
- Does a desceened MAF affect A4
- 2001 SS Factory Ride Height
- you guessed it
- Need advice on mods...
- poly tanny mount very loud?
- Rear and Tranny Fluid?
- Broken Rear?
- New times from a 00 SS.
- why is my exhaust soo low!!!
- O2 sims, do they work?
- Leaves.....
- HELP: Tripometer resets itself
- How difficult to install lowering springs?
- My Camaro doesn't want to idle when in drive
- ??? reason speedometer isn't working (rebuilt wreck car)
- Moser 12 Bolt - T/A Mount Bolt Size?
- Just got my Magnaflows installed..........
- Fra
- SLP MAF: Does it work?
- Car wont start
- whats the biggest tire can i put in the rear with the sock 16x8 rim?
- cold weather=2 much wheel spin?
- Green Filter
- A few questions about CAI....
- !MAF Porting HP
